MC6 Thermostat
Hi @Frans1960.
MC6 uses login “admin” and password “admin” for the broker.
You can get the values like this:
current_temperature_topic: "updData/YOURTHERMOSTATMACADDRESSLOWERCASE"
current_temperature_template: "{{ value_json.temp | float / 10  }}"
Cheers,
Mateusz
Hello @YuQiang.
I have a problem with setting the temperature (reading the values works great). It looks like the thermostat does not read the new values.
I’m publishing e.g.:
"settemp": 230
My entities get updated but the thermostat does not change it’s value.
Could You please help me with this?
Cheers,
Mateusz
P.S. Firmware 2.04z with Mosquitto broker.
Hi Mateusz,
Try to publish it in the topic with only the Mac address: eg. /yourmc6mac/
This will set the values.
Cheers,
Serfio
Hello Sergio.
It works! :smiley:
Thank you very much.
Cheers,
Mateusz
Hi guys!
One more question.
What is mode 5? It is not listed in JSON description.
Cheers,
Mateusz
Hi Mateusz,
I had the same question some time ago but not investigated further. Maybe @YuQiang knows if there are changes in the ‘Mode’ attribute with new descriptions.
Alternatively you can reverse engineer it to figure out them :wink:
BTW, once you get in a good shape with your development, would be great if you share your code and howtos.
Thanks so much,
Sergio
Hi Sergo
the mode parameter is only for the fan coil MC6, 1= cool; 2= heat ;3= vent; 4=auto; for the heating MC6 this mode dose not work.
Regards
Yu
Was anyone able to add humidity to thermostat card ? Like this one
Hi Mateusz,
Thanks for the info. I have another password on my mqtt broker, can I set the password or must I use admin / admin?
Thanks, Frans
Hi Yu,
No need to change Topic.
Maybe I missed something, I missing documentation / manual for this. And some examples would be help full.
Thanks, Frans
Hello Frans.
I have not seen an option to change user and password on 2.04z firmware.
You can add these lines to the mosquitto broker configuration:
logins:
  - username: admin
    password: admin
Cheers,
Mateusz
Hello Mateusz,
Thanks for the info and if I would change to admin/admin, I have to change al my devices that connect trough mqtt and it’s a very obvious user/password.
I have now working with the Modbus and Node-Red. Its winter, so I will change it to mqtt in the summer.
Best regards, Frans
Hello Frans.
The above lines only add a mqtt user. You don’t have to change logins and passwords on all your devices.
But I do understand you don’t want to mess with a working system :slight_smile: The weather is horrible…
Cheers,
Mateusz
Hi Yu,
Can I set the Home/Away mode trough mqtt?
Regards,
Frans
P.S. I have a Modbus manual for the MC6, is there also a mqtt manual or will this be made?
Hello Frans.
In mqtt it is called standby: 1 no, 2 yes
For a list of available commands see this post:
HTH.
Cheers,
Mateusz
Ciao Tiziano, ci possiamo sentire in privato per alcune domanda sul termostato??
Ok va bene
come facciamo a sentirci in privato??
Please… Can I add HEAT button?
My experiment didn’t work:
NR:
{"id":"68da138e.e3b8fc","type":"mqtt in","z":"56deb452.46025c","name":"Set Mode","topic":"home/termostato/mode/set","qos":"2","datatype":"auto","broker":"99ab3ff6.4455d","x":200,"y":1380,"wires":[["2396e0a1.f33d6"]]},{"id":"2396e0a1.f33d6","type":"template","z":"56deb452.46025c","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"[{{ payload }}]","output":"str","x":500,"y":1380,"wires":[["702f8922.58b8c8"]]},{"id":"702f8922.58b8c8","type":"json","z":"56deb452.46025c","name":"","property":"payload","action":"","pretty":false,"x":650,"y":1380,"wires":[["1b2f80ea.a810a7"]]},{"id":"1b2f80ea.a810a7","type":"modbus-write","z":"56deb452.46025c","name":"Set Mode","showStatusActivities":false,"showErrors":false,"unitid":"","dataType":"MHoldingRegisters","adr":"9","quantity":"1","server":"36e9f5f4.01499a","emptyMsgOnFail":false,"keepMsgProperties":false,"x":820,"y":1380,"wires":[[],[]]},{"id":"99ab3ff6.4455d","type":"mqtt-broker","name":"MQTT HA Server","broker":"192.168.10.17","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"36e9f5f4.01499a","type":"modbus-client","name":"Termostato","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"tcpHost":"192.168.10.75","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":1,"commandDelay":1,"clientTimeout":1000,"reconnectOnTimeout":true,"reconnectTimeout":2000,"parallelUnitIdsAllowed":true}]
in config
switch:
  - platform: mqtt
    state_topic: "home/termostato/mode/state"
    command_topic: "home/termostato/mode/set"
    payload_on: "1"
    payload_off: "0"
    qos: 0
    retain: true
    icon: mdi:radiator
dashboard:
      - entity: switch.termostato_heat
        hold_action:
          action: more-info
        show_icon: true
        show_name: true
        show_state: true
        tap_action:
          action: toggle
        type: button
Hello @YuQiang.
Is there a version of mqtt firmware that has floor temperature reporting support?
Thanks.
Cheers,
Mateusz
