First let me also thank you for this release, i can now control the thermostats via MQTT, and its working great.
I’m facing a issue with the thermostat, if i set them to heat 22 degrees, it open the valve until 22,1 and then stop, but then it open again reaching 22,0, it doesn’t respect the diff parameter. This make the thermostat always being going on - off - on - off.
Im also taking this post, to give some feedback on some small bugs, for your consideration:
Add to MQTT msg the status of the valve and fan (if its open or close, and the current speed).
From time to time, i still receive some encrypted messages in the MQTT broker.
The symbols of operation are not centered (picture in attachment).
Time in standby screen ( i believe that this was there in previous versions).
OK, thanks. we will check the differ function and the encrypted messages issue,adding the fan, valve output status, adding time in standby screen after holiday(22th Feb).
For the OTA update currently it download the update from our cloud server, after we upload the firmware file to server you will see the “Upgrade” button in “system information” screen.
Hi i have two of those Thermostats with two diferent firmawer and same problem on each with switch diff temperature, acording to manual defaulf spouse to be 0.5 degr, but mines have 1 deg, i prefer 0.5 because i am using it for underflor heating. On The screen lowest available is 1 deg in smart house i can set up 0.5 but after power cut off this settings and only this is going back to 1 deg, which is enojng because before temperature drop by 1 deg, floor is very cold and it is take ages before flor and room heat up again. Any solution for This it is device or app fault?
@ Slawomir_Grubiak
This is the default behaviour for this thermostat, despite it is not desiderable. Factory default is 1 degree which means it will revert to that value once the thermostat is powered off (power socket disconnect) no matter if you have set it to .5°C from the screen menu(settings>feature settings>switch diff) previously. Question is: why would you completely remove the power?
hi everyone, I’m michele!
I bought the MC6 thermostat with 3.29H firmware and in the “device information” menu it reports that there is a new 3.30 ota firmware. If I try to update it crashes at 64% and restarts without updating. is it possible to give us the firmware to be loaded manually with jtag? Even with firmware 3.29 I find inconsistencies with the thermal differential. Once set it works, if you then change the weekly parameters or the type of program (weekend, 7 days, etc.), the differential is “lost” and works with diff. = 0 ° C even if it is set to 0.5 ° C in the menu (by resetting it it works again). thank you all
Hi YuQiang
Do you have software for mc6-hd (MC6 BASIC-3.5PS-USB/2019-6-9) wireless thermostat? Because I made the updates and the touch of the screen is not working for me…
hi @YuQiang,
very thanks for quick reply!
a clarification: you tell me that you have firmware 2.xx … but I already have the 3.29 operating … and in ota there would be the 3.30, am I missing something? or is this page for modded and non-factory firmware of the thermostat? I ask …thank you
2.xx is not problem, because we have upgraded the cloud server , app and mc6 firmware, so we renamed the version number and add a letter P in the front of the number, you can see it in “System information” screen, this means MC6 Pro, it works with MyHouse Pro app and new MQTT server .
In the future we will add more features base on this new cloud server and firmware.
perfect very kind @YuQiang! I wonder if it’s not too much to have the source code available to customize certain things or try to make some changes. My version is MC6-HW-B and has two relay outputs: one manages the heating and the other the hot water (I assume, I don’t understand). It would be more useful for me to manage the second relay with the humidity sensor control to start the air conditioning in the summer period, approaching a weekly control system as for the temperature. it should be doable … many thanks for your work
Two fast questions, will this version be available as a OTA upgrade? (to avoid remove the devices from the wall, my current version is P2.04F2 and for now no upgrade is appearing).
If it will be available OTA, will it support the MQTT messages without encryption?
For the MQTT none enctryion version with the OTA upgrade function is avialble from v2.06, i will upload this firmware asap.
For the MQTT enctryion version with the OTA upgrade function is avialble from v2.06, it works with our own App and cloud server , please check this download link https://we.tl/t-rOTPNoLaPX , please note this firmware is encrption version, it works with our cloud server and App(Myhouse Pro)
