sorry, my fault
all working now
Picture Elements card - aka MercedesMe clone
After some tinkering (and help from Rene for the individual window opening/closing), I’m done for now with my picture elements card for a Mercedes EQS using Rene’s integration.
Clear inspiration was from the MercedesMe app, as you can readily see.
The stand-in for the card is a Mercedes EQS, which can open and close individual windows. Adjust for you car’s capabilities.
Requirements
In order to drive the picture elements, we have to define some custom sensors (basically extracting some attributes, and combining sensors).
It will make sense later on.
Images
The baseline image, as well as the individual states you can get directly from Mercedes using the steps outlined by Rene some time ago:
https://community.home-assistant.io/t/mercedes-me-component/41911/597
EDIT: Things changed on Rene’s and Mercedes’ end, use the new service call mbapi2020.download_images
from version v0.14.0-beta.1 or later.
This picture set comprises of the base image of your car type, and individual “warning” (red) sub images for states that need attention: Open or unlocked doors, open windows or trunk, tyre etc. Same as the overview image in your MercedesMe app.
The windows icon are screengrabs (reduced in size) from the (iOS) MercedesMe App, with the “vent” icon desatured (to be used as the “moving” image). Again, this will make sense later one.
The filename of these are:
I put all images in the www/eqs/
folder in HA.
Sensors
Please substitute your own sensor name, the XXX is just a placeholder for the name of your car. Also, put everything under the sensor:
tag.
Lets start with the definition of the door. These are: Locked
(no warning sub-image), Unlocked
, and Open
. These are all in the lock
sensor.
# Codes for open/unlocked/venting of doors and sunroof (sensor.XXX_lock):
# doorlockstatus*: true: unlocked, false: locked
# doorstatus*: true: open, false: closed
# sunroofstatus: 0: closed, 1: open, 2: vent, 7: opening, 8: closing, 11: open vent, 12: closing vent
# Codes for open/venting of windows (binary_sensor.XXX_windows_closed):
# windowstatus*: 1: open, 2: closed, 4: vent, 5: moving
sensors:
eqs_door_frontleft:
friendly_name: "Front Left Door"
icon_template: >
{% if not state_attr('sensor.XXX_lock', 'doorlockstatusfrontleft') %} {# door locked #}
mdi:car-door-lock
{% else %} {# door unlocked #}
mdi:car-door-lock-open
value_template: >
{% set door = "frontleft" %}
{% if not state_attr('sensor.XXX_lock', 'doorstatus'+door) %} {# door closed #}
{% if not state_attr('sensor.XXX_lock', 'doorlockstatus'+door) %} {# door locked #}
Locked
Unlocked
{% else %} {# door open #}
Open
eqs_door_frontright:
friendly_name: "Front Right Door"
icon_template: >
{% if not state_attr('sensor.XXX_lock', 'doorlockstatusfrontright') %} {# door locked #}
mdi:car-door-lock
value_template: >
{% set door = "frontright" %}
Locked
Unlocked
Open
eqs_door_rearleft:
friendly_name: "Rear Left Door"
icon_template: >
{% if not state_attr('sensor.XXX_lock', 'doorlockstatusrearleft') %} {# door locked #}
mdi:car-door-lock
value_template: >
{% set door = "rearleft" %}
Locked
Unlocked
Open
eqs_door_rearright:
friendly_name: "Rear Right Door"
icon_template: >
{% if not state_attr('sensor.XXX_lock', 'doorlockstatusrearright') %} {# door locked #}
mdi:car-door-lock
value_template: >
{% set door = "rearright" %}
Locked
Unlocked
Open
Next we look into the states of the windows. These can be: Closed
, Open
, Vent
, or Moving
eqs_window_frontleft:
friendly_name: "Front Left Window"
icon_template: mdi:car-door
value_template: >
{% set window = "frontleft" %}
{% if is_state_attr('binary_sensor.XXX_windows_closed', 'windowstatus'+window, "2") %} {# window closed #}
Closed
{% elif is_state_attr('binary_sensor.XXX_windows_closed', 'windowstatus'+window, "4") %} {# window vent #}
{% if not state_attr('sensor.XXX_lock', 'doorstatus'+window) %} {# door closed #}
VentDC
VentDO
{% elif is_state_attr('binary_sensor.XXX_windows_closed', 'windowstatus'+window, "1") %} {# window open #}
OpenDC
OpenDO
{% else %} {# window moving #}
Moving
eqs_window_frontright:
friendly_name: "Front Right Window"
value_template: >
{% set window = "frontright" %}
Closed
VentDC
VentDO
OpenDC
OpenDO
Moving
eqs_window_rearleft:
friendly_name: "Rear Left Window"
value_template: >
{% set window = "rearleft" %}
Closed
VentDC
VentDO
OpenDC
OpenDO
Moving
eqs_window_rearright:
friendly_name: "Rear Right Window"
value_template: >
{% set window = "rearright" %}
Closed
VentDC
VentDO
OpenDC
OpenDO
Moving
And last, we have to integrate the sunroof, and the trunk. The image set has a warning image of an opened hood, but my EQS does not report the hood status, so thats not used. Maybe your car is different?
eqs_sunroof:
friendly_name: "Sunroof"
value_template: >
{% if is_state_attr('sensor.XXX_lock', 'sunroofstatus', "2") %}
vent
{% elif is_state_attr('sensor.XXX_lock', 'sunroofstatus', "1") %}
open
{% elif is_state_attr('sensor.XXX_lock', 'sunroofstatus', "0") %}
closed
moving
eqs_trunk:
friendly_name: "Trunk"
value_template: >
{% if state_attr('sensor.XXX_lock', 'doorlockstatusdecklid') %}
unlocked
{% elif state_attr('sensor.XXX_lock', 'decklidstatus') %}
open
closed
Now all thats missing is the tyre warning, these are straight foreward, albeit I did have to guess, as I didn’t have a tyre warning in my car yet.
eqs_tire_image_frontleft:
friendly_name: "Tire Warning Front Left"
icon_template: mdi:car-tire-alert
value_template: >
{% if is_state_attr('binary_sensor.XXX_tire_warning', 'tireMarkerFrontLeft', "0") %}
OK
Warning
eqs_tire_image_frontright:
friendly_name: "Tire Warning Front Right"
value_template: >
{% if is_state_attr('binary_sensor.XXX_tire_warning', 'tireMarkerFrontRight', "0") %}
OK
Warning
eqs_tire_image_rearleft:
friendly_name: "Tire Warning Rear Left"
value_template: >
{% if is_state_attr('binary_sensor.XXX_tire_warning', 'tireMarkerRearLeft', "0") %}
OK
Warning
eqs_tire_image_rearright:
friendly_name: "Tire Warning Rear Right"
value_template: >
{% if is_state_attr('binary_sensor.XXX_tire_warning', 'tireMarkerRearRight', "0") %}
OK
Warning
Picture Element card
Now to the meat of the whole excercise: The Picture Element card that ties it all together.
As you can see I implemented window control on the window icons. Feel free to change those if your car does not offer them. Replace the VIN number to the one of your car in the service calls.
Also replace all the 297100
in the filenames to your filenames of the downloaded zip from earlier.
type: picture-elements
image: local/eqs/297100_car.png
transform: translate(-50%, -50%)
elements:
- type: image
entity: sensor.eqs_door_frontleft
state_image:
Open: local/eqs/297100_door_frontleft_open.png
Unlocked: local/eqs/297100_door_frontleft_unlock.png
Locked: null
style:
top: 0%
left: 0%
transform: translate(0, 0)
tap_action:
action: none
- type: image
entity: sensor.eqs_window_frontleft
state_image:
OpenDC: local/eqs/297100_window_frontleft_opendoorclosed.png
OpenDO: local/eqs/297100_window_frontleft_opendooropened.png
VentDC: local/eqs/297100_window_frontleft_ventilatedoorclosed.png
VentDO: local/eqs/297100_window_frontleft_ventilatedooropened.png
Closed: null
Moving: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: image
entity: sensor.eqs_door_frontright
state_image:
Open: local/eqs/297100_door_frontright_open.png
Unlocked: local/eqs/297100_door_frontright_unlock.png
Locked: null
style:
top: 0%
left: 0%
transform: none
- type: image
entity: sensor.eqs_window_frontright
state_image:
OpenDC: local/eqs/297100_window_frontright_opendoorclosed.png
OpenDO: local/eqs/297100_window_frontright_opendooropened.png
VentDC: local/eqs/297100_window_frontright_ventilatedoorclosed.png
VentDO: local/eqs/297100_window_frontright_ventilatedooropened.png
Closed: null
Moving: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: image
entity: sensor.eqs_door_rearleft
state_image:
Open: local/eqs/297100_door_rearleft_open.png
Unlocked: local/eqs/297100_door_rearleft_unlock.png
Locked: null
style:
top: 0%
left: 0%
transform: none
- type: image
entity: sensor.eqs_window_rearleft
state_image:
OpenDC: local/eqs/297100_window_rearleft_opendoorclosed.png
OpenDO: local/eqs/297100_window_rearleft_opendooropened.png
VentDC: local/eqs/297100_window_rearleft_ventilatedoorclosed.png
VentDO: local/eqs/297100_window_rearleft_ventilatedooropened.png
Closed: null
Moving: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: image
entity: sensor.eqs_door_rearright
state_image:
Open: local/eqs/297100_door_rearright_open.png
Unlocked: local/eqs/297100_door_rearright_unlock.png
Locked: null
style:
top: 0%
left: 0%
transform: none
- type: image
entity: sensor.eqs_window_rearright
state_image:
OpenDC: local/eqs/297100_window_rearright_opendoorclosed.png
OpenDO: local/eqs/297100_window_rearright_opendooropened.png
VentDC: local/eqs/297100_window_rearright_ventilatedoorclosed.png
VentDO: local/eqs/297100_window_rearright_ventilatedooropened.png
Closed: null
Moving: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: image
entity: sensor.eqs_sunroof
state_image:
open: local/eqs/297100_sunroof_open.png
vent: local/eqs/297100_sunroof_ventilate.png
closed: null
moving: local/eqs/297100_sunroof_open.png
style:
top: 0%
left: 0%
transform: none
- type: image
entity: sensor.eqs_trunk
state_image:
open: local/eqs/297100_trunk_open.png
unlocked: local/eqs/297100_trunk_unlock.png
closed: null
style:
top: 0%
left: 0%
transform: none
- type: image
title: Front Left
state_image:
OpenDC: local/eqs/window_left_open.png
OpenDO: local/eqs/window_left_open.png
VentDC: local/eqs/window_left_vent.png
VentDO: local/eqs/window_left_vent.png
Closed: local/eqs/window_left_closed.png
Moving: local/eqs/window_left_moving.png
style:
top: 43%
left: 23%
transform: translate(-50%,-50%)
tap_action:
action: call-service
service: mbapi2020.windows_move
vin: W1KXXXXXXXXXXXXXX
front_left: '0'
hold_action:
front_left: '10'
double_tap_action:
front_left: '100'
- type: image
title: Front Right
state_image:
OpenDC: local/eqs/window_right_open.png
OpenDO: local/eqs/window_right_open.png
VentDC: local/eqs/window_right_vent.png
VentDO: local/eqs/window_right_vent.png
Closed: local/eqs/window_right_closed.png
Moving: local/eqs/window_right_moving.png
style:
top: 43%
left: 77%
tap_action:
front_right: '0'
hold_action:
front_right: '10'
double_tap_action:
front_right: '100'
- type: image
title: Rear Left
state_image:
style:
top: 61%
left: 23%
tap_action:
rear_left: '0'
hold_action:
rear_left: '10'
double_tap_action:
rear_left: '100'
- type: image
title: Rear Right
state_image:
style:
top: 61%
left: 77%
tap_action:
rear_right: '0'
hold_action:
rear_right: '10'
double_tap_action:
rear_right: '100'
- type: state-label
entity: sensor.XXX_tire_pressure_front_left
title: Front Left
style:
top: 23%
left: 33%
transform: translate(-100%,-50%)
- type: image
entity: sensor.eqs_tire_image_frontleft
state_image:
Warning: local/eqs/297100_tire_frontleft.png
OK: null
title: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: state-label
entity: sensor.XXX_tire_pressure_front_right
title: Front Right
style:
top: 23%
left: 66.5%
transform: translate(0%,-50%)
- type: image
entity: sensor.eqs_tire_image_frontright
state_image:
Warning: local/eqs/297100_tire_frontright.png
OK: null
title: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: state-label
entity: sensor.XXX_tire_pressure_rear_left
title: Rear Left
style:
top: 74%
left: 33%
- type: image
entity: sensor.eqs_tire_image_rearleft
state_image:
Warning: local/eqs/297100_tire_rearleft.png
OK: null
title: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: state-label
entity: sensor.XXX_tire_pressure_rear_right
title: Rear Right
style:
top: 74%
left: 66.5%
- type: image
entity: sensor.eqs_tire_image_rearright
state_image:
Warning: local/eqs/297100_tire_rearright.png
OK: null
title: null
style:
top: 0%
left: 0%
tap_action:
action: none
Thats it. It may have a few bugs and inconsistentcies, nothing severe that I have noticed.
Huge Thanks to Rene for providing the windows_move
service call on my request.
Thanks,
Thomas
PS
I have also a sideview version, I can elaborate if there is interest.
EDIT: See below for the sideways version.
PPS
Here is the whole sensor:
thing in one big chunk:
sensors:
eqs_door_frontleft:
icon_template: >
mdi:car-door-lock
value_template: >
Locked
Unlocked
Open
icon_template: >
mdi:car-door-lock
value_template: >
Locked
Unlocked
Open
eqs_door_rearleft:
icon_template: >
mdi:car-door-lock
value_template: >
Locked
Unlocked
Open
eqs_door_rearright:
icon_template: >
mdi:car-door-lock
value_template: >
Locked
Unlocked
Open
value_template: >
Closed
VentDC
VentDO
OpenDC
OpenDO
Moving
value_template: >
Closed
VentDC
VentDO
OpenDC
OpenDO
Moving
value_template: >
Closed
VentDC
VentDO
OpenDC
OpenDO
Moving
value_template: >
Closed
VentDC
VentDO
OpenDC
OpenDO
Moving
eqs_sunroof:
value_template: >
vent
open
closed
moving
eqs_trunk:
value_template: >
unlocked
open
closed
value_template: >
OK
Warning
value_template: >
OK
Warning
value_template: >
OK
Warning
value_template: >
OK
Warning
Could someone with a Mercedes EQE perhaps run the command Rene shared here Mercedes Me Component - #597 by ReneNulschDE and share the files please?
I’d need to SSH into HA but the SSH addon refuses to work so I can’t run the command in the correct spot…
You would receive my eternal gratitude
It seems like the access token is no longer stored in the HA config root folder.
I dimly remember a changelog about that…
Maybe @ReneNulschDE can weight in on that?
Also, you need the file, not a shell to HA. You can get files off HA either via Studio Code Server, or Samba share.
I did read that HA and ssh had changes over the year, what is currently working in my installation is the “Terminal & SSH” Add-On from the official add-on store. I do run HAOS in a VM.
MB and I made a lot of changes since this posting and I assume its easier to have a service to download the images. I’m currently implementing this and will publish a beta later today.
In the beta you will see a new service mbapi2020.download_images. It will require the VIN. After starting the service a zip-file will be available locally.
Supporting the great post from @Thomas01, I have published a new beta version “v0.14.0-beta.1 - AdBlue Sensor, Images download”:
New:
- New service “download_images”. This service will download a zip-file from the MB-servers with images (of your car of course) (to custom_components/mbapi2020/resources/vin.zip) that Thomas used in his post
- New sensor “tankleveladblue”. Shows the level of the AdBlue tank in %.
Fixes:
- Next try on the ReAuth issue. (I can’t reproduce it and changed the logic a little bit)
I am interested in the sideview car, it fits better.
Picture Element card - Sideways orientation
In my previous post, I described how to use picture elements to generate a view similar to the MercedesMe app (in an “upright” view), with the help of the images provided by Mercedes Benz.
Now to continue with a rotated, “sideview” version:
Let’s start with the
Requirements
The set-up of the sensors is the same as with the upright version, so start there.
The difference starts with the supplied images. The CSS of the picture elements card take care of rotating the images, except for the background image (XXXXXX_car.png
), which needs to be rotated using your favourite image manipulation programme (GIMP comes to mind). I called the rotated image XXX_car_rotate.png
in my case.
images are used for the states of the windows.
Just as before (replace all the 297100
in the filenames to your filenames of the downloaded zip from earlier, and XXX
with your car name), except that now a rotate
command is added (and some coordinates change).
image: local/eqs/297100_car_rotate.png
elements:
- type: image
state_image:
Locked: null
style:
top: 0%
left: 0%
transform: translate(0, 0) rotate(0.25turn)
tap_action:
action: none
- type: image
state_image:
Closed: null
Moving: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: image
state_image:
Locked: null
style:
top: 0%
left: 0%
- type: image
state_image:
Closed: null
Moving: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: image
state_image:
Locked: null
style:
top: 0%
left: 0%
- type: image
state_image:
Closed: null
Moving: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: image
state_image:
Locked: null
style:
top: 0%
left: 0%
- type: image
state_image:
Closed: null
Moving: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: image
state_image:
closed: null
style:
top: 0%
left: 0%
- type: image
state_image:
closed: null
style:
top: 0%
left: 0%
- type: image
title: Front Left
state_image:
style:
top: 24%
left: 56%
tap_action:
front_left: '0'
hold_action:
front_left: '10'
double_tap_action:
front_left: '100'
- type: image
title: Front Right
state_image:
style:
top: 76%
left: 56%
tap_action:
front_right: '0'
hold_action:
front_right: '10'
double_tap_action:
front_right: '100'
- type: image
title: Rear Left
state_image:
style:
top: 24%
left: 39%
tap_action:
rear_left: '0'
hold_action:
rear_left: '10'
double_tap_action:
rear_left: '100'
- type: image
title: Rear Right
state_image:
style:
top: 76%
left: 39%
tap_action:
rear_right: '0'
hold_action:
rear_right: '10'
double_tap_action:
rear_right: '100'
- type: state-label
title: Front Left
style:
top: 34%
left: 77%
transform: translate(-50%,-100%)
- type: image
state_image:
OK: null
title: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: state-label
title: Front Right
style:
top: 66%
left: 77%
transform: translate(-50%,0%)
- type: image
state_image:
OK: null
title: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: state-label
title: Rear Left
style:
top: 34%
left: 26%
- type: image
state_image:
OK: null
title: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: state-label
title: Rear Right
style:
top: 66%
left: 26%
- type: image
state_image:
OK: null
title: null
style:
top: 0%
left: 0%
tap_action:
action: none
Thanks @ReneNulschDE and @Thomas01 for the excellent work, ran the beta, got the images, followed Thomas’ tutorial and it all seems to be up and running (haven’t fiddled with the status of doors and windows yet, will do so another day).
Pics!
Would love to see other peoples implementation of status/control cards. Especially if they are image based.
Here you go!
there’s another card with efficiency, range etc but that contains my license plate so I’ve kept that out.
Nice.
What are the wiggly lines on the hood?
And the Eco Scores look a bit like the Apple fitnes rings. How did you do the rings?
Thanks!
The wiggly lines are the preconditioning of the car - rather important when my better half wants to use the car during colder days
The ring graph is made with the custom apexcharts card.
I might try and play around to change the colour of the car to the actual colour of mine (black) and also redistribute the icons to make it look more ‘balanced’…
Hi All and first a big thank you to @ReneNulschDE and @Thomas01 for their combined effort! I just installed the newest beta version v0.14.0-beta.1 and tried downloading the images. Unfortunately I got this error: Given VIN/FIN is not managed by any coordinator or excluded in the integration options.
What am I doing wrong?
First guess: The VIN/FIN needs to be in upper case or you have a typo. (Just copy the FIN from one existing sensor - see the attributes list)
That’s what I did in the first time. Second time exactly the same and now it works. Thanks!
First of all: Thanks for this great add-in.It is working here since some months and most of the time without any problems.
Here was a stupid beginners question before.
Sorry for that, i found the solution myself
Hi guys,
Thanks for the composent ! everything is OK but in my configuration i cant find the file mercedesme-token-cache for get zip from mercedes
i try to delete and add it’s the same …
Hi Matt, the file is in .storage folder in you HA-config folder.
You could install v0.14.0-beta1 too, this version has a HA-Service to download the file.
