First guess: The VIN/FIN needs to be in upper case or you have a typo. (Just copy the FIN from one existing sensor - see the attributes list)
Thatās what I did in the first time. Second time exactly the same and now it works. Thanks!
First of all: Thanks for this great add-in.It is working here since some months and most of the time without any problems.
Here was a stupid beginners question before.
Sorry for that, i found the solution myself
Hi guys,
Thanks for the composent ! everything is OK but in my configuration i cant find the file mercedesme-token-cache for get zip from mercedes
i try to delete and add itās the same ā¦
Hi Matt, the file is in .storage folder in you HA-config folder.
You could install v0.14.0-beta1 too, this version has a HA-Service to download the file.
Thankās Rene, now its perfect !
HI there:
I need help in creating a template switch for the preconditioning, but it doesnāt work at allā¦
If I call the service manually to start for instance, nothing happens in the car. Also vice versa, the attributes in the range_electric sensor are not updated, if I switch preconditioning āonā in MercedesMe app. Something is odd.
Interestingly the buttons in the overview to start/stop preconditioning are working fineā¦
Not sure if my changes in configuration.yaml are ok in principle.
standheizung_glc:
value_template: "{{ is_state_attr('sensor.ohv_g513e_range_electric', 'PrecondActive', 'on') }}"
turn_on:
service: mbapi2020.auxheat_start
vin: W1N253xxxxxxxxxxxxx
turn_off:
service: mbapi2020.auxheat_stop
This is my switch definition (it works on my car):
switch:
switches:
eqs_precond:
friendly_name: Pre-entry Climate Control
value_template: "{{ state_attr('sensor.XXX_range_electric', 'precondNow') or state_attr('sensor.XXX_range_electric', 'precondActive') }}"
icon_template: mdi:air-conditioner
turn_on:
service: mbapi2020.preheat_start
target: {}
vin: "{{ state_attr('sensor.XXX_car', 'vin') }}"
type: "0"
turn_off:
service: mbapi2020.preheat_stop
target: {}
Do you have the indentation right?
EDIT: Thats at least how it works with my electric car, I donāt know if a gasoline (or hybrid) car behaves differently. Ie. auxheat_start
vs preheat_start
Hi everyone, attempting to integrate this delightful addon for my 2018 vehicle.
Normally I utilize the Mercedes Me app to access the car. I do not see anywhere to create a PIN, though there is the option of biometric vs PIN access to the app. It doesnāt sound like thatās what is intended with the PIN configuration spot.
After adding the addon, and successfully logging in, I have no entities or cars still. This is in the US.
What are the next troubleshooting steps? Is the fact it is a 2018 vehicle an issue?
Thanks. Missed it byā¦ that much!
So, every now and then the app loses connection to the vehicle. Reload configuration doesnāt do anything. How do I reconnect it without deleting the entire integration and reinstalling?
Doesnāt happen with my car, @ReneNulschDE mentioned in his latest beta (v0.14.0-beta 1) that heās continuing working on the authentification issue:
Next try on the ReAuth issue. (I canāt reproduce it and changed the logic a little bit)
Check out the beta and see if the issue resolves.
Hi @ReneNulschDE,
is it possible to force-start a charge while a charging interruption (āLadeunterbrechungā) is active?
Thomas
Thanks for the hint! The āpreheatā fixed it.
Thomas
Thanks a lot for all the information shared here. This is my take on a personalized dashboard for my car.
Hi @Thomas01 ,
There are some APIs around chargeoptstart/stop. I have never analyzed this in detail. Iām spending the whole May in south Europe without a laptop.
Let us try this when Iām backā¦
Best
RenƩ
PS: thanks for answering the questions here!
No worries, enjoy your absence from laptops and enjoy your holiday (?).
Huh, you use kPa as a unit for air pressure in The Nederland?
Or maybe just a fellow Engineer
Iām indeed a Flemish engineer.
