Set the desired unit in the MercedesMe app on your iPhone/Android.
@ReneNulschDE It was jan. '21 when I posted this message below :-), now it is time to move on. Thank you very much for all your hard work and effort you have put into this integration for all these years already. Decided to switch to a Tesla (lease) so I wonāt be using your services anymore. Keep up the great work for this community for all current and future MB drivers! Much appreciated! Mercedes Me Component - #558 by Mobiledude
The map on the card is build with leaflet open source library, same as in HA. Google map is not free.
Wouldnāt you mind share your images folder? I have an EQB and have no clue how to get these images. Rene is mentioning a beta version to grab these images but couldnāt figure out where it is
I apologize that this is such a stupid question, but Iām only a few days into switching over form Homeseer and there is a simple concept that is going over my head with some of these HACS integrations. Iāve got HACS in-place, seemingly working properlty and Iāve added a couple integrations. With this one, for instance, it says:
- Use the āAdd Integrationā in Home Assistant, Settings, Devices & Services and select āMercedesME 2020ā.
- Use your MB-login email address. Your will receive a 6-digit code via email (valid for 15min).
Iāve completed the Add Integration part, after the restart, but I donāt understand where the jump to MB-login happens? I feel like Iāve poked around every, at least 10 times, so I assume Iām missing some YAML configuration or something.
Thank you, in advance, for helping my past this basic hurdle that seems to be holding me back!
Hi, Welcome in the Home Assistant World
There is no need for any yaml stuff ā¦
I assume you have installed the MB-component via HACS. Please restart HA after the download. Then refresh your browser window with for example Ctrl+F5 on Windows. Now go to the Settings, Devices + Servicesā¦ Click on the " + Add Integration" button on the right-bottom side and search for Mercedes or MBAPI2020ā¦ ā
Let me know if you need more helpā¦
PS: Maybe you have installed the āmercedes_me_apiā component from @Giorgio_Ravera - this is an old component. MB has stopped the public apiā¦ - please use the MBAPI2020 componentā¦
Thank you very much! Iāve got my server going through some other reboot stuff now, but will walk back through this. Thank you!
This did it! I was missing the part where an HACS Integration becomes searchable after adding through HACS - makes sense now! Thank you!
If anyone is up for another dumb noob question, since Iām still not there after watching 3 videos and perusing numerous sites. How do a I add a custom card, like the ones presented in this thread, to my HA? I tried it with @VietNgoc cool card, but canāt seem to get it to show up. I downloaded the components and added the Resources Config, I think.
If it helps, Iām running HA OS in a VM on TrueNAS.
Thanks again!
Got it - just needed a couple more restarts and a couple more drinks! Now Iām truckin!
I have a question about @VietNgocās custom card. Iāve added a custom button to show fuel in litres:
> {{float(states('sensor.*******_fuel_level')) * 43/100 }}
> ({{int(states('sensor.*******_fuel_level'))}}%)
If I click the card I get this
Iāve tried various flavours of YAML to show info but canāt get anything. What should I be doing?
You have no lovelace config for this button. Config for a custom card should look like the normal yaml format for lovelace
Got it. I missed out the dash.
