Do we have any EQA driver here?
If yes, could you post the attributes that you see for your state of charge sensor? I would like to check if the maxsoc attribute is available.
Thx
Rene
Thx
Rene
Hi, my english is very bad, sorry
YOURS error â> value_template: â{{ states.binary_sensor.8206lng_tire_warning.attributes.tirepressureRearLeft }}â
VS value_template: â{{ state_attr(âbinary_sensor.8206lng_tire_warningâ, âtirepressureRearLeftâ) }}â
Thank you
Hi Guys,
Just isntalled MercedesMe 2020 from HACS, rebooting HA, but when I got to integrations and search it doesnât show up? Any ideas?
Sorry for my English.
Same thing happened to me. Since HACS doesnât work. So I downloaded the custom from github and through WINSCP I copied it to the custom_components directory, I restarted and it came out in integrations
Ok so I managed to get the plugin installed. However after many refreshes, clearning cache and reboots all my elements show as unavalable? If I click into say the mileage one it shows my milage but still sits as unavailable? Do i need to change the state of all of these or should this be automatic? This used to work for me on a previous install of HA, not sure what has changed?
Have now sorted this, reinstalled for a final time and it worked
Has something fundametal changed at Mercedes? ⊠the MercedesME integration has stopped updating battery charge and range at 8pm GMT. battery is full but it reports 30% and 78Miles
The logs have tons ofâŠ
2022-05-12 06:45:51 DEBUG (MainThread) [custom_components.mbapi2020.websocket] Got notification: apptwin_pending_command_request
2022-05-12 06:46:06 DEBUG (MainThread) [custom_components.mbapi2020.websocket] Got notification: apptwin_pending_command_request
2022-05-12 06:46:21 DEBUG (MainThread) [custom_components.mbapi2020.websocket] Got notification: apptwin_pending_command_request
2022-05-12 06:46:36 DEBUG (MainThread) [custom_components.mbapi2020.websocket] Got notification: apptwin_pending_command_request
Richard
The component is working for me. Do you see the updates in the MB app?
It started working again a few hours later⊠no idea what went wrong!
Same here three times
Is it still true that this will not work for my 2017 SLC 300?
Depends on your region. EU/Asia - could be, US - should not work.
Just try it.
Br René
Does anyone notice a unusual update frequency of the device tracker?
Had this on Tuesday and today again that it hasnât updated for at least 10 hours now.
Hi @RodgerDodger ,
For me it works but few other people stated some slowness esp. in the Netherlands, Belgium and UK. But Iâm not sure if this problem is a region topic.
BR
Rene
Thanks for the quick reply. You have another slow device tracker than from Germany.
Iâm definetely not at the barber 10:00.
But I just noticed that it probably is Mercedes themselves as the door lock status hasnât updated in the MercedesMe app until I just closed the car doors via app.
Not your fault this time.
You mean as always
Amusing thing: Today my app isnât working, it hasnât received anything from the car since yesterday around 18.30, when I had my last trip yesterday. According to it the car is still parked outside the cabin here. But the integration is working, because I can see the battery percentage fall around 06.20 to 06.35, when my wife drove to work this morning!
Which gave me an idea: Can the carâs position be shown in the integration? Even better, with a âtailâ, so I can see where itâs been driving for the last x hours? That doesnât function in the Mercedes app, but it does in another app I had for it, Tronity. I quit using it when it became a rather expensive pay app, since I only used the âhas my wife already been to this shop yet on her shopping trip, or can I still add to the shopping listâ function in it.
I use this Lovelace card to do just that:
- type: map
hours_to_show: 48
default_zoom: 15
aspect_ratio: 16x9
# dark_mode: true
entities:
- device_tracker.XXX_device_tracker
(where XXX is the license number)
Fantastic, thanks a lot! I didnât know that was possible now! I have made a separate page with from one week to 12 hours of tracking. Love it! I wish there was an easy way to make the map better (change soure), but that requires a reverse proxy and that would only work as long as Iâm on the home or cabin network, where pfSense could do that.
But is it possible to change the point where the car is now? Itâs a rather big circle with MDT (I assume Mastiff Device Tracker), and when zooming out it covers quite a few hundred meters.
Yeah, thatâs how the HA map card works Perhaps itâs possible to make it smaller using something like card-mod
