Danke sehr.
Any idea how to fix the following error:
This error originated from a custom integration.
Logger: custom_components.mbapi2020
Source: custom_components/mbapi2020/init.py:64
integration: MercedesME 2020 (documentation, issues)
First occurred: 11:57:25 (1 occurrences)
Last logged: 11:57:25
Authentication failed. Please reauthenticate.
Logger: custom_components.mbapi2020.oauth
Source: custom_components/mbapi2020/oauth.py:312
First occurred: 11:41:16 (1 occurrences)
Last logged: 11:41:16
Error requesting: https://id.mercedes-benz.com/as/token.oauth2 - 0 - {“error_description”:“unknown, invalid, or expired refresh token”,“error”:“invalid_grant”}
Hi @mental4vray,
whenever you are on the latest version and the reauth procedure is not working, please delete the integration from HA. Restart HA. Add the integration again. (A deletion from HACS is not needed.)
I’m still trying to fix/reproduce the reauth problems.
Just update the componenet and HA to latest version, and all entities show as ‘unavailable’
Log grab from what may be relevant:
2024-04-11 11:47:07.781 DEBUG (MainThread) [custom_components.mbapi2020] VIN not found in masterdata. Used FIN WDD20XXXXXXXX4636 instead.
2024-04-11 11:47:07.781 DEBUG (MainThread) [custom_components.mbapi2020.coordinator] Finished fetching mbapi2020 data in 0.000 seconds (success: True)
2024-04-11 11:47:07.793 DEBUG (MainThread) [custom_components.mbapi2020.websocket] _start_websocket_handler: aafebf53878335ed06c36d7dff0f92b4
2024-04-11 11:47:07.793 DEBUG (MainThread) [custom_components.mbapi2020.oauth] Start async_get_cached_token()
2024-04-11 11:47:07.793 INFO (MainThread) [custom_components.mbapi2020.websocket] Connecting to wss://websocket.emea-prod.mobilesdk.mercedes-benz.com/v2/ws
2024-04-11 11:47:07.948 INFO (MainThread) [custom_components.mbapi2020.websocket] Connected to mercedes websocket at wss://websocket.emea-prod.mobilesdk.mercedes-benz.com/v2/ws
2024-04-11 11:47:07.953 DEBUG (MainThread) [custom_components.mbapi2020.websocket] Got notification: debugMessage
2024-04-11 11:47:07.953 DEBUG (MainThread) [custom_components.mbapi2020.client] debugMessage - Data: Registering User with ciamID: <redacted> and App-UUID: <redacted>
2024-04-11 11:47:07.954 DEBUG (MainThread) [custom_components.mbapi2020.websocket] Got notification: debugMessage
2024-04-11 11:47:07.954 DEBUG (MainThread) [custom_components.mbapi2020.client] debugMessage - Data: app twin actor was initialized
2024-04-11 11:47:07.993 DEBUG (MainThread) [custom_components.mbapi2020.websocket] Got notification: assigned_vehicles
2024-04-11 11:47:07.994 DEBUG (MainThread) [custom_components.mbapi2020.client] Start _process_assigned_vehicles
2024-04-11 11:47:07.994 INFO (MainThread) [custom_components.mbapi2020.coordinator] Car Load complete - start sensor creation
2024-04-11 11:47:08.014 DEBUG (MainThread) [custom_components.mbapi2020.websocket] Got notification: apptwin_pending_command_request
2024-04-11 11:47:08.048 DEBUG (MainThread) [custom_components.mbapi2020.websocket] Got notification: vepUpdates
2024-04-11 11:47:08.049 DEBUG (MainThread) [custom_components.mbapi2020.client] Start _process_vep_updates
2024-04-11 11:47:08.093 DEBUG (MainThread) [custom_components.mbapi2020.client] vepUpdates Sequence: 0
2024-04-11 11:47:10.760 INFO (MainThread) [homeassistant.components.device_tracker] Setting up mobile_app.device_tracker
2024-04-11 11:47:10.784 INFO (MainThread) [homeassistant.components.device_tracker] Setting up mobile_app.device_tracker
2024-04-11 11:47:14.031 INFO (MainThread) [homeassistant.components.remote] Setting up androidtv_remote.remote
2024-04-11 11:47:14.078 INFO (MainThread) [custom_components.mbapi2020] No Cars found.
2024-04-11 11:47:14.110 INFO (MainThread) [custom_components.mbapi2020] No Cars found.
2024-04-11 11:47:14.121 INFO (MainThread) [custom_components.mbapi2020] No Cars found.
2024-04-11 11:47:14.130 INFO (MainThread) [custom_components.mbapi2020] No Cars found.
2024-04-11 11:47:14.144 INFO (MainThread) [homeassistant.components.device_tracker] Setting up mbapi2020.device_tracker
2024-04-11 11:47:14.145 INFO (MainThread) [custom_components.mbapi2020.device_tracker] No Cars found.
2024-04-11 11:47:14.154 INFO (MainThread) [custom_components.mbapi2020] No Cars found.
VIN and PIN are added to integration config
Adding the VIN in the config will exclude the car. Please remove the VIN from the options and reload the component.
This option should be used if you want to exclude a car.
sorry, my fault
all working now
Picture Elements card - aka MercedesMe clone
After some tinkering (and help from Rene for the individual window opening/closing), I’m done for now with my picture elements card for a Mercedes EQS using Rene’s integration.
Clear inspiration was from the MercedesMe app, as you can readily see.
The stand-in for the card is a Mercedes EQS, which can open and close individual windows. Adjust for you car’s capabilities.
Requirements
In order to drive the picture elements, we have to define some custom sensors (basically extracting some attributes, and combining sensors).
It will make sense later on.
Images
The baseline image, as well as the individual states you can get directly from Mercedes using the steps outlined by Rene some time ago:
https://community.home-assistant.io/t/mercedes-me-component/41911/597
EDIT: Things changed on Rene’s and Mercedes’ end, use the new service call mbapi2020.download_images from version v0.14.0-beta.1 or later.
This picture set comprises of the base image of your car type, and individual “warning” (red) sub images for states that need attention: Open or unlocked doors, open windows or trunk, tyre etc. Same as the overview image in your MercedesMe app.
The windows icon are screengrabs (reduced in size) from the (iOS) MercedesMe App, with the “vent” icon desatured (to be used as the “moving” image). Again, this will make sense later one.
The filename of these are (download them below):
window_right_open.pngwindow_right_vent.pngwindow_right_closed.png, andwindow_right_moving.png.
The same for the left windows (window_left_*.png)
I put all images in the www/eqs/ folder in HA.
Sensors
Please substitute your own sensor name, the XXX is just a placeholder for the name of your car. Also, put everything under the sensor: tag.
Lets start with the definition of the door. These are: Locked (no warning sub-image), Unlocked, and Open. These are all in the lock sensor.
# Codes for open/unlocked/venting of doors and sunroof (sensor.XXX_lock):
# doorlockstatus*: true: unlocked, false: locked
# doorstatus*: true: open, false: closed
# sunroofstatus: 0: closed, 1: open, 2: vent, 7: opening, 8: closing, 11: open vent, 12: closing vent
# Codes for open/venting of windows (binary_sensor.XXX_windows_closed):
# windowstatus*: 1: open, 2: closed, 4: vent, 5: moving
sensors:
eqs_door_frontleft:
friendly_name: "Front Left Door"
icon_template: >
{% if not state_attr('sensor.XXX_lock', 'doorlockstatusfrontleft') %} {# door locked #}
mdi:car-door-lock
{% else %} {# door unlocked #}
mdi:car-door-lock-open
{% endif %}
value_template: >
{% set door = "frontleft" %}
{% if not state_attr('sensor.XXX_lock', 'doorstatus'+door) %} {# door closed #}
{% if not state_attr('sensor.XXX_lock', 'doorlockstatus'+door) %} {# door locked #}
Locked
Unlocked
{% endif %}
{% else %} {# door open #}
Open
{% endif %}
eqs_door_frontright:
friendly_name: "Front Right Door"
icon_template: >
{% if not state_attr('sensor.XXX_lock', 'doorlockstatusfrontright') %} {# door locked #}
mdi:car-door-lock
{% endif %}
value_template: >
{% set door = "frontright" %}
Locked
Unlocked
{% endif %}
Open
{% endif %}
eqs_door_rearleft:
friendly_name: "Rear Left Door"
icon_template: >
{% if not state_attr('sensor.XXX_lock', 'doorlockstatusrearleft') %} {# door locked #}
mdi:car-door-lock
{% endif %}
value_template: >
{% set door = "rearleft" %}
Locked
Unlocked
{% endif %}
Open
{% endif %}
eqs_door_rearright:
friendly_name: "Rear Right Door"
icon_template: >
{% if not state_attr('sensor.XXX_lock', 'doorlockstatusrearright') %} {# door locked #}
mdi:car-door-lock
{% endif %}
value_template: >
{% set door = "rearright" %}
Locked
Unlocked
{% endif %}
Open
{% endif %}
Next we look into the states of the windows. These can be: Closed, Open, Vent, or Moving:
eqs_window_frontleft:
friendly_name: "Front Left Window"
icon_template: mdi:car-door
value_template: >
{% set window = "frontleft" %}
{% if is_state_attr('binary_sensor.XXX_windows_closed', 'windowstatus'+window, "2") %} {# window closed #}
Closed
{% elif is_state_attr('binary_sensor.XXX_windows_closed', 'windowstatus'+window, "4") %} {# window vent #}
{% if not state_attr('sensor.XXX_lock', 'doorstatus'+window) %} {# door closed #}
VentDC
VentDO
{% endif %}
{% elif is_state_attr('binary_sensor.XXX_windows_closed', 'windowstatus'+window, "1") %} {# window open #}
OpenDC
OpenDO
{% endif %}
{% else %} {# window moving #}
Moving
{% endif %}
eqs_window_frontright:
friendly_name: "Front Right Window"
value_template: >
{% set window = "frontright" %}
Closed
VentDC
VentDO
{% endif %}
OpenDC
OpenDO
{% endif %}
Moving
{% endif %}
eqs_window_rearleft:
friendly_name: "Rear Left Window"
value_template: >
{% set window = "rearleft" %}
Closed
VentDC
VentDO
{% endif %}
OpenDC
OpenDO
{% endif %}
Moving
{% endif %}
eqs_window_rearright:
friendly_name: "Rear Right Window"
value_template: >
{% set window = "rearright" %}
Closed
VentDC
VentDO
{% endif %}
OpenDC
OpenDO
{% endif %}
Moving
{% endif %}
And last, we have to integrate the sunroof, and the trunk. The image set has a warning image of an opened hood, but my EQS does not report the hood status, so thats not used. Maybe your car is different?
eqs_sunroof:
friendly_name: "Sunroof"
value_template: >
{% if is_state_attr('sensor.XXX_lock', 'sunroofstatus', "2") %}
vent
{% elif is_state_attr('sensor.XXX_lock', 'sunroofstatus', "1") %}
open
{% elif is_state_attr('sensor.XXX_lock', 'sunroofstatus', "0") %}
closed
{% else %}
moving
{% endif %}
eqs_trunk:
friendly_name: "Trunk"
value_template: >
{% if state_attr('sensor.XXX_lock', 'doorlockstatusdecklid') %}
unlocked
{% elif state_attr('sensor.XXX_lock', 'decklidstatus') %}
open
{% else %}
closed
{% endif %}
Now all thats missing is the tyre warning, these are straight foreward, albeit I did have to guess, as I didn’t have a tyre warning in my car yet.
eqs_tire_image_frontleft:
friendly_name: "Tire Warning Front Left"
icon_template: mdi:car-tire-alert
value_template: >
{% if is_state_attr('binary_sensor.XXX_tire_warning', 'tireMarkerFrontLeft', "0") %}
OK
{% else %}
Warning
{% endif %}
eqs_tire_image_frontright:
friendly_name: "Tire Warning Front Right"
value_template: >
{% if is_state_attr('binary_sensor.XXX_tire_warning', 'tireMarkerFrontRight', "0") %}
OK
{% else %}
Warning
{% endif %}
eqs_tire_image_rearleft:
friendly_name: "Tire Warning Rear Left"
value_template: >
{% if is_state_attr('binary_sensor.XXX_tire_warning', 'tireMarkerRearLeft', "0") %}
OK
{% else %}
Warning
{% endif %}
eqs_tire_image_rearright:
friendly_name: "Tire Warning Rear Right"
value_template: >
{% if is_state_attr('binary_sensor.XXX_tire_warning', 'tireMarkerRearRight', "0") %}
OK
{% else %}
Warning
{% endif %}
Picture Element card
Now to the meat of the whole excercise: The Picture Element card that ties it all together.
As you can see I implemented window control on the window icons. Feel free to change those if your car does not offer them. Replace the VIN number to the one of your car in the service calls.
Also replace all the 297100 in the filenames to your filenames of the downloaded zip from earlier.
type: picture-elements
image: local/eqs/297100_car.png
transform: translate(-50%, -50%)
elements:
- type: image
entity: sensor.eqs_door_frontleft
state_image:
Open: local/eqs/297100_door_frontleft_open.png
Unlocked: local/eqs/297100_door_frontleft_unlock.png
Locked: null
style:
top: 0%
left: 0%
transform: translate(0, 0)
tap_action:
action: none
- type: image
entity: sensor.eqs_window_frontleft
state_image:
OpenDC: local/eqs/297100_window_frontleft_opendoorclosed.png
OpenDO: local/eqs/297100_window_frontleft_opendooropened.png
VentDC: local/eqs/297100_window_frontleft_ventilatedoorclosed.png
VentDO: local/eqs/297100_window_frontleft_ventilatedooropened.png
Closed: null
Moving: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: image
entity: sensor.eqs_door_frontright
state_image:
Open: local/eqs/297100_door_frontright_open.png
Unlocked: local/eqs/297100_door_frontright_unlock.png
Locked: null
style:
top: 0%
left: 0%
transform: none
- type: image
entity: sensor.eqs_window_frontright
state_image:
OpenDC: local/eqs/297100_window_frontright_opendoorclosed.png
OpenDO: local/eqs/297100_window_frontright_opendooropened.png
VentDC: local/eqs/297100_window_frontright_ventilatedoorclosed.png
VentDO: local/eqs/297100_window_frontright_ventilatedooropened.png
Closed: null
Moving: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: image
entity: sensor.eqs_door_rearleft
state_image:
Open: local/eqs/297100_door_rearleft_open.png
Unlocked: local/eqs/297100_door_rearleft_unlock.png
Locked: null
style:
top: 0%
left: 0%
transform: none
- type: image
entity: sensor.eqs_window_rearleft
state_image:
OpenDC: local/eqs/297100_window_rearleft_opendoorclosed.png
OpenDO: local/eqs/297100_window_rearleft_opendooropened.png
VentDC: local/eqs/297100_window_rearleft_ventilatedoorclosed.png
VentDO: local/eqs/297100_window_rearleft_ventilatedooropened.png
Closed: null
Moving: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: image
entity: sensor.eqs_door_rearright
state_image:
Open: local/eqs/297100_door_rearright_open.png
Unlocked: local/eqs/297100_door_rearright_unlock.png
Locked: null
style:
top: 0%
left: 0%
transform: none
- type: image
entity: sensor.eqs_window_rearright
state_image:
OpenDC: local/eqs/297100_window_rearright_opendoorclosed.png
OpenDO: local/eqs/297100_window_rearright_opendooropened.png
VentDC: local/eqs/297100_window_rearright_ventilatedoorclosed.png
VentDO: local/eqs/297100_window_rearright_ventilatedooropened.png
Closed: null
Moving: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: image
entity: sensor.eqs_sunroof
state_image:
open: local/eqs/297100_sunroof_open.png
vent: local/eqs/297100_sunroof_ventilate.png
closed: null
moving: local/eqs/297100_sunroof_open.png
style:
top: 0%
left: 0%
transform: none
- type: image
entity: sensor.eqs_trunk
state_image:
open: local/eqs/297100_trunk_open.png
unlocked: local/eqs/297100_trunk_unlock.png
closed: null
style:
top: 0%
left: 0%
transform: none
- type: image
title: Front Left
state_image:
OpenDC: local/eqs/window_left_open.png
OpenDO: local/eqs/window_left_open.png
VentDC: local/eqs/window_left_vent.png
VentDO: local/eqs/window_left_vent.png
Closed: local/eqs/window_left_closed.png
Moving: local/eqs/window_left_moving.png
style:
top: 43%
left: 23%
transform: translate(-50%,-50%)
tap_action:
action: call-service
service: mbapi2020.windows_move
vin: W1KXXXXXXXXXXXXXX
front_left: '0'
hold_action:
front_left: '10'
double_tap_action:
front_left: '100'
- type: image
title: Front Right
state_image:
OpenDC: local/eqs/window_right_open.png
OpenDO: local/eqs/window_right_open.png
VentDC: local/eqs/window_right_vent.png
VentDO: local/eqs/window_right_vent.png
Closed: local/eqs/window_right_closed.png
Moving: local/eqs/window_right_moving.png
style:
top: 43%
left: 77%
tap_action:
front_right: '0'
hold_action:
front_right: '10'
double_tap_action:
front_right: '100'
- type: image
title: Rear Left
state_image:
style:
top: 61%
left: 23%
tap_action:
rear_left: '0'
hold_action:
rear_left: '10'
double_tap_action:
rear_left: '100'
- type: image
title: Rear Right
state_image:
style:
top: 61%
left: 77%
tap_action:
rear_right: '0'
hold_action:
rear_right: '10'
double_tap_action:
rear_right: '100'
- type: state-label
entity: sensor.XXX_tire_pressure_front_left
title: Front Left
style:
top: 23%
left: 33%
transform: translate(-100%,-50%)
- type: image
entity: sensor.eqs_tire_image_frontleft
state_image:
Warning: local/eqs/297100_tire_frontleft.png
OK: null
title: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: state-label
entity: sensor.XXX_tire_pressure_front_right
title: Front Right
style:
top: 23%
left: 66.5%
transform: translate(0%,-50%)
- type: image
entity: sensor.eqs_tire_image_frontright
state_image:
Warning: local/eqs/297100_tire_frontright.png
OK: null
title: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: state-label
entity: sensor.XXX_tire_pressure_rear_left
title: Rear Left
style:
top: 74%
left: 33%
- type: image
entity: sensor.eqs_tire_image_rearleft
state_image:
Warning: local/eqs/297100_tire_rearleft.png
OK: null
title: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: state-label
entity: sensor.XXX_tire_pressure_rear_right
title: Rear Right
style:
top: 74%
left: 66.5%
- type: image
entity: sensor.eqs_tire_image_rearright
state_image:
Warning: local/eqs/297100_tire_rearright.png
OK: null
title: null
style:
top: 0%
left: 0%
tap_action:
action: none
Thats it. It may have a few bugs and inconsistentcies, nothing severe that I have noticed.
Huge Thanks to Rene for providing the windows_move service call on my request.
Thanks,
Thomas
PS
I have also a sideview version, I can elaborate if there is interest.
EDIT: See below for the sideways version.
PPS
Here is the whole sensor: thing in one big chunk:
sensors:
eqs_door_frontleft:
icon_template: >
mdi:car-door-lock
{% endif %}
value_template: >
Locked
Unlocked
{% endif %}
Open
{% endif %}
icon_template: >
mdi:car-door-lock
{% endif %}
value_template: >
Locked
Unlocked
{% endif %}
Open
{% endif %}
eqs_door_rearleft:
icon_template: >
mdi:car-door-lock
{% endif %}
value_template: >
Locked
Unlocked
{% endif %}
Open
{% endif %}
eqs_door_rearright:
icon_template: >
mdi:car-door-lock
{% endif %}
value_template: >
Locked
Unlocked
{% endif %}
Open
{% endif %}
value_template: >
Closed
VentDC
VentDO
{% endif %}
OpenDC
OpenDO
{% endif %}
Moving
{% endif %}
value_template: >
Closed
VentDC
VentDO
{% endif %}
OpenDC
OpenDO
{% endif %}
Moving
{% endif %}
value_template: >
Closed
VentDC
VentDO
{% endif %}
OpenDC
OpenDO
{% endif %}
Moving
{% endif %}
value_template: >
Closed
VentDC
VentDO
{% endif %}
OpenDC
OpenDO
{% endif %}
Moving
{% endif %}
eqs_sunroof:
value_template: >
vent
open
closed
{% else %}
moving
{% endif %}
eqs_trunk:
value_template: >
unlocked
open
{% else %}
closed
{% endif %}
value_template: >
OK
{% else %}
Warning
{% endif %}
value_template: >
OK
{% else %}
Warning
{% endif %}
value_template: >
OK
{% else %}
Warning
{% endif %}
value_template: >
OK
{% else %}
Warning
{% endif %}
Could someone with a Mercedes EQE perhaps run the command Rene shared here Mercedes Me Component - #597 by ReneNulschDE and share the files please?
I’d need to SSH into HA but the SSH addon refuses to work so I can’t run the command in the correct spot…
You would receive my eternal gratitude ![]()
It seems like the access token is no longer stored in the HA config root folder.
I dimly remember a changelog about that…
Maybe @ReneNulschDE can weight in on that?
Also, you need the file, not a shell to HA. You can get files off HA either via Studio Code Server, or Samba share.
I did read that HA and ssh had changes over the year, what is currently working in my installation is the “Terminal & SSH” Add-On from the official add-on store. I do run HAOS in a VM.
MB and I made a lot of changes since this posting and I assume its easier to have a service to download the images. I’m currently implementing this and will publish a beta later today.
In the beta you will see a new service mbapi2020.download_images. It will require the VIN. After starting the service a zip-file will be available locally.
Supporting the great post from @Thomas01, I have published a new beta version “v0.14.0-beta.1 - AdBlue Sensor, Images download”:
New:
- New service “download_images”. This service will download a zip-file from the MB-servers with images (of your car of course) (to custom_components/mbapi2020/resources/vin.zip) that Thomas used in his post
- New sensor “tankleveladblue”. Shows the level of the AdBlue tank in %.
Fixes:
- Next try on the ReAuth issue. (I can’t reproduce it and changed the logic a little bit)
Thanks, updated my post above.
I am interested in the sideview car, it fits better.
Picture Element card - Sideways orientation
In my previous post, I described how to use picture elements to generate a view similar to the MercedesMe app (in an “upright” view), with the help of the images provided by Mercedes Benz.
Now to continue with a rotated, “sideview” version:
Let’s start with the
Requirements
The set-up of the sensors is the same as with the upright version, so start there.
The difference starts with the supplied images. The CSS of the picture elements card take care of rotating the images, except for the background image (XXXXXX_car.png), which needs to be rotated using your favourite image manipulation programme (GIMP comes to mind). I called the rotated image XXX_car_rotate.png in my case.
Also, only the window_right_*.png images are used for the states of the windows.
Just as before (replace all the 297100 in the filenames to your filenames of the downloaded zip from earlier, and XXX with your car name), except that now a rotate command is added (and some coordinates change).
image: local/eqs/297100_car_rotate.png
elements:
- type: image
state_image:
Locked: null
style:
top: 0%
left: 0%
transform: translate(0, 0) rotate(0.25turn)
tap_action:
action: none
- type: image
state_image:
Closed: null
Moving: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: image
state_image:
Locked: null
style:
top: 0%
left: 0%
- type: image
state_image:
Closed: null
Moving: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: image
state_image:
Locked: null
style:
top: 0%
left: 0%
- type: image
state_image:
Closed: null
Moving: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: image
state_image:
Locked: null
style:
top: 0%
left: 0%
- type: image
state_image:
Closed: null
Moving: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: image
state_image:
closed: null
style:
top: 0%
left: 0%
- type: image
state_image:
closed: null
style:
top: 0%
left: 0%
- type: image
title: Front Left
state_image:
style:
top: 24%
left: 56%
tap_action:
front_left: '0'
hold_action:
front_left: '10'
double_tap_action:
front_left: '100'
- type: image
title: Front Right
state_image:
style:
top: 76%
left: 56%
tap_action:
front_right: '0'
hold_action:
front_right: '10'
double_tap_action:
front_right: '100'
- type: image
title: Rear Left
state_image:
style:
top: 24%
left: 39%
tap_action:
rear_left: '0'
hold_action:
rear_left: '10'
double_tap_action:
rear_left: '100'
- type: image
title: Rear Right
state_image:
style:
top: 76%
left: 39%
tap_action:
rear_right: '0'
hold_action:
rear_right: '10'
double_tap_action:
rear_right: '100'
- type: state-label
title: Front Left
style:
top: 34%
left: 77%
transform: translate(-50%,-100%)
- type: image
state_image:
OK: null
title: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: state-label
title: Front Right
style:
top: 66%
left: 77%
transform: translate(-50%,0%)
- type: image
state_image:
OK: null
title: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: state-label
title: Rear Left
style:
top: 34%
left: 26%
- type: image
state_image:
OK: null
title: null
style:
top: 0%
left: 0%
tap_action:
action: none
- type: state-label
title: Rear Right
style:
top: 66%
left: 26%
- type: image
state_image:
OK: null
title: null
style:
top: 0%
left: 0%
tap_action:
action: none
Thanks @ReneNulschDE and @Thomas01 for the excellent work, ran the beta, got the images, followed Thomas’ tutorial and it all seems to be up and running (haven’t fiddled with the status of doors and windows yet, will do so another day).
Pics!
Would love to see other peoples implementation of status/control cards. Especially if they are image based.
Here you go!
there’s another card with efficiency, range etc but that contains my license plate so I’ve kept that out.
Nice.
What are the wiggly lines on the hood?
And the Eco Scores look a bit like the Apple fitnes rings. How did you do the rings?
Thanks!
The wiggly lines are the preconditioning of the car - rather important when my better half wants to use the car during colder days ![]()
The ring graph is made with the custom apexcharts card.
I might try and play around to change the colour of the car to the actual colour of mine (black) and also redistribute the icons to make it look more ‘balanced’…
Hi All and first a big thank you to @ReneNulschDE and @Thomas01 for their combined effort! I just installed the newest beta version v0.14.0-beta.1 and tried downloading the images. Unfortunately I got this error: Given VIN/FIN is not managed by any coordinator or excluded in the integration options.
What am I doing wrong?
