I’ve made a blueprint for the Aqara Cube.
Use this URL to import to your blueprints!
I have not tested EVERY function yet but every function is built the same way so it should work. But let me know if you see any errors. Be sure to listen to deconz_event to see if cube is actually registering when it’s not working.
Blueprint
blueprint:
name: Mi Magic Cube
description: |
Control anything using Mi Magic Cube.
Remember not to use an action on every combination, then you won't be able to start from anywhere without triggering an action
domain: automation
input:
remote:
description: Mi Magic Cube
selector:
device:
integration: deconz
manufacturer: LUMI
model: lumi.sensor_cube.aqgl01
#Extra conf
flip_90:
name: Flip 90 degrees
description: |
Actions to run when cube flips 90 degrees
This cancels all specific 90 degrees functions
e.g From side 1 to side 2 will be the same as from side 6 to side 2
default: false
selector:
boolean: {}
cube_flip_90:
name: Flip cube 90 degrees
description: Action to run when cube flips 90 degrees. This only works if 'Flip 90 degrees' is toggled
default: []
selector:
flip_180:
name: Flip 180 degrees
description: |
Actions to run when cube flips 180 degrees.
This cancels all specific 180 degrees functions
e.g From side 1 to side 6 will be the same as from side 5 to side 2
default: false
selector:
boolean: {}
cube_flip_180:
name: Flip cube 180 degrees
description: Action to run when cube flips 180 degrees. This only works if 'Flip 180 degrees' is toggled
default: []
selector:
one_side_slide:
name: Slide any side
description: |
Actions to run when cube slides on any side
This cancels all specific slide functions
e.g Slide on side 1 will be the same as slide on side 2
default: false
selector:
boolean: {}
cube_one_side_slide:
name: Slide cube on any side
description: Action to run when cube slides on any slide. This only works if 'Slide any side' is toggled
default: []
selector:
double_tap_any_side:
name: Double tap on any side
description: |
Actions to run when double tapping cube regardless of the side.
This cancels all specific double tap functions
e.g Double tap on side 1 will be the same as double tapping side 2
default: false
selector:
boolean: {}
cube_double_tap_any:
name: Double tap cube on any side
description: Action to run when double tapping cube on any side. This only works if 'Double tap on any side' is toggled
default: []
selector:
#From Side 1
one_to_two:
name: From side 1 to side 2
description: Action to run when cube goes from side 1 to side 2
default: []
selector:
one_to_three:
name: From side 1 to side 3
description: Action to run when cube goes from side 1 to side 3
default: []
selector:
one_to_four:
name: From side 1 to side 4
description: Action to run when cube goes from side 1 to side 4
default: []
selector:
one_to_five:
name: From side 1 to side 5
description: Action to run when cube goes from side 1 to side 5
default: []
selector:
one_to_six:
name: From side 1 to side 6
description: Action to run when cube goes from side 1 to side 6
default: []
selector:
#From Side 2
two_to_one:
name: From side 2 to side 1
description: Action to run when cube goes from side 2 to side 1
default: []
selector:
two_to_three:
name: From side 2 to side 3
description: Action to run when cube goes from side 2 to side 3
default: []
selector:
two_to_four:
name: From side 2 to side 4
description: Action to run when cube goes from side 2 to side 4
default: []
selector:
two_to_five:
name: From side 2 to side 5
description: Action to run when cube goes from side 2 to side 5
default: []
selector:
two_to_six:
name: From side 2 to side 6
description: Action to run when cube goes from side 2 to side 6
default: []
selector:
#From Side 3
three_to_one:
name: From side 3 to side 1
description: Action to run when cube goes from side 3 to side 1
default: []
selector:
three_to_two:
name: From side 3 to side 2
description: Action to run when cube goes from side 3 to side 2
default: []
selector:
three_to_four:
name: From side 3 to side 4
description: Action to run when cube goes from side 3 to side 4
default: []
selector:
three_to_five:
name: From side 3 to side 5
description: Action to run when cube goes from side 3 to side 5
default: []
selector:
three_to_six:
name: From side 3 to side 6
description: Action to run when cube goes from side 3 to side 6
default: []
selector:
#From Side 4
four_to_one:
name: From side 4 to side 1
description: Action to run when cube goes from side 4 to side 1
default: []
selector:
four_to_two:
name: From side 4 to side 2
description: Action to run when cube goes from side 4 to side 2
default: []
selector:
four_to_three:
name: From side 4 to side 3
description: Action to run when cube goes from side 4 to side 3
default: []
selector:
four_to_five:
name: From side 4 to side 5
description: Action to run when cube goes from side 4 to side 5
default: []
selector:
four_to_six:
name: From side 4 to side 6
description: Action to run when cube goes from side 4 to side 6
default: []
selector:
#From Side 5
five_to_one:
name: From side 5 to side 1
description: Action to run when cube goes from side 5 to side 1
default: []
selector:
five_to_two:
name: From side 5 to side 2
description: Action to run when cube goes from side 5 to side 2
default: []
selector:
five_to_three:
name: From side 5 to side 3
description: Action to run when cube goes from side 5 to side 3
default: []
selector:
five_to_four:
name: From side 5 to side 4
description: Action to run when cube goes from side 5 to side 4
default: []
selector:
five_to_six:
name: From side 5 to side 6
description: Action to run when cube goes from side 5 to side 6
default: []
selector:
#From Side 6
six_to_one:
name: From side 6 to side 1
description: Action to run when cube goes from side 6 to side 1
default: []
selector:
six_to_two:
name: From side 6 to side 2
description: Action to run when cube goes from side 6 to side 2
default: []
selector:
six_to_three:
name: From side 6 to side 3
description: Action to run when cube goes from side 6 to side 3
default: []
selector:
six_to_four:
name: From side 6 to side 4
description: Action to run when cube goes from side 6 to side 4
default: []
selector:
six_to_five:
name: From side 6 to side 5
description: Action to run when cube goes from side 6 to side 5
default: []
selector:
#Double taps
one_to_one:
name: Double tap - Side 1
description: Action to run when double tap on side 1
default: []
selector:
two_to_two:
name: Double tap - Side 2
description: Action to run when double tap on side 2
default: []
selector:
three_to_three:
name: Double tap - Side 3
description: Action to run when double tap on side 3
default: []
selector:
four_to_four:
name: Double tap - Side 4
description: Action to run when double tap on side 4
default: []
selector:
five_to_five:
name: Double tap - Side 5
description: Action to run when double tap on side 5
default: []
selector:
six_to_six:
name: Double tap - Side 6
description: Action to run when double tap on side 6
default: []
selector:
#Rotates
rotate_clockwise:
name: Rotate clockwise
description: Action to run when cube rotates clockwise
default: []
selector:
rotate_counter_clockwise:
name: Rotate counter clockwise
description: Action to run when cube rotates counter clockwise
default: []
selector:
#Slides
slide_on_one:
name: Slide - Side 1 up
description: Action to run when slides with Side 1 up
default: []
selector:
slide_on_two:
name: Slide - Side 2 up
description: Action to run when slides with Side 2 up
default: []
selector:
slide_on_three:
name: Slide - Side 3 up
description: Action to run when slides with Side 3 up
default: []
selector:
slide_on_four:
name: Slide - Side 4 up
description: Action to run when slides with Side 4 up
default: []
selector:
slide_on_five:
name: Slide - Side 5 up
description: Action to run when slides with Side 5 up
default: []
selector:
slide_on_six:
name: Slide - Side 6 up
description: Action to run when slides with Side 6 up
default: []
selector:
#Misc
cube_wake:
name: Wake up the cube
description: Action to run when cube wakes up
default: []
selector:
cube_fall:
description: |
Action to run when cube falls
pro tip: throw up and catch
default: []
selector:
cube_shake:
description: Action to run when you shake the cube
default: []
selector:
mode: restart
max_exceeded: silent
- platform: event
event_type: deconz_event
event_data:
device_id: !input "remote"
- variables:
event: "{{ trigger.event.data.event }}"
gesture: "{{ trigger.event.data.gesture }}"
flip_90: !input "flip_90"
flip_180: !input "flip_180"
one_side_slide: !input "one_side_slide"
double_tap_any_side: !input "double_tap_any_side"
- choose:
#From Side 1
- conditions:
- "{{ event == 1001 }}"
sequence:
- choose:
- conditions: "{{ double_tap_any_side }}"
sequence: !input cube_double_tap_any
default: !input one_to_one
- conditions:
- "{{ event == 2001 }}"
sequence:
- choose:
- conditions: "{{ flip_90 }}"
sequence: !input cube_flip_90
default: !input one_to_two
- conditions:
- "{{ event == 3001 }}"
sequence:
- choose:
default: !input one_to_three
- conditions:
- "{{ event == 4001 }}"
sequence:
- choose:
default: !input one_to_four
- conditions:
- "{{ event == 5001 }}"
sequence:
- choose:
default: !input one_to_five
- conditions:
- "{{ event == 6001 }}"
sequence:
- choose:
- conditions: "{{ flip_180 }}"
sequence: !input cube_flip_180
default: !input one_to_six
#From Side 2
- conditions:
- "{{ event == 1002 }}"
sequence:
- choose:
default: !input two_to_one
- conditions:
- "{{ event == 2002 }}"
sequence:
- choose:
default: !input two_to_two
- conditions:
- "{{ event == 3002 }}"
sequence:
- choose:
default: !input two_to_three
- conditions:
- "{{ event == 4002 }}"
sequence:
- choose:
default: !input two_to_four
- conditions:
- "{{ event == 5002 }}"
sequence:
- choose:
default: !input two_to_five
- conditions:
- "{{ event == 6002 }}"
sequence:
- choose:
default: !input two_to_six
#From Side 3
- conditions:
- "{{ event == 1003 }}"
sequence:
- choose:
default: !input three_to_one
- conditions:
- "{{ event == 2003 }}"
sequence:
- choose:
default: !input three_to_two
- conditions:
- "{{ event == 3003 }}"
sequence:
- choose:
default: !input three_to_three
- conditions:
- "{{ event == 4003 }}"
sequence:
- choose:
default: !input three_to_four
- conditions:
- "{{ event == 5003 }}"
sequence:
- choose:
default: !input three_to_five
- conditions:
- "{{ event == 6003 }}"
sequence:
- choose:
default: !input three_to_six
#From Side 4
- conditions:
- "{{ event == 1004 }}"
sequence:
- choose:
default: !input four_to_one
- conditions:
- "{{ event == 2004 }}"
sequence:
- choose:
default: !input four_to_two
- conditions:
- "{{ event == 3004 }}"
sequence:
- choose:
default: !input four_to_three
- conditions:
- "{{ event == 4004 }}"
sequence:
- choose:
default: !input four_to_four
- conditions:
- "{{ event == 5004 }}"
sequence:
- choose:
default: !input four_to_five
- conditions:
- "{{ event == 6004 }}"
sequence:
- choose:
default: !input four_to_six
#From Side 5
- conditions:
- "{{ event == 1005 }}"
sequence:
- choose:
default: !input five_to_one
- conditions:
- "{{ event == 2005 }}"
sequence:
- choose:
default: !input five_to_two
- conditions:
- "{{ event == 3005 }}"
sequence:
- choose:
default: !input five_to_three
- conditions:
- "{{ event == 4005 }}"
sequence:
- choose:
default: !input five_to_four
- conditions:
- "{{ event == 5005 }}"
sequence:
- choose:
default: !input five_to_five
- conditions:
- "{{ event == 6005 }}"
sequence:
- choose:
default: !input five_to_six
#From Side 1
- conditions:
- "{{ event == 1006 }}"
sequence:
- choose:
default: !input six_to_one
- conditions:
- "{{ event == 2006 }}"
sequence:
- choose:
default: !input six_to_two
- conditions:
- "{{ event == 3006 }}"
sequence:
- choose:
default: !input six_to_three
- conditions:
- "{{ event == 4006 }}"
sequence:
- choose:
default: !input six_to_four
- conditions:
- "{{ event == 5006 }}"
sequence:
- choose:
default: !input six_to_five
- conditions:
- "{{ event == 6006 }}"
sequence:
- choose:
default: !input six_to_six
#Slides
- conditions:
- "{{ event == 1000 }}"
sequence:
- choose:
- conditions: "{{ one_side_slide }}"
sequence: !input cube_one_side_slide
default: !input slide_on_one
- conditions:
- "{{ event == 2000 }}"
sequence:
- choose:
default: !input slide_on_two
- conditions:
- "{{ event == 3000 }}"
sequence:
- choose:
default: !input slide_on_three
- conditions:
- "{{ event == 4000 }}"
sequence:
- choose:
default: !input slide_on_four
- conditions:
- "{{ event == 5000 }}"
sequence:
- choose:
default: !input slide_on_five
- conditions:
- "{{ event == 6000 }}"
sequence:
- choose:
default: !input slide_on_six
#Rotates
- conditions:
- "{{ gesture == 7 }}"
sequence: !input rotate_clockwise
- conditions:
- "{{ gesture == 8 }}"
sequence: !input rotate_counter_clockwise
#Misc
- conditions:
- "{{ event == 7000 }}"
sequence: !input cube_wake
- conditions:
- "{{ event == 7007 }}"
sequence: !input cube_shake
- conditions:
- "{{ event == 7008 }}"
sequence: !input cube_fall
. I do not know when I have the time, might be in the evening tomorrow.
