Blueprint to support the Xiaomi Cube Controller using ZHA.
Thanks to @bergstrom for this inspiration.
All has been tested.
Supported actions
- Slide
- Knock
- Flip 90 degress
- Flip 180 degress
- Shake
- Drop
- Wake
- Rotate clockwise
- Rotate counter-clockwise
Blueprint
Click the badge to import this Blueprint: (needs Home Assistant Core 2021.3 or higher)
blueprint:
name: Aqara Magic Cube
description: Control anything using Aqara Magic Cube.
domain: automation
input:
remote:
description: Select the Aqara Magic Cube device
selector:
device:
integration: zha
manufacturer: LUMI
flip_90:
name: Flip 90 degrees
description: Actions to run when cube flips 90 degrees.
This cancels all specific 90 degrees functions.
e.g From side 1 to side 2 will be the same as from side 6 to side 2
default: false
selector:
boolean: {}
cube_flip_90:
name: Flip cube 90 degrees
description: Action to run when cube flips 90 degrees. This only works if 'Flip 90 degrees' is toggled
default: []
selector:
action: {}
flip_180:
name: Flip 180 degrees
description: Actions to run when cube flips 180 degrees.
This cancels all specific 180 degrees functions
e.g From side 1 to side 4 will be the same as from side 5 to side 2
default: false
selector:
boolean: {}
cube_flip_180:
name: Flip cube 180 degrees
description: Action to run when cube flips 180 degrees. This only works if 'Flip 180 degrees' is toggled
default: []
selector:
action: {}
slide_any_side:
name: Slide any side
description: Actions to run when cube slides on any side.
This cancels all specific 'slide' functions
e.g Slide on side 1 will be the same as slide on side 2
default: false
selector:
boolean: {}
cube_slide_any:
name: Slide cube on any side
description: Action to run when cube slides on any slide. This only works if 'Slide any side' is toggled
default: []
selector:
action: {}
knock_any_side:
name: Knock on any side
description: Actions to run when knocking cube regardless of the side.
This cancels all specific 'knock' functions
e.g Knock on side 1 will be the same as knocking side 2
default: false
selector:
boolean: {}
cube_knock_any:
name: Knock cube on any side
description: Action to run when knocking cube on any side. This only works if 'Knock on any side' is toggled
default: []
selector:
action: {}
one_to_two:
name: From side 1 to side 2
description: Action to run when cube goes from side 1 to side 2
default: []
selector:
action: {}
one_to_three:
name: From side 1 to side 3
description: Action to run when cube goes from side 1 to side 3
default: []
selector:
action: {}
one_to_four:
name: From side 1 to side 4
description: Action to run when cube goes from side 1 to side 4
default: []
selector:
action: {}
one_to_five:
name: From side 1 to side 5
description: Action to run when cube goes from side 1 to side 5
default: []
selector:
action: {}
one_to_six:
name: From side 1 to side 6
description: Action to run when cube goes from side 1 to side 6
default: []
selector:
action: {}
two_to_one:
name: From side 2 to side 1
description: Action to run when cube goes from side 2 to side 1
default: []
selector:
action: {}
two_to_three:
name: From side 2 to side 3
description: Action to run when cube goes from side 2 to side 3
default: []
selector:
action: {}
two_to_four:
name: From side 2 to side 4
description: Action to run when cube goes from side 2 to side 4
default: []
selector:
action: {}
two_to_five:
name: From side 2 to side 5
description: Action to run when cube goes from side 2 to side 5
default: []
selector:
action: {}
two_to_six:
name: From side 2 to side 6
description: Action to run when cube goes from side 2 to side 6
default: []
selector:
action: {}
three_to_one:
name: From side 3 to side 1
description: Action to run when cube goes from side 3 to side 1
default: []
selector:
action: {}
three_to_two:
name: From side 3 to side 2
description: Action to run when cube goes from side 3 to side 2
default: []
selector:
action: {}
three_to_four:
name: From side 3 to side 4
description: Action to run when cube goes from side 3 to side 4
default: []
selector:
action: {}
three_to_five:
name: From side 3 to side 5
description: Action to run when cube goes from side 3 to side 5
default: []
selector:
action: {}
three_to_six:
name: From side 3 to side 6
description: Action to run when cube goes from side 3 to side 6
default: []
selector:
action: {}
four_to_one:
name: From side 4 to side 1
description: Action to run when cube goes from side 4 to side 1
default: []
selector:
action: {}
four_to_two:
name: From side 4 to side 2
description: Action to run when cube goes from side 4 to side 2
default: []
selector:
action: {}
four_to_three:
name: From side 4 to side 3
description: Action to run when cube goes from side 4 to side 3
default: []
selector:
action: {}
four_to_five:
name: From side 4 to side 5
description: Action to run when cube goes from side 4 to side 5
default: []
selector:
action: {}
four_to_six:
name: From side 4 to side 6
description: Action to run when cube goes from side 4 to side 6
default: []
selector:
action: {}
five_to_one:
name: From side 5 to side 1
description: Action to run when cube goes from side 5 to side 1
default: []
selector:
action: {}
five_to_two:
name: From side 5 to side 2
description: Action to run when cube goes from side 5 to side 2
default: []
selector:
action: {}
five_to_three:
name: From side 5 to side 3
description: Action to run when cube goes from side 5 to side 3
default: []
selector:
action: {}
five_to_four:
name: From side 5 to side 4
description: Action to run when cube goes from side 5 to side 4
default: []
selector:
action: {}
five_to_six:
name: From side 5 to side 6
description: Action to run when cube goes from side 5 to side 6
default: []
selector:
action: {}
six_to_one:
name: From side 6 to side 1
description: Action to run when cube goes from side 6 to side 1
default: []
selector:
action: {}
six_to_two:
name: From side 6 to side 2
description: Action to run when cube goes from side 6 to side 2
default: []
selector:
action: {}
six_to_three:
name: From side 6 to side 3
description: Action to run when cube goes from side 6 to side 3
default: []
selector:
action: {}
six_to_four:
name: From side 6 to side 4
description: Action to run when cube goes from side 6 to side 4
default: []
selector:
action: {}
six_to_five:
name: From side 6 to side 5
description: Action to run when cube goes from side 6 to side 5
default: []
selector:
action: {}
one_to_one:
name: Knock - Side 1
description: Action to run when knocking on side 1
default: []
selector:
action: {}
two_to_two:
name: Knock - Side 2
description: Action to run when knocking on side 2
default: []
selector:
action: {}
three_to_three:
name: Knock - Side 3
description: Action to run when knocking on side 3
default: []
selector:
action: {}
four_to_four:
name: Knock - Side 4
description: Action to run when knocking on side 4
default: []
selector:
action: {}
five_to_five:
name: Knock - Side 5
description: Action to run when knocking on side 5
default: []
selector:
action: {}
six_to_six:
name: Knock - Side 6
description: Action to run when knocking on side 6
default: []
selector:
action: {}
slide_on_one:
name: Slide - Side 1 up
description: Action to run when slides with Side 1 up
default: []
selector:
action: {}
slide_on_two:
name: Slide - Side 2 up
description: Action to run when slides with Side 2 up
default: []
selector:
action: {}
slide_on_three:
name: Slide - Side 3 up
description: Action to run when slides with Side 3 up
default: []
selector:
action: {}
slide_on_four:
name: Slide - Side 4 up
description: Action to run when slides with Side 4 up
default: []
selector:
action: {}
slide_on_five:
name: Slide - Side 5 up
description: Action to run when slides with Side 5 up
default: []
selector:
action: {}
slide_on_six:
name: Slide - Side 6 up
description: Action to run when slides with Side 6 up
default: []
selector:
action: {}
cube_wake:
name: Wake up the cube
description: Action to run when cube wakes up
default: []
selector:
action: {}
cube_drop:
description: Action to run when cube drops
default: []
selector:
action: {}
cube_shake:
description: Action to run when you shake the cube
default: []
selector:
action: {}
rotate_right:
description: Action to run when cube rotates right
default: []
selector:
action: {}
rotate_left:
description: Action to run when cube rotates left
default: []
selector:
action: {}
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input "remote"
- variables:
command: "{{ trigger.event.data.command }}"
value: "{{ trigger.event.data.args.value }}"
flip_degrees: "{{ trigger.event.data.args.flip_degrees }}"
relative_degrees: "{{ trigger.event.data.args.relative_degrees }}"
flip_90: !input "flip_90"
flip_180: !input "flip_180"
slide_any_side: !input "slide_any_side"
knock_any_side: !input "knock_any_side"
flip90: 64
flip180: 128
slide: 256
knock: 512
shake: 0
drop: 3
activated_face: >
{% if command == "slide" or command == "knock" %}
{% if trigger.event.data.args.activated_face == 1 %} 1
{% elif trigger.event.data.args.activated_face == 2 %} 5
{% elif trigger.event.data.args.activated_face == 3 %} 6
{% elif trigger.event.data.args.activated_face == 4 %} 4
{% elif trigger.event.data.args.activated_face == 5 %} 2
{% elif trigger.event.data.args.activated_face == 6 %} 3
{% endif %}
{% elif command == 'flip' %}
{{ trigger.event.data.args.activated_face | int }}
{% endif %}
from_face: >
{% if command == "flip" and flip_degrees == 90 %}
{{ ((value - flip90 - (trigger.event.data.args.activated_face - 1)) / 8) + 1 | int }}
{% endif %}
- choose:
# ---------------------------- Rotate Right ----------------------------
- conditions:
- "{{ command == 'rotate_right' }}"
sequence: !input "rotate_right"
# ---------------------------- Rotate Left ----------------------------
- conditions:
- "{{ command == 'rotate_left' }}"
sequence: !input "rotate_left"
# ---------------------------- Wake ----------------------------
- conditions:
- "{{ command == 'checkin' }}"
sequence: !input "cube_wake"
# ---------------------------- Shake ----------------------------
- conditions:
- "{{ value == shake }}"
sequence: !input "cube_shake"
# ---------------------------- Drop ----------------------------
- conditions:
- "{{ value == drop }}"
sequence: !input "cube_drop"
# ---------------------------- Knock any side ----------------------------
- conditions:
- "{{ command == 'knock' and knock_any_side }}"
sequence: !input "cube_knock_any"
# ---------------------------- Slide any side ----------------------------
- conditions:
- "{{ command == 'slide' and slide_any_side }}"
sequence: !input "cube_slide_any"
# ---------------------------- Flip 90 to any side ----------------------------
- conditions:
- "{{ flip_degrees == 90 and flip_90 }}"
sequence: !input "cube_flip_90"
# ---------------------------- Flip 180 to any side ----------------------------
- conditions:
- "{{ flip_degrees == 180 and flip_180 }}"
sequence: !input "cube_flip_180"
# ---------------------------- Flip 90 to side 1 ----------------------------
- conditions:
- "{{ flip_degrees == 90 and activated_face == 1 }}"
sequence:
- choose:
- conditions: "{{ from_face == 2 }}"
sequence: !input "two_to_one"
- conditions: "{{ from_face == 3 }}"
sequence: !input "three_to_one"
- conditions: "{{ from_face == 5 }}"
sequence: !input "five_to_one"
- conditions: "{{ from_face == 6 }}"
sequence: !input "six_to_one"
# ---------------------------- Flip 90 to side 2 ----------------------------
- conditions:
- "{{ flip_degrees == 90 and activated_face == 2 }}"
sequence:
- choose:
- conditions: "{{ from_face == 1 }}"
sequence: !input "one_to_two"
sequence: !input "three_to_two"
- conditions: "{{ from_face == 4 }}"
sequence: !input "four_to_two"
sequence: !input "six_to_two"
# ---------------------------- Flip 90 to side 3 ----------------------------
- conditions:
- "{{ flip_degrees == 90 and activated_face == 3 }}"
sequence:
- choose:
sequence: !input "one_to_three"
sequence: !input "two_to_three"
sequence: !input "four_to_three"
sequence: !input "five_to_three"
# ---------------------------- Flip 90 to side 4 ----------------------------
- conditions:
- "{{ flip_degrees == 90 and activated_face == 4 }}"
sequence:
- choose:
sequence: !input "two_to_four"
sequence: !input "three_to_four"
sequence: !input "five_to_four"
sequence: !input "six_to_four"
# ---------------------------- Flip 90 to side 5 ----------------------------
- conditions:
- "{{ flip_degrees == 90 and activated_face == 5 }}"
sequence:
- choose:
sequence: !input "one_to_five"
sequence: !input "three_to_five"
sequence: !input "four_to_five"
sequence: !input "six_to_five"
# ---------------------------- Flip 90 to side 6 ----------------------------
- conditions:
- "{{ flip_degrees == 90 and activated_face == 6 }}"
sequence:
- choose:
sequence: !input "one_to_six"
sequence: !input "two_to_six"
sequence: !input "four_to_six"
sequence: !input "five_to_six"
# ---------------------------- Flip 180 to side x ----------------------------
- conditions:
- "{{ value == flip180 + activated_face - 1 }}"
sequence:
- choose:
- conditions: "{{ activated_face == 1 }}"
sequence: !input "four_to_one"
- conditions: "{{ activated_face == 2 }}"
sequence: !input "five_to_two"
- conditions: "{{ activated_face == 3 }}"
sequence: !input "six_to_three"
- conditions: "{{ activated_face == 4 }}"
sequence: !input "one_to_four"
- conditions: "{{ activated_face == 5 }}"
sequence: !input "two_to_five"
- conditions: "{{ activated_face == 6 }}"
sequence: !input "three_to_six"
# ---------------------------- Knock side x ----------------------------
- conditions:
- "{{ value == knock + activated_face - 1 }}"
sequence:
- choose:
sequence: !input "one_to_one"
sequence: !input "two_to_two"
sequence: !input "three_to_three"
sequence: !input "four_to_four"
sequence: !input "five_to_five"
sequence: !input "six_to_six"
# ---------------------------- Slide side x ----------------------------
- conditions:
- "{{ value == slide + activated_face - 1 }}"
sequence:
- choose:
sequence: !input "slide_on_one"
sequence: !input "slide_on_two"
sequence: !input "slide_on_three"
sequence: !input "slide_on_four"
sequence: !input "slide_on_five"
sequence: !input "slide_on_six"
