Midea A/C and ESPHome component - list of all known working models and manufacturers
Manufacturer: MaxiCool (Midea)
Model: AMD-AUR-09HDI
Year: 2020
Market: EU
Installed in 3 A/C units,all with ESPHOME ESP01S+Adapter
All work great. Thanks.
Manufacturer: Simando/Dimstal (Midea/Coolix)
Model: SMND-PAC-12
Year: 2020
Market: EU
I’m trying to make my Mr Cool diy 12k working so far all I get is unknown for everything and it shows 32°F any ideas as to what I’m doing wrong? I’ve swapped TX and Rx to no help.
Brand: kentatsu
Model: ksgi26hfan1
Year: 2021?
Market: RU
I finally got to update this list. :slight_smile: Sorry for the wait! :slight_smile:
All devices named in posts above are now added to the list (=this is only to remind me :rofl: )
Thanks to all, that keep adding their models! :slight_smile: :+1:
I want to confirm that it works too with:
#1
Brand: Rotenso
Model: Ukura (U35Wi/o)
Year: 2020
Market: PL
Basically any A/C that can take in OSK103 (or newer OSK105) will work with midea-ac & esphome.
For ESP-Module Dongle info: GitHub - dudanov/iot-uni-dongle: An project of universal minimalistic Wi-Fi dongle for various IOT appliances controlled via UART. (On photo my module based on iot-uni-dongle circuit)
obraz
Here is some more info about the USB cable adapter:
USBpin -- color  -- function
 1     --  Red   -- +5V
 2     -- Orange -- Uart Rx (ESP8266: GPIO3) (receive data from A/C)
 3     -- Brown  -- Uart Tx (ESP8266: GPIO1) (send data to A/C)
 4     -- Black  -- GND (0V)
On the display board there is JST XH 4pin 2.5mm pitch (you can buy from ali a box with those for ~2-3$)
USB pinout is here: Universal Serial Bus (USB) - HwB
You can use some USB-A extension cable, USB-OTG cable and cut off other side, or just solder wires to USB-A socket :smile: and crimp JST XH terminals on wires.
And here is my module from bottom with added description of signals:
obraz
An here one more photo:
The following AC is working with this component:
Brand: Airfel
Model: LTXN35UBV1B/LRXN35UBV1B
Year: 2019(?)
Market: HU
(There is an other model with lesser performance: Airfel LTXN25UBV1B/LRXN25UBV1B, I think it is the same electronics, so it has to work)
Best regards!
Hey,
I found a model working on the German market. It is working perfectly with the Wifi dongle
It’s the Midea Real Cool 35
Brand: Midea
EAN: 4048 164 10826 8 (Real Cool 35)
Year: 2021
Market: DE
It’s a little hard to get to the module. If interested I can add more pictures and instructions on the procedure.
Thanks to @dudanov for the excellent module! AC is working flawlessly.
Cheers
Just wanted to confirm this is also working with my Samsung 3.5kW aircon-unit which is another Midea spin-off:
Brand: Samsung
Model: AR12TXHQASIN
Year: 2022
Market: UK (EU)
Using the ESPhome controller USB wifi adapter - SLWF-01pro Air conditioner Wi-Fi module for Midea, Idea, Neoclima, Electrolux, Beko and many more. Model SMARTLIGHT SLWF-01pro (v.1.0)
From Telegram:
Brand: Ballu
Model: BSY/in-12HN8/ES_21Y
Year: ??
Market: UK (EU)/UA
@paddy0174 time to update the main post?
Please append to support list
Zanussi ZACS/i-09 HS/N1
With esp01 and special adapter uart board.
Manufacturer: PIONEER
Model: WYS009GMFI22RL Mini Split Heat Pump
Year: 2022
Market: US
Link
Manufacturer: Mitsui
Model: TRENDLINE (12000)
Year: 2022
Market: EU
Model ID: MTXI12HP24
Model: TRENDLINE (18000)
Year: 2022
Market: EU
Model ID: MTXI18HP24X
Manufacturer: Royal Clima
Model: RCI-TMN09HN
Year: 2022
Market: RU
Manufacturer: Carrier
Model: 42HVA1801E / 53HVA1801E
Market: Argentina, Latin America
Model: 42HVA0901E / 53HVA0901E
Model: 42HVA1201E / 53HVA1201E
Manufacturer: Bluestar
Model: ‎IC309RBTU
Market: Bangalore, India
Did you get this fixed im having the same problem
Edit: sorry this was a reply to the mrcool diy that
It was just showing unknown and the swaping of rx and tx
List updated :slight_smile:
Brand: Lennox
Model: MWMC009S4-1P / MWMC012S4-1P
Year: 2023 (installed, but model is possibly older, current generation seems to be -3P)
Market: US
Note: power and humidity show 0, other features work:
Manufacturer: KoolKing
Model: Monosplit Serie KK (12000btu)
Year: 2021
Market: Italy - EU
Model ID: CF-KK12A
Link
Notes: This KoolKing model is the same as the MrCool 3rd Gen mini split that is sold in the US (with the obvious C → F change), and it has exaclty the same module as henkvdt’s here
I used the DIY ESPhome dongle with @aceindy yaml file and it works good. Except that it shows as 0 for both Power and Humidity, even if it sees it as available characteristics.
