I am rather new to Home Assistant. Until now I got everthing running, but the “mini-graph-card” just show me the middle-finger. I read, changed, saved, rebooted, again and again and …
Hello Didier,
thanks for answering me. In my question, I showed all the variantions I tried.
Your proposition was part of it. I changed the files according your Message and booted again.
No success.
You wrote “(if installed using Hacs):”
I opened the HACS Menu, which includes in Frontend the mini-graph-card, but nor in Integration or Frontend Lovelace.
I expect, that I installed Lovelace the way you described in an answer in:
Most of the time I work on HA when my wife is sleeping, so my brain is maybe near this state too.
What now?
Thanks, Peter
@browetd Is the resources: part in configuration.yaml really necessary now that home assistant auto-detects and lists the installed (via HACKS) resources in Configuration > Dashboards > Resources
I am a beginner and I am confused. I am asking about the the following chunk of yaml:
@Homa Can you share a working configuration for mini-graph-card that you have used. I too am having trouble with a custom configuration for mini-graph-card.
I am trying to modify and use the following chunk from its github repository:
Yes i restarted HA. several times.
Do you have a specific log file for me to look at?
The main log file isn’t telling much. There is also not much done. I place the resource lines in configuration.yaml, do a check, to see the message from HA. At this point i block out the yaml lines, because en restart is not possible.
The log file tells nothing about the mini-graph-card.
I missed something. I didn’t put “lovelace” in the yaml file. Now HA accepts the configuration.
Still it looks double to me. Because in Configuration > Dashboards > Recourses there is also a /hacsfiles/mini-graph-card/mini-graph-card-bundle.js line.
But still, even after a restart, the graph card is not working:
And with my Mini Graph Card working, i thought, why not block out the lines in configuration.yaml. So i did. Restarted HA. Edited a dashboard, still could create a new Mini Graph Card. Restarted it again. Cards are still working.
I really think the automatic add in: Configuration > Dashboards > Recourses is doing it’s job.
Hello.
I have a graph for rain status (yes or no) and wind (number of beaufort), but I would like to add another sensor that says if it is cloudy, raining, sunny, etc.
The question is, can I add another sensor without showing its graph? The graph of 2 other sensors I would like to see them.
