Mirabella Genio Smart Home
I have created Mirabella Genio Door & Window Sensor I002575 HKWL-DWS02W topic to track the progress of this integration. @jivesinger @a_lunatic @JohanPotgieter
If you could post what you know, that would be great.
Wondering if someone could help me here, this is my first time flashing Tasmoto
I used the tuya-convert method listed here
http://www.thesmarthomehookup.com/tuya-convert-walk-through-february-2019/
using a Rasperry Pi 3 B+
All went well and it flashed quickly and easily.
I then used the ESPhome addon for home assistant to generate the firmware file using the code from
which also succeeded. The device flashed successfully and i can see it is connected to my wifi and can see the ip address that it has. The only thing is i cant access the webserver using it’s ip address to finish configuring the mqtt. Have tried multiple browsers and rebooting it once
By default, esphome doesn’t have a webserver.
You can enable it by including
webserver:
in your devices esphome config.
It’s not used for setup though, thats all through the yaml file.
The webserver is more for checking the status of inputs and outputs.
As for your MQTT problem, personally I’d just add
api:
to your config and let esphome do its auto discovery magic.
If your dead keen on MQTT though, post your config and we’ll see what up :+1:
EDIT:
Actually, if you used that config you linked to, api is already enabled so the light strip should already be showing in Home Assistant ?
I may even be asking the wrong questions as i’m stumbling my way along with this
How does HA automatically detect the new item?
I have it flashed, i can tell it’s connected to my wifi, but i can’t see where to go next
HA should detect it through mdns (avahi, bonjour). Check your HA notifications, it should say it found a device. Or look at the integrations list to see any new discovered devices.
OMG! So easy!
Thank you
Hi guys,
Picked up one of these today for an outside light.
Flashed with tuya_convert put tasmota on it fine then upgraded to Esphome after that.
This is the Esphome YAML that I needed to use. small change from the standard monochromatic option.
Brightness works as expected in home assistant.
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: 'WIFI'
  password: 'WIFIPASS'
logger:
api:
ota:
light:
  - platform: monochromatic
    name: "Mirabella Genio Smart Bulb"
    output: output_component1
output:
  - platform: esp8266_pwm
    pin: GPIO5
Note the change from GPI0 pin 13 to GPIO pin 05.
efleming,
Did you ever get this sorted?
I have the same issue with the RGB lights, the colour control isn’t working as expected.
Hi, I have this Mirrabella Genio globe that is Warm White, Colour changing and dimmable. I have flashed it with Tasmota but Im buggered if I can get it to work using all the published GPIO pinouts. If I use the RGB template on Blakadders site, it initially turns on warm white but goes off if i touch any of the sliders (in Tasmota page) and wont come back on again. I’ve tried this on 2 separate globes and the same happens, so, now I have 2 globes that wont work.
Anyone have a template for this globe by any chance? I’ve tried making a template but cant figure it out. The part number is 1002608 WIFI LED GLS
thanks
I dissembled one of mine to try and get it to work, but I couldn’t figure it out. It has a sm2135e controller inside. A small search says you could try these settings:
{ā€œNAMEā€:ā€œLSC RGBCW LEDā€,ā€œGPIOā€:[0,0,0,0,0,0,0,0,181,0,180,0,0],ā€œFLAGā€:0,ā€œBASEā€:18} source
Thanks Freyta, unfortunately it doesn’t work. I put the bulb in a fitting and powered it on and now it acts as a normal light globe for one cycle then nothing, on and off but no colour control and now nothing.
Has anyone had experience with these and ESPHome
I see the light switch version is working
It has a Tasmota template so it’ll be a breeze to get it working with ESPhome.
Not quite there yet , but have got a Woolies genio I002608 bulb to mostly work with this template:
{ā€œNAMEā€:ā€œMI-BW906-999Wā€,ā€œGPIOā€:[0,0,0,0,37,38,0,0,181,142,180,0,0],ā€œFLAGā€:0,ā€œBASEā€:18}
is a modification of existing Merkury bulb, which used SM16716 driver. Have modified the clock and data pins to reflect SM2135.
The colour bar seems out of sync (backwards?) but is my most stable configuration so far.
(No real knowledge of the LED driver (SM2135), any help would be appreciated)
addit: Console command: setoption37 30 seems to align the colours
addit2: setoption37 31 is best so far
addit3: The PWM commands don’t appear to be needed. This template seems to work just as well
{ā€œNAMEā€:ā€œMI-BW906-999Wā€,ā€œGPIOā€:[0,0,0,0,0,0,0,0,181,0,180,0,0],ā€œFLAGā€:0,ā€œBASEā€:18}
Thats great, at least it will go ā€œonā€. Im at work at a mine at the moment and fly home Wednesday so I will try it then.
Has anyone been able to come up with a way of sending multiple codes in the one procedure to the Mirabella IR bridge? I am trying to send 2 codes, one to select the channel and the other to send the ok to execute the channel change. Thanks.
I apologise if this has already been covered in the thread but I couldn’t find any solutions above. I bought a double pack of Mirabella Genio Smart Switches from Costco Perth the other night and cant get them to broadcast an SSID so that I can access the config. I’ve been flashing them via serial (following the the wiki instructions) and according to the app I’m using it’s successful but they seem to be bricked.
I’ve had no issues doing this with sonoff switches before and assumed it wouldn’t be much different.
Any ideas on what I’m doing wrong?
Hi
Has anyone got a working template for the Genio Candle bulb???
https://mirabellagenio.net.au/ses-led-candle
EDIT:
Tried this one and it appears to work OK
Any issues with using that/
Also, anyone use the CCT downlights and know what commands in tasmota to set for the brightness range?
I find that the brightness only works from about 3/4 way up the slider (being the most dim) to then full
not sure how to set the range properly, using this template
Hi Guys, I’ve successfully obtained and flashed a Mirabella genio plug power-board with ESP-Home. It’s one of these.
I’ve used this template
https://esphome-configs.io/devices/mirabella-genio-i002340_plug/
Config as follows:
substitutions:
# Change the disp_name to something you want
  dnum: "1"
  dname: genio_pb4p1u
  sname: genpb
  full_name: ${dname}_${location}_${dnum}
  short_name: ${sname}_${location}_${dnum}
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: 192.168.1.38
    gateway: 192.168.1.1
    subnet: 255.255.255.0
captive_portal:
# Enable Home Assistant API
api:
  password: !secret esp_home_password
ota:
web_server:
  port: 80
# Enable logging
logger:
  #level: VERBOSE
globals:
  - id: set_on
    type: "bool"
    restore_value: no
    initial_value: "1"
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO13
      inverted: True
    on_multi_click:
    - timing:
        - ON for at most 0.5s
        - OFF for at least 0.5s
      then:
        lambda: |-
          if ( id(set_on) ) {
            if (! id(relay1).state  ) {
              id(relay1).turn_on();
            } else if ( ! id(relay2).state ) {
              id(relay2).turn_on();
            } else if ( ! id(relay3).state ) {
              id(relay3).turn_on();
            } else if ( ! id(relay4).state ) {
              id(relay4).turn_on();
              id(set_on) = 0;
            } else {
              id(relay1).turn_off();
              id(relay2).turn_off();
              id(relay3).turn_off();
              id(relay4).turn_off();
          } else {
            if ( id(relay1).state  ) {
            } else if (  id(relay2).state ) {
            } else if (  id(relay3).state ) {
            } else if (  id(relay4).state ) {
              id(set_on) = 1;
            } else {
    - timing:
        - OFF for at most 0.5s
        - OFF for at least 0.2s
      then:
      - switch.toggle: usb
    - timing:
        - ON for at least 0.5s
      then:
        lambda: |-
          if (id(relay1).state ||
          id(relay2).state ||
          id(relay3).state ||
          } else {
switch:
  - platform: gpio
    pin: GPIO4
  - platform: gpio
    pin: GPIO15
  - platform: gpio
    pin: GPIO12
  - platform: gpio
    pin: GPIO14
  - platform: gpio
    pin: GPIO5
status_led:
  pin:
    number: GPIO0
    inverted: yes
It shows as being on-line within ESP home in Home Assistant, but unfortunately it doesn’t control the switches. They just remain on.
The logs are indicating the switches being turned on and off, but they don’t actually switch on and off.
Any pointers on how to trouble shoot this?
Thanks in advance.
