Hi all! First time poster here, thank you for all the information from you all so far!
I have just flashed one of the genio motion sensors OTA with tasmota. Very easy process, however, I too had to use a power source rather than batteries or else it would fail. I then used the template, ran the console commands plus a few random ones on various forums and then added a binary sensor to my config.yaml. The sensor itself works on batteries but none of the other entities that sensor creates does.
So far I have the sensor showing up as a normal motion icon within HA, motion is being reported (on batteries). I want to use the sensor with automations but it doesnt show up as a binary motion sensor when selecting āUse motion to turn on lightsā etc. I have tried a manual state but donāt know what to input in the to/from etc. Does anyone know how to get the sensor to show up with the hue sensors when selecting an automation etc??
I purchased the warm white I002604 and canāt get it to flash tasmota via Tuya convert. When putting it under pairing mode (blinking fast) and setting my phone as a donor, I can see it stops blinking once I hit enter on the tuya convert but then it doesnāt go any further.
GāDay all, new to HA+ESPHome.
Iāve picked up a Genio RGBW 1002339 and successfully flashed ESPHome using the cookbook.
It appears in HA but the bulb is unresponsive to any colour changes. Twice, at random, Iāve manged to get it full bright white, no idea how or why.
After a power cycle the bulb still does not turn on despite the setting āRESTORE_DEFAULT_ONā
EDIT: Iāve just tried Tasmota firmware and this template https://templates.blakadder.com/mirabella_genio_1002338.html
The only time it turns on - warm white light - is with the sliders in this position. Any other setting has zero output. Canāt change brightness either.
You beauty!
Genio RGBW B22 1002339 (plastic clam-shell packaging)
This seems to get it going:
{āNAMEā:āMI-BW906-999Wā,āGPIOā:[0,0,0,0,0,0,0,0,181,0,180,0,0],āFLAGā:0,āBASEā:18}
setoption37 31
EDIT:Yet somehow I missed the template page which would have saved me all of the headacheā¦
Iām new here (I set up my HA instance only a week or so ago) but I did manage to get the new Mirabella RGBW globes with the sm2135 chip working with ESPhome. I could have chosen a slightly easier device for my first attempt at flashing ESPhome, but anyway, got there eventually.
I used the sm2135 custom component linked above but replaced the sm2135.cpp file with this one:
Itās not perfect but the altered driver fixes some weird behaviour with the ww/cw settings. Itās definitely useable and I think the main issues are ww/cw balance (seems to be more like a switch now) and the saturation slider in lovelace didnāt work (but you can still desaturate colours using the colour wheel).
I am now stuck, with a Genio Mirabella light section but I canāt change colour, just brightness?
Itās like the colour spectrum adjustment control UI element is missing / broken?
Guys thanks for indulging me - finally. So sorry - I didnāt know that option was hidden down there!
Iām up and running!
Sorry, thank you!
Can I ask, if youāre free.
Iād like to do a fade in from particularly dark to bright over the course of at least 15 minutes.
Iāve configured it to turn on in the morning at 12% brightness, via automation (11% or less, it wonāt turn on?!!?!?)
Then 2 minutes later, it goes up 5% and so on - a lot of automations.
Is this the best method?
and has anyone figured out how to change colour in an automation?
Iām not too smart.
Is there a way to create an automation, using the user interface (not command line / yaml hand editing) which can not only define brightness AND colour shade?
I get prompted actions for the globe.
turn_off
turn_on
toggle
brightness_increase
brightness_decrease
flash
But not colour range or RGB definition or anything - can that be done in UI?
Donāt use āDeviceā as the Action Type. Use āCall Serviceā instead and then add in the data
If you go to Developer Tools and then Service, you can test it out. Make the Service ālight.turn_onā and then click Fill Example Data (make sure the correct light is selected) and play with that. Then you can copy and paste the data into your automation.
Hi Riccardo. No, I never tried. I didnāt want to lose the effects, so happy enough to wait until someone else tries it
The site youāre referring to is for Arlec lights, it seems.
Maybe try one of the Mirabella templates? At a guess, something like: https://templates.blakadder.com/mirabella_genio_I002800.html perhaps.
@safepay Scheme 4 was the only thing of any value. Not sure what commands you are trying?
I didnāt end up doing much with these other than setting up a schedule and leaving them on flashy flash. The sliders had to be at like 30% and 70% or something.
