selvalt7
(Stanisław Krzeptowski)
October 24, 2024, 1:03pm
1
Modern Circular Gauge
Modern circular gauge card for Home Assistant
Modern take on Home Assistant gauge. This card has mostly the same config as the gauge included in HASS with few additions like template support and badge.
Features
Card and badge gauge
Secondary info under the state with two size options
Sections support
Needle
Template support for min, max, entity, icon and secondary (YAML only)
Color segments with gradient
Dual gauge
Dual value representing as a dot on the same gauge
Visual editor
somansch
(Andreas)
November 29, 2024, 12:23pm
3
@selvalt7 , great work! Many thanks for this card.
Is it bug or feature? I get a view with a decimal. Is there an option to change this behaviour?
The default view inside the entity is without a decimal:
selvalt7
November 29, 2024, 12:30pm
4
Thanks,
Yeah, it’s a bug which is fixed in the dev branch, so hopefully soon it will be available in the main branch.
It would be great if you could provide few yaml examples!
selvalt7
December 10, 2024, 8:59am
6
I’ve added few examples in the repository readme file on the dev branch.
Jm71570
(monot)
January 13, 2025, 10:55am
7
Bonjour
comment peut on rendre plus opaque la jauge svp?
cordialement
selvalt7
January 13, 2025, 8:50pm
8
Could you be more specific which part of gauge?
Rooverz
(Rooverz)
February 9, 2025, 8:58am
9
Is it possible to change the thickness of the line and scale the text? It’s an layout of my pv panels but the graphic layout is a bit too small.
Mar1us
(Mar1us)
April 29, 2025, 8:36am
10
is there a way to use theme varibales for the color segements like var(–red-color) etc.?
selvalt7
April 29, 2025, 8:59am
11
Yes, here’s a code and image how it looks
segments:
color: var(--orange-color)
color: var(--green-color)
color: var(--red-color)
Mar1us
(Mar1us)
April 29, 2025, 11:24am
12
tried this but it goes black:
type: custom:modern-circular-gauge-badge
entity: sensor.temperatur_aussen
min: -20
max: 50
show_name: true
show_state: true
show_icon: true
smooth_segments: true
segments:
- color: var(--red-color)
- color: var(--green-color)
- color: var(--blue-color)
Mar1us
(Mar1us)
April 29, 2025, 11:29am
13
ok had to remove smooth_segments: true
selvalt7
April 29, 2025, 2:29pm
14
Because It seems that I forgot to implement css variables handling inside color interpolation function, so variables does not work with smooth_segments for now.
elRadix
(elRadix)
April 29, 2025, 6:09pm
15
Nice card, I’m using the following config
entity: sensor.alfen_monthly_energy
height: 200
header_position: bottom
min: 0
max: 650
decimals: 0
unit: kWh
needle: false
show_icon: true
show_unit: true
show_header: true
show_state: true
adaptive_state_color: true
adaptive_icon_color: true
icon: |-
{% if is_state('sensor.alfen_active_power_total_socket_1', '0') %}
mdi:car-off
{% else %}
mdi:car-electric
{% endif %}
gauge_foreground_style:
color: adaptive
width: 6
gauge_background_style:
width: 8
color: rgba(200,200,200,0.3)
segments:
color:
- 18
- 147
- 94
color:
- 244
- 228
- 0
color:
- 255
- 117
- 20
color:
- 222
- 49
- 99
secondary:
entity: sensor.alfen_yearly_energy
unit: kWh
min: 0
max: 3500
show_gauge: inner
state_size: small
needle: false
segments:
color:
- 18
- 147
- 94
color:
- 244
- 228
- 0
color:
- 255
- 117
- 20
color:
- 222
- 49
- 99
animation_speed: 500
style: |
ha-card {
margin: 5px;
border-radius: 12px;
background: var(--card-background-color);
This is nice @elRadix !! Just built a couple of gauges yesterday and I really love how compact they can be and still show a ton of data.
Used my Sense energy monitor data and some sensor templates to give me kWh Cost and personal CO2 Emission (Carbon Footprint):
Outdoor UVI and Air Quality using WAQI and OpenUV integrations:
Mar1us
(Mar1us)
May 13, 2025, 12:18pm
17
can you share the code for the UV gauge?
Greg.o
(Greg)
July 9, 2025, 9:23pm
18
Tjx for your work !
I tried to implement a card for my tmp and humidity sensors. It seems to work well, excepted for a detail:
Here is my code (just part of it: it’s in a dashboard file).
cards:
- type: custom:modern-circular-gauge
entity: sensor.temp_hum_1_temperature
label: température
unit: °C
min: 10
max: 30
icon: mdi:thermometer
needle: true
segments:
color:
- 255
- 245
- 200
color:
- 255
- 200
- 100
color:
- 220
- 70
- 20
secondary:
entity: sensor.temp_hum_1_humidity
label: humidité
unit: '%'
show_gauge: inner
segements:
color:
- 153
- 204
- 255
layout: vertical
I tried to make a difference between the temperature and the humidity : blue for humidity and 3 segments of “red” for temperature. But, here is the result :
Can you explain me why the colour for the secondary sensor is not (153; 204; 255) ?
By the way, thx for the job !
selvalt7
July 9, 2025, 9:38pm
19
You’ve mistyped segments in the secondary.
Instead of segments you have “segements”.
Really like the appearance of this card. But I am struggeling with the combined gauge feature which was integrated in the latest release. Cann somebody give me a hint?
gauge_type: full
entity: sensor.waschmaschine_verbrauch_mit_aktueller_autarkie_jahrlich
secondary:
entity: sensor.jahrlicher_stromverbrauch_waschmaschine_autark
show_gauge: inner
max: 300
start_from_zero: true
adaptive_state_color: false
show_icon: false
icon: mdi:washing-machine
unit: kWh
show_state: true
show_unit: true
combine_gauges: true
tertiary: {}
