Moes BRT-100 TRV does not respond to temperature change request
Hi, I have two types of TRVs in my home. 1 tado, and 1 recent moes TRV which is the newer model I got from aliexpress, and is model number BRT-100:-
The TRV paired in ZHA no problem, and reports temperature just fine, but it does it in a different way to Tado:-
Using the lovelace thermostat card I can change the target temperature by dragging the marker around the circle, but I cannot get it to change via automation.
The following script changes first changes to tado trv (which works), then goes onto the moes TRV and it just does nothing, no errors in the logs:-
alias: Moes and Tado 5 test
description: ""
  - type: not_plugged_in
    platform: device
    device_id: a47f7db07a4a9c7633ac807ab9d13457
    entity_id: binary_sensor.ro_p30_pro_is_charging
    domain: binary_sensor
condition: []
  - service: climate.set_temperature
      temperature: 5
      entity_id: climate.main_house
      temperature: 5
      entity_id: climate.moes_trv_green_room_becathermostat
  - service: climate.set_preset_mode
      preset_mode: away
  - device_id: a47f7db07a4a9c7633ac807ab9d13457
    domain: mobile_app
    type: notify
    message: hvac
    title: hvac test
mode: single
I also canā€™t set any other option like ā€˜operationā€™ or ā€˜presetā€™.
The TRV is definitely in range of the coordinator, with over 200 LQI and RSSOI of -41.
Help??!
I think this might be related to this:-
I believe the ZHA guys are looking at this currently.
Not sure whats happened, but the TRV now seems to be responding to automations as I would expect. I did upgrade to Home Assistant 2022.11.4 this morning, I wonder if that has fixed it.
However, the comments about the thermostat going to 300 degrees instead of 30 are still there :wink:
Hi there, It seems that I stumbled over the solution in another thread.
If you have a beca based thermostat in your moes TRV, then this file gave me full control over the device:-
https://github.com/zigpy/zha-device-handlers/files/9844752/ts0601_trv_beca.py.zip
Its mentioned in this thread:-
You can set the correct values to stop the thermostat going to 300 degrees, and a variety of other things, like it also now correctly reports the battery level and a host of other things.
The only thing I donā€™t think works correctly is the slider for ā€˜number valve stateā€™ (although it does get updated correctly when the valve opens and closes).
Note you will need to set values for min and max here so your thermostat doesnā€™t go to 300, and also, there are three unnamed switches which Iā€™m not sure what they do.
I just turned on open window detection on the trv itself, and the bottom switch turned on in Home assistant, so I assume the bottom one is for that:-
The other two switches, according to the leaflet that came with the TRV are likely to be:-
Energy saving mode
Detection Valve head opening
but Iā€™m not sure which is which in the list.
How can I use this file? What should I do with this? Sorry, Iā€™m quite a newbee about this.
Take a look at this thread which explains how to use a local zha quirk:-
Managed to install the quirk but when i restarted the ZHA got an error and did not wanted to start. This resulted in that all my Zigbee devices could not be reached. the log showed an error in the setup.
Which steps to take here ?
Logger: homeassistant.config_entries
Source: zha_quirks/ts0601_trv_beca.py:601
First occurred: 21:13:21 (1 occurrences)
Last logged: 21:13:21
Error setting up entry socket://192.168.1.148:8888 for zha
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 382, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 100, in async_setup_entry
    setup_quirks(config)
  File "/usr/local/lib/python3.10/site-packages/zhaquirks/__init__.py", line 409, in setup
    importer.find_module(modname).load_module(modname)
  File "<frozen importlib._bootstrap_external>", line 548, in _check_name_wrapper
  File "<frozen importlib._bootstrap_external>", line 1063, in load_module
  File "<frozen importlib._bootstrap_external>", line 888, in load_module
  File "<frozen importlib._bootstrap>", line 290, in _load_module_shim
  File "<frozen importlib._bootstrap>", line 719, in _load
  File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 883, in exec_module
  File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
  File "/config/zha_quirks/ts0601_trv_beca.py", line 558, in <module>
    class BecaWindowDetection(LocalDataCluster, OnOff):
  File "/config/zha_quirks/ts0601_trv_beca.py", line 601, in BecaWindowDetection
    command_id: Union[foundation.Command, int, t.uint8_t],
AttributeError: module 'zigpy.zcl.foundation' has no attribute 'Command'
Try this quirk, its the one I used. Just copy and paste the code to a file.
Iā€™ve had to split it over 2 posts to get within the character limit.
"""Beca TRV devices support."""
import logging
from typing import Optional, Union
import zigpy.types as t
from zhaquirks import Bus, LocalDataCluster
from zhaquirks.const import (
    DEVICE_TYPE,
    ENDPOINTS,
    INPUT_CLUSTERS,
    MODELS_INFO,
    OUTPUT_CLUSTERS,
    PROFILE_ID,
from zhaquirks.tuya import (
    TuyaManufClusterAttributes,
    TuyaPowerConfigurationCluster,
    TuyaThermostat,
    TuyaThermostatCluster,
    TuyaUserInterfaceCluster,
from zigpy.profiles import zha
from zigpy.zcl import foundation
from zigpy.zcl.clusters.general import (
    AnalogOutput,
    Basic,
    BinaryInput,
    Groups,
    OnOff,
    Ota,
    Scenes,
    Time,
from zigpy.zcl.clusters.hvac import Thermostat
_LOGGER = logging.getLogger(__name__)
BECA_TARGET_TEMP_ATTR = 0x0202  # target room temp (degree)
BECA_TEMPERATURE_ATTR = 0x0203  # current room temp (decidegree)
BECA_MODE_ATTR = 0x0401  # [0] schedule [1] manual [2] temporary manual [3] away
BECA_CHILD_LOCK_ATTR = 0x010D  # [0] unlocked [1] locked
BECA_TEMP_CALIBRATION_ATTR = 0x0269  # temperature calibration (degree)
BECA_MIN_TEMPERATURE_ATTR = 0x026D  # minimum limit of temperature setting (degree)
BECA_MAX_TEMPERATURE_ATTR = 0x026C  # maximum limit of temperature setting (degree)
BECA_WINDOW_DETECT_ATTR = 0x0409  # [1] alarm not active [0] alarm active
BECA_WINDOW_DETECT_A2_ATTR = 0x0108  # [0] function disactive [1] function active
BECA_BOOST_TIME_ATTR = 0x0267  # BOOST mode operating time in (sec)
BECA_BOOST_ATTR = 0x0104  # [0] off [1] on
BECA_BOOST_COUNTDOWN_ATTR = 0x0205  # (seconds)
BECA_ECO_TEMP_ATTR = 0x026B  # eco mode temperature (degree)
BECA_ECO_MODE_ATTR = 0x016A  # [0] off [1] on
BECA_VALVE_STATE_ATTR = 0x0268  # opening percentage
BECA_VALVE_STATE_ONOFF_ATTR = 0x0407  # [0] closed [1] opened
BECA_BATTERY_ATTR = 0x020E  # battery percentage remaining 0-100%
BECA_SCHEDULE = 0x0065  # schedule
# [6, 0, 40, 11, 30, 42, 13, 30, 44, 17, 30, 46, 6, 0, 48, 12, 0, 46, 14, 30, 44, 17, 30, 42, 6, 0, 38, 12, 30, 40, 14, 30, 42, 18, 30, 40] for :
# Monday to friday : 06:00 20Ā°C / 11:30 21Ā°C / 13:30 22Ā°C / 17:30 23Ā°C
# Saturday : 06:00 24Ā°C / 12:00 23Ā°C / 14:30 22Ā°C / 17:30 21Ā°C
# Sunday : 06:00 19Ā°C / 12:30 20Ā°C / 14:30 21Ā°C / 18:30 20Ā°C )
BecaManufClusterSelf = {}
class data288(t.FixedList, item_type=t.uint8_t, length=36):
    """General data, Discrete, 288 bit."""
    pass
class BecaManufCluster(TuyaManufClusterAttributes):
    """Manufacturer Specific Cluster of thermostatic valves."""
    def __init__(self, *args, **kwargs):
        """Init."""
        super().__init__(*args, **kwargs)
        global BecaManufClusterSelf
        BecaManufClusterSelf[self.endpoint.device.ieee] = self
    set_time_offset = 1970
    attributes = TuyaManufClusterAttributes.attributes.copy()
    attributes.update(
            BECA_TEMPERATURE_ATTR: ("temperature", t.uint32_t),
            BECA_TARGET_TEMP_ATTR: ("target_temperature", t.uint32_t),
            BECA_MODE_ATTR: ("mode", t.uint8_t),
            BECA_CHILD_LOCK_ATTR: ("child_lock", t.uint8_t),
            BECA_TEMP_CALIBRATION_ATTR: ("temperature_calibration", t.int32s),
            BECA_MIN_TEMPERATURE_ATTR: ("min_temperature", t.uint32_t),
            BECA_MAX_TEMPERATURE_ATTR: ("max_temperature", t.uint32_t),
            BECA_WINDOW_DETECT_ATTR: ("window_detection", t.uint8_t),
            BECA_WINDOW_DETECT_A2_ATTR: ("window_detection_A2_function", t.uint8_t),
            BECA_BOOST_TIME_ATTR: ("boost_duration_seconds", t.uint32_t),
            BECA_BOOST_ATTR: ("boost_enabled", t.uint8_t),
            BECA_BOOST_COUNTDOWN_ATTR: ("boost_duration_seconds", t.uint32_t),
            BECA_ECO_TEMP_ATTR: ("eco_mode_temperature", t.uint32_t),
            BECA_ECO_MODE_ATTR: ("eco_mode_enabled", t.uint8_t),
            BECA_VALVE_STATE_ATTR: ("valve_state", t.uint32_t),
            BECA_VALVE_STATE_ONOFF_ATTR: ("valve_state_onoff", t.uint8_t),
            BECA_BATTERY_ATTR: ("battery", t.uint32_t),
            BECA_SCHEDULE: ("schedule", data288),
    DIRECT_MAPPED_ATTRS = {
        BECA_TEMPERATURE_ATTR: ("local_temperature", lambda value: value * 10),
        BECA_TARGET_TEMP_ATTR: ("occupied_heating_setpoint", lambda value: value * 100),
        BECA_TEMP_CALIBRATION_ATTR: ("local_temperature_calibration", None),
            "min_heat_setpoint_limit",
            lambda value: value * 100,
            "max_heat_setpoint_limit",
    def _update_attribute(self, attrid, value):
        """Override default _update_attribute."""
        super()._update_attribute(attrid, value)
        if attrid in self.DIRECT_MAPPED_ATTRS:
            self.endpoint.device.thermostat_bus.listener_event(
                "temperature_change",
                self.DIRECT_MAPPED_ATTRS[attrid][0],
                value
                if self.DIRECT_MAPPED_ATTRS[attrid][1] is None
                else self.DIRECT_MAPPED_ATTRS[attrid][1](value),
        if attrid == BECA_WINDOW_DETECT_ATTR:
            self.endpoint.device.BecaWindowDetection_bus.listener_event(
                "set_value", value
        if attrid == BECA_WINDOW_DETECT_A2_ATTR:
            self.endpoint.device.BecaWindowDetection_A2_bus.listener_event(
                "switch_change", value
        elif attrid == BECA_CHILD_LOCK_ATTR:
            mode = 1 if value else 0
            self.endpoint.device.ui_bus.listener_event("child_lock_change", mode)
            self.endpoint.device.BecaChildLock_bus.listener_event("switch_change", mode)
        elif attrid in (BECA_MODE_ATTR, BECA_BOOST_ATTR, BECA_ECO_MODE_ATTR):
            if attrid == BECA_BOOST_ATTR and value == 1:
                self.endpoint.device.thermostat_bus.listener_event("mode_change", 5)
            elif attrid == BECA_ECO_MODE_ATTR and value == 1:
                self.endpoint.device.thermostat_bus.listener_event("mode_change", 4)
            elif attrid == BECA_MODE_ATTR:
                self.endpoint.device.thermostat_bus.listener_event("mode_change", value)
        elif attrid == BECA_VALVE_STATE_ATTR:
            self.endpoint.device.BecaValveState_bus.listener_event("set_value", value)
        elif attrid == BECA_TEMP_CALIBRATION_ATTR:
            self.endpoint.device.BecaTempCalibration_bus.listener_event(
                "set_value", value
        elif attrid == BECA_BOOST_TIME_ATTR:
            self.endpoint.device.BecaBoostTime_bus.listener_event("set_value", value)
        elif attrid == BECA_BOOST_COUNTDOWN_ATTR:
            self.endpoint.device.BecaBoostCountdown_bus.listener_event(
                "set_value", value
        elif attrid == BECA_ECO_TEMP_ATTR:
            self.endpoint.device.BecaEcoTemp_bus.listener_event("set_value", value)
        elif attrid == BECA_BATTERY_ATTR:
            self.endpoint.device.battery_bus.listener_event("battery_change", value)
        elif attrid == BECA_MIN_TEMPERATURE_ATTR:
            self.endpoint.device.BecaMinTemp_bus.listener_event("set_value", value)
        elif attrid == BECA_MAX_TEMPERATURE_ATTR:
            self.endpoint.device.BecaMaxTemp_bus.listener_event("set_value", value)
        elif attrid == BECA_SCHEDULE:
            self.endpoint.device.thermostat_bus.listener_event("schedule_change", value)
        # elif attrid in (BECA_TEMPERATURE_ATTR, BECA_TARGET_TEMP_ATTR):
        #     self.endpoint.device.thermostat_bus.listener_event(
        #         "hass_climate_state_change", attrid, value
        elif attrid == BECA_VALVE_STATE_ONOFF_ATTR:
                "state_change", not value
class BecaThermostat(TuyaThermostatCluster):
    """Thermostat cluster for thermostatic valves."""
    class Preset(t.enum8):
        """Working modes of the thermostat."""
        Away = 0x00
        Schedule = 0x01
        Manual = 0x02
        Comfort = 0x03
        Eco = 0x04
        Boost = 0x05
        Complex = 0x06
        TempManual = 0x07
    class WorkDays(t.enum8):
        """Workday configuration for scheduler operation mode."""
        MonToFri = 0x00
        MonToSat = 0x01
        MonToSun = 0x02
    class ForceValveState(t.enum8):
        """Force valve state option."""
        Normal = 0x00
        Open = 0x01
        Close = 0x02
    _CONSTANT_ATTRIBUTES = {
        0x001B: Thermostat.ControlSequenceOfOperation.Heating_Only,
        0x001C: Thermostat.SystemMode.Heat,
    attributes = TuyaThermostatCluster.attributes.copy()
    attributes.update(
            0x4002: ("operation_preset", Preset),
            0x4110: ("schedule_workday_1_hour", t.uint8_t),
            0x4111: ("schedule_workday_1_minute", t.uint8_t),
            0x4112: ("schedule_workday_1_temperature", t.uint8_t),
            0x4113: ("schedule_workday_2_hour", t.uint8_t),
            0x4114: ("schedule_workday_2_minute", t.uint8_t),
            0x4115: ("schedule_workday_2_temperature", t.uint8_t),
            0x4116: ("schedule_workday_3_hour", t.uint8_t),
            0x4117: ("schedule_workday_3_minute", t.uint8_t),
            0x4118: ("schedule_workday_3_temperature", t.uint8_t),
            0x4119: ("schedule_workday_4_hour", t.uint8_t),
            0x4120: ("schedule_workday_4_minute", t.uint8_t),
            0x4121: ("schedule_workday_4_temperature", t.uint8_t),
            0x4122: ("schedule_saturday_1_hour", t.uint8_t),
            0x4123: ("schedule_saturday_1_minute", t.uint8_t),
            0x4124: ("schedule_saturday_1_temperature", t.uint8_t),
            0x4125: ("schedule_saturday_2_hour", t.uint8_t),
            0x4126: ("schedule_saturday_2_minute", t.uint8_t),
            0x4127: ("schedule_saturday_2_temperature", t.uint8_t),
            0x4128: ("schedule_saturday_3_hour", t.uint8_t),
            0x4129: ("schedule_saturday_3_minute", t.uint8_t),
            0x4130: ("schedule_saturday_3_temperature", t.uint8_t),
            0x4131: ("schedule_saturday_4_hour", t.uint8_t),
            0x4132: ("schedule_saturday_4_minute", t.uint8_t),
            0x4133: ("schedule_saturday_4_temperature", t.uint8_t),
            0x4134: ("schedule_sunday_1_hour", t.uint8_t),
            0x4135: ("schedule_sunday_1_minute", t.uint8_t),
            0x4136: ("schedule_sunday_1_temperature", t.uint8_t),
            0x4137: ("schedule_sunday_2_hour", t.uint8_t),
            0x4138: ("schedule_sunday_2_minute", t.uint8_t),
            0x4139: ("schedule_sunday_2_temperature", t.uint8_t),
            0x4140: ("schedule_sunday_3_hour", t.uint8_t),
            0x4141: ("schedule_sunday_3_minute", t.uint8_t),
            0x4142: ("schedule_sunday_3_temperature", t.uint8_t),
            0x4143: ("schedule_sunday_4_hour", t.uint8_t),
            0x4144: ("schedule_sunday_4_minute", t.uint8_t),
            0x4145: ("schedule_sunday_4_temperature", t.uint8_t),
    DIRECT_MAPPING_ATTRS = {
        "min_heat_setpoint_limit": (
            BECA_MIN_TEMPERATURE_ATTR,
            lambda value: round(value / 100),
        "max_heat_setpoint_limit": (
            BECA_MAX_TEMPERATURE_ATTR,
        "local_temperature_calibration": (
            BECA_TEMP_CALIBRATION_ATTR,
            lambda value: value,
    SCHEDULE_ATTRS = {
        "schedule_sunday_4_temperature": 20,
        "schedule_sunday_4_minute": 30,
        "schedule_sunday_4_hour": 18,
        "schedule_sunday_3_temperature": 21,
        "schedule_sunday_3_minute": 30,
        "schedule_sunday_3_hour": 14,
        "schedule_sunday_2_temperature": 20,
        "schedule_sunday_2_minute": 30,
        "schedule_sunday_2_hour": 12,
        "schedule_sunday_1_temperature": 19,
        "schedule_sunday_1_minute": 0,
        "schedule_sunday_1_hour": 6,
        "schedule_saturday_4_temperature": 21,
        "schedule_saturday_4_minute": 30,
        "schedule_saturday_4_hour": 17,
        "schedule_saturday_3_temperature": 22,
        "schedule_saturday_3_minute": 30,
        "schedule_saturday_3_hour": 14,
        "schedule_saturday_2_temperature": 23,
        "schedule_saturday_2_minute": 00,
        "schedule_saturday_2_hour": 12,
        "schedule_saturday_1_temperature": 24,
        "schedule_saturday_1_minute": 0,
        "schedule_saturday_1_hour": 6,
        "schedule_workday_4_temperature": 23,
        "schedule_workday_4_minute": 30,
        "schedule_workday_4_hour": 17,
        "schedule_workday_3_temperature": 22,
        "schedule_workday_3_minute": 30,
        "schedule_workday_3_hour": 13,
        "schedule_workday_2_temperature": 21,
        "schedule_workday_2_minute": 30,
        "schedule_workday_2_hour": 11,
        "schedule_workday_1_temperature": 20,
        "schedule_workday_1_minute": 0,
        "schedule_workday_1_hour": 6,
    def map_attribute(self, attribute, value):
        """Map standardized attribute value to dict of manufacturer values."""
        if attribute in self.DIRECT_MAPPING_ATTRS:
            return {
                self.DIRECT_MAPPING_ATTRS[attribute][0]: value
                if self.DIRECT_MAPPING_ATTRS[attribute][1] is None
                else self.DIRECT_MAPPING_ATTRS[attribute][1](value)
        if attribute == "occupied_heating_setpoint":
            mode = self._attr_cache.get(self.attributes_by_name["operation_preset"].id)
            if mode == self.Preset.Schedule:
                return {BECA_MODE_ATTR: 2, BECA_TARGET_TEMP_ATTR: value / 100}
            else:
                return {BECA_TARGET_TEMP_ATTR: value / 100}
        if attribute == "operation_preset":
            if value == 0:
                return {BECA_MODE_ATTR: 3, BECA_BOOST_ATTR: 0, BECA_ECO_MODE_ATTR: 0}
            if value == 1:
                return {BECA_MODE_ATTR: 0, BECA_BOOST_ATTR: 0, BECA_ECO_MODE_ATTR: 0}
            if value == 2:
                return {BECA_MODE_ATTR: 1, BECA_BOOST_ATTR: 0, BECA_ECO_MODE_ATTR: 0}
            if value == 4:
                return {BECA_BOOST_ATTR: 0, BECA_ECO_MODE_ATTR: 1}
            if value == 5:
                return {BECA_BOOST_ATTR: 1, BECA_ECO_MODE_ATTR: 0}
            if value == 7:
                return {BECA_MODE_ATTR: 2, BECA_BOOST_ATTR: 0, BECA_ECO_MODE_ATTR: 0}
        if attribute in ("programing_oper_mode", "occupancy"):
            if attribute == "occupancy":
                occupancy = value
                oper_mode = self._attr_cache.get(
                    self.attributes_by_name["programing_oper_mode"].id,
                    self.ProgrammingOperationMode.Simple,
            else:
                occupancy = self._attr_cache.get(
                    self.attributes_by_name["occupancy"].id, self.Occupancy.Occupied
                oper_mode = value
            if occupancy == self.Occupancy.Unoccupied:
                return {BECA_MODE_ATTR: 3}
            if occupancy == self.Occupancy.Occupied:
                if oper_mode == self.ProgrammingOperationMode.Schedule_programming_mode:
                    return {BECA_MODE_ATTR: 0}
                if oper_mode == self.ProgrammingOperationMode.Simple:
                    return {BECA_MODE_ATTR: 1}
                self.error("Unsupported value for ProgrammingOperationMode")
            else:
                self.error("Unsupported value for Occupancy")
        if attribute in self.SCHEDULE_ATTRS:
            data = data288()
            for num, (attr, default) in enumerate(self.SCHEDULE_ATTRS.items()):
                if num % 3 == 0:
                    if attr == attribute:
                        val = round(value * 2)
                    else:
                        val = round(
                                self.attributes_by_name[attr].id, default
                            * 2
                else:
                        val = value
                    else:
                        val = self._attr_cache.get(
                data.append(val)
            return {BECA_SCHEDULE: data}
    def hass_climate_state_change(self, attrid, value):
        """Update of the HASS Climate gui state according to temp difference."""
        if attrid == BECA_TEMPERATURE_ATTR:
            temp_current = value * 10
            temp_set = self._attr_cache.get(
                self.attributes_by_name["occupied_heating_setpoint"].id
        else:
            temp_set = value * 100
            temp_current = self._attr_cache.get(
                self.attributes_by_name["local_temperature"].id
        state = 0 if (int(temp_current) >= int(temp_set)) else 1
        self.endpoint.device.thermostat_bus.listener_event("state_change", state)
    def mode_change(self, value):
        """System Mode change."""
        if value == 1:
            operation_preset = self.Preset.Manual
            prog_mode = self.ProgrammingOperationMode.Simple
            occupancy = self.Occupancy.Occupied
        elif value == 2:
            operation_preset = self.Preset.TempManual
        elif value == 3:
            operation_preset = self.Preset.Away
            occupancy = self.Occupancy.Unoccupied
        elif value == 4:
            operation_preset = self.Preset.Eco
            prog_mode = self.ProgrammingOperationMode.Economy_mode
        elif value == 5:
            operation_preset = self.Preset.Boost
        else:
            operation_preset = self.Preset.Schedule
            prog_mode = self.ProgrammingOperationMode.Schedule_programming_mode
        self._update_attribute(
            self.attributes_by_name["programing_oper_mode"].id, prog_mode
        self._update_attribute(self.attributes_by_name["occupancy"].id, occupancy)
            self.attributes_by_name["operation_preset"].id, operation_preset
    def schedule_change(self, value):
        """Scheduler attribute change."""
            self.attributes_by_name["schedule_workday_1_hour"].id, value[35]
            self.attributes_by_name["schedule_workday_1_minute"].id, value[34]
            self.attributes_by_name["schedule_workday_1_temperature"].id, value[33] / 2
            self.attributes_by_name["schedule_workday_2_hour"].id, value[32]
            self.attributes_by_name["schedule_workday_2_minute"].id, value[31]
            self.attributes_by_name["schedule_workday_2_temperature"].id, value[30] / 2
            self.attributes_by_name["schedule_workday_3_hour"].id, value[29]
            self.attributes_by_name["schedule_workday_3_minute"].id, value[28]
            self.attributes_by_name["schedule_workday_3_temperature"].id, value[27] / 2
            self.attributes_by_name["schedule_workday_4_hour"].id, value[26]
            self.attributes_by_name["schedule_workday_4_minute"].id, value[25]
            self.attributes_by_name["schedule_workday_4_temperature"].id, value[24] / 2
            self.attributes_by_name["schedule_saturday_1_hour"].id, value[23]
            self.attributes_by_name["schedule_saturday_1_minute"].id, value[22]
            self.attributes_by_name["schedule_saturday_1_temperature"].id, value[21] / 2
            self.attributes_by_name["schedule_saturday_2_hour"].id, value[20]
            self.attributes_by_name["schedule_saturday_2_minute"].id, value[19]
            self.attributes_by_name["schedule_saturday_2_temperature"].id, value[18] / 2
            self.attributes_by_name["schedule_saturday_3_hour"].id, value[17]
            self.attributes_by_name["schedule_saturday_3_minute"].id, value[16]
            self.attributes_by_name["schedule_saturday_3_temperature"].id, value[15] / 2
            self.attributes_by_name["schedule_saturday_4_hour"].id, value[14]
            self.attributes_by_name["schedule_saturday_4_minute"].id, value[13]
            self.attributes_by_name["schedule_saturday_4_temperature"].id, value[12] / 2
            self.attributes_by_name["schedule_sunday_1_hour"].id, value[11]
            self.attributes_by_name["schedule_sunday_1_minute"].id, value[10]
            self.attributes_by_name["schedule_sunday_1_temperature"].id, value[9] / 2
            self.attributes_by_name["schedule_sunday_2_hour"].id, value[8]
            self.attributes_by_name["schedule_sunday_2_minute"].id, value[7]
            self.attributes_by_name["schedule_sunday_2_temperature"].id, value[6] / 2
            self.attributes_by_name["schedule_sunday_3_hour"].id, value[5]
            self.attributes_by_name["schedule_sunday_3_minute"].id, value[4]
            self.attributes_by_name["schedule_sunday_3_temperature"].id, value[3] / 2
            self.attributes_by_name["schedule_sunday_4_hour"].id, value[2]
            self.attributes_by_name["schedule_sunday_4_minute"].id, value[1]
            self.attributes_by_name["schedule_sunday_4_temperature"].id, value[0] / 2
class BecaUserInterface(TuyaUserInterfaceCluster):
    """HVAC User interface cluster for tuya electric heating thermostats."""
    _CHILD_LOCK_ATTR = BECA_CHILD_LOCK_ATTR
class BecaWindowDetection(LocalDataCluster, BinaryInput):
    """On/Off cluster for the window detect function of the electric heating thermostats."""
        """Init."""
        self.endpoint.device.BecaWindowDetection_bus.add_listener(self)
    def set_value(self, value):
        """Set value."""
        self._update_attribute(self.attributes_by_name["present_value"].id, value)
class BecaWindowDetection_A2(LocalDataCluster, OnOff):
    """On/Off cluster for the window detect A2 function of the electric heating thermostats."""
        """Init."""
        self.endpoint.device.BecaWindowDetection_A2_bus.add_listener(self)
    def switch_change(self, value):
        """Window detect A2 change."""
        self._update_attribute(self.attributes_by_name["on_off"].id, value)
    async def write_attributes(self, attributes, manufacturer=None):
        """Defer attributes writing to the set_data tuya command."""
        records = self._write_attr_records(attributes)
        if not records:
            return [[foundation.WriteAttributesStatusRecord(foundation.Status.SUCCESS)]]
        has_change = False
        for record in records:
            attr_name = self.attributes[record.attrid][0]
            if attr_name == "on_off":
                value = record.value.value
                has_change = True
        if has_change:
            return await BecaManufClusterSelf[
            ].endpoint.tuya_manufacturer.write_attributes(
                {BECA_WINDOW_DETECT_A2_ATTR: value}, manufacturer=manufacturer
        return [
                    foundation.Status.FAILURE, r.attrid
                for r in records
    async def command(
        self,
        command_id: Union[foundation.GeneralCommand, int, t.uint8_t],
        *args,
        manufacturer: Optional[Union[int, t.uint16_t]] = None,
        expect_reply: bool = True,
        tsn: Optional[Union[int, t.uint8_t]] = None,
        """Override the default Cluster command."""
        if command_id in (0x0000, 0x0001, 0x0002):
            if command_id == 0x0000:
                value = False
            elif command_id == 0x0001:
                value = True
            else:
                attrid = self.attributes_by_name["on_off"].id
                success, _ = await self.read_attributes(
                    (attrid,), manufacturer=manufacturer
                try:
                    value = success[attrid]
                except KeyError:
                    return foundation.Status.FAILURE
                value = not value
            (res,) = await self.write_attributes(
                {"on_off": value}, manufacturer=manufacturer
            return [command_id, res]
        return [command_id, foundation.Status.UNSUP_CLUSTER_COMMAND]
class BecaChildLock(LocalDataCluster, OnOff):
    """On/Off cluster for the child lock function of the electric heating thermostats."""
        """Init."""
        self.endpoint.device.BecaChildLock_bus.add_listener(self)
        """Child lock change."""
        if not records:
        has_change = False
                has_change = True
        if has_change:
                {BECA_CHILD_LOCK_ATTR: value}, manufacturer=manufacturer
        return [
                for r in records
    async def command(
        self,
        *args,
                value = False
                value = True
            else:
                try:
                except KeyError:
                value = not value
class BecaValveState(LocalDataCluster, AnalogOutput):
    """Analog output for Valve State."""
        """Init."""
        self.endpoint.device.BecaValveState_bus.add_listener(self)
        self._update_attribute(self.attributes_by_name["description"].id, "Valve State")
        self._update_attribute(self.attributes_by_name["max_present_value"].id, 100)
        self._update_attribute(self.attributes_by_name["min_present_value"].id, 0)
        self._update_attribute(self.attributes_by_name["resolution"].id, 1)
        self._update_attribute(self.attributes_by_name["application_type"].id, 4 << 16)
        self._update_attribute(self.attributes_by_name["engineering_units"].id, 98)
        """Set value."""
class BecaTempCalibration(LocalDataCluster, AnalogOutput):
    """Analog output for Temp Calibration."""
        """Init."""
        self.endpoint.device.BecaTempCalibration_bus.add_listener(self)
            self.attributes_by_name["description"].id, "Temperature Calibration"
        self._update_attribute(self.attributes_by_name["max_present_value"].id, 9)
        self._update_attribute(self.attributes_by_name["min_present_value"].id, -9)
        self._update_attribute(self.attributes_by_name["application_type"].id, 13 << 16)
        self._update_attribute(self.attributes_by_name["engineering_units"].id, 62)
        """Set value."""
    def get_value(self):
        """Get value."""
        return self._attr_cache.get(self.attributes_by_name["present_value"].id)
        """Override the default Cluster write_attributes."""
        for attrid, value in attributes.items():
            if isinstance(attrid, str):
                attrid = self.attributes_by_name[attrid].id
            if attrid not in self.attributes:
                self.error("%d is not a valid attribute id", attrid)
                continue
            self._update_attribute(attrid, value)
                {BECA_TEMP_CALIBRATION_ATTR: value},
                manufacturer=None,
        return ([foundation.WriteAttributesStatusRecord(foundation.Status.SUCCESS)],)
class BecaBoostTime(LocalDataCluster, AnalogOutput):
    """Analog output for Boost Time."""
        """Init."""
        self.endpoint.device.BecaBoostTime_bus.add_listener(self)
        self._update_attribute(self.attributes_by_name["description"].id, "Boost Time")
        self._update_attribute(self.attributes_by_name["max_present_value"].id, 9999)
        self._update_attribute(self.attributes_by_name["application_type"].id, 14 << 16)
        self._update_attribute(self.attributes_by_name["engineering_units"].id, 73)
        """Set value."""
        """Get value."""
                continue
                {BECA_BOOST_TIME_ATTR: value},
                manufacturer=None,
class BecaBoostCountdown(LocalDataCluster, AnalogOutput):
    """Analog output for Boost Countdown time."""
        """Init."""
        self.endpoint.device.BecaBoostCountdown_bus.add_listener(self)
            self.attributes_by_name["description"].id, "Boost Countdown"
        self._update_attribute(self.attributes_by_name["application_type"].id, 12 << 16)
        self._update_attribute(self.attributes_by_name["engineering_units"].id, 72)
        """Set value."""
class BecaEcoTemp(LocalDataCluster, AnalogOutput):
    """Analog output for Eco Temperature."""
        """Init."""
        self.endpoint.device.BecaEcoTemp_bus.add_listener(self)
            self.attributes_by_name["description"].id, "Eco Temperature"
        self._update_attribute(self.attributes_by_name["max_present_value"].id, 35)
        self._update_attribute(self.attributes_by_name["min_present_value"].id, 5)
        """Set value."""
        """Get value."""
                continue
                {BECA_ECO_TEMP_ATTR: value},
                manufacturer=None,
class BecaMinTemp(LocalDataCluster, AnalogOutput):
    """Analog output for Min Temperature."""
        """Init."""
        self.endpoint.device.BecaMinTemp_bus.add_listener(self)
            self.attributes_by_name["description"].id, "Min Temperature"
        self._update_attribute(self.attributes_by_name["max_present_value"].id, 15)
        """Set value."""
        """Get value."""
                continue
                {BECA_MIN_TEMPERATURE_ATTR: value},
                manufacturer=None,
class BecaMaxTemp(LocalDataCluster, AnalogOutput):
    """Analog output for Max Temperature."""
        """Init."""
        self.endpoint.device.BecaMaxTemp_bus.add_listener(self)
            self.attributes_by_name["description"].id, "Max Temperature"
        self._update_attribute(self.attributes_by_name["max_present_value"].id, 45)
        self._update_attribute(self.attributes_by_name["min_present_value"].id, 15)
        """Set value."""
        """Get value."""
                continue
                {BECA_MAX_TEMPERATURE_ATTR: value},
                manufacturer=None,
class Beca(TuyaThermostat):
    """BECA Thermostatic radiator valve."""
        """Init device."""
        self.BecaWindowDetection_bus = Bus()
        self.BecaWindowDetection_A2_bus = Bus()
        self.BecaChildLock_bus = Bus()
        self.BecaValveState_bus = Bus()
        self.BecaTempCalibration_bus = Bus()
        self.BecaBoostTime_bus = Bus()
        self.BecaBoostCountdown_bus = Bus()
        self.BecaEcoTemp_bus = Bus()
        self.BecaMinTemp_bus = Bus()
        self.BecaMaxTemp_bus = Bus()
    signature = {
        #  endpoint=1 profile=260 device_type=81 device_version=0 input_clusters=[0, 4, 5, 61184]
        #  output_clusters=[10, 25]>
        MODELS_INFO: [
            ("_TZE200_b6wax7g0", "TS0601"),
        ENDPOINTS: {
            1: {
                PROFILE_ID: zha.PROFILE_ID,
                DEVICE_TYPE: zha.DeviceType.SMART_PLUG,
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    TuyaManufClusterAttributes.cluster_id,
                OUTPUT_CLUSTERS: [Time.cluster_id, Ota.cluster_id],
    replacement = {
        ENDPOINTS: {
            1: {
                DEVICE_TYPE: zha.DeviceType.THERMOSTAT,
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    BecaManufCluster,
                    BecaThermostat,
                    BecaUserInterface,
                    BecaWindowDetection,
            2: {
                DEVICE_TYPE: zha.DeviceType.ON_OFF_SWITCH,
                INPUT_CLUSTERS: [BecaChildLock],
                OUTPUT_CLUSTERS: [],
            3: {
                DEVICE_TYPE: zha.DeviceType.CONSUMPTION_AWARENESS_DEVICE,
                INPUT_CLUSTERS: [BecaValveState],
            4: {
                INPUT_CLUSTERS: [BecaWindowDetection_A2],
            5: {
                INPUT_CLUSTERS: [BecaTempCalibration],
            6: {
                INPUT_CLUSTERS: [BecaBoostTime],
            7: {
                INPUT_CLUSTERS: [BecaBoostCountdown],
            8: {
                INPUT_CLUSTERS: [BecaEcoTemp],
            9: {
                INPUT_CLUSTERS: [BecaMinTemp],
            10: {
                INPUT_CLUSTERS: [BecaMaxTemp],
Also remove the old quirk file, and the file with the same name in the pycache folder
Tanks for your swift reply !
Got it in a file and uploaded it, could not find the pycache folder.
I tried it again and still it dont wok the ZHA integration wonā€™t load and the error indicates :Error setting up entry socket://192.168.1.148:8888 for zha. Iā€™m very bad in reading and understanding the exact code
Source: components/zha/__init__.py:100
First occurred: 22:04:59 (1 occurrences)
Last logged: 22:04:59
  File "<frozen importlib._bootstrap_external>", line 879, in exec_module
  File "<frozen importlib._bootstrap_external>", line 1017, in get_code
  File "<frozen importlib._bootstrap_external>", line 947, in source_to_code
  File "/config/zha_quirks/ts0601_trv_beca1.py", line 569
    self._update_attribute(self.attributes_by_name["present_value"].id, value)class BecaWindowDetection_A2(LocalDataCluster, OnOff):
SyntaxError: invalid syntax
Looks like when you joined the two parts together the indenting got messed up.
Iā€™ve put the whole file here:-
Hi thanks for you analysis, i tried to download the file but can not as it says the file is deleted (location is empty)
can you please repost it
thanks
The other option is to find the file you made, and look for this line:-
And break it into 2 lines like so:-
(so just hit the enter key between the closing bracket ) and the ā€˜cā€™ of class.
Then resave the file and restart HA, or your ZHA integration, either will reload the quirk.
It should be around line 569:-
Thanks again and i can report that the indent was not correct and with above help corrected. Added the valve successful and will dive deeper in all the functionalities
If I may, could someone help me with this similar problem?
I have zha running with about 10 devices connected to a sonoff usb zigbee adapter connected to my home assistant serving running on a raspberry pi.
I recently bought the same Moes BRT-100 TRV and connected it to my zha. I realised there were very few entities so I did some research and figures itā€™s because Iā€™m missing a quirk. So I followed the steps from @Rofo
and created a .py file with the contents @Rofo posted, then put the file in ā€œcustom_zha_quirksā€ directory in config/
and in my configuration.yaml i wrote this:
zha:
  custom_quirks_path: /config/custom_zha_quirks/
When I restart home assistant, and go to Settings > Integrations I see that my zha integration foiled to set up.
This is the error I get:
2023-03-08 15:35:46.327 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Sonoff Zigbee 3.0 USB Dongle Plus - Sonoff Zigbee 3.0 USB Dongle Plus for zha
File "/config/custom_zha_quirks/moes.py", line 570
2023-03-08 15:35:58.551 ERROR (MainThread) [homeassistant.components.automation.toggle_bedroom_bulb] Got error 'Unable to get zha device f4b6b0d9efb38a4e9326d7755a0d0caa' when setting up triggers for Toggle Bedroom Bulb
2023-03-08 15:35:58.589 ERROR (MainThread) [homeassistant.components.automation.button_br_day] Got error 'Unable to get zha device f4b6b0d9efb38a4e9326d7755a0d0caa' when setting up triggers for Button BR Day
2023-03-08 15:35:58.594 ERROR (MainThread) [homeassistant.components.automation.button_br_night] Got error 'Unable to get zha device f4b6b0d9efb38a4e9326d7755a0d0caa' when setting up triggers for Button BR Night
2023-03-08 15:35:58.612 ERROR (MainThread) [homeassistant.components.automation.br_red_dark] Got error 'Unable to get zha device f4b6b0d9efb38a4e9326d7755a0d0caa' when setting up triggers for BR Red dark
2023-03-08 15:35:58.615 ERROR (MainThread) [homeassistant.components.automation.button_br_warm_50] Got error 'Unable to get zha device f4b6b0d9efb38a4e9326d7755a0d0caa' when setting up triggers for Button BR Warm 50%
2023-03-08 15:35:58.620 ERROR (MainThread) [homeassistant.components.automation.button_bedroom_color_swap] Got error 'Unable to get zha device f4b6b0d9efb38a4e9326d7755a0d0caa' when setting up triggers for Button Bedroom Color Swap
What am I doing wrong? I canā€™t find any solution to my problem anywhere.
I would greatly appreciate some assistance. Thanks in advance!
Iā€™m guessing you called your file moes.py
Looks like when you pasted the two parts together you had the same issue as @TheeBeginner.
Check your file to see that around line 570 looks like this:
Iā€™m guessing you have what is on line 572 on the end of line 569.
Just press enter and break it onto another line, making sure the word class starts on the far left with no white space indents.
Yes, youā€™re right! Thank you very much!
I didnā€™t realise that the indenting mattered, so I had the ā€œclassā€¦ā€ part right under ā€œself._updateā€¦ā€
Now I put line 572 to the far left and it works! Thanks again
