I think this might be related to this:-
I believe the ZHA guys are looking at this currently.
Not sure whats happened, but the TRV now seems to be responding to automations as I would expect. I did upgrade to Home Assistant 2022.11.4 this morning, I wonder if that has fixed it.
However, the comments about the thermostat going to 300 degrees instead of 30 are still there
Hi there, It seems that I stumbled over the solution in another thread.
If you have a beca based thermostat in your moes TRV, then this file gave me full control over the device:-
https://github.com/zigpy/zha-device-handlers/files/9844752/ts0601_trv_beca.py.zip
Its mentioned in this thread:-
You can set the correct values to stop the thermostat going to 300 degrees, and a variety of other things, like it also now correctly reports the battery level and a host of other things.
The only thing I don’t think works correctly is the slider for ‘number valve state’ (although it does get updated correctly when the valve opens and closes).
Note you will need to set values for min and max here so your thermostat doesn’t go to 300, and also, there are three unnamed switches which I’m not sure what they do.
I just turned on open window detection on the trv itself, and the bottom switch turned on in Home assistant, so I assume the bottom one is for that:-
The other two switches, according to the leaflet that came with the TRV are likely to be:-
Energy saving mode
Detection Valve head opening
but I’m not sure which is which in the list.
How can I use this file? What should I do with this? Sorry, I’m quite a newbee about this.
Take a look at this thread which explains how to use a local zha quirk:-
Managed to install the quirk but when i restarted the ZHA got an error and did not wanted to start. This resulted in that all my Zigbee devices could not be reached. the log showed an error in the setup.
Which steps to take here ?
Source: zha_quirks/ts0601_trv_beca.py:601
First occurred: 21:13:21 (1 occurrences)
Last logged: 21:13:21
Error setting up entry socket://192.168.1.148:8888 for zha
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 382, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 100, in async_setup_entry
setup_quirks(config)
File "/usr/local/lib/python3.10/site-packages/zhaquirks/__init__.py", line 409, in setup
importer.find_module(modname).load_module(modname)
File "<frozen importlib._bootstrap_external>", line 548, in _check_name_wrapper
File "<frozen importlib._bootstrap_external>", line 1063, in load_module
File "<frozen importlib._bootstrap_external>", line 888, in load_module
File "<frozen importlib._bootstrap>", line 290, in _load_module_shim
File "<frozen importlib._bootstrap>", line 719, in _load
File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 883, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "/config/zha_quirks/ts0601_trv_beca.py", line 558, in <module>
class BecaWindowDetection(LocalDataCluster, OnOff):
File "/config/zha_quirks/ts0601_trv_beca.py", line 601, in BecaWindowDetection
command_id: Union[foundation.Command, int, t.uint8_t],
AttributeError: module 'zigpy.zcl.foundation' has no attribute 'Command'
Try this quirk, its the one I used. Just copy and paste the code to a file.
I’ve had to split it over 2 posts to get within the character limit.
"""Beca TRV devices support."""
import logging
from typing import Optional, Union
import zigpy.types as t
from zhaquirks import Bus, LocalDataCluster
from zhaquirks.const import (
DEVICE_TYPE,
ENDPOINTS,
INPUT_CLUSTERS,
MODELS_INFO,
OUTPUT_CLUSTERS,
PROFILE_ID,
from zhaquirks.tuya import (
TuyaManufClusterAttributes,
TuyaPowerConfigurationCluster,
TuyaThermostat,
TuyaThermostatCluster,
TuyaUserInterfaceCluster,
from zigpy.profiles import zha
from zigpy.zcl import foundation
from zigpy.zcl.clusters.general import (
AnalogOutput,
Basic,
BinaryInput,
Groups,
OnOff,
Ota,
Scenes,
Time,
from zigpy.zcl.clusters.hvac import Thermostat
_LOGGER = logging.getLogger(__name__)
BECA_TARGET_TEMP_ATTR = 0x0202 # target room temp (degree)
BECA_TEMPERATURE_ATTR = 0x0203 # current room temp (decidegree)
BECA_MODE_ATTR = 0x0401 # [0] schedule [1] manual [2] temporary manual [3] away
BECA_CHILD_LOCK_ATTR = 0x010D # [0] unlocked [1] locked
BECA_TEMP_CALIBRATION_ATTR = 0x0269 # temperature calibration (degree)
BECA_MIN_TEMPERATURE_ATTR = 0x026D # minimum limit of temperature setting (degree)
BECA_MAX_TEMPERATURE_ATTR = 0x026C # maximum limit of temperature setting (degree)
BECA_WINDOW_DETECT_ATTR = 0x0409 # [1] alarm not active [0] alarm active
BECA_WINDOW_DETECT_A2_ATTR = 0x0108 # [0] function disactive [1] function active
BECA_BOOST_TIME_ATTR = 0x0267 # BOOST mode operating time in (sec)
BECA_BOOST_ATTR = 0x0104 # [0] off [1] on
BECA_BOOST_COUNTDOWN_ATTR = 0x0205 # (seconds)
BECA_ECO_TEMP_ATTR = 0x026B # eco mode temperature (degree)
BECA_ECO_MODE_ATTR = 0x016A # [0] off [1] on
BECA_VALVE_STATE_ATTR = 0x0268 # opening percentage
BECA_VALVE_STATE_ONOFF_ATTR = 0x0407 # [0] closed [1] opened
BECA_BATTERY_ATTR = 0x020E # battery percentage remaining 0-100%
BECA_SCHEDULE = 0x0065 # schedule
# [6, 0, 40, 11, 30, 42, 13, 30, 44, 17, 30, 46, 6, 0, 48, 12, 0, 46, 14, 30, 44, 17, 30, 42, 6, 0, 38, 12, 30, 40, 14, 30, 42, 18, 30, 40] for :
# Monday to friday : 06:00 20°C / 11:30 21°C / 13:30 22°C / 17:30 23°C
# Saturday : 06:00 24°C / 12:00 23°C / 14:30 22°C / 17:30 21°C
# Sunday : 06:00 19°C / 12:30 20°C / 14:30 21°C / 18:30 20°C )
BecaManufClusterSelf = {}
class data288(t.FixedList, item_type=t.uint8_t, length=36):
"""General data, Discrete, 288 bit."""
pass
class BecaManufCluster(TuyaManufClusterAttributes):
"""Manufacturer Specific Cluster of thermostatic valves."""
def __init__(self, *args, **kwargs):
"""Init."""
super().__init__(*args, **kwargs)
global BecaManufClusterSelf
BecaManufClusterSelf[self.endpoint.device.ieee] = self
set_time_offset = 1970
attributes = TuyaManufClusterAttributes.attributes.copy()
attributes.update(
BECA_TEMPERATURE_ATTR: ("temperature", t.uint32_t),
BECA_TARGET_TEMP_ATTR: ("target_temperature", t.uint32_t),
BECA_MODE_ATTR: ("mode", t.uint8_t),
BECA_CHILD_LOCK_ATTR: ("child_lock", t.uint8_t),
BECA_TEMP_CALIBRATION_ATTR: ("temperature_calibration", t.int32s),
BECA_MIN_TEMPERATURE_ATTR: ("min_temperature", t.uint32_t),
BECA_MAX_TEMPERATURE_ATTR: ("max_temperature", t.uint32_t),
BECA_WINDOW_DETECT_ATTR: ("window_detection", t.uint8_t),
BECA_WINDOW_DETECT_A2_ATTR: ("window_detection_A2_function", t.uint8_t),
BECA_BOOST_TIME_ATTR: ("boost_duration_seconds", t.uint32_t),
BECA_BOOST_ATTR: ("boost_enabled", t.uint8_t),
BECA_BOOST_COUNTDOWN_ATTR: ("boost_duration_seconds", t.uint32_t),
BECA_ECO_TEMP_ATTR: ("eco_mode_temperature", t.uint32_t),
BECA_ECO_MODE_ATTR: ("eco_mode_enabled", t.uint8_t),
BECA_VALVE_STATE_ATTR: ("valve_state", t.uint32_t),
BECA_VALVE_STATE_ONOFF_ATTR: ("valve_state_onoff", t.uint8_t),
BECA_BATTERY_ATTR: ("battery", t.uint32_t),
BECA_SCHEDULE: ("schedule", data288),
DIRECT_MAPPED_ATTRS = {
BECA_TEMPERATURE_ATTR: ("local_temperature", lambda value: value * 10),
BECA_TARGET_TEMP_ATTR: ("occupied_heating_setpoint", lambda value: value * 100),
BECA_TEMP_CALIBRATION_ATTR: ("local_temperature_calibration", None),
"min_heat_setpoint_limit",
lambda value: value * 100,
"max_heat_setpoint_limit",
def _update_attribute(self, attrid, value):
"""Override default _update_attribute."""
super()._update_attribute(attrid, value)
if attrid in self.DIRECT_MAPPED_ATTRS:
self.endpoint.device.thermostat_bus.listener_event(
"temperature_change",
self.DIRECT_MAPPED_ATTRS[attrid][0],
value
if self.DIRECT_MAPPED_ATTRS[attrid][1] is None
else self.DIRECT_MAPPED_ATTRS[attrid][1](value),
if attrid == BECA_WINDOW_DETECT_ATTR:
self.endpoint.device.BecaWindowDetection_bus.listener_event(
"set_value", value
if attrid == BECA_WINDOW_DETECT_A2_ATTR:
self.endpoint.device.BecaWindowDetection_A2_bus.listener_event(
"switch_change", value
elif attrid == BECA_CHILD_LOCK_ATTR:
mode = 1 if value else 0
self.endpoint.device.ui_bus.listener_event("child_lock_change", mode)
self.endpoint.device.BecaChildLock_bus.listener_event("switch_change", mode)
elif attrid in (BECA_MODE_ATTR, BECA_BOOST_ATTR, BECA_ECO_MODE_ATTR):
if attrid == BECA_BOOST_ATTR and value == 1:
self.endpoint.device.thermostat_bus.listener_event("mode_change", 5)
elif attrid == BECA_ECO_MODE_ATTR and value == 1:
self.endpoint.device.thermostat_bus.listener_event("mode_change", 4)
elif attrid == BECA_MODE_ATTR:
self.endpoint.device.thermostat_bus.listener_event("mode_change", value)
elif attrid == BECA_VALVE_STATE_ATTR:
self.endpoint.device.BecaValveState_bus.listener_event("set_value", value)
elif attrid == BECA_TEMP_CALIBRATION_ATTR:
self.endpoint.device.BecaTempCalibration_bus.listener_event(
"set_value", value
elif attrid == BECA_BOOST_TIME_ATTR:
self.endpoint.device.BecaBoostTime_bus.listener_event("set_value", value)
elif attrid == BECA_BOOST_COUNTDOWN_ATTR:
self.endpoint.device.BecaBoostCountdown_bus.listener_event(
"set_value", value
elif attrid == BECA_ECO_TEMP_ATTR:
self.endpoint.device.BecaEcoTemp_bus.listener_event("set_value", value)
elif attrid == BECA_BATTERY_ATTR:
self.endpoint.device.battery_bus.listener_event("battery_change", value)
elif attrid == BECA_MIN_TEMPERATURE_ATTR:
self.endpoint.device.BecaMinTemp_bus.listener_event("set_value", value)
elif attrid == BECA_MAX_TEMPERATURE_ATTR:
self.endpoint.device.BecaMaxTemp_bus.listener_event("set_value", value)
elif attrid == BECA_SCHEDULE:
self.endpoint.device.thermostat_bus.listener_event("schedule_change", value)
# elif attrid in (BECA_TEMPERATURE_ATTR, BECA_TARGET_TEMP_ATTR):
# self.endpoint.device.thermostat_bus.listener_event(
# "hass_climate_state_change", attrid, value
elif attrid == BECA_VALVE_STATE_ONOFF_ATTR:
"state_change", not value
class BecaThermostat(TuyaThermostatCluster):
"""Thermostat cluster for thermostatic valves."""
class Preset(t.enum8):
"""Working modes of the thermostat."""
Away = 0x00
Schedule = 0x01
Manual = 0x02
Comfort = 0x03
Eco = 0x04
Boost = 0x05
Complex = 0x06
TempManual = 0x07
class WorkDays(t.enum8):
"""Workday configuration for scheduler operation mode."""
MonToFri = 0x00
MonToSat = 0x01
MonToSun = 0x02
class ForceValveState(t.enum8):
"""Force valve state option."""
Normal = 0x00
Open = 0x01
Close = 0x02
_CONSTANT_ATTRIBUTES = {
0x001B: Thermostat.ControlSequenceOfOperation.Heating_Only,
0x001C: Thermostat.SystemMode.Heat,
attributes = TuyaThermostatCluster.attributes.copy()
attributes.update(
0x4002: ("operation_preset", Preset),
0x4110: ("schedule_workday_1_hour", t.uint8_t),
0x4111: ("schedule_workday_1_minute", t.uint8_t),
0x4112: ("schedule_workday_1_temperature", t.uint8_t),
0x4113: ("schedule_workday_2_hour", t.uint8_t),
0x4114: ("schedule_workday_2_minute", t.uint8_t),
0x4115: ("schedule_workday_2_temperature", t.uint8_t),
0x4116: ("schedule_workday_3_hour", t.uint8_t),
0x4117: ("schedule_workday_3_minute", t.uint8_t),
0x4118: ("schedule_workday_3_temperature", t.uint8_t),
0x4119: ("schedule_workday_4_hour", t.uint8_t),
0x4120: ("schedule_workday_4_minute", t.uint8_t),
0x4121: ("schedule_workday_4_temperature", t.uint8_t),
0x4122: ("schedule_saturday_1_hour", t.uint8_t),
0x4123: ("schedule_saturday_1_minute", t.uint8_t),
0x4124: ("schedule_saturday_1_temperature", t.uint8_t),
0x4125: ("schedule_saturday_2_hour", t.uint8_t),
0x4126: ("schedule_saturday_2_minute", t.uint8_t),
0x4127: ("schedule_saturday_2_temperature", t.uint8_t),
0x4128: ("schedule_saturday_3_hour", t.uint8_t),
0x4129: ("schedule_saturday_3_minute", t.uint8_t),
0x4130: ("schedule_saturday_3_temperature", t.uint8_t),
0x4131: ("schedule_saturday_4_hour", t.uint8_t),
0x4132: ("schedule_saturday_4_minute", t.uint8_t),
0x4133: ("schedule_saturday_4_temperature", t.uint8_t),
0x4134: ("schedule_sunday_1_hour", t.uint8_t),
0x4135: ("schedule_sunday_1_minute", t.uint8_t),
0x4136: ("schedule_sunday_1_temperature", t.uint8_t),
0x4137: ("schedule_sunday_2_hour", t.uint8_t),
0x4138: ("schedule_sunday_2_minute", t.uint8_t),
0x4139: ("schedule_sunday_2_temperature", t.uint8_t),
0x4140: ("schedule_sunday_3_hour", t.uint8_t),
0x4141: ("schedule_sunday_3_minute", t.uint8_t),
0x4142: ("schedule_sunday_3_temperature", t.uint8_t),
0x4143: ("schedule_sunday_4_hour", t.uint8_t),
0x4144: ("schedule_sunday_4_minute", t.uint8_t),
0x4145: ("schedule_sunday_4_temperature", t.uint8_t),
DIRECT_MAPPING_ATTRS = {
"min_heat_setpoint_limit": (
BECA_MIN_TEMPERATURE_ATTR,
lambda value: round(value / 100),
"max_heat_setpoint_limit": (
BECA_MAX_TEMPERATURE_ATTR,
"local_temperature_calibration": (
BECA_TEMP_CALIBRATION_ATTR,
lambda value: value,
SCHEDULE_ATTRS = {
"schedule_sunday_4_temperature": 20,
"schedule_sunday_4_minute": 30,
"schedule_sunday_4_hour": 18,
"schedule_sunday_3_temperature": 21,
"schedule_sunday_3_minute": 30,
"schedule_sunday_3_hour": 14,
"schedule_sunday_2_temperature": 20,
"schedule_sunday_2_minute": 30,
"schedule_sunday_2_hour": 12,
"schedule_sunday_1_temperature": 19,
"schedule_sunday_1_minute": 0,
"schedule_sunday_1_hour": 6,
"schedule_saturday_4_temperature": 21,
"schedule_saturday_4_minute": 30,
"schedule_saturday_4_hour": 17,
"schedule_saturday_3_temperature": 22,
"schedule_saturday_3_minute": 30,
"schedule_saturday_3_hour": 14,
"schedule_saturday_2_temperature": 23,
"schedule_saturday_2_minute": 00,
"schedule_saturday_2_hour": 12,
"schedule_saturday_1_temperature": 24,
"schedule_saturday_1_minute": 0,
"schedule_saturday_1_hour": 6,
"schedule_workday_4_temperature": 23,
"schedule_workday_4_minute": 30,
"schedule_workday_4_hour": 17,
"schedule_workday_3_temperature": 22,
"schedule_workday_3_minute": 30,
"schedule_workday_3_hour": 13,
"schedule_workday_2_temperature": 21,
"schedule_workday_2_minute": 30,
"schedule_workday_2_hour": 11,
"schedule_workday_1_temperature": 20,
"schedule_workday_1_minute": 0,
"schedule_workday_1_hour": 6,
def map_attribute(self, attribute, value):
"""Map standardized attribute value to dict of manufacturer values."""
if attribute in self.DIRECT_MAPPING_ATTRS:
return {
self.DIRECT_MAPPING_ATTRS[attribute][0]: value
if self.DIRECT_MAPPING_ATTRS[attribute][1] is None
else self.DIRECT_MAPPING_ATTRS[attribute][1](value)
if attribute == "occupied_heating_setpoint":
mode = self._attr_cache.get(self.attributes_by_name["operation_preset"].id)
if mode == self.Preset.Schedule:
return {BECA_MODE_ATTR: 2, BECA_TARGET_TEMP_ATTR: value / 100}
else:
return {BECA_TARGET_TEMP_ATTR: value / 100}
if attribute == "operation_preset":
if value == 0:
return {BECA_MODE_ATTR: 3, BECA_BOOST_ATTR: 0, BECA_ECO_MODE_ATTR: 0}
if value == 1:
return {BECA_MODE_ATTR: 0, BECA_BOOST_ATTR: 0, BECA_ECO_MODE_ATTR: 0}
if value == 2:
return {BECA_MODE_ATTR: 1, BECA_BOOST_ATTR: 0, BECA_ECO_MODE_ATTR: 0}
if value == 4:
return {BECA_BOOST_ATTR: 0, BECA_ECO_MODE_ATTR: 1}
if value == 5:
return {BECA_BOOST_ATTR: 1, BECA_ECO_MODE_ATTR: 0}
if value == 7:
return {BECA_MODE_ATTR: 2, BECA_BOOST_ATTR: 0, BECA_ECO_MODE_ATTR: 0}
if attribute in ("programing_oper_mode", "occupancy"):
if attribute == "occupancy":
occupancy = value
oper_mode = self._attr_cache.get(
self.attributes_by_name["programing_oper_mode"].id,
self.ProgrammingOperationMode.Simple,
else:
occupancy = self._attr_cache.get(
self.attributes_by_name["occupancy"].id, self.Occupancy.Occupied
oper_mode = value
if occupancy == self.Occupancy.Unoccupied:
return {BECA_MODE_ATTR: 3}
if occupancy == self.Occupancy.Occupied:
if oper_mode == self.ProgrammingOperationMode.Schedule_programming_mode:
return {BECA_MODE_ATTR: 0}
if oper_mode == self.ProgrammingOperationMode.Simple:
return {BECA_MODE_ATTR: 1}
self.error("Unsupported value for ProgrammingOperationMode")
else:
self.error("Unsupported value for Occupancy")
if attribute in self.SCHEDULE_ATTRS:
data = data288()
for num, (attr, default) in enumerate(self.SCHEDULE_ATTRS.items()):
if num % 3 == 0:
if attr == attribute:
val = round(value * 2)
else:
val = round(
self.attributes_by_name[attr].id, default
* 2
else:
val = value
else:
val = self._attr_cache.get(
data.append(val)
return {BECA_SCHEDULE: data}
def hass_climate_state_change(self, attrid, value):
"""Update of the HASS Climate gui state according to temp difference."""
if attrid == BECA_TEMPERATURE_ATTR:
temp_current = value * 10
temp_set = self._attr_cache.get(
self.attributes_by_name["occupied_heating_setpoint"].id
else:
temp_set = value * 100
temp_current = self._attr_cache.get(
self.attributes_by_name["local_temperature"].id
state = 0 if (int(temp_current) >= int(temp_set)) else 1
self.endpoint.device.thermostat_bus.listener_event("state_change", state)
def mode_change(self, value):
"""System Mode change."""
if value == 1:
operation_preset = self.Preset.Manual
prog_mode = self.ProgrammingOperationMode.Simple
occupancy = self.Occupancy.Occupied
elif value == 2:
operation_preset = self.Preset.TempManual
elif value == 3:
operation_preset = self.Preset.Away
occupancy = self.Occupancy.Unoccupied
elif value == 4:
operation_preset = self.Preset.Eco
prog_mode = self.ProgrammingOperationMode.Economy_mode
elif value == 5:
operation_preset = self.Preset.Boost
else:
operation_preset = self.Preset.Schedule
prog_mode = self.ProgrammingOperationMode.Schedule_programming_mode
self._update_attribute(
self.attributes_by_name["programing_oper_mode"].id, prog_mode
self._update_attribute(self.attributes_by_name["occupancy"].id, occupancy)
self.attributes_by_name["operation_preset"].id, operation_preset
def schedule_change(self, value):
"""Scheduler attribute change."""
self.attributes_by_name["schedule_workday_1_hour"].id, value[35]
self.attributes_by_name["schedule_workday_1_minute"].id, value[34]
self.attributes_by_name["schedule_workday_1_temperature"].id, value[33] / 2
self.attributes_by_name["schedule_workday_2_hour"].id, value[32]
self.attributes_by_name["schedule_workday_2_minute"].id, value[31]
self.attributes_by_name["schedule_workday_2_temperature"].id, value[30] / 2
self.attributes_by_name["schedule_workday_3_hour"].id, value[29]
self.attributes_by_name["schedule_workday_3_minute"].id, value[28]
self.attributes_by_name["schedule_workday_3_temperature"].id, value[27] / 2
self.attributes_by_name["schedule_workday_4_hour"].id, value[26]
self.attributes_by_name["schedule_workday_4_minute"].id, value[25]
self.attributes_by_name["schedule_workday_4_temperature"].id, value[24] / 2
self.attributes_by_name["schedule_saturday_1_hour"].id, value[23]
self.attributes_by_name["schedule_saturday_1_minute"].id, value[22]
self.attributes_by_name["schedule_saturday_1_temperature"].id, value[21] / 2
self.attributes_by_name["schedule_saturday_2_hour"].id, value[20]
self.attributes_by_name["schedule_saturday_2_minute"].id, value[19]
self.attributes_by_name["schedule_saturday_2_temperature"].id, value[18] / 2
self.attributes_by_name["schedule_saturday_3_hour"].id, value[17]
self.attributes_by_name["schedule_saturday_3_minute"].id, value[16]
self.attributes_by_name["schedule_saturday_3_temperature"].id, value[15] / 2
self.attributes_by_name["schedule_saturday_4_hour"].id, value[14]
self.attributes_by_name["schedule_saturday_4_minute"].id, value[13]
self.attributes_by_name["schedule_saturday_4_temperature"].id, value[12] / 2
self.attributes_by_name["schedule_sunday_1_hour"].id, value[11]
self.attributes_by_name["schedule_sunday_1_minute"].id, value[10]
self.attributes_by_name["schedule_sunday_1_temperature"].id, value[9] / 2
self.attributes_by_name["schedule_sunday_2_hour"].id, value[8]
self.attributes_by_name["schedule_sunday_2_minute"].id, value[7]
self.attributes_by_name["schedule_sunday_2_temperature"].id, value[6] / 2
self.attributes_by_name["schedule_sunday_3_hour"].id, value[5]
self.attributes_by_name["schedule_sunday_3_minute"].id, value[4]
self.attributes_by_name["schedule_sunday_3_temperature"].id, value[3] / 2
self.attributes_by_name["schedule_sunday_4_hour"].id, value[2]
self.attributes_by_name["schedule_sunday_4_minute"].id, value[1]
self.attributes_by_name["schedule_sunday_4_temperature"].id, value[0] / 2
class BecaUserInterface(TuyaUserInterfaceCluster):
"""HVAC User interface cluster for tuya electric heating thermostats."""
_CHILD_LOCK_ATTR = BECA_CHILD_LOCK_ATTR
class BecaWindowDetection(LocalDataCluster, BinaryInput):
"""On/Off cluster for the window detect function of the electric heating thermostats."""
"""Init."""
self.endpoint.device.BecaWindowDetection_bus.add_listener(self)
def set_value(self, value):
"""Set value."""
self._update_attribute(self.attributes_by_name["present_value"].id, value)
class BecaWindowDetection_A2(LocalDataCluster, OnOff):
"""On/Off cluster for the window detect A2 function of the electric heating thermostats."""
"""Init."""
self.endpoint.device.BecaWindowDetection_A2_bus.add_listener(self)
def switch_change(self, value):
"""Window detect A2 change."""
self._update_attribute(self.attributes_by_name["on_off"].id, value)
async def write_attributes(self, attributes, manufacturer=None):
"""Defer attributes writing to the set_data tuya command."""
records = self._write_attr_records(attributes)
if not records:
return [[foundation.WriteAttributesStatusRecord(foundation.Status.SUCCESS)]]
has_change = False
for record in records:
attr_name = self.attributes[record.attrid][0]
if attr_name == "on_off":
value = record.value.value
has_change = True
if has_change:
return await BecaManufClusterSelf[
].endpoint.tuya_manufacturer.write_attributes(
{BECA_WINDOW_DETECT_A2_ATTR: value}, manufacturer=manufacturer
return [
foundation.Status.FAILURE, r.attrid
for r in records
async def command(
self,
command_id: Union[foundation.GeneralCommand, int, t.uint8_t],
*args,
manufacturer: Optional[Union[int, t.uint16_t]] = None,
expect_reply: bool = True,
tsn: Optional[Union[int, t.uint8_t]] = None,
"""Override the default Cluster command."""
if command_id in (0x0000, 0x0001, 0x0002):
if command_id == 0x0000:
value = False
elif command_id == 0x0001:
value = True
else:
attrid = self.attributes_by_name["on_off"].id
success, _ = await self.read_attributes(
(attrid,), manufacturer=manufacturer
try:
value = success[attrid]
except KeyError:
return foundation.Status.FAILURE
value = not value
(res,) = await self.write_attributes(
{"on_off": value}, manufacturer=manufacturer
return [command_id, res]
return [command_id, foundation.Status.UNSUP_CLUSTER_COMMAND]
class BecaChildLock(LocalDataCluster, OnOff):
"""On/Off cluster for the child lock function of the electric heating thermostats."""
"""Init."""
self.endpoint.device.BecaChildLock_bus.add_listener(self)
"""Child lock change."""
if not records:
has_change = False
has_change = True
if has_change:
{BECA_CHILD_LOCK_ATTR: value}, manufacturer=manufacturer
return [
for r in records
async def command(
self,
*args,
value = False
value = True
else:
try:
except KeyError:
value = not value
class BecaValveState(LocalDataCluster, AnalogOutput):
"""Analog output for Valve State."""
"""Init."""
self.endpoint.device.BecaValveState_bus.add_listener(self)
self._update_attribute(self.attributes_by_name["description"].id, "Valve State")
self._update_attribute(self.attributes_by_name["max_present_value"].id, 100)
self._update_attribute(self.attributes_by_name["min_present_value"].id, 0)
self._update_attribute(self.attributes_by_name["resolution"].id, 1)
self._update_attribute(self.attributes_by_name["application_type"].id, 4 << 16)
self._update_attribute(self.attributes_by_name["engineering_units"].id, 98)
"""Set value."""
class BecaTempCalibration(LocalDataCluster, AnalogOutput):
"""Analog output for Temp Calibration."""
"""Init."""
self.endpoint.device.BecaTempCalibration_bus.add_listener(self)
self.attributes_by_name["description"].id, "Temperature Calibration"
self._update_attribute(self.attributes_by_name["max_present_value"].id, 9)
self._update_attribute(self.attributes_by_name["min_present_value"].id, -9)
self._update_attribute(self.attributes_by_name["application_type"].id, 13 << 16)
self._update_attribute(self.attributes_by_name["engineering_units"].id, 62)
"""Set value."""
def get_value(self):
"""Get value."""
return self._attr_cache.get(self.attributes_by_name["present_value"].id)
"""Override the default Cluster write_attributes."""
for attrid, value in attributes.items():
if isinstance(attrid, str):
attrid = self.attributes_by_name[attrid].id
if attrid not in self.attributes:
self.error("%d is not a valid attribute id", attrid)
continue
self._update_attribute(attrid, value)
{BECA_TEMP_CALIBRATION_ATTR: value},
manufacturer=None,
return ([foundation.WriteAttributesStatusRecord(foundation.Status.SUCCESS)],)
class BecaBoostTime(LocalDataCluster, AnalogOutput):
"""Analog output for Boost Time."""
"""Init."""
self.endpoint.device.BecaBoostTime_bus.add_listener(self)
self._update_attribute(self.attributes_by_name["description"].id, "Boost Time")
self._update_attribute(self.attributes_by_name["max_present_value"].id, 9999)
self._update_attribute(self.attributes_by_name["application_type"].id, 14 << 16)
self._update_attribute(self.attributes_by_name["engineering_units"].id, 73)
"""Set value."""
"""Get value."""
continue
{BECA_BOOST_TIME_ATTR: value},
manufacturer=None,
class BecaBoostCountdown(LocalDataCluster, AnalogOutput):
"""Analog output for Boost Countdown time."""
"""Init."""
self.endpoint.device.BecaBoostCountdown_bus.add_listener(self)
self.attributes_by_name["description"].id, "Boost Countdown"
self._update_attribute(self.attributes_by_name["application_type"].id, 12 << 16)
self._update_attribute(self.attributes_by_name["engineering_units"].id, 72)
"""Set value."""
class BecaEcoTemp(LocalDataCluster, AnalogOutput):
"""Analog output for Eco Temperature."""
"""Init."""
self.endpoint.device.BecaEcoTemp_bus.add_listener(self)
self.attributes_by_name["description"].id, "Eco Temperature"
self._update_attribute(self.attributes_by_name["max_present_value"].id, 35)
self._update_attribute(self.attributes_by_name["min_present_value"].id, 5)
"""Set value."""
"""Get value."""
continue
{BECA_ECO_TEMP_ATTR: value},
manufacturer=None,
class BecaMinTemp(LocalDataCluster, AnalogOutput):
"""Analog output for Min Temperature."""
"""Init."""
self.endpoint.device.BecaMinTemp_bus.add_listener(self)
self.attributes_by_name["description"].id, "Min Temperature"
self._update_attribute(self.attributes_by_name["max_present_value"].id, 15)
"""Set value."""
"""Get value."""
continue
{BECA_MIN_TEMPERATURE_ATTR: value},
manufacturer=None,
class BecaMaxTemp(LocalDataCluster, AnalogOutput):
"""Analog output for Max Temperature."""
"""Init."""
self.endpoint.device.BecaMaxTemp_bus.add_listener(self)
self.attributes_by_name["description"].id, "Max Temperature"
self._update_attribute(self.attributes_by_name["max_present_value"].id, 45)
self._update_attribute(self.attributes_by_name["min_present_value"].id, 15)
"""Set value."""
"""Get value."""
continue
{BECA_MAX_TEMPERATURE_ATTR: value},
manufacturer=None,
class Beca(TuyaThermostat):
"""BECA Thermostatic radiator valve."""
"""Init device."""
self.BecaWindowDetection_bus = Bus()
self.BecaWindowDetection_A2_bus = Bus()
self.BecaChildLock_bus = Bus()
self.BecaValveState_bus = Bus()
self.BecaTempCalibration_bus = Bus()
self.BecaBoostTime_bus = Bus()
self.BecaBoostCountdown_bus = Bus()
self.BecaEcoTemp_bus = Bus()
self.BecaMinTemp_bus = Bus()
self.BecaMaxTemp_bus = Bus()
signature = {
# endpoint=1 profile=260 device_type=81 device_version=0 input_clusters=[0, 4, 5, 61184]
# output_clusters=[10, 25]>
MODELS_INFO: [
("_TZE200_b6wax7g0", "TS0601"),
ENDPOINTS: {
1: {
PROFILE_ID: zha.PROFILE_ID,
DEVICE_TYPE: zha.DeviceType.SMART_PLUG,
INPUT_CLUSTERS: [
Basic.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
TuyaManufClusterAttributes.cluster_id,
OUTPUT_CLUSTERS: [Time.cluster_id, Ota.cluster_id],
replacement = {
ENDPOINTS: {
1: {
DEVICE_TYPE: zha.DeviceType.THERMOSTAT,
INPUT_CLUSTERS: [
Basic.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
BecaManufCluster,
BecaThermostat,
BecaUserInterface,
BecaWindowDetection,
2: {
DEVICE_TYPE: zha.DeviceType.ON_OFF_SWITCH,
INPUT_CLUSTERS: [BecaChildLock],
OUTPUT_CLUSTERS: [],
3: {
DEVICE_TYPE: zha.DeviceType.CONSUMPTION_AWARENESS_DEVICE,
INPUT_CLUSTERS: [BecaValveState],
4: {
INPUT_CLUSTERS: [BecaWindowDetection_A2],
5: {
INPUT_CLUSTERS: [BecaTempCalibration],
6: {
INPUT_CLUSTERS: [BecaBoostTime],
7: {
INPUT_CLUSTERS: [BecaBoostCountdown],
8: {
INPUT_CLUSTERS: [BecaEcoTemp],
9: {
INPUT_CLUSTERS: [BecaMinTemp],
10: {
INPUT_CLUSTERS: [BecaMaxTemp],
Also remove the old quirk file, and the file with the same name in the pycache folder
Tanks for your swift reply !
Got it in a file and uploaded it, could not find the pycache folder.
I tried it again and still it dont wok the ZHA integration won’t load and the error indicates :Error setting up entry socket://192.168.1.148:8888 for zha. I’m very bad in reading and understanding the exact code
Source: components/zha/__init__.py:100
First occurred: 22:04:59 (1 occurrences)
Last logged: 22:04:59
File "<frozen importlib._bootstrap_external>", line 879, in exec_module
File "<frozen importlib._bootstrap_external>", line 1017, in get_code
File "<frozen importlib._bootstrap_external>", line 947, in source_to_code
File "/config/zha_quirks/ts0601_trv_beca1.py", line 569
self._update_attribute(self.attributes_by_name["present_value"].id, value)class BecaWindowDetection_A2(LocalDataCluster, OnOff):
SyntaxError: invalid syntax
Looks like when you joined the two parts together the indenting got messed up.
I’ve put the whole file here:-
Hi thanks for you analysis, i tried to download the file but can not as it says the file is deleted (location is empty)
can you please repost it
thanks
The other option is to find the file you made, and look for this line:-
And break it into 2 lines like so:-
(so just hit the enter key between the closing bracket ) and the ‘c’ of class.
Then resave the file and restart HA, or your ZHA integration, either will reload the quirk.
Thanks again and i can report that the indent was not correct and with above help corrected. Added the valve successful and will dive deeper in all the functionalities
If I may, could someone help me with this similar problem?
I have zha running with about 10 devices connected to a sonoff usb zigbee adapter connected to my home assistant serving running on a raspberry pi.
I recently bought the same Moes BRT-100 TRV and connected it to my zha. I realised there were very few entities so I did some research and figures it’s because I’m missing a quirk. So I followed the steps from @Rofo
and created a .py file with the contents @Rofo posted, then put the file in “custom_zha_quirks” directory in config/
and in my configuration.yaml i wrote this:
zha:
custom_quirks_path: /config/custom_zha_quirks/
When I restart home assistant, and go to Settings > Integrations I see that my zha integration foiled to set up.
This is the error I get:
2023-03-08 15:35:46.327 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Sonoff Zigbee 3.0 USB Dongle Plus - Sonoff Zigbee 3.0 USB Dongle Plus for zha
File "/config/custom_zha_quirks/moes.py", line 570
2023-03-08 15:35:58.551 ERROR (MainThread) [homeassistant.components.automation.toggle_bedroom_bulb] Got error 'Unable to get zha device f4b6b0d9efb38a4e9326d7755a0d0caa' when setting up triggers for Toggle Bedroom Bulb
2023-03-08 15:35:58.589 ERROR (MainThread) [homeassistant.components.automation.button_br_day] Got error 'Unable to get zha device f4b6b0d9efb38a4e9326d7755a0d0caa' when setting up triggers for Button BR Day
2023-03-08 15:35:58.594 ERROR (MainThread) [homeassistant.components.automation.button_br_night] Got error 'Unable to get zha device f4b6b0d9efb38a4e9326d7755a0d0caa' when setting up triggers for Button BR Night
2023-03-08 15:35:58.612 ERROR (MainThread) [homeassistant.components.automation.br_red_dark] Got error 'Unable to get zha device f4b6b0d9efb38a4e9326d7755a0d0caa' when setting up triggers for BR Red dark
2023-03-08 15:35:58.615 ERROR (MainThread) [homeassistant.components.automation.button_br_warm_50] Got error 'Unable to get zha device f4b6b0d9efb38a4e9326d7755a0d0caa' when setting up triggers for Button BR Warm 50%
2023-03-08 15:35:58.620 ERROR (MainThread) [homeassistant.components.automation.button_bedroom_color_swap] Got error 'Unable to get zha device f4b6b0d9efb38a4e9326d7755a0d0caa' when setting up triggers for Button Bedroom Color Swap
What am I doing wrong? I can’t find any solution to my problem anywhere.
I would greatly appreciate some assistance. Thanks in advance!
I’m guessing you called your file moes.py
Looks like when you pasted the two parts together you had the same issue as @TheeBeginner.
Check your file to see that around line 570 looks like this:
I’m guessing you have what is on line 572 on the end of line 569.
Just press enter and break it onto another line, making sure the word class starts on the far left with no white space indents.
Yes, you’re right! Thank you very much!
I didn’t realise that the indenting mattered, so I had the “class…” part right under “self._update…”
Now I put line 572 to the far left and it works! Thanks again
You wouldn’t happen to know what you did to make the automations work do you?
I’m using this automation blueprint:
It (somehow) worked before I had the quirk installed, but now the thermostat doesn’t respond to the automation at all. It would be great if I can continue to use the thermostat with the quirk so that I can adjust the calibration, but it would also work with automations.
Is something preventing the thermostat from listening to automations? Like, I don’t know what the binary sensor is for, but in the logs I can see it’s active. Do you maybe know something about that?
Any suggestions would be appreciated. But, thenk again, you’ve already helped me very much with the quirk
