Hi everyone,
Iâve been busy with this blueprint merged with some of my other Tuya blueprints and added the color temperature integration as well as switching modes:
- Color temp: Press and rotate, simple as that
- Event/Scene mode: Press button 3 times (fast) and it will switch to event mode.
- Speed: I also took the âspeedâ param in dimmer mode into account for the transition speed.
Keep in mind that this blueprint contains input for both schene (event) and dimmer (command) mode.
This way you can switch modes and use both in one automation!
At the moment Iâve kept the automation mode as restart
, however Iâm unsure whether this is the best mode. parallel
might build up quite fast and single
or queued
isnât useful for dimming.
More info about the different modes: [Device Support Request] TS004F Tuya Smart Knob ¡ Issue #1322 ¡ zigpy/zha-device-handlers ¡ GitHub
blueprint:
name: ZHA - Tuya - TS004F Rotating Knob - Custom Actions
description: >-
This automation adds triggers for all actions of the rotating knob remote
form AliExpress brands like Moes, Girier etc.
domain: automation
input:
remote:
name: Tuya - TS004F Rotating Knob
description: Select the remote control you wish to use.
selector:
device:
integration: zha
manufacturer: _TZ3000_4fjiwweb
model: TS004F
light:
name: Light (Command/Dimmer mode)
selector:
entity:
domain: light
toggle:
name: Toggle (Command/Dimmer mode)
selector:
default: []
press_short:
name: Short Press (Event/Scene mode)
selector:
default: []
press_double:
name: Double Press (Event/Scene mode)
selector:
default: []
press_long:
name: Long Press (Event/Scene mode)
selector:
default: []
rotate_left:
name: Rotate Left (Event/Scene mode)
selector:
default: []
rotate_right:
name: Rotate Right (Event/Scene mode)
selector:
default: []
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input remote
- variables:
light: !input light
command: "{{ trigger.event.data.command }}"
cluster_id: "{{ trigger.event.data.cluster_id }}"
endpoint_id: "{{ trigger.event.data.endpoint_id }}"
args: "{{ trigger.event.data.args }}"
#direction: "{% if trigger.event.data.args[0] %} {{ trigger.event.data.args[0]|int(0) }} {% endif %}"
direction: "{% if trigger.event.data.args[0] == 0 %} 0 {% elif trigger.event.data.args[0] == 1 %} 1 {% elif trigger.event.data.args[0] == 3 %} 3 {% endif %}"
value: "{% if trigger.event.data.args[1] %} {{ trigger.event.data.args[1] / 2 }} {% endif %}"
speed: "{% if trigger.event.data.args[2] == 1 %} 0.5 {% else %} 0 {% endif %}"
- choose:
# Command Mode
- conditions:
- "{{ command == 'toggle' }}"
- "{{ cluster_id == 6 }}"
- "{{ endpoint_id == 1 }}"
sequence: !input toggle
- conditions:
- "{{ command == 'step' }}"
- "{{ cluster_id == 8 }}"
- "{{ direction == 0 }}"
- repeat:
while:
- condition: template
value_template: "{{ repeat.index < 2 }}"
- service_template: light.turn_on
target: !input light
data_template:
brightness_step_pct: "{{ value }}"
transition: "{{ speed }}"
- conditions:
- "{{ direction == 1 }}"
- repeat:
while:
data_template:
brightness_step_pct: "{{ - value }}"
- conditions:
- "{{ command == 'step_color_temp' }}"
- "{{ cluster_id == 768 }}"
- repeat:
while:
data_template:
color_temp: "{{ state_attr( light.entity_id, 'color_temp') + value }}"
- conditions:
- "{{ direction == 3 }}"
- repeat:
while:
data_template:
color_temp: "{{ state_attr( light.entity_id, 'color_temp' ) - value }}"
# Short Press
- conditions:
- "{{ command == 'remote_button_short_press' }}"
sequence: !input press_short
# Double Press
- conditions:
- "{{ command == 'remote_button_double_press' }}"
sequence: !input press_double
# Long Press
- conditions:
- "{{ command == 'remote_button_long_press' }}"
sequence: !input press_long
# Rotate Left
- conditions:
- "{{ command == 'left' }}"
sequence: !input rotate_left
# Rotate Right
- conditions:
- "{{ command == 'right' }}"
sequence: !input rotate_right
Let me know your thoughts!
