Is it possible to have multiple Envisalink integrations? I have two office buildings with two separate alarm systems, but both have Envisalink 4 units which are on the same network. I want to combine everything in one home assistant dashboard. From what it looks like you can’t have duplicates in the config file.
madrian
(madrian)
January 25, 2022, 8:40pm
2
I have same question, somewhere we should post a feature request for this.
I’m wondering if there is a way to connect Home Assistant to two separate Envisalink EVL4 modules? I have one in my home DSC alarm but also a second one in a separate DSC alarm system in a shop that is remotely on the property. Both are accessible to Home Assistant but I can’t seem to figure out how to allow it to connect to two units.
Any ideas? Presumably this should be possible but perhaps just not implemented or documented?
Thanks!
I have two (2) Honeywell Vista 20p alarm panels with the Eyezon Envisalink 4 units. The service home page for the envisalink is: http://www.eyezon.com
There is a Home Assisrtant integration is located at: https://www.home-assistant.io/components/envisalink/
The request is to have multiple envisalink modules as part of the same HA instance. I imagine that with rental units, offices, Airbnb, this request is going to become more prevalent.
Phillip
(Phibins)
March 8, 2023, 9:26pm
3
I would like this also. I will be following this thread.
