Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Mushroom Animations :mushroom: - Part 5
Mushroom Chip Animations
Mushroom Chip Animated Scene
Chip Animated Scene
type: custom:mushroom-chips-card
chips:
  - type: template
    icon: mdi:mushroom
    icon_color: red
  - type: template
    icon: mdi:snail
    icon_color: brown
  - type: template
    icon: mdi:flower
    icon_color: amber
  - type: template
    icon: mdi:butterfly
    icon_color: cyan
card_mod:
  style:
    mushroom-template-chip:nth-child(1)$: |
      ha-icon {
        animation: bump 10s infinite;
        transform-origin: 50% 100%;
      @keyframes bump {
        0% { transform: translateX(0); }
        1% { transform: translateX(-0.6px) rotate(-9deg); }
        2% { transform: translateX(0.5px) rotate(7deg); }
        3% { transform: translateX(-0.3px) rotate(-5deg); }
        4% { transform: translateX(0.2px) rotate(3deg); }
        5% { transform: translateX(0); }
    mushroom-template-chip:nth-child(2)$: |
      ha-icon {
        animation: slip 0.5s linear infinite alternate;
        transform-origin: 100% 100%;
      @keyframes slip {
        from { transform: scale(1.05, 0.9);}
        to { transform: scale(0.9, 1.05); }
    mushroom-template-chip:nth-child(3)$: |
      ha-icon {
      @keyframes bump {
        50% { transform: translateX(0); }
        51% { transform: translateX(-0.6px) rotate(-9deg); }
        52% { transform: translateX(0.5px) rotate(7deg); }
        53% { transform: translateX(-0.3px) rotate(-5deg); }
        54% { transform: translateX(0.2px) rotate(3deg); }
        55% { transform: translateX(0); }
    mushroom-template-chip:nth-child(4)$: |
      ha-icon {
        animation: flutter 5s infinite alternate;
      @keyframes flutter {
        0% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
        10% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg) scalex({{ range(3, 7) | random / 10 }}); }
        20% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
        30% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg) scalex({{ range(3, 7) | random / 10 }}); }
        40% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
        50% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg) scalex({{ range(3, 7) | random / 10 }}); }
        60% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
        70% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg) scalex({{ range(3, 7) | random / 10 }}); }
        80% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
        90% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg) scalex({{ range(3, 7) | random / 10 }}); }
        100% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
      .chip-container {
        background: radial-gradient(circle, rgba(var(--rgb-light-blue), 0.1) 0%, transparent 100%);
        border-bottom: 3px dotted rgba(var(--rgb-green));
        border-radius: 20%;
        box-shadow: 0 5px 1px 0.1px rgba(var(--rgb-green), 0.2)
      mushroom-template-chip:nth-child(2) {
        animation: slide 10s ease-in-out infinite;
      @keyframes slide {
        0% { transform: translate(0px, 0px) rotateY(0deg); }
        50% { transform: translate(100px, 0px) rotateY(0deg); }
        50.1% { transform: translate(100px, 0px) rotateY(180deg); }
        100% { transform: translate(0px, 0px) rotateY(180deg); }
      mushroom-template-chip:nth-child(3) {
          transform: translate(100px);
      mushroom-template-chip:nth-child(4) {
          animation: by {{ range(5, 15) | random }}s ease infinite;
      @keyframes by {
        0% { transform: translate(100px, 0px); }
        50% { transform: translate({{ range(110, 150) | random }}px, 0px); }
        100% { transform: translate(100px, 0px); }
Adding Animations to Chips
Adding an animation to a Mushroom Chip is a bit more complicated than a normal Mushroom Card. You have the Chips 'parent' and multiple Chip 'children'. The card_mod can be applied differently to each.
To the Chip
The simplest method is to add the card_mod to the Chip. The disadvantage of doing this is that we can't address the icon directly, so animations such as clip-path will not work and we can't have any text on the Chip. This method also breaks the GUI editor of the Chips, so you have to configure with YAML.
Chip Animation
chips:
  - type: template
    icon: mdi:mushroom
    icon_color: red
    card_mod:
      style: |
        .content {
          animation: boing 3s ease infinite;
          transform-origin: 50% 90%;
        @keyframes boing {
          0% { transform: scale3d(1, 1, 1); }
          7% { transform: scale3d(1.25, 0.75, 1); }
          10% { transform: scale3d(0.75, 1.25, 1); }
          12% { transform: scale3d(1.15, 0.85, 1); }
          16% { transform: scale3d(0.95, 1.05, 1); }
          19% { transform: scale3d(1.05, 0.95, 1); }
          25% { transform: scale3d(1, 1, 1); }
  - type: template
    icon: mdi:mushroom
    icon_color: red
    card_mod:
      style: |
        .content {
          animation: spin 3s ease 1.5s infinite;
        @keyframes spin {
          100% { transform: rotate(360deg); }
To the Chips
The more complex but correct method is to add the card_mod to the Chips (parent) and then address each Chip (child). This is done by referencing the mushroom-<chip-type>-chip:nth-child(x) where x is the number of the Chip and <chip-type> is type of Chip, such as template, entity, light etc. So, if I wanted to reference the 5th Entity Chip I would use mushroom-entity-chip:nth-child(5) or the 2nd Template Chip mushroom-template-chip:nth-child(2). The functionality of the GUI editor is retained with this method.
Chips Animation
chips:
  - type: template
    icon: mdi:mushroom
    icon_color: red
  - type: template
    content: Mushroom
    icon: mdi:mushroom
    icon_color: red
  - type: light
    entity: light.rocket_man
    icon: mdi:rocket-launch
    content_info: name
card_mod:
  style:
      ha-icon {
      @keyframes boing {
      ha-icon {
      @keyframes spin {
    mushroom-light-chip:nth-child(3)$: |
      ha-icon {
        {{ 'animation: thrust 100ms infinite, motion 3s ease-in-out infinite;' if is_state('light.rocket_man', 'on') }}
      @keyframes thrust {
        0% { clip-path: polygon(0 0, 0 47%, 22% 57%, 28% 63%, 0 91%, 11% 100%, 37% 73%, 45% 77%, 55% 100%, 100% 100%, 100% 0%); }
        33% { clip-path: polygon(0 0, 0 47%, 24% 59%, 42% 76%, 54% 100%, 100% 100%, 100% 0); }
        66% { clip-path: polygon(0 0, 0 92%, 28% 64%, 36% 72%, 9% 100%, 100% 100%, 100% 0%); }
      @keyframes motion {
        0%, 100% { transform: translateY(-2px) translateX(-3px); }
        50% { transform: translateY(3px) translateX(2px); }
Even More Mushroom Card Icon Animations
Mushroom Monitor Animation
Monitor Animation
type: custom:mushroom-template-card
icon: mdi:monitor
icon_color: purple
primary: Monitor
card_mod:
  style:
    mushroom-shape-icon$: |
      ha-icon:before {
        content: "";
        position: absolute;
        width: 40%;
        height: 30%;
        margin: 6%;
        animation: refresh 300ms linear infinite;
      @keyframes refresh {
        0% { background: linear-gradient(180deg, rgba(var(--rgb-{{ config.icon_color }}), 0.2) 0%, transparent 50%, transparent 100%); }
        25% { background: linear-gradient(180deg, transparent 0%, rgba(var(--rgb-{{ config.icon_color }}), 0.2) 25%, transparent 100%); }
        50% { background: linear-gradient(180deg, transparent 0%, rgba(var(--rgb-{{ config.icon_color }}), 0.2) 50%, transparent 100%); }
        75% { background: linear-gradient(180deg, transparent 0%, rgba(var(--rgb-{{ config.icon_color }}), 0.2) 75%, transparent 100%); }
        100% { background: linear-gradient(180deg, transparent 0%, transparent 50%, rgba(var(--rgb-{{ config.icon_color }}), 0.2) 100%); }
Mushroom Email Animation
Email Animation
type: custom:stack-in-card
cards:
    icon: mdi:email
    icon_color: orange
    primary: Email
    card_mod:
      style:
          ha-icon {
            --icon-animation: email 4s infinite;
          @keyframes email {
            0%, 32%, 100% { opacity: 1; }
            33%, 99% { opacity: 0; }
    icon: mdi:email-open
    icon_color: orange
    card_mod:
      style:
          ha-icon {
            --icon-animation: email-open 4s infinite;
          @keyframes email-open {
            0%, 32%, 100% { opacity: 0; }
            33%, 65% { opacity: 1; }
            66% { opacity: 0; }
          .shape {
            --shape-color: none;
          ha-card {
            width: 66px;
            top: -66px;
    icon: mdi:email-newsletter
    icon_color: orange
    card_mod:
      style:
          ha-icon {
            --icon-animation: email-newsletter 4s infinite;
          @keyframes email-newsletter {
            0%, 65% { opacity: 0; }
            66% { opacity: 1; }
          .shape {
          ha-card {
            width: 66px;
            top: -132px;
card_mod:
  style: |
    ha-card {
      height: 66px;
Mushroom Email #2 Animation
Email #2 Animation
cards:
    icon: mdi:email
    icon_color: orange
    primary: 'Email #2'
    card_mod:
      style:
          ha-icon {
            --icon-animation: email 2s infinite;
          @keyframes email {
            0%, 49%, 100% { opacity: 1; }
            50%, 99% { opacity: 0; }
    icon_color: orange
    card_mod:
      style:
          ha-icon {
            --icon-animation: email-open 2s infinite;
            0%, 49%, 100% { opacity: 0; }
            50%, 99% { opacity: 1; }
          .shape {
          ha-card {
            width: 66px;
            top: -66px;
card_mod:
  style: |
    ha-card {
      height: 66px;
Mushroom Christmas Tree #2 Animation
cards:
    icon: mdi:pine-tree
    icon_color: green
    primary: 'Christmas Tree #2'
    icon: mdi:star-four-points
    icon_color: yellow
    primary: Star
    card_mod:
      style:
          ha-icon {
            --icon-animation: star 8s ease infinite alternate;
          @keyframes star {
            0%, 100% { transform: translateY(-10px) rotate(0deg) scale(0.4); }
            50% { transform: translateY(-10px) rotate(360deg) scale(0.6); }
          .shape {
          ha-card {
            width: 66px;
            top: -66px;
    icon: mdi:grain
    icon_color: red
    card_mod:
      style:
          ha-icon {
            --icon-animation: flash 2s steps(1) infinite, lights 2s infinite;
            clip-path: polygon(51% 15%, 24% 74%, 74% 74%);
          @keyframes flash {
            50% { transform: rotateY(180deg); }
          @keyframes lights {
            0%, 100% {--icon-color: rgb(var(--rgb-red)); }
            6.25% { --icon-color: rgb(var(--rgb-deep-orange)); }
            12.5% { --icon-color: rgb(var(--rgb-orange)); }
            18.75% { --icon-color: rgb(var(--rgb-amber)); }
            25% { --icon-color: rgb(var(--rgb-yellow)); }
            31.25% { --icon-color: rgb(var(--rgb-lime)); }
            37.5% { --icon-color: rgb(var(--rgb-light-green)); }
            43.75% { --icon-color: rgb(var(--rgb-green)); }
            50% { --icon-color: rgb(var(--rgb-teal)); }
            56.25% { --icon-color: rgb(var(--rgb-cyan)); }
            62.5% { --icon-color: rgb(var(--rgb-light-blue)); }
            68.75% { --icon-color: rgb(var(--rgb-blue)); }
            75% { --icon-color: rgb(var(--rgb-indigo)); }
            81.25% { --icon-color: rgb(var(--rgb-deep-purple)); }
            87.5% { --icon-color: rgb(var(--rgb-purple)); }
            93.75% { --icon-color: rgb(var(--rgb-pink)); }
          .shape {
          ha-card {
            width: 66px;
            top: -132px;
    icon: mdi:gift
    icon_color: red
    card_mod:
      style:
          ha-icon {
            --icon-animation: surprise 4s ease infinite;
          @keyframes surprise {
            0%, 20%, 100% { transform: translateY(0); }
            2.5% { transform: translateY(-2px) rotate(-27deg); }
            5% { transform: translateY(-2px) rotate(21deg); }
            7.5% { transform: translateY(-2px) rotate(-15deg); }
            10% { transform: translateY(-2px) rotate(9deg); }
            12.5% { transform: translateY(0); }
            15% { transform: translateY(-1.2px) }
          .shape {
            --icon-size: 18px;
            top: 18px;
            left: 18px;
          ha-card {
            width: 66px;
            top: -198px;
card_mod:
  style: |
    ha-card {
      height: 66px;
Mushroom 3D Printing Animation
cards:
    icon: mdi:printer-3d-nozzle
    icon_color: cyan
    primary: 3D Printing
    card_mod:
      style:
          ha-icon {
            clip-path: inset(83% 72% 0 0);
          ha-card {
            --ha-card-border-width: 0;
    icon_color: cyan
    primary: ''
    card_mod:
      style:
          ha-icon {
            --icon-animation: print 1s linear infinite alternate;
          @keyframes print {
            0% { transform: translateX(4px); }
            30% { clip-path: polygon(0 0, 100% 0%, 100% 100%, 0 100%, 0 26%); }
            100% { transform: translateX(-4px); clip-path: polygon(0 0, 100% 0%, 100% 100%, 40% 100%, 0 26%); }
          .shape {
          ha-card {
            width: 66px;
            top: -66px;
card_mod:
  style: |
    ha-card {
      height: 66px;
Mushroom 3D Printer Animation
primary: 3D Printer
icon_color: light-blue
card_mod:
  style:
      ha-icon {
        --icon-animation: print 2s infinite;
      @keyframes print {
        0%, 100% { clip-path: polygon(0 0, 0 51%, 20% 51%, 51% 33%, 81% 53%, 100% 53%, 100% 0); }
        10% { clip-path: polygon(0 0, 0 100%, 49% 100%, 85% 83%, 49% 98%, 50% 89%, 51% 82%, 46% 79%, 36% 73%, 17% 82%, 20% 50%, 51% 33%, 81% 52%, 100% 52%, 100% 0); }
        20% { clip-path: polygon(0 0, 0 100%, 100% 100%, 85% 83%, 66% 73%, 56% 79%, 51% 83%, 46% 79%, 36% 73%, 17% 82%, 20% 50%, 51% 33%, 81% 52%, 100% 52%, 100% 0); }
        30% { clip-path: polygon(0 0, 0 100%, 100% 100%, 85% 83%, 66% 73%, 54% 69%, 50% 61%, 45% 69%, 36% 73%, 17% 82%, 20% 50%, 51% 33%, 81% 52%, 100% 52%, 100% 0); }
        40% { clip-path: polygon(0 0, 0 100%, 100% 100%, 85% 83%, 66% 73%, 54% 69%, 50% 61%, 45% 69%, 34% 63%, 25% 54%, 20% 50%, 51% 33%, 81% 52%, 100% 52%, 100% 0); }
        50% { clip-path: polygon(0 0, 0 100%, 100% 100%, 76% 51%, 66% 63%, 54% 69%, 50% 61%, 45% 69%, 34% 63%, 25% 54%, 20% 50%, 51% 33%, 81% 52%, 100% 52%, 100% 0); }
        60% { clip-path: polygon(0 0, 0 100%, 100% 100%, 76% 51%, 66% 63%, 55% 69%, 50% 61%, 39% 55%, 32% 55%, 25% 54%, 20% 50%, 51% 33%, 81% 52%, 100% 52%, 100% 0); }
        70% { clip-path: polygon(0 0, 0 100%, 100% 100%, 76% 51%, 68% 53%, 60% 55%, 50% 61%, 39% 55%, 32% 55%, 25% 54%, 20% 50%, 51% 33%, 81% 52%, 100% 52%, 100% 0); }
        80% { clip-path: polygon(0 0, 0 100%, 100% 100%, 76% 51%, 68% 53%, 60% 55%, 50% 61%, 50% 50%, 51% 37%, 31% 44%, 30% 35%, 51% 33%, 81% 52%, 100% 52%, 100% 0); }
        90% { clip-path: polygon(0 0, 0 100%, 100% 100%, 77% 51%, 67% 42%, 64% 34%, 56% 34%, 50% 36%, 39% 40%, 31% 44%, 30% 35%, 41% 33%, 85% 53%, 100% 52%, 100% 0); }
Mushroom Auto Fix #2 Animation
icon: mdi:auto-fix
icon_color: cyan
primary: 'Auto Fix #2'
card_mod:
  style:
      ha-icon {
        --icon-animation: sparkle 2s linear infinite, kadabra 2s ease-in-out infinite;
       transform-origin: 10% 90%
      @keyframes sparkle {
        0%, 68%, 100% { clip-path: polygon(0% 100%, 1% 75%, 56% 22%, 80% 43%, 26% 100%); }
        69%, 74%, 79%, 85% { clip-path: inset(0 0 0 0); }
        70% { clip-path: polygon(0 100%, 0 76%, 75% 0, 100% 0, 100% 100%); }
        75% { clip-path: polygon(0 100%, 0 0, 39% 0, 100% 62%, 100% 100%); }
        80% { clip-path: polygon(0 100%, 0 0, 100% 0, 100% 26%, 25% 100%); }
      @keyframes kadabra {
        0%, 65%, 100% { transform: rotate(-15deg); }
        70% { transform: rotate(20deg); }
        75% { transform: rotate(15deg); }
        80% { transform: rotate(25deg); }
Mushroom Vroom Animation
Vroom Animation
icon: mdi:car-hatchback
icon_color: red
primary: Vroom
card_mod:
  style:
      ha-icon {
        --icon-animation: vroom 2s ease-in-out infinite;
      .shape {
      @keyframes vroom {
        49% { opacity: 1;}
        50% { transform: translate(32px); opacity: 0; }
        51% { transform: translate(-32px); opacity: 0; }
        52% { opacity: 1; }
Mushroom Double Garage Animation
primary: Double Garage
icon: mdi:garage-variant
icon_color: amber
card_mod:
  style:
      ha-icon {
        --icon-animation: door 3s steps(1) infinite alternate;
      @keyframes door {
        0% { clip-path: inset(0 0 0 0); }
        25%  { clip-path: polygon(0 0, 0 100%, 19% 100%, 19% 74%, 81% 74%, 81% 100%, 100% 100%, 100% 0); }
        50%  { clip-path: polygon(0 0, 0 100%, 19% 100%, 19% 60%, 81% 60%, 81% 100%, 100% 100%, 100% 0); }
        75% { clip-path: polygon(0 0, 0 100%, 19% 100%, 19% 48%, 81% 48%, 81% 100%, 100% 100%, 100% 0); }
:point_right: Continued in Part 1, Part 2, Part 3 & Part 4
