Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Maybe I donā€™t read something, but my mushroom animation doesnā€™t work . I just copy/paste your code, install card-mod plugin via HACS but itā€™s doesnā€™t workā€¦ for example with the basic fan animation :
Look at my post with updated animations. How animations are applied changed months ago.
This explains how these symbols work :slight_smile:
Does anybody know how to minimize the delay between clicking the up or down arrow on a mushroom number card and the actual update of the input number value ? Iā€™ve already tried to lower the values of ā€˜mush-slider-tresholdā€™ and ā€˜mush-input-number-debounceā€™ with card-mod and in my theme but the delay of approximately 2 seconds wonā€™t change.
Iā€™m trying to use custom:mushroom-select-card as an overlay to a custom:button-card.
Essentially, I just want the select-option part to be visible once the card is clicked, the rest should be transparent.
Iā€™m pretty close to the result (see code below) but two issues remain:
1- can the ā€œbottom barā€ be hidden / made transparent?
2- is it possible to custom size the clickable zone so it covers the full card (see gray zone when cursor hovers the card)? Iā€™ve tried changing the font size hoping it would expand the zone but it doesnā€™t.
2023-10-17 102351
type: custom:layout-card
layout_type: grid
layout:
  grid-template-columns: 25% 25% 25% 25%
  grid-template-areas: |
    "A1 A2 A3 A4"
cards:
  - type: horizontal-stack
    view_layout:
      grid-area: A1
    cards:
      - type: custom:button-card
        entity: input_select.ir_command_ac2_mode
        show_state: true
        show_entity_picture: true
        entity_picture: \local\!MYDATA\WEATHER\temperature2.png
        styles:
          card:
            - font-size: 2rem
            - font-weight: bold
          icon:
            - height: 4rem
            - width: 4rem
    view_layout:
      grid-area: A1
    cards:
      - type: custom:mushroom-select-card
        secondary_info: none
        icon_type: none
        fill_container: true
        card_mod:
          style:
            mushroom-select-option-control$:
              mushroom-select$: |
                .mdc-select__anchor{
                  background: none !important
                .mdc-select__selected-text {
                  color: transparent !important;
                .mdc-select__dropdown-icon {
                  fill: transparent !important;
              ha-card {
               background: none;
I dont normally just figure out the answer for people, but i liked the use case so here you go!
layout_type: grid
layout:
    "A1 A2 A3 A4"
cards:
    view_layout:
      grid-area: A1
    cards:
        entity: input_select.bedroom_fan_direction
        show_state: true
        styles:
          card:
            - font-size: 2rem
            - font-weight: bold
          icon:
            - height: 4rem
            - width: 4rem
    view_layout:
      grid-area: A1
    cards:
        icon_type: none
        card_mod:
          style:
              mushroom-select$: |
                  background: none !important;
                  border-radius: 20px !important;
                .mdc-line-ripple::before {
                  border-bottom-width: 0px !important;
                .mdc-line-ripple::after {
                .mdc-select {
                  position: absolute !important;
                  width: 100% !important;
                  --select-height: 97px;
                  top: 0%;
                  right: 0%;
              ha-card {
               background: none;
i had to set the position to absolute for the dropdown, so it may not work well in grids. but since its already in a layout card, perhaps it will, who knows! :slight_smile:
removes the line before you clicked.
removes the blue line from after you have clicked.
Amazing. Thanks for the extra mile. Glad you like the use case =)
This will be a great building block for my dashboard. Thank you!
Just to improve my search skills, was this documented in your guide or elsewhere?
Not really. i have a section for the selection value in the select card in my guide. but it doesnt mention removing the line.
Select Card is in the same post as the person card.
then go to the selection value sections of this post.
i did answer the question regarding the line removal recently here:
so perhaps i will update my guide to include it :slight_smile:
Hi all,
Iā€™m using mushroom-entity-buttons to highlight which rooms my vacuum should clean. I had the intention that every button would light up when I press it, but unfortunately they all light up when I press only one.
Is it possible because they all refer to the same script (but with different parameters) ?
Does anyone have a clue how to change that ?
Hereā€™s my code:
            cards:
                  - type: custom:mushroom-entity-card
                    tap_action:
                      action: call-service
                      service: script.jarvis_room_cleaner
                      service_data:
                        room: bartjessie
                    entity: script.jarvis_room_cleaner
                    icon_height: 30px
                    icon: mdi:bed-king-outline
                    layout: vertical
                    tap_action:
                      service_data:
                        room: joosarne
                    icon_height: 30px
                    icon: mdi:bed-queen-outline
                    layout: vertical
                    tap_action:
                      service_data:
                        room: bentjesse
                    icon_height: 30px
                    icon: mdi:bed-single-outline
                    layout: vertical
            cards:
                    tap_action:
                      service_data:
                        room: hallway
                    icon_height: 30px
                    icon: mdi:hanger
                    layout: vertical
                    tap_action:
                      service_data:
                        room: berging
                    icon_height: 30px
                    layout: vertical
                    icon: mdi:vacuum-outline
                    tap_action:
                      service_data:
                        room: kitchen
                    icon_height: 30px
                    icon: mdi:silverware-fork-knife
                    layout: vertical
            columns: 4
            square: false
Thanks a lot in advance !
Kr,
Bart
Yes. it will be because your entity is the same script. your tap action has no bearing on what the card does. it is the fact that the script is being ran that changes the state of the entity in your card, which is the same between all cards.
I would make the amount of scripts you need for each card. they can even do identical things and you can keep your service data as is, if you like. but the scripts need to be different if you are referring to them in in this way as your entity.
Thanks Dimitri,
The only problem is, as far as I think itā€™s a problem, is that the script is needed to fill up a queue. With other words, more buttons can be pushed at the same time that fill the queue. Donā€™t know if ā€˜a script per buttonā€™ will result in the same.
Iā€™ll show you the script below:
jarvis_room_cleaner:
  alias: Jarvis Room Cleaner
  max: 20
  mode: queued
  fields:
    room:
      required: true
      selector:
        select:
          options:
          - bathroom
          - bedroom
          - hallway
          - kitchen
          - living_room
          - joosarne
          - bentjesse
          - berging
  - choose:
    - conditions:
      - condition: or
        conditions:
        - condition: state
          entity_id: vacuum.jarvis
          state: cleaning
        - condition: state
          state: error
      - wait_for_trigger:
        - platform: state
          to: returning
        - platform: state
          to: docked
        continue_on_timeout: false
        timeout: 01:30:00
      - service: vacuum.send_command
          device_id: xxxxxxxxxxxxxxxxxxx
        data_template:
          command: app_segment_clean
          params: >
           {% set room_id = states("input_number.roborock_room_enum_" + room)
            | int(0) %} {{ room_id }}
      - wait_for_trigger:
        - platform: state
          to: returning
        - platform: state
          to: docked
        timeout: 01:30:00
    - conditions:
      - condition: or
        conditions:
        - condition: state
          state: returning
        - condition: state
          state: docked
        - condition: state
          state: idle
          device_id: xxxxxxxxxxxxxxxxxxxx
        data_template:
          params: >
      - wait_for_trigger:
        - platform: state
          to: returning
        - platform: state
          to: docked
        timeout: 01:30:00
    default: []
Kr,
Bart
This may not be good advice, but a script can run a script. so again maybe make a script per button, but each just calls your main script?
sounds like plan ! Iā€™ll give it a try and report back with feedback
thx again !
still related to the same overlay card:
not a big deal but wondering if this is also customizable;
once a selection is made, the mushroom select card stays ā€œselectedā€ (greyed out) unless you click elsewhere.
Any way to hide / make this transparent as well? Thanks!
Animation
this should do it. but then your hover is also gone.
                .mdc-select__ripple::before {
you could add a new hover back like this:
                .mdc-select__anchor:hover {
                  background-color: rgba(var(--rgb-grey), 0.05) !important;
:+1: Perfect. Thank you!
Animation
Unfortunately, the HA-alerts do not work in the template-card:
e.g.
<ha-alert alert-type="error"> Your alert text </ha-alert>
Can I integrate them by other code or is it possible to integrate them?
Iā€™ve made a button-specific script to call the main script after push of the button, but all buttons are still activated, probably because of the fact that the script calls the same entity.
jarvis_bathroom:
  alias: Jarvis Bathroom
  - service: script.jarvis_room_cleaner
      room: bathroom
And the script behind my bathroom button:
                    tap_action:
                      service: script.jarvis_bathroom
                    entity: script.jarvis_bathroom
type or paste code here
So, this doesnā€™t work and I canā€™t figure out why not
Kr,
Bart
Can you show me the yaml for the entire card please?
Spotify Card V3 with Room Presence
Page Properties:
  • White and Dark Theme Ready.
  • 2 different card styles for white and dark template in one single card!!
  • Design changes on white theme.
  • Switch between white and dark modes with one click
  • Beatiful artwork design for every song.
  • Room Presence. Start the music in your last entered room (More effective on single occupancy)
  • Media Player controls
  • Music Follow. Let the music follow you around the house automatically.
  • Hidden playlist. Activate your favorite songs with a single click.
  • Exclusively designed for Spotify control.
  • Ambilight animations. Glowing light in all over the card.
  • Browser Mode integration.
  • Minimalistic design. You can hide spotify playlist.
  • The playing media player is highlighted in a circle.
  • Rewind - Forward your music.
  • Developed on the basis of Amazon Echo devices but you can also use it with any other media player type.
  • Can easily be installed with the given manual
You can find the page code and ultra-detailed user manual in the link below.:
