Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
@rhysb spot on! Thanks again, you are a CSS ninja!
.ninja {
    color: black;
    visibility: hidden;
    animation-duration: 0.000001s;
How did you get the chips in line with Server vs under uptime as in Sparkydaves card above?
wow this is an active thread…
back with some more on the printer cartridges:
  - entity: sensor.epson_ink_level_black
    color: black
    <<: &card
      type: tile
      icon: mdi:water
      vertical: true
      tap_action:
        action: more-info
      card_mod:
        style:
          ha-tile-icon$: |
            .shape {
              background: radial-gradient(var(--card-background-color) 60%,
                          transparent calc(60% + 1px)),
                          conic-gradient(var(--tile-color) {{ states(config.entity)}}% 0%,
                          var(--card-background-color) 0% 100%);
#           ha-tile-info$: |
#             .secondary {
#               visibility: hidden;
#             .secondary:before {
#               visibility: visible;
#               content: "{{ states(config.entity)}}% 0%";
this fixed the numbers/% like @rhysb instructed.
As you can see I also commented the complete ha-tile-info$: | mod and tbh, I am puzzled what that would do in the first place, as it has no consequence. taking that out gives me a nice:
SchermĀ­afbeelding 2023-01-29 om 10.15.13
albeit still flickering, have to find what is causing that.
also, back to the color name: any thoughts why magenta wont work? In Mushroom that is.
using:
  - entity: sensor.epson_ink_level_magenta
    icon_color: magenta #pink
    <<: *card
result in:
Yeah, you can just ignore ha-tile-info stuff. I added it for completeness of the example. You can use it to replace/template the primary and secondary info if required.
Mushroom has it’s own color scheme, now added to HA, and doesn’t support other named colors. You can use hex or RGB colors like this:
type: custom:mushroom-entity-card
entity: switch.coffee_machine
icon_color: '#ff00ff'
or
icon_color: '255,0,255'
thanks for explaining! On both accounts.
on the colors: that makes it a bit less obvious really. Seems a system default like html color names would have to be supported by any card, core or custom.
what is the code above?
can you share it please
Thanks.
I think it was a design decision of Paul’s, wanting to have simple color selection in the UI.
Here you go:
type: custom:mushroom-template-card
primary: Status
secondary: >-
  {{states((entity)) | title }} • {{
  states('sensor.mfc_9340cdw_page_counter') }} p
icon: mdi:printer
entity: sensor.mfc_9340cdw_status
icon_color: '{{ ''disabled'' if is_state((entity), ''sleep'') else ''blue'' }}'
badge_icon: >-
  {{ 'mdi:clock-time-five-outline' if is_state((entity), 'sleep') else
  'mdi:file-document' if is_state((entity), 'printing') }}
tap_action:
  action: more-info
hold_action:
  action: none
double_tap_action:
  action: none
This is from UI Lovelace Minimalist no?
thank you…
Hi everyone?
How can I make the icon blink when the days are 0?
icon: mdi:cat
primary: Frontline
icon_color: orange
secondary: '{{ (states(entity) | as_datetime | as_local - now()).days + 1 }} Tag(e)'
hold_action:
  action: call-service
  service: script.frontline_reminder
  data: {}
  target: {}
entity: input_datetime.frontline_reminder
tap_action:
  action: more-info
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
        background: radial-gradient(var(--card-background-color) 60%, transparent calc(60% + 1px)), conic-gradient(rgb(var(--rgb-{{ config.icon_color }})) {{ ((states(config.entity) | as_datetime | as_local - now()).days + 1) / 30 * 100 }}% 0%, var(--card-background-color) 0% 100%);
      .shape:after {
        content: "";
        height: 100%;
        width: 100%;
        position: absolute;
        border-radius: 50%;
        background: rgba(var(--rgb-{{ config.icon_color }}), 0.2);
Hey @rhysb, sorry to bother you again mate. Hoping to seek your assistance again with another issue.
Might it be possible to integrate the dropdown from the select card into the template card, so that the templating for the icon, badges and text can be preserved?
EDIT:
Sorry! Ignore me, solved it:
type: custom:stack-in-card
mode: horizontal
cards:
    primary: Pet Flap
    secondary: >-
      {{ states(entity) }} • {{ state_attr('sensor.pet_flap_battery_level',
      'battery_level') }} %
    icon: |-
      {% if is_state('input_select.pet_flap_lock', 'Unlocked') %}
        mdi:lock-open
      {% elif is_state('input_select.pet_flap_lock', 'Locked') %}
        mdi:lock
      {% elif is_state('input_select.pet_flap_lock', 'Locked Out') %}
        mdi:home-export-outline
      {% elif is_state('input_select.pet_flap_lock', 'Locked In') %}
        mdi:home-import-outline
      {% endif %}
    entity: input_select.pet_flap_lock
    tap_action:
      action: more-info
    hold_action:
      action: none
    double_tap_action:
      action: none
    icon_color: |-
        green
        red
        orange
        yellow
      {% endif %}
    badge_icon: ''
  - type: custom:mushroom-select-card
    primary_info: none
    secondary_info: none
    icon: None
    layout: horizontal
    tap_action:
      action: none
    hold_action:
      action: none
    double_tap_action:
      action: none
    card_mod:
      style: |
        mushroom-shape-icon {
          display: none
card_mod:
  style: |
    ha-card {
      overflow: visible !important;
Hi
About is_state and attribute for an entity.
If looking at an entity state you can use:
{% if is_state(config.entity, 'on') %}
But what if it’s the attribute for an entity I need to look at, what do I write?
{% if is_state(media_player.bluesound_mini.attributes.media_title, 'P4 Midt og vest') %}
Or, it’s not working as I hoped…
Can you share your group section pls? Thx!
{{ if state_attr('vacuum.james', 'fan_speed') == ā€˜something’ }}
To get state attribute you write that :slight_smile:
Working, THX.
{% if state_attr('media_player.bluesound_mini', 'media_title') == 'P4 Midt og vest' %}
Ah, I have no idea! They’re very visually similar so very possible! If so… does anyone have this replicated in mushroom? Perhaps it’s not possible in mushroom?
That’s a Minimalist UI card. Not sure someone have hacked it into Mushroom.
https://ui-lovelace-minimalist.github.io/UI/usage/custom_cards/custom_card_esh_room/
Horizontal view.
atm. I have these 4 radio buttons, and it’s working.
Then one selected have color and is playing.
What I want now, is to add a background image to the player, if I have selected ā€œskalaā€ radio like now.
And how can I align the 4 buttons horizontal and not vertical like now?
square: false
columns: 1
type: grid
cards:
  - type: custom:mini-media-player
    entity: media_player.bluesound_mini
    artwork: full-cover
  - type: custom:text-divider-row
    text: Spotify Musik
    primary: Dansk
    secondary: ''
    icon: ''
    fill_container: false
    multiline_secondary: false
    tap_action:
      service: spotcast.start
        spotify_device_id: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
        uri: spotify:playlist:3QE1nbYEMEyF0wWCAwQzmC
        random_song: true
        shuffle: true
      target: {}
    text: Radio
    primary: ''
    secondary: ''
    icon: ''
    layout: vertical
    picture: /local/image/radio/p4.png
    tap_action:
      service: script.start_spotify_playlist1
      data: {}
      target: {}
    entity: script.start_spotify_playlist1
    card_mod:
      style: |
        :host {
          {% else %}
            filter: grayscale(100%);
          {% endif %}
          background-size: cover;
          background-blend-mode: overlay;
          background-color: rgba(var(--rgb-card-background-color), 0.8);
          --mush-icon-size: 50px;
    primary: ''
    secondary: ''
    icon: ''
    layout: vertical
    picture: /local/image/radio/nova.jpg
    tap_action:
      service: script.start_spotify_playlist2
      data: {}
      target: {}
    entity: script.start_spotify_playlist2
    card_mod:
      style: |
        :host {
          {% if state_attr('media_player.bluesound_mini', 'media_title') == 'nova' %}
          {% else %}
          {% endif %}
    primary: ''
    secondary: ''
    icon: ''
    layout: vertical
    picture: /local/image/radio/skala.jpg
    tap_action:
      service: script.start_spotify_playlist3
      data: {}
      target: {}
    entity: script.start_spotify_playlist3
    card_mod:
      style: |
        :host {
          {% if state_attr('media_player.bluesound_mini', 'media_title') == 'skala.fm' %}
          {% else %}
          {% endif %}
    primary: ''
    secondary: ''
    icon: ''
    layout: vertical
    picture: /local/image/radio/voice.jpg
    tap_action:
      service: script.start_spotify_playlist4
      data: {}
      target: {}
    entity: script.start_spotify_playlist4
    card_mod:
      style: |
        :host {
          {% if state_attr('media_player.bluesound_mini', 'media_title') == 'the voice' %}
          {% else %}
          {% endif %}
Ah you’re right, sadly :frowning: I’ve had a go myself but my CSS skills aren’t the best with this card stuff so the spacing between ā€œKitchenā€ and icons is too much and I’ll need to find out how to make the light icon a bit wider. I’ll keep trying!
