Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
im verry new to HA and HACS, i wonder if its possebole to make some ligth card, but maybe 14 entity
Thanks a lot
It works fine
Try columns: 4
@alexandrechoske by Group section I assume you mean the Light Groups?
I use old-style (not helper-created) groups. This is because of one key factor, I want the state to be “on” only when “all” lights are on. Note, I had set these up long ago and used the actual entity names from my Insteon devices, you can also use the friendlier names like light.kitchen_cans. So in a YAML import, I have the following:
# LEDs
ledlights:
    entities:
      - switch.switchlinc_relay_dual_band_1f_a8_e0
      - switch.switchlinc_relay_dual_band_1f_a8_f1
      - switch.on_off_outlet_58_13_d8_bottom
    all: true
# Master
masterlights:
    entities:
      - light.switchlinc_dimmer_49_af_14
      - light.switchlinc_dimmer_2b_e4_c5
    all: true
# Front
frontlights:
    entities:
      - switch.keypadlinc_on_off_1f_13_c1_main
      - switch.switchlinc_relay_dual_band_1f_c0_46
      - light.in_linelinc_dimmer_4a_ab_70
      - switch.switchlinc_relay_dual_band_1f_b0_1c
    all: true
# Kitchen
kitchenlights:
    icon: mdi:pot-steam
    entities:
      - light.switchlinc_dimmer_1e_3f_70
      - light.switchlinc_dimmer_1e_40_f6
    all: true
# Couch
couchlights:
    icon: mdi:sofa
    entities:
      - group.kitchenlights
      - light.switchlinc_dimmer_1e_40_66
      - light.switchlinc_dimmer_1e_40_d7
    all: true
# Pergola
pergolalights:
    icon: 'mdi:home-variant'
    entities:
      - switch.switchlinc_relay_dual_band_1f_ae_0d
      - switch.switchlinc_relay_dual_band_1f_ad_f7
    all: true
# Dogs
doglights:
    icon: mdi:dog
    entities:
      - switch.keypadlinc_on_off_1f_15_0a_main
#      - light.in_linelinc_dimmer_4a_ad_d3
    all: true
# Dining
dininglights:
    icon: 'mdi:silverware'
    entities:
      - light.switchlinc_dimmer_1e_3f_72
      - light.switchlinc_dimmer_1e_3e_4a
      - light.switchlinc_dimmer_1e_40_26
      - light.keypadlinc_dimmer_1c_df_46_main
      - light.switchlinc_dimmer_1e_40_88
    all: true
# Backyard
backyardlights:
    icon: 'mdi:tree'
    entities:
      - group.pergolalights
      - switch.keypadlinc_on_off_1f_14_f6_main
    all: true
# Foyer
foyerlights:
    icon: mdi:home-lightbulb
    entities:
      - switch.switchlinc_relay_dual_band_1f_ae_13
      - light.switchlinc_dimmer_1e_3e_07
      - light.switchlinc_dimmer_1e_3e_f3
      - light.switchlinc_dimmer_1e_41_93
      - light.switchlinc_dimmer_1e_3e_c0
      - light.switchlinc_dimmer_1e_3e_dc
      - light.switchlinc_dimmer_1e_3f_e2
    all: true
# Art
artlights:
    icon: phu:double-spot
    entities:
    all: true
# ArriveHome
arrivehomelights:
    icon: mdi:car
    entities:
      - group.foyerlights
      - group.frontlights
    all: true
# Panic
paniclights:
    icon: mdi:run-fast
    entities:
      - group.foyerlights
      - group.frontlights
      - group.backyardlights
      - group.masterlights
    all: true
The key here is all: true so that the state is set to ‘on’ only when all the entities in the group are on. The other key is that old-style groups support groups inside other groups, which if you have super groups (like arrivehomelights) you can add other groups to that group.
Then the card uses custom:stack-in (only because I like the look of no borders). The action is toggle and toggling a group will turn them all on (or off if they are on).
type: custom:stack-in-card
mode: vertical
title: Light Groups
cards:
  - type: horizontal-stack
    cards:
      - type: custom:mushroom-entity-card
        entity: group.doglights
        tap_action:
          action: toggle
        hold_action:
          action: none
        double_tap_action:
          action: none
        entity: group.couchlights
        tap_action:
          action: toggle
        hold_action:
          action: none
        double_tap_action:
          action: none
        entity: group.kitchenlights
        tap_action:
          action: toggle
        hold_action:
          action: none
        double_tap_action:
          action: none
    cards:
        entity: group.dininglights
        tap_action:
          action: toggle
        hold_action:
          action: none
        double_tap_action:
          action: none
        entity: group.backyardlights
        tap_action:
          action: toggle
        hold_action:
          action: none
        double_tap_action:
          action: none
        entity: group.pergolalights
        tap_action:
          action: toggle
        hold_action:
          action: none
        double_tap_action:
          action: none
    cards:
        entity: group.ledlights
        tap_action:
          action: toggle
        hold_action:
          action: none
        double_tap_action:
          action: none
        entity: group.masterlights
        tap_action:
          action: toggle
        hold_action:
          action: none
        double_tap_action:
          action: none
        entity: group.frontlights
        tap_action:
          action: toggle
        hold_action:
          action: none
        double_tap_action:
          action: none
    cards:
        entity: group.artlights
        tap_action:
          action: toggle
        hold_action:
          action: none
        double_tap_action:
          action: none
        entity: group.foyerlights
        tap_action:
          action: toggle
        hold_action:
          action: none
        double_tap_action:
          action: none
        entity: group.arrivehomelights
        tap_action:
          action: toggle
        hold_action:
          action: none
        double_tap_action:
          action: none
    cards:
        entity: group.paniclights
        tap_action:
          action: toggle
        hold_action:
          action: none
        double_tap_action:
          action: none
As you can see here, I merely clicked “Dogs” and it toggled the group.doglights to on. This group includes all the parts of group.pergolalights so it is shown as “on” too.
It’s about “Not being able to see the wood for the trees”…
Thx. didn’t think logically there for a second…
It seems to be fixed now. Capitalisation and underscore to space conversion in chips is back. No need to use mapper for now.
Interesting the all true situation, I didnt know about that, make sense.
This is one thing that bothered me on HA with groups hahaha, when 1 light is on the group say is on :smiley:
Thanks for the instructions =)
I am “copying” your lights layout with some adjustments.
Numbers of lights on the right of the room name, and also I am pretending to insert the energy consumption as well.
Something like this? Can be further customized to look more like from the minimalist screenshot, of course. Using vertical-stack-in-card now, but could be stack-in-card as well.
square: false
columns: 2
type: grid
cards:
  - type: custom:vertical-stack-in-card
    cards:
        cards:
            primary: ''
            secondary: ''
            icon: mdi:sofa
            icon_color: red
          - type: custom:mushroom-chips-card
            chips:
              - type: template
                entity: light.local_tuya_light_2
                icon: mdi:lightbulb
                icon_color: |-
                  {% if states(entity) == 'on' %}
                  amber
                  {% else %}
                  disabled
                  {% endif %}
                tap_action:
                  action: toggle
            alignment: center
            card_mod:
              style: |
                ha-card {
                  margin: 12px 24px 0px 0px;
                  --chip-background:
                    {% if states('light.local_tuya_light_2') == 'on' %}
                    rgba(var(--mush-rgb-amber), 0.2);
                    {% else %}
                    rgba(var(--mush-rgb-disabled), 0.15);
                    {% endif %}
                  --chip-box-shadow: none;
                  --chip-border-radius: 12px;
                  --chip-height: 42px;
                  --chip-padding: 32px;
        icon: ''
        icon_color: ''
        primary: Living room
        secondary: 20 °C
        layout: horizontal
        fill_container: false
    cards:
        cards:
            primary: ''
            secondary: ''
            icon: mdi:silverware-fork-knife
            icon_color: blue
            chips:
              - type: template
                entity: light.local_tuya_light_3
                icon: mdi:lightbulb
                icon_color: |-
                  amber
                  {% else %}
                  disabled
                  {% endif %}
                tap_action:
                  action: toggle
            alignment: center
            card_mod:
              style: |
                ha-card {
                  --chip-background:
                    {% if states('light.local_tuya_light_3') == 'on' %}
                    {% else %}
                    {% endif %}
        icon: ''
        icon_color: ''
        primary: Kitchen
        secondary: 19 °C
        layout: horizontal
Hi
Atm I have this button
Screenshot 2023-01-29 201558
But I want something like this
Screenshot 2023-01-29 201612
Atm. my code is like this, but how can I get the full filled box, with the image?
type: custom:mushroom-template-card
primary: ''
secondary: ''
icon: ''
layout: vertical
fill_container: true
multiline_secondary: false
picture: /local/image/radio/p4.png
tap_action:
  action: call-service
  service: script.start_spotify_playlist1
  data: {}
  target: {}
entity: script.start_spotify_playlist1
card_mod:
  style: |
   :host {
      {% if state_attr('media_player.bluesound_mini', 'media_title') == 'P4 Midt og vest' %}
      {% else %}
        filter: grayscale(100%);
      {% endif %}
      padding: 0px 0px 0px 0px !important;
      background-blend-mode: overlay;
      --mush-icon-size: 50px;
      height: 70px;
      width: 70px;
Exactly that, thank you! Very similar to the code I had thankfully but looks like you’re using a chips card for the light instead of the light card. Might explain why you’re able to do the styling on it to change the width with styling as I’ve had no luck!
Although even with card-mod installed as I use it elsewhere, for some reason I’m not getting the styling around the light button like in your example… Caches cleaned on both phone and laptop - also tried with rarely used Safari.
What styling doesn’t work, the width/padding or background?
Oddly… the rgba lines… Changing them to something like grey works… but doesn’t look great.
Edit: Removing mush was the answer!
Change your container card from vertical-stack to stack-in-card, and then give the vertical-stack with the mushroom cards and that apex chart card transparent backgrounds.
I use picture entity to get them to be ‘filled’
type: picture
image: local/radio/p1.jpg
hold_action:
  action: none
tap_action:
  service: input_select.select_option
  service_data:
    option: P1
    entity_id: input_select.radiokanal
those are simply binary_sensor entities
In a Template card is it possible somehow check if any light is ON in a room? I’d like to make a Template card where the badge icon color changes if any of a light in the room is ON, not a specific light entity.
Thanks @Mariusthvdb, I’ll look at that :+1:
I use a group of lights, you can use that even in an entity card.
If the group is on, at least one light is on, group off, all the lights are off
I use this solution too, but it is just a workaround. When there is a new entity in any room, I have to add this manually to the group. Even wore that the current Helper solution for groups is partially useless.
So still looking for a solution to be able to check if any of the light entities are on in a room.
you can modify this, where “entity” is just some random entity in that area
{{ 'amber' if expand(area_entities(area_id(entity))) | selectattr('domain','eq','light') | selectattr('state','eq','on') | list | count > 0 else 'disabled' }}
edit: I went away from this approach since it made my landingpage take 2-3 seconds to load (I had 12 ‘rooms’ where they all had 4-5 templates going through all entities on that area and displaying various info)
Double-edit: if you’re curious:
icon: hue:room-office
entity: sensor.kontoret_multi_temperatur
primary: '{{area_name(entity) | capitalize}}'
secondary: >-
  {% set hum = (area_entities(area_id(entity)) | select('is_state_attr',
  'device_class', 'humidity') | map('states') | select('is_number') |
  map('float') | list or [0]) | average %}
  {% set temp = (area_entities(area_id(entity)) | select('is_state_attr',
  'device_class', 'temperature') | map('states') | select('is_number') |
  map('float') | list or [0]) | average | round(1) %}
  {{ [ (temp|int ~ '°C') if temp, (hum | int ~ '%') if hum] | select() | join('
multiline_secondary: true
icon_color: >-
tap_action:
  action: navigate
  navigation_path: /lovelace-rom/kontoret
hold_action:
  service: light.turn_off
  data: {}
    area_id: kontor
double_tap_action:
  action: none
badge_color: blue
badge_icon: >
  {{'mdi:motion-sensor' if 'on' in (area_entities(area_id(entity)) |
  select('is_state_attr', 'device_class', 'motion') | map('states') | list) }}
