Perfect solution! Works like a charm. Thanks a lot!
Can you help me here?
I want use a lot of fold cards and it will be insane create all the boleans to use that system⦠i have this code that works⦠only issue⦠the chevron is ugly and i canāt add the animation you added
This is with your mushroom style and with transition
This is with fold code without boolean and without transition
type: custom:stack-in-card
cards:
- type: custom:fold-entity-row
head:
label: padding
type: custom:mushroom-entity-card
entity: sensor.passadeira_power
primary_info: name
secondary_info: state
layout: horizontal
icon: mdi:dumbbell
icon_color: light-green
multiline_secondary: true
card_mod:
style: |
ha-card {
margin-left: 0px;
border: none;
--ha-card-box-shadow: 0px;
padding: 0
entities:
- type: custom:stack-in-card
cards:
- type: custom:mini-graph-card
entities:
- entity: sensor.passadeira_power
line_color: deep-orange
hours_to_show: 24
points_per_hour: 4
line_width: 1
font_size: 50
animate: true
show:
icon: false
state: false
legend: true
fill: fade
card_mod:
style: |
ha-card {
background: none;
border: none;
card_mod:
style: |
ha-card {
background: none;
border: none;
Is there a way to allow the text to fill right across, it should ready āGood Afternoon, Stuart!ā
cards:
- square: false
columns: 2
type: grid
cards:
primary: |-
{% set time = now().hour %}
{% if (time >= 18) %}
Good Evening, {{user}}!
{% elif (time >= 12) %}
Good Afternoon, {{user}}!
{% elif (time >= 5) %}
Good Morning, {{user}}!
{% else %}
Hello, {{user}}!
{% endif %}
secondary: ''
fill_container: true
tap_action:
action: toggle
entity: input_boolean.mushroom_menu_down
- type: custom:mushroom-chips-card
chips:
- type: template
icon: |-
{% if is_state("input_boolean.mushroom_menu_down", 'off') %}
mdi:chevron-down
{% elif is_state("input_boolean.mushroom_menu_down", 'on') %}
mdi:chevron-up
{% endif %}
tap_action:
action: toggle
alignment: end
style: |
ha-card {
--chip-box-shadow: none;
--chip-background: none;
padding: 10px 10px;
Tried markdown card?
Most likely not the most clean solution. Using margin-top, see below
style: |
ha-card {
--chip-height: 50px;
--chip-border-width: 0;
--chip-padding: 4 1.5em;
margin-top: -65px;
chips:
- type: template
entity: sensor.processor_temperature
@Haningback
Thx. alot⦠looks nice and itās working so the active radio station is in color, so itās easy to see the channel playing. ![]()
So much nicer and makes the card so much slimmer. Thank you!!!
Use layout-card instead of Grid, like this:
- type: custom:layout-card
layout_type: custom:grid-layout
layout:
grid-template-columns: auto 33px
margin: '-4px -4px -8px -4px;'
cards:
How can i use the chip card (light group) with browser mod 2 to show the devices that are on? (ā> Pop-Up)
Have a look here:
Hey @rhysb ⦠you seem to be the resident expert for getting things coded perfectly ⦠could you tell me where Iāve messed this up? I started with someone elses code, and I think the template is set up right butā¦
chips:
- type: template
content: >-
{{ state_attr('back_basement_2','message')}} in
{{ ((state_attr('calendar.back_basement_2', 'end_time') | as_datetime | as_local - now()).total_seconds() / 60) | int }} minutes.
style: |
ha-card {
--ha-card-border-width: 0;
--chip-height: 75px;
--chip-padding:12px;
--chip-box-shadow:none;
--chip-border-width:0;
border-width: 0;
The intent is to display a āchipā card that displays the next event in a calender and how many minutes it is from occuring.
Itāll be the last (far right) element on the bottom line of this display:
Thanks for any thoughts you (or anyone else) might be able to offer!
You can style the fold-entity-row like this:
cards:
head:
primary_info: name
layout: horizontal
icon: mdi:dumbbell
card_mod:
style: |
ha-card {
--ha-card-box-shadow: 0;
padding: 0
entities:
entities:
hours_to_show: 24
points_per_hour: 4
line_width: 1
font_size: 50
animate: true
show:
icon: false
state: false
legend: true
fill: fade
card_mod:
style: |
ha-card {
card_mod:
style:
hui-vertical-stack-card$:
fold-entity-row$: |
ha-icon {
background: none !important;
margin-right: 24px !important;
--toggle-icon-width: 21px !important;
color: rgb(var(--rgb-disabled-color));
Just be aware of Thomasā warning that it is intended to be used with an Entities Card āAny usage outside an entities card is entirely unsupportedā.
You can animate the fan on/off like this.
Mushroom Fan On/Off Animation:
type: custom:mushroom-fan-card
entity: fan.garage_fan
card_mod:
style:
mushroom-shape-icon$: |
ha-icon {
{{ '--icon-animation: spin 1.5s ease-in, spin 1s linear 1.5s infinite;' if is_state(config.entity, 'on') }}
mushroom-shape-icon {
display: flex;
{{ 'animation: spin 1.5s ease-out;' if is_state(config.entity, 'off') }}
Brilliant, thanks a lot!
Looks like you are missing calendar. in you first state_attr and some bad indentation.
chips:
- type: template
content: >-
{{ state_attr('calendar.back_basement_2','message')}} in {{
card_mod:
style: |
ha-card {
border-width: 0;
Thanks @rhysb as always, but wonāt this cause the animation to ease-out on page loads?
Yep, will think about a better solution⦠
The calendar was a good catch, but it (and the rest of the fixes you mentioned) didnāt seem to solve it.
Hereās an image of it as part of the bigger pile of code:
I think our code is basically identical, unless Iām missing something?
- type: template
content: >-
{{ state_attr('calendar.back_basement_2','message')}} in {{ ((state_attr('calendar.back_basement_2','end_time') | as_datetime | as_local - now()).total_seconds() / 60) | int }} minutes.
style: |
ha-card {
border-width: 0;
Is the format of my template otherwise incorrect? That SHOULD be showing Laundry in 6564 minutes.
Kinda feeling like the village idiot at the moment.
Okay, so it just doesnāt like me then?
Is the bit after content: correct? the >-?
Otherwise, any other ideas what might be causing this to go into the neverending clock and not let me save it?
