Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Really love these cards. Did someone manage to get multiple entities in the same card like the default ha entities card?
Would be great for me to have something like this.
Thanks in advance
This is how I made a title with chips
With Subtitle
No Subtitle
type: custom:layout-card
layout_type: custom:grid-layout
layout:
  grid-template-columns: auto 1fr
  grid-template-areas: |
    "title chips"
    "subtitle subtitle"
  margin: '-4px 0 -4px 0'
cards:
  - type: custom:mushroom-title-card
    title: Title
    view_layout:
      grid-area: title
    subtitle: Subtitle
    view_layout:
      grid-area: subtitle
    card_mod:
      style:
          h2 {
            transition: all 0s;
            padding: 0 16px 12px;
          .header {
            transition: all 0s;
            --title-padding: 0;
  - type: custom:mushroom-chips-card
    view_layout:
      grid-area: chips
    alignment: end
    card_mod:
      style: |
        ha-card {
          transition: all 0s;
          transform: translateY(30%);
    chips: []
I split the title and subtitle so the subtitle can be longer than the title space. You can adjust translateY to move the chips up and down if needed.
Still having massive trouble with this.
Let’s go on steps:
The mushroom-template-chip:nth-child(1)$: | works, 2 and 3 don’t. Just the first one.
If I use template instead of “condition” it works, but it creates invisible icons disaligning everything.
type: custom:stack-in-card
cards:
    entity: input_boolean.room_kitchen
    primary: Cozinha
    secondary: >-
      {{ states('sensor.temp_kitchen') | round(1) }}°C | {{
      states('sensor.humd_kitchen') | round(0) }}%
    icon: mdi:fridge-outline
    icon_color: blue
    fill_container: true
    layout: horizontal
    multiline_secondary: false
    tap_action:
      action: navigate
      navigation_path: cozinha
    hold_action:
      action: call-service
      service: light.turn_off
        transition: 3
        area_id: kitchen
    double_tap_action:
      action: toggle
    card_mod:
      style: |
        :host([dark-mode]) {
          background: rgba(var(--rgb-primary-background-color), 0.2);
        :host {
          background: rgba(var(--rgb-primary-text-color), 0.025);
          --mush-icon-size: 80px;
          height: 65px;
          margin-left: -18px !important;
    chips:
      - type: conditional
        conditions:
          - entity: input_boolean.vacuum_kitchen
            state: 'on'
        chip:
          type: template
          icon: |-
            {% if states('input_boolean.vacuum_kitchen') == 'on' %}
            mdi:robot-vacuum
            {% elif states('input_boolean.vacuum_kitchen') == 'on' and
            states('vacuum.robot_cleaner') == 'returning' %}
            mdi:robot-vacuum
            {% endif %}
          icon_color: |-
            {% if states('input_boolean.vacuum_kitchen') == 'on' and
            states('vacuum.robot_cleaner') == 'cleaning' %}
            pink
            disabled
            {% endif %}
          tap_action:
            action: none
          hold_action:
            action: none
          content_info: none
      - type: conditional
        conditions:
            state: 'on'
        chip:
          type: template
          icon: |-
            mdi:robot-vacuum
            mdi:robot-vacuum
            {% endif %}
          icon_color: |-
            pink
            disabled
            {% endif %}
          tap_action:
            action: none
          hold_action:
            action: none
          content_info: none
      - type: conditional
        conditions:
            state: 'on'
        chip:
          type: template
          icon: >-
            mdi:robot-vacuum
            mdi:robot-vacuum
            {% endif %}
          icon_color: >-
            pink
            disabled
            {% endif %}
          tap_action:
            action: none
          hold_action:
            action: none
          content_info: none
    alignment: end
    card_mod:
      style:
        mushroom-template-chip:nth-child(2)$: |
          ha-icon {
            animation: spin 6s ease 1.5s infinite;
          @keyframes spin {
            100% { transform: rotate(360deg); }
          ha-icon {
          @keyframes spin {
        mushroom-template-chip:nth-child(3)$: |
          ha-icon {
            animation: shake 400ms ease-in-out infinite, drum 1s infinite;
            transform-origin: 50% 65%;
          @keyframes shake {
            0%, 100% { transform: rotate(4deg); }
            50%  { transform: rotate(-4deg); }
          @keyframes drum {
            50%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 36% 74%, 31% 43%, 61% 40%, 71% 69%, 62% 78%, 36% 73%, 35% 100%, 100% 100%, 100% 0); }
          ha-card {
            --chip-box-shadow: none;
            --chip-background: none;
            --chip-spacing: 0;
            margin-right: 6px;
card_mod:
  style: |
    ha-card {
      height: 100px;
      {% if is_state('light.lightstrip_kitchen_light', 'on') %}
         background: rgba({{ (state_attr('light.lightstrip_kitchen_light', 'rgb_color') | join(',')) }},0.1)
      {% elif is_state('light.candeeiro_cozinha', 'on') %}
         background: rgba(245, 192, 47, 0.1);
      {% endif %}
Captura de ecrĂŁ 2023-04-23 224211
and on top of that, I can’t make the icon follow the RBG still (as I asked on the previous post: Mushroom Cards - Build a beautiful dashboard easily 🍄 - #6647 by MARTWIN)
Thanks. My config looks like this:
type: vertical-stack
cards:
  - type: custom:layout-card
    cards:
        title: Salon
        chips:
          - type: entity
            entity: sensor.temperature_salon
            icon_color: amber
          - type: entity
            entity: sensor.humidity_salon
            icon_color: light-blue
          - type: entity
            entity: sensor.co2_salon
            icon_color: green
        alignment: end
        card_mod:
          style: |
            div.chip-container.align-end {
              margin-top: 19px
    layout:
      grid-template-columns: auto 70%
      margin: '-4px'
and this is a result:
obraz
FOR THE ICON:
icon_color: |
        {% if is_state(entity, 'on') %}
        {{ '#%02x%02x%02x' % state_attr(entity, 'rgb_color') }}
        {% endif %}
FOR ANIMATION:
mushroom-conditional-chip:nth-child(3):
            mushroom-template-chip$: |
                        ha-icon {
                          {{ 'animation: shake 400ms ease-in-out infinite;' if is_state('binary_sensor.input_asciugatrice', 'on') }}
                          transform-origin: 50% 58%;
                          clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0);
                        @keyframes shake {
                          0%, 100% { transform: translate(0, 0) rotate(0); }
                          20%  { transform: translate(0.4px, -0.4px) rotate(-4deg); }
                          40%  { transform: translate(-0.4px, 0.4px) rotate(4deg); }
                          60%  { transform: translate(0.4px, 0.4px) rotate(-4deg); }
                          80%  { transform: translate(-0.4px, -0.4px) rotate(4deg); }
Okay, I think the animations are working. Had to slightly change your code from {{ 'animation: to just animation: and it works.
For the lightstrip, no success yet. It’s showing this way.
Screenshot 2023-04-24 101654
I’m also posting the states the lightstrip gives. Sometimes it isn’t on RBG but on Brightness. But still, both modes still break. The gray part works.
cards:
    primary: Cozinha
    secondary: >-
    icon_color: >
      {{ iif(is_state('light.lightstrip_kitchen_light','on'), "'#%02x%02x%02x' %
      state_attr('light.lightstrip_kitchen_light','rgb_color')", 'grey') }}
    layout: horizontal
    tap_action:
      action: navigate
    hold_action:
        transition: 3
        area_id: kitchen
    double_tap_action:
      action: toggle
    card_mod:
      style: |
        :host {
          height: 65px;
    chips:
      - type: conditional
        conditions:
            state: 'on'
        chip:
          type: template
          icon: |-
            mdi:robot-vacuum
            mdi:robot-vacuum
            {% endif %}
          icon_color: |-
            pink
            disabled
            {% endif %}
          tap_action:
            action: none
          hold_action:
            action: none
          content_info: none
      - type: conditional
        conditions:
            state: 'on'
        chip:
          type: template
          icon: |-
            mdi:robot-vacuum
            mdi:robot-vacuum
            {% endif %}
          icon_color: |-
            pink
            disabled
            {% endif %}
          tap_action:
            action: none
          hold_action:
            action: none
          content_info: none
      - type: conditional
        conditions:
            state: 'on'
        chip:
          type: template
          icon: >-
            mdi:robot-vacuum
            {% elif states('input_boolean.test_martwin') == 'on' and
            states('input_boolean.room_bedroom') == 'on' %}
            mdi:robot-vacuum
            {% endif %}
          icon_color: >-
            pink
            disabled
            {% endif %}
          tap_action:
            action: none
          hold_action:
            action: none
          content_info: none
    alignment: end
    card_mod:
      style:
        mushroom-conditional-chip:nth-child(1):
            ha-icon {
            @keyframes shake {
            @keyframes drum {
        mushroom-conditional-chip:nth-child(2):
            ha-icon {
            @keyframes shake {
            ha-icon {
            @keyframes shake {
card_mod:
  style: |
    ha-card {
      height: 100px;
      {% endif %}
@edit
Okay, I figured this works:
      {{ '#%02x%02x%02x' % state_attr('light.lightstrip_kitchen_light',
      'rgb_color') if states('light.lightstrip_kitchen_light') == 'on' else
      'disabled' }}
But if the color isn’t really RGB, and is doing a “brightness” only color, it still shows the “broken black”.
Can you help me fixing that?
I don’t know which state I should look for tho, would brightness work?
Or even, show a SOLID COLOR, if the lightstrip isn’t on rgb_mode, is that possible?
Imgur: The magic of the Internet - for help with states / understanding what I mean
Hi lads,
My shutters provided trough my local domotics provider doesn’t support ‘stop / pause’ function
(i can use the slider to set it to percentage X or Y but i only use that as a secondary control)
my primary control look like this:
is there a way to completly hide the pause / stop button and keep the other 2?
you have spacing before sunny but not before cloudy or partlycloudy, maybe that’s it
Found it!!! :grinning: and it works!
the conditional chip has to parts. The first part is the condition like shown in your screenshot. Thesecond part ist the part where you define the chip that should be shown if your condition ist met.
Part I
Part II
So even if you like to display the entity of your condition you has to define that in the chips part.
I’m pulling my hair out so hoping someone can save me from myself.
I have put several hours over a few attempts at this. There’s several people talking about it, but I just want to enlarge the size of the chips to be about double the size.
I haven’t used card-mod much, but I tried that and no luck. I also straight edited the mushroom.js file to edit the " --chip-height: var(–mush-chip-height, 36px);" line to read " --chip-height: var(–mush-chip-height, 72px);" but every time i reload the page in Chrome, it is somehow showing 36px still. I’m checking in the developer tools and in it shows " --chip-height: var(–mush-chip-height, 36px);"
I have even restarted the entire HA OS a couple of times in my attempts. The actual js file still shows my edits.
WTH am I missing? It seems like people using the card-mod method are just adjusting that same parameter in the card yaml, but I actually don’t mind just making them all double to save effort on doing each one over and over.
I would be eternally grateful if someone can point me in the correct direction as to what I’m missing. Thanks.
EDIT: For anyone else searching (or me 3 weeks from now when I forget) I figured out the card_mod: method of doing it and will just truck forward with that. I realized that whenever I update the mushroom installation that it’s probably going to overwrite my file adjustments anyway so this is likely the better way to do it. My issue was that I wasn’t using the “–” designator.
This changes all the chips to be 60px high, when added to the yaml for the dashboard
    card_mod:
      style: |
        ha-card {
          --chip-height: 60px;
How do I change the color of Rhy’s person card, to tone them down a little.
If I modify these entries, nothing changes. I’m missing something…
 /* Define Person State colors. Can be added to theme */
                        --state-person-home: var(--green-color);
                        --state-person-not-home: var(--red-color);
                        --state-person-zone: var(--blue-color);
                        --state-person-unknown: var(--grey-color);
You can simply create another file, calling it “mushroom custom” where I customize the theme as you want. If, on the other hand, you modify the already installed theme, it will go back to the way it was before with each update.
So I would like to share my weather mushroom button card. A big thanks to @rhysb for putting up with my nagging questions and also for creating the beautiful animations which I used in this card. The card is not complete because I haven’t experienced all the weather conditions yet from my weather entities.
Basically, the animated icons change when the weather condition changes. When the card is clicked it navigates to my weather page.
type: custom:mushroom-template-card
icon: |-
  {% set state=states(entity) %}
  {% if state=='sunny' %}
  mdi:weather-sunny
  {% elif state== 'cloudy' %}
  mdi:weather-cloudy
  {% elif state== 'partlycloudy' %}
  mdi:weather-partly-cloudy
  {% elif state== 'rainy' %}
  mdi:weather-rainy
  {% elif state== 'clear-night' %}
  mdi:weather-night
  {% else %}
  mdi:weather-cloudy-alert
  {% endif %}
secondary: |
  Weather
icon_color: |-
  amber
  grey
  amber
  blue
  orange
  {% else %}
  black
  {% endif %}
primary: |2-
   {% set d ={
    'sunny': 'Sunny',
    'partlycloudy': 'Partly Cloudy',
    'cloudy': 'Cloudy',
    'clear-night': 'Clear Night',
    'rainy': 'Rainy',
    {{ d.get(states(entity)) }}
tap_action:
  action: navigate
  navigation_path: /lovelace/weather
hold_action:
  action: none
double_tap_action:
  action: none
multiline_secondary: true
entity: weather.tomorrow_io_sawa_home_hourly
card_mod:
  style:
    mushroom-shape-icon$: |
      ha-icon {
        {{ '--icon-animation: sunny 5s ease-in-out infinite alternate;' if is_state(config.entity, 'sunny') }}
      @keyframes sunny {
        70% { transform: rotate(360deg) scale(1); }
        80% { transform: scale(1); }
        90% { transform: scale(1.15); }
        100% { transform: scale(1); }
      ha-icon {
        {{ '--icon-animation: cloudy 10s ease-in-out infinite, sun 2s infinite;' if is_state(config.entity, 'partlycloudy') }}
      @keyframes cloudy {
        0%, 100% { transform: translateX(3px); }
        30% { transform: translateX(-1px); }
        45% { transform: translateX(1.5px); }
        75% { transform: translateX(-3.2px); }
      @keyframes sun {
        50% { clip-path: polygon(0 67%, 18% 55%, 16% 31%, 41% 12%, 67% 24%, 77% 59%, 100% 64%, 100% 100%, 0 100%); }
      ha-icon {
           {{ '--icon-animation: cloudy 10s ease-in-out infinite, rain 1.5s infinite;' if is_state(config.entity, 'rainy') }}
      @keyframes cloudy {
      @keyframes rain {
        50% { clip-path: polygon(0 0, 100% 0, 100% 73%, 71% 73%, 50% 39%, 29% 73%, 0 73%); }
      ha-icon {
        {{'--icon-animation: cloudy 10s ease-in-out infinite;' if is_state(config.entity, 'cloudy') }}
      @keyframes cloudy {
      ha-icon {
        {{'--icon-animation: moon 10s linear infinite, stars 5s linear infinite;' if is_state(config.entity, 'clear-night') }}
      @keyframes moon {
        0%, 100% { transform: rotate(12deg); }
        30% { transform: rotate(-6deg); }
        45% { transform: rotate(8deg); }
        75% { transform: rotate(-10deg); }
      @keyframes stars {
        0%, 3.1%, 14.1% { clip-path: inset(0 0 0 0); }
        3% { clip-path: polygon(1% 1%, 0% 99%, 99% 100%, 99% 62%, 68% 62%, 62% 44%, 76% 34%, 100% 34%, 99% 0%); }
        14% { clip-path: polygon(1% 1%, 0% 99%, 99% 100%, 100% 25%, 51% 45%, 38% 34%, 36% 0); }
However I do have a question and maybe someone can help. I wondering if I can display a value from a second entity as a secondary value? I have an outdoor sensor that gives me the real temperature at my home.
How could I add that if possible to my card to display as Secondary information?
Update:
So I was able to answer my own question and completed the secondary information with this code:
{{states('sensor.current_outdoor_temperature_bt1_30002') }}°C
is it possible to use the button cards notification badge with mushroom entity card? for example:
The following custom button card doesn’t show state of the entity when state is zero (0), but when I press the button, state can be some number (=>1), then it is shown on the badge. Also when it has a value i want to change the card’s background color.
but i tried to use these at mushroom entity card, i cant see any badge. (bathroom button has value of 2 in this case)
I could also just use custom button card, but I like the style of the icon. Does anybody know how can i make icon look like mushroom card? icon inside a circle?
I am trying to make a fan icon spin, but I am not having much luck.
Can someone check my code please.
   card_mod:
      style:
          ha-card {
           width: 66px;
           margin-left: 76%;
           top: -186px;
           background: none;
           --chip-border-width: 0;
           --icon-animation: rotation 1s linear infinite;
           @keyframes rotation {
             100% {
          :host {
           --mush-icon-size: 20px;
           --mush-chip-spacing: -2.9px
have a look here:
https://community.home-assistant.io/t/mushroom-cards-build-a-beautiful-dashboard-easily/388590/3240
@rhysb has created some amazing icon animations
I have a question regarding the state of scenes.
I have created two scenes, one is called “Evening Lights” and the other is called “Night Lights”
Both scenes have some common light entities.
This is the card for the evening scene.
type: custom:mushroom-entity-card
icon: mdi:lamps
tap_action:
  service: scene.turn_on
  data: {}
    entity_id: scene.evening_lights
hold_action:
  action: toggle
entity: light.evening_lights
icon_color: orange
fill_container: false
This is the card for the Night Lights Scene
entity: light.night_light
icon: ''
icon_color: deep-purple
tap_action:
  data: {}
    entity_id: scene.night_lights
hold_action:
  action: toggle
When i turn on the evening scene, the night scene icon and state show on and vice versa
Lights 1
Is there a way to only show the state of the active scene only? If evening lights are on then night scene is off and if night is on then evening scene is off?
Thanks in advance!
A quick way to do this is to change your light group options to only activate when All entities are on in the helper.
maybe it does rotate, but i guess you dont have to “blink” when it’s rotating 360deg in a split second :slight_smile:
your “solution” will be found among the 100+ working examples, by a simple search in the forum
