OMG THANK YOU!
I have been hunting and trying to figure this out for hours⌠And this was my second attempt at it.
I have been searching for âAnimate Mushroom Template Badgeâ and variations. hopefully this will help someone else find it.
Now - for the followup challenge. How do I get both animations of the main icon, and the badge into the same card? I donât understand the purpose of the pipe ("|") used in some of the examples. My main icon animation uses "style: " without the pipe. Instead it is after the âmushroom-shape-icon$:â line.
If I add the pipe to the example below, it breaks it. but without the pipe, the badge animation doesnât work. I would like to better understand the actual function of the pipe if thereâs a reference i can be pointed at. And if you have a quick fix for me to accommodate both animations, that would be helpful as well.
card_mod:
style:
mushroom-shape-icon$: |
ha-icon {
{% if( state_attr('climate.thermostat','hvac_action')=="heating") %}
{{ '--icon-animation: flame 3s linear infinite; transform-origin: 50% 50%;' }}
{% elif ( state_attr('climate.thermostat','hvac_action')=="cooling") %}
{{ '--icon-animation: aircon 3s linear infinite;' }}
{% endif %}
@keyframes flame {
0% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
5% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
10% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
15% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
20% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
25% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
30% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
35% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
40% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
45% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
50% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
55% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
60% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
65% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
70% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
75% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
80% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
85% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
90% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
95% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
100% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
@keyframes aircon {
0% { transform: rotate(0deg); }
50% { transform: rotate(180deg); }
UPDATE:
Figured it out (I think) by chasing down the pipe character some more. Iâm still not really sure what it does - but knowing that it was important enough to likely be related to the root of my problems, I also discovered " .: | " and started playing.
From how the HA GUI handles text coloring for syntax stuff, I realized that by using the pipe character you are sort of entering into a mode that doesnât apply the usual yaml filtering. I believe this is because it is treating everything as exact text, to be fed straight out to CSS (in this case). So I need a way to get out, to escape out, of this mode. indentation is the key. Moving below the indentation level of the | characterâs line got me back to normal looking yaml in the HA GUI. But I canât use âstyle:â a second time to open a new block to add my other animation/card-mod details.
Enter " .: "
I gather, from my very limited experience, this is sort of a indent level modifer (or at least Iâm using it that way) so I can add my other animations in, and push them one more indentation in. This way, I can still escape back to the original level and continue adding functionality.
I know, none of this makes a ton of sense to me either, but hopefully itâs the start of the journey towards actually understanding. Again, if anyone has a way to explain this to me, or documentation that covers it, please let me know.
Soooooo.
I created this. And it fracking works!
card_mod:
style:
mushroom-badge-icon {
{% if( state_attr('climate.thermostat','fan_action')=="running") %}
animation: spin 750ms linear infinite;
opacity: 60%;
{% endif %}
@keyframes spin {
100% { transform: rotate(360deg); }
ha-icon {
{% endif %}
@keyframes flame {
@keyframes aircon {
