Apologies @rhysb, where did I go wrong?
With template cards, is it possible to define a secondary action for tapping on the secondary info?
Should work better if you add the card_mod to the Chips instead of Chip:
card_mod:
style: |
mushroom-action-chip:nth-child(3):active {
background: rgba(var(--rgb-red), 0.5);
border-radius: var(--chip-border-radius);
transform: scale(1.2);
mushroom-action-chip:nth-child(4):active {
background: rgba(var(--rgb-green), 0.5);
I know your post about the air purifier card is over a year old, I have several of these in my home. I love the button card you used, but I needed four presets for one air purifier and wanted to add an off button. I got all of that sorted out and it works for controlling the air purifier, but the animation doesn’t work and I have a strange line in the card. Any ideas?
EDIT: It looks like setting the theme to either of the mushroom shadow or mushroom square shadow hides the line.
type: custom:stack-in-card
cards:
entity: fan.first_floor_air_purifier
icon: mdi:fan
primary: First Floor Air Purifier
secondary: |-
{% set fanspeed = state_attr(config.entity, 'percentage') %}
{% if is_state('fan.first_floor_air_purifier', 'off') %}
Off
{% elif is_state_attr(config.entity, "mode", "auto") %}
Auto
{% elif is_state_attr(config.entity, "mode", "sleep") %}
Sleep
{% elif fanspeed == 100 %}
Very High
{% elif fanspeed == 75 %}
High
{% elif fanspeed == 50 %}
Medium
{% elif fanspeed == 25 %}
Low
{% endif %}
icon_color: green
card_mod:
style:
mushroom-shape-icon$: |
@keyframes rotation {
0% {
transform: rotate(0deg);
100% {
transform: rotate(360deg);
ha-icon {
box-shadow: 0px 0px;
animation: rotation linear infinite !important;
{% set fanspeed = state_attr(config.entity, 'percentage') |float %}
{% if is_state_attr(config.entity, "mode", "auto") %}
animation-duration: 2s !important;
animation-duration: 6s !important;
animation-duration: 0.5s !important;
animation-duration: 1.5s !important;
animation-duration: 2.5s !important;
animation-duration: 3.5s !important;
{% else %}
animation-duration: ;
{% endif %}
- type: horizontal-stack
cards:
- type: custom:layout-card
layout_type: grid
cards:
layout: vertical
primary: 'Off'
tap_action:
action: call-service
service: fan.set_percentage
percentage: 0
entity_id: fan.first_floor_air_purifier
view_layout:
grid-area: button1
card_mod:
style: |
ha-card {
height: 44px !important;
box-shadow: none;
--card-primary-font-weight: normal;
layout: vertical
primary: Low
tap_action:
percentage: 25
view_layout:
grid-area: button2
card_mod:
style: |
ha-card {
box-shadow: none;
layout: vertical
primary: Medium
tap_action:
percentage: 50
view_layout:
grid-area: button3
card_mod:
style: |
ha-card {
box-shadow: none;
layout: vertical
primary: High
tap_action:
percentage: 75
view_layout:
grid-area: button4
card_mod:
style: |
ha-card {
box-shadow: none;
layout: vertical
primary: Very High
tap_action:
percentage: 100
view_layout:
grid-area: button5
card_mod:
style: |
ha-card {
box-shadow: none;
layout: vertical
icon: mdi:fan-auto
icon_color: white
tap_action:
service: fan.set_preset_mode
preset_mode: auto
double_tap_action:
preset_mode: sleep
view_layout:
grid-area: button6
card_mod:
style: |
ha-card {
box-shadow: none;
mushroom-shape-icon {
--shape-color: none !important;
--icon-symbol-size: 20px;
layout:
grid-template-columns: 14% 16% 21% 16% 23% 10%
grid-template-rows: auto
grid-template-areas: |
"button1 button2 button3 button4 button5 button6"
card_mod:
style: |
ha-card {
{% if is_state('fan.first_floor_air_purifier', 'on') %}
background: rgba(101,170,91,0.1);
{% endif %}
No worries, I an effort to condense my page I did actually switch to a tile card however it looks like using a variable in the animation logic is preventing the spin (not sure why). Replacing the fan speed variable seems to fix the issue. Let me know if you want the code for the full card or if this is ok
ha-icon {
{% elif state_attr(config.entity, 'percentage') == 100 %}
{% elif state_attr(config.entity, 'percentage') == 75 %}
{% elif state_attr(config.entity, 'percentage') == 50 %}
{% elif state_attr(config.entity, 'percentage') == 25 %}
{% else %}
{% endif %}
Thanks for the quick reply!!! I really appreciate it. That worked for everything, except for off. In the off state the animation still spins at what looks like the “Low” value. From the code it looks like it should stop, but I’m no expert by any means.
Ahh yea forgot to add an off condition
ha-icon {
{% if is_state(config.entity, "off") %}
{%- else -%}
{%- endif %}
Thank you! That works perfectly. You mentioned you switched to tile card, when you have a minute, would you mind showing what that looks like? Some of your older post of your Dashboards are really great. I’d love to see what this particular device looks like now.
No worries! Thanks haha and yea of course. I mainly wanted two devices on one row and the tile card is perfect fit except it’s missing the auto button (technically missing sleep as well but I never use it). Basically just added the auto button and styled to match the rest of my dashboard. It does use percent in the secondary but I don’t mind the percentage either.
Card code
type: custom:vertical-stack-in-card
cards:
- type: tile
entity: fan.andrews_air_purifier
color: green
features:
- type: fan-speed
card_mod:
style:
ha-tile-icon$: |
ha-svg-icon {
{% if is_state(config.entity,'off') %}
animation: ;
{% elif is_state_attr(config.entity,'percentage',33) %}
animation: rotate 1.2s linear infinite;
{% elif is_state_attr(config.entity,'percentage',66) %}
animation: rotate 0.7s linear infinite;
{% elif is_state_attr(config.entity,'percentage',100) %}
animation: rotate 0.5s linear infinite;
{% elif is_state_attr(config.entity,'mode','auto') %}
{% elif is_state_attr(config.entity,'mode','sleep') %}
animation: rotate 2s linear infinite;
{%- endif %}
@keyframes rotate {
100% { transform: rotate(360deg); }
ha-tile-info$: |
.secondary {
opacity: 80%;
ha-card {
--primary-text-color: var(--tile-color);
{% if is_state(config.entity, 'on') %}
{% endif %}
- type: custom:mushroom-chips-card
chips:
- type: template
icon_color: |-
{% if is_state_attr(config.entity, 'mode', 'manual') %}
disabled
{% elif is_state_attr(config.entity, 'mode', 'auto') %}
green
{% endif %}
icon: mdi:fan-auto
tap_action:
preset_mode: auto
entity_id: fan.andrews_air_purifier
card_mod:
style: |
ha-card {
--chip-background: rgba(var(--rgb-disabled), 0.15);
--chip-background: rgba(var(--rgb-green), 0.15);
{% endif %}
alignment: end
card_mod:
style: |
ha-card {
--ha-card-box-shadow: none;
top: 12px;
width: -webkit-fill-available;
right: 12px;
position: absolute;
.chip-container {
right: 0px;
position: absolute;
card_mod:
style: |
ha-card {
background: none;
Thanks @rhysb, I do remember coming across your post on nth-child, but I couldn’t locate it again. However, the solution only seemed to work on the 4th chip and not the 3rd
Is it because the 1st and 2nd chips are mushroom-entity-chips while the 3rd and 4th are mushroom-action-chips?
It is working for me. With the smaller icon it just doesn’t appear to change as much.
Wow, what a beautiful interface
Can I get help - I have the following code:
I want to insert the timer of the times inside this window if one button will open the buttons thanks
type: grid
title: fan_test
cards:
- show_name: true
show_icon: true
type: button
tap_action:
service: mqtt.publish
service_data:
topic: cmnd/fan_parents/FanSpeed
payload: '0'
target: {}
entity: light.fan_parents_room
hold_action:
action: none
icon: mdi:stop-circle-outline
- type: button
tap_action:
service_data:
payload: '1'
target: {}
entity: fan.fan_parents_room
hold_action:
action: none
- type: button
tap_action:
service_data:
payload: '2'
target: {}
hold_action:
action: none
- type: button
tap_action:
service_data:
payload: '3'
target: {}
hold_action:
action: none
- type: button
tap_action:
action: toggle
hold_action:
action: none
cards:
- aspect_ratio: 3/3
color: rgb(44, 109, 214)
color_type: label-card
entity: >-
input_boolean.fan_on_for_20_minutes_minutes_minutes_minutes_minutes_minutes
state:
- styles:
card:
- box-shadow: 0px 0px 10px 3px var(--button-card-light-color)
value: 'on'
- styles:
card:
- '--paper-card-background-color': rgb(44, 109, 214)
value: 'off'
styles:
card:
- margin: 0px 0px 0px -3px
name:
- font-weight: bold
- font-size: 25px
- color: white
tap_action:
service: script.set_20_time_for_fan_parents
type: custom:button-card
- aspect_ratio: 3/3
entity: input_boolean.fan_on_for_30_minutes_minutes_minutes
state:
- styles:
card:
value: 'on'
- styles:
card:
value: 'off'
styles:
card:
name:
- font-weight: bold
- font-size: 25px
- color: white
tap_action:
service: script.set_30_time_for_fan_parents_time_for_fan_parents
- aspect_ratio: 3/3
entity: input_boolean.fan_on_for_45_minutes_minutes_minutes_minutes_minutes
state:
- styles:
card:
value: 'on'
- styles:
card:
value: 'off'
styles:
card:
name:
- font-weight: bold
- font-size: 25px
- color: white
tap_action:
service: script.set_45_time_for_fan_parents
- aspect_ratio: 3/3
entity: input_boolean.fan_on_for_60_minutes_minutes_minutes_minutes
state:
- styles:
card:
value: 'on'
- styles:
card:
value: 'off'
styles:
card:
name:
- font-weight: bold
- font-size: 25px
- color: white
tap_action:
service: >-
script.set_60_time_for_fan_parents_time_for_fan_parents_time_for_fan_parents
- aspect_ratio: 3/3
entity: input_boolean.fan_on_for_120_minutes_minutes
state:
- styles:
card:
value: 'on'
- styles:
card:
value: 'off'
styles:
card:
name:
- font-weight: bold
- font-size: 25px
- color: white
tap_action:
service: script.set_120_time_for_fan_parents
square: false
columns: 5
cards:
- type: tile
color: green
features:
- type: fan-speed
card_mod:
style:
ha-tile-icon$: |
ha-svg-icon {
animation: ;
{%- endif %}
@keyframes rotate {
ha-tile-info$: |
.secondary {
opacity: 80%;
ha-card {
{% endif %}
chips:
- type: template
icon_color: |-
disabled
green
{% endif %}
icon: mdi:fan-auto
tap_action:
preset_mode: auto
card_mod:
style: |
ha-card {
{% endif %}
alignment: end
card_mod:
style: |
ha-card {
top: 12px;
right: 12px;
position: absolute;
.chip-container {
right: 0px;
position: absolute;
card_mod:
style: |
ha-card {
background: none;
Can anything help?
So can we achieve this in the sticky footer?
Thanks for all your contribution, you’re a mushroom hero!
If you have card_mod installed you can try the following, it will change the background colour of all chips on the card. Add to the bottom of the card configuration. There’s a few other things in there as well for spacing and padding , but naturally the last line will change the background colour.
card_mod:
style: |
:host {
--mush-chip-spacing: 0.1em;
--mush-chip-font-size: 0.28em;
--mush-chip-padding: 0em;
--mush-chip-background: #003355
Apologies for the cross post ( also posted on Swiper Thread) but I thought I might actually be better off posting in here as it may be something to do with the “Mushroom Card” ccs class (??!??!).
I’m trying to use Mushroom + Swiper for a 4" NSPanel Pro GUI and its going well; other than when I need to use a mushroom card slider ( see gif below)
I think ( according to the Swiper Docs) I can use the class of a ccs object to inhibit Swiper:
parameters:
edgeSwipeDetection: prevent
effect: slider
observer: true
noSwiping: true
noSwipingClass: slider
preventInteractionOnTransition: true
Taken from https://swiperjs.com/swiper-api#param-noSwiping.
If you can’t tell I haze zero experience with css or coding in general; but any advice to be able to use the mushroom slider would be much appreciated!
TIA
Alex
Actually yes, I’m almost there. I just have to find a way to make the popup appear on top of the other cards.
Nice work, maybe better from a UI perspective to keep the icons small and on the left of the room name like a list?
If you share your code so far I can play around with it too to make the popup work
