Friend, can you help me?
How did you create the rapi card
I would love to use your system on my home assistant, but I’m quite new to home. Could you explain me?
Would it be possible for you to share detailed instructions once it’s completed
Does anyone know a simple way to get Mushroom Cards and the built-in Tile Card to use the same font? I am using both throughout my dashboard and the difference between the two drives my OCD crazy haha.
can help ?
type: vertical-stack
cards:
- type: custom:layout-card
layout_type: custom:grid-layout
layout:
grid-template-columns: 1fr auto
grid-template-areas: |
"title chips"
margin: '-4px'
cards:
- type: custom:mushroom-title-card
title: סלון
view_layout:
grid-area: title
- type: custom:mushroom-chips-card
view_layout:
grid-area: chips
chips:
- type: entity
entity: sensor.temperature_goscinny
icon_color: amber
- type: template
content: ''
icon_color: |-
{% if is_state(entity, "on") %}
amber
{% else %}
default
{% endif %}
icon: |-
mdi:window-open
{% else %}
mdi:window-closed
{% endif %}
tap_action:
action: more-info
entity: binary_sensor.0x00158d00049fddee_contact
- type: template
entity: binary_sensor.presence_sensor_in_living_room_presence
icon: |-
mdi:motion-sensor
{% else %}
mdi:motion-sensor-off
{% endif %}
icon_color: |-
amber
{% else %}
default
{% endif %}
tap_action:
action: more-info
alignment: end
card_mod:
style: |
ha-card {
transform: translateY(43%);
- type: conditional
conditions:
- entity: input_boolean.heating_season
state_not: 'off'
card:
type: custom:mushroom-climate-card
entity: climate.salon
show_temperature_control: true
collapsible_controls: false
hvac_modes: []
layout: horizontal
tap_action:
action: more-info
primary: Curtain
secondary: ''
entity: cover.curtain
icon: |
{% if is_state('cover.curtain', 'open') %}
mdi:curtains
{% else %}
mdi:curtains-closed
{% endif %}
badge_color: ''
badge_icon: ''
icon_color: ''
card_mod:
style:
mushroom-shape-icon$: |
.shape {
{% if is_state(config.entity, 'open') %}
{% if state_attr(config.entity, 'rgb_color') == none %}
--icon-color: rgb(255,190,137) !important;
--shape-color: rgb(255,190,137, 0.2 ) !important;
{% else %}
{% set r = state_attr(config.entity, 'rgb_color')[0] %}
{% set g = state_attr(config.entity, 'rgb_color')[1] %}
{% set b = state_attr(config.entity, 'rgb_color')[2] %}
--icon-color: rgb( {{r}}, {{g}}, {{b}} ) !important;
--shape-color: rgba( {{r}}, {{g}}, {{b}}, 0.2 ) !important;
{% endif %}
{% endif %}
ha-card {
width: px;
margin-left: 35%;
top: -200px;
background: none;
:host {
--mush-icon-size: 45px;
can you help. How can I add the curtain in a good way?
I also want to add a camera, how is it possible?
My OCD won’t let me use the tile card
Why don’t you use a mushroom template card instead? You can achieve the same I’m sure.
You can change the tap action to a pop up and add your cards there.
Summary
type: custom:vertical-stack-in-card
cards:
- type: tile
entity: fan.andrews_air_purifier
color: green
features:
- type: fan-speed
card_mod:
style:
ha-tile-icon$: |
ha-svg-icon {
{% if is_state(config.entity,'off') %}
animation: ;
{% elif is_state_attr(config.entity,'percentage',33) %}
animation: rotate 1.2s linear infinite;
{% elif is_state_attr(config.entity,'percentage',66) %}
animation: rotate 0.7s linear infinite;
{% elif is_state_attr(config.entity,'percentage',100) %}
animation: rotate 0.5s linear infinite;
{% elif is_state_attr(config.entity,'mode','auto') %}
{% elif is_state_attr(config.entity,'mode','sleep') %}
animation: rotate 2s linear infinite;
{%- endif %}
@keyframes rotate {
100% { transform: rotate(360deg); }
ha-tile-info$: |
.secondary {
opacity: 80%;
ha-card {
--primary-text-color: var(--tile-color);
{% if is_state(config.entity, 'on') %}
background: rgba(101,170,91,0.1);
{% endif %}
chips:
- type: template
icon_color: |-
{% if is_state_attr(config.entity, 'mode', 'manual') %}
disabled
{% elif is_state_attr(config.entity, 'mode', 'auto') %}
green
{% endif %}
icon: mdi:fan-auto
tap_action:
action: fire-dom-event
browser_mod:
service: browser_mod.popup
title: fan_test
content:
type: grid
cards:
- show_name: true
show_icon: true
type: button
tap_action:
action: call-service
service: mqtt.publish
service_data:
topic: cmnd/fan_parents/FanSpeed
payload: '0'
target: {}
entity: fan.andrew_s_fan
hold_action:
action: none
icon: mdi:stop-circle-outline
- type: button
tap_action:
service_data:
payload: '1'
target: {}
hold_action:
action: none
- type: button
tap_action:
service_data:
payload: '2'
target: {}
hold_action:
action: none
- type: button
tap_action:
service_data:
payload: '3'
target: {}
hold_action:
action: none
- type: button
tap_action:
action: toggle
entity: light.fan_parents_room
hold_action:
action: none
- type: horizontal-stack
cards:
- aspect_ratio: 3/3
color: rgb(44, 109, 214)
color_type: label-card
entity: >-
input_boolean.fan_on_for_20_minutes_minutes_minutes_minutes_minutes_minutes
state:
- styles:
card:
- box-shadow: 0px 0px 10px 3px var(--button-card-light-color)
value: 'on'
- styles:
card:
- '--paper-card-background-color': rgb(44, 109, 214)
value: 'off'
styles:
card:
- margin: 0px 0px 0px -3px
name:
- font-weight: bold
- font-size: 25px
- color: white
tap_action:
service: script.set_20_time_for_fan_parents
type: custom:button-card
- aspect_ratio: 3/3
entity: input_boolean.fan_on_for_30_minutes_minutes_minutes
state:
- styles:
card:
value: 'on'
- styles:
card:
value: 'off'
styles:
card:
name:
- font-weight: bold
- font-size: 25px
- color: white
tap_action:
service: script.set_30_time_for_fan_parents_time_for_fan_parents
- aspect_ratio: 3/3
entity: >-
input_boolean.fan_on_for_45_minutes_minutes_minutes_minutes_minutes
state:
- styles:
card:
value: 'on'
- styles:
card:
value: 'off'
styles:
card:
name:
- font-weight: bold
- font-size: 25px
- color: white
tap_action:
service: script.set_45_time_for_fan_parents
- aspect_ratio: 3/3
entity: input_boolean.fan_on_for_60_minutes_minutes_minutes_minutes
state:
- styles:
card:
value: 'on'
- styles:
card:
value: 'off'
styles:
card:
name:
- font-weight: bold
- font-size: 25px
- color: white
tap_action:
service: >-
script.set_60_time_for_fan_parents_time_for_fan_parents_time_for_fan_parents
- aspect_ratio: 3/3
entity: input_boolean.fan_on_for_120_minutes_minutes
state:
- styles:
card:
value: 'on'
- styles:
card:
value: 'off'
styles:
card:
name:
- font-weight: bold
- font-size: 25px
- color: white
tap_action:
service: script.set_120_time_for_fan_parents
square: false
columns: 5
card_mod:
style: |
ha-card {
--chip-background: rgba(var(--rgb-disabled), 0.15);
--chip-background: rgba(var(--rgb-green), 0.15);
{% endif %}
alignment: end
card_mod:
style: |
ha-card {
--ha-card-box-shadow: none;
top: 12px;
width: -webkit-fill-available;
right: 12px;
position: absolute;
.chip-container {
right: 0px;
position: absolute;
card_mod:
style: |
ha-card {
background: none;
Does anyone have any tips for this? I’m using the custom area cards with “chips” as indicators across the bottom of each card, but the icons are spaced too far apart. I’m looking for a way to apply negative spacing (overlapping) to a chips card. Here’s what it looks like with 0px chip spacing, and below is what I’m hoping to achieve:
I’m doing this using card_mod with “–chip-spacing,” but the negative value doesn’t seem to have any affect:
card_mod:
style: |
ha-card {
--chip-spacing: -4;
Is there a way to use negative spacing, or to adjust the individual chips to have 0px left padding?
can you share code for media player bar & naviation function ?
Thank you for your work.
If you want to fix your card at the bottom, you can try this:
card_mod:
style: |
ha-card {
max-height: calc(100vh - var(--header-height)) !important;
overflow-y: auto !important;
max-width: var(--masonry-column-width, 490px) !important;
:host {
position: fixed !important;
z-index: 0 !important;
bottom: 10px !important;
width: 100% !important;
How I can set background color, icon size, … vor a chip:nth-child?
type: custom:state-switch
entity: media_player.camera_mattia
default: 'off'
transition: swap-left
transition_time: 10
states:
'off':
type: custom:stack-in-card
mode: horizontal
cards:
- type: vertical-stack
cards:
- type: conditional
conditions:
- entity: input_boolean.menu1
state: 'on'
card:
mode: vertical
cards:
primary: Home
secondary: ''
icon: mdi:home
icon_color: white
fill_container: false
layout: vertical
entity: input_select.seleziona_stanza
tap_action:
service: input_select.select_option
entity_id: input_select.seleziona_stanza
option: Home
card_mod:
style: |
ha-card {
width: 210px;
height: 20px;
--spacing: 0px;
padding-top: 10px !important;
//box-shadow: var(--ha-card-box-shadow) !important;
//border-radius: 10px 10px 10px 10px !important;
transition: all 0s;
--icon-size: 60px;
mushroom-shape-icon {
--shape-color: rgba(var(--rgb-{{ 'white' if is_state('input_select.seleziona_stanza', 'Home') else 'none' }}), 0.4) !important;
primary: Cucina
secondary: ''
icon: mdi:fridge
icon_color: white
layout: vertical
tap_action:
option: Cucina
card_mod:
style: |
ha-card {
width: 210px;
height: 20px;
--spacing: 0px;
transition: all 0s;
--icon-size: 60px;
--shape-color: rgba(var(--rgb-{{ 'white' if is_state('input_select.seleziona_stanza', 'Cucina') else 'none' }}), 0.4) !important;
primary: Salotto
secondary: ''
icon: mdi:sofa
icon_color: white
layout: vertical
tap_action:
option: Salotto
card_mod:
style: |
ha-card {
width: 210px;
height: 20px;
--spacing: 0px;
transition: all 0s;
--icon-size: 60px;
--shape-color: rgba(var(--rgb-{{ 'white' if is_state('input_select.seleziona_stanza', 'Salotto') else 'none' }}), 0.4) !important;
card_mod:
style: |
ha-card {
position: fixed;
top: 0;
bottom: 40px;
left: 8px;
right: 0;
animation: slide-up 0.5s;
z-index: 5;
width: 210px;
height: 400px !important;
padding: 0px;
overflow-y: hidden;
border-radius: 35px 35px 35px 35px !important;
@keyframes slide-up {
from {
transform: translateY(100%);
to {
transform: translateY(0);
- type: custom:stack-in-card
mode: horizontal
cards:
primary: >-
{% set stanza = states('input_select.seleziona_stanza') %} {%
if stanza == 'Home' %}
Home
{% elif stanza == 'Cucina' %}
Cucina
{% elif stanza == 'Salotto' %}
Salotto
{% endif %}
secondary: ''
icon: >-
mdi:home
mdi:fridge
mdi:sofa
{% endif %}
icon_color: white
tap_action: none
card_mod:
style: |
ha-card {
--spacing: 8px;
--icon-size: 35px;
--primary-text-color: rgb(var(--rgb-white));
--shape-color: none !important;
chips:
- type: template
double_tap_action:
action: none
icon: mdi:chevron-up
tap_action:
action: toggle
hold_action:
action: none
card_mod:
style: |
ha-card {
margin-top: 7px;
margin-left: 50px;
--chip-icon-size: 20px;
--chip-box-shadow: none;
--chip-background: none;
--chip-spacing: 0;
card_mod:
style: |
ha-card {
padding: 0px;
width: 210px;
height: 50px;
background: var(--card-background-color);
secondary: ''
icon: mdi:music-note-eighth
layout: vertical
icon_color: blue
tap_action:
action: navigate
navigation_path: house
card_mod:
style: |
ha-card {
width: 50px;
--spacing: 5px;
background: var(--card-background-color) !important;
border-radius: calc(var(--ha-card-border-radius, 12px) * 2) !important;
margin: 0px 0px 0px 120px;
transition: all 0.5s;
secondary: ''
icon: mdi:video
layout: vertical
icon_color: ''
tap_action:
action: navigate
card_mod:
style: |
ha-card {
width: 50px;
--spacing: 5px;
margin: 0px 0px 0px 80px;
secondary: ''
icon: mdi:chart-bar
layout: vertical
icon_color: orange
tap_action:
action: navigate
card_mod:
style: |
ha-card {
width: 50px;
--spacing: 5px;
margin: 0px 0px 0px 40px;
card_mod:
style: |
ha-card {
overflow: visible !important;
margin-top: 100%;
margin-bottom: 0;
box-shadow: none;
border: none;
background: none;
padding: var(--mush-chip-spacing, 8px);
transition: all 0s;
:host {
position: sticky;
z-index: 4;
bottom: 0px;
ha-card:after {
content: "";
position: absolute;
bottom: 0px;
height: 80px;
width: 100%;
max-width: calc(var(--column-max-width) - 2 * var(--ha-card-border-width, 1px) - var(--mush-chip-spacing, 8px));
left: 50%;
transform: translateX(-50%);
z-index: -1;
background: color-mix(in srgb, var(--card-background-color) 40%, var(--primary-background-color));
border-radius: 35px 35px 0px 0px;
ha-card:before {
content: "";
position: absolute;
top: 0px;
left: 0px;
height: 100%;
width: 100%;
z-index: -1;
backdrop-filter: blur(12px);
-webkit-backdrop-filter: blur(12px);
background: rgba(var(--rgb-card-background-color), 0.8);
box-shadow: var(--ha-card-box-shadow);
border: var(--ha-card-border-width, 1px) solid var(--ha-card-border-color, var(--divider-color, #e0e0e0));
playing:
mode: horizontal
cards:
cards:
secondary: ''
icon: >-
{% set room = states('input_select.seleziona_stanza') %} {% if
room == 'Home' %} mdi:home {% elif room == 'Cucina' %} mdi:fridge
{% elif room == 'Salotto' %} mdi:sofa {% endif %}
layout: vertical
icon_color: white
tap_action:
action: toggle
card_mod:
style: |
ha-card {
width: 50px;
--spacing: 5px;
margin-top: 0px;
margin-left: 0px;
mode: horizontal
cards:
- type: custom:mushroom-media-player-card
layout: horizontal
show_volume_level: true
use_media_info: true
card_mod:
style: |
display: flex;
{% set media_type = state_attr(config.entity, 'media_content_type') %}
{% if media_type == 'tvshow' %}
--card-mod-icon: mdi:television-classic;
animation: flicker 1s linear infinite alternate;
{% elif media_type == 'movie' %}
--card-mod-icon: mdi:movie-roll;
animation: spin 2s linear infinite reverse;
{% elif media_type in ['music', 'playlist'] %}
--card-mod-icon: mdi:music;
animation: beat 1.3s ease-out infinite both;
{% else %}
--card-mod-icon: mdi:play;
{% endif %}
@keyframes flicker {
0%, 31.98%, 32.98%, 34.98%, 36.98%, 39.98%, 67.98%, 68.98%, 95.98%, 96.98%, 97.98%, 98.98%, 100% { --icon-color: rgba(var(--rgb-indigo), 1); }
32%, 33%, 35%, 36%, 37%, 40%, 68%, 69%, 96%, 97%, 98%, 99% { --icon-color: rgba(var(--rgb-indigo), 0.6); }
@keyframes beat {
0%, 60% { --icon-symbol-size: 21px; }
5%, 17%, 57% { --icon-symbol-size: 22px; }
10%, 20%, 51% { --icon-symbol-size: 23px; }
25%, 45% { --icon-symbol-size: 24px; }
30%, 39% { --icon-symbol-size: 25px; }
33% { --icon-symbol-size: 26px; }
ha-card {
{% if not is_state(config.entity, 'off') %}
background: rgba(var(--rgb-card-background-color), 0.6) url('{{ state_attr(config.entity, "entity_picture") }}') center no-repeat;
background-size: cover;
background-blend-mode: overlay;
{% endif %}
height: 50px !important;
margin-left: -8px;
card_mod:
style: |
ha-card {
width: 210px;
margin-left: -40px;
{% if is_state('media_player.camera_mattia', 'off') %}
{% else %}
background-image: url('{{ state_attr("media_player.camera_mattia", "entity_picture") }}');
background-position: center;
background-repeat: no-repeat;
background-color: rgba(var(--rgb-card-background-color), 0.8);
position: relative;
{% endif %}
secondary: ''
icon: mdi:video
layout: vertical
icon_color: ''
tap_action:
action: navigate
card_mod:
style: |
ha-card {
width: 50px;
--spacing: 5px;
margin-top: 0px;
margin-left: 80px;
transition: all 0s;
secondary: ''
icon: mdi:chart-bar
layout: vertical
icon_color: orange
tap_action:
action: navigate
card_mod:
style: |
ha-card {
width: 50px;
--spacing: 5px;
margin-top: 0px;
margin-left: 40px;
transition: all 0s;
card_mod:
style: |
ha-card {
//overflow: visible !important;
overflow: hidden !important;
margin-top: 100%;
margin-bottom: 0px;
box-shadow: none;
border: none;
background: none;
transition: all 0s;
:host {
position: sticky;
z-index: 4;
bottom: 0px;
overflow: hidden;
ha-card:after {
content: "";
position: absolute;
bottom: 0px;
height: 80px;
width: 100%;
left: 50%;
z-index: -1;
ha-card:before {
content: "";
position: absolute;
top: 0px;
left: 0px;
height: 100%;
width: 100%;
z-index: -1;
Thanks for this! It nearly works perfectly on my device and looks great but there’s a few small issues that are still a little bit off. Might have just been my copy/paste/edit though.
- When music is playing you can’t change the room.
- The room popup doesn’t popup over the screen contents, it’ll only popup above the bar itself meaning you need to scroll down to see all options.
Can anyone help me to fill the boxes with a background? I can only get a background on the Title line where the temparature sensor is, but i want it to fill the whole box.
cards:
- square: false
columns: 2
type: grid
cards:
primary: Stua
secondary: >-
{{ states('sensor.verisure_rv_stua_temp') }} °C | {{
states('sensor.verisure_rv_stua_fukt') | int(0) }} %
icon: ''
icon_color: blue
tap_action:
service: script.popup_stua
hold_action:
action: navigate
navigation_path: /lovelace-panel/stua
card_mod:
style:
mushroom-state-info$: |
.container {
display: table !important;
.secondary {
display: table-cell;
text-align: right;
width: 100%;
primary: Kjøkken
secondary: >-
{{ states('sensor.aqara_multisensor_kjokkenet_temp') }} °C | {{
states('sensor.aqara_multisensor_kjokkenet_fukt') | int(0) }} %
icon: ''
icon_color: orange
tap_action:
service: script.popup_kjokken
hold_action:
action: navigate
navigation_path: /lovelace-panel/kjokken
card_mod:
style:
.container {
.secondary {
text-align: right;
width: 100%;
chips:
- type: template
icon: |-
mdi:radiator
{% else %}
mdi:radiator-off
{% endif %}
entity: switch.hue_kontakt_stua_1
icon_color: |-
red
{% else %}
blue
{% endif %}
tap_action:
action: toggle
card_mod:
style: |
ha-card {
--chip-spacing: 0;
--chip-icon-size: 0.6em
- type: template
entity: light.over_stuebordet
icon: |-
mdi:ceiling-light
{% else %}
mdi:ceiling-light-outline
{% endif %}
icon_color: |-
orange
{% else %}
grey
{% endif %}
content_info: none
tap_action:
action: toggle
card_mod:
style: |
ha-card {
--chip-spacing: 0;
- type: template
entity: light.stua_uten_stuebordlys_dz
content_info: none
icon: |-
mdi:lamp
{% else %}
mdi:lamp-outline
{% endif %}
icon_color: |-
orange
{% else %}
grey
{% endif %}
tap_action:
action: toggle
hold_action:
action: more-info
card_mod:
style: |
ha-card {
--chip-spacing: 0;
- type: template
entity: input_boolean.boolean_filmlys_stua
content_info: none
icon: |-
mdi:movie-open-outline
{% else %}
mdi:movie-open-off-outline
{% endif %}
icon_color: |-
green
{% else %}
grey
{% endif %}
tap_action:
action: toggle
card_mod:
style: |
ha-card {
--chip-spacing: 0;
card_mod:
style: |
ha-card {
--chip-spacing: 10;
margin-top: -10px;
chips:
- type: template
icon: |-
{% if is_state(config.entity, 'heat') %}
mdi:radiator
{% else %}
mdi:radiator-off
{% endif %}
entity: climate.mill_ovn_kjokkenet
icon_color: |-
red
{% else %}
blue
{% endif %}
tap_action:
action: more-info
card_mod:
style: |
ha-card {
--chip-spacing: 0;
- type: template
entity: light.taklyset_pa_kjokken
icon: |-
mdi:ceiling-light
{% else %}
{% endif %}
icon_color: |-
orange
{% else %}
grey
{% endif %}
content_info: none
tap_action:
action: toggle
card_mod:
style: |
ha-card {
--chip-spacing: 0;
- type: template
entity: light.kjokkenbenken
icon: |-
mdi:led-strip-variant
{% else %}
mdi:led-strip-variant-off
{% endif %}
icon_color: |-
orange
{% else %}
grey
{% endif %}
content_info: none
tap_action:
action: toggle
card_mod:
style: |
ha-card {
--chip-spacing: 0;
- type: template
entity: switch.aqara_kontakt_kjokkenet_1
content_info: none
icon: |-
hue:plug
{% else %}
hue:plug
{% endif %}
icon_color: |-
green
{% else %}
grey
{% endif %}
tap_action:
action: toggle
card_mod:
style: |
ha-card {
--chip-spacing: 0;
card_mod:
style: |
ha-card {
--chip-spacing: 10;
margin-top: -10px;
you’re right, but I’m implementing the functions hand hand. Unfortunately the work steals a lot of time
Yeah I can appreciate that and thanks for the hard work! My yaml skills are no way near good enough to get anywhere near sadly but just wanted to check you had the same problems and it wasn’t my copying. Hopefully stuff like this comes out of the box at some point but I think we’re probably years off seeing that yet.
I’m using
--chip-spacing: -12px !important;
to get chips close enough together for my cards
Thank you for your response. However, what I am trying to do is add a new button that will open another window to activate the timer. Specifically, I have created an input boolean for the fan to turn on for 20 minutes, 30 minutes, and 120 minutes, with the name “20”, “30”, and “120” respectively.( input_boolean.fan_on_for_20_minutes_minutes_minutes_minutes_minutes_minutes
name: 20) The service I am using is “script.set_20_time_for_fan_parents”. My question is, how can I add these options to the new window I am creating with the additional button? Thank you for your assistance.
I also adapted your code to no longer go through state-switch but rather with conditional-card and CSS:
Without media_player being played:
When media_player is playing or paused:
cards:
primary: Search...
secondary: ''
icon: mdi:search-web
icon_color: white
entity: input_select.plex_recently
tap_action:
browser_mod:
title: ChatGPT
content:
cards:
- type: entities
entities:
- entity: input_text.gpt_prompt
- type: markdown
content: >-
{{ state_attr('sensor.hassio_mindsdb_response',
'response_text') }}
title: Réponse
card_mod:
style: |
ha-card {
{% if is_state('media_player.currently_playing', ['idle','off']) %}
width: 100%;
--spacing: 5px;
margin-bottom: 2px;
margin-top: 2px;
margin-left: 0px;
margin-right: auto;
{% else %}
width: 50px;
--spacing: 5px;
margin-top: 2px;
margin-bottom: 2px;
margin-left: 1%;
{% endif %}
ha-card:hover {
background: color-mix(in srgb, var(--{{ config.icon_color }}-color) 25%, var(--card-background-color)) !important;
transition: all 0.1s;
- type: conditional
conditions:
- entity: media_player.currently_playing
state_not: 'off'
state_not: idle
card:
mode: horizontal
cards:
layout: horizontal
tap_action:
browser_mod:
title: En cours
content:
cards:
icon_type: none
layout: vertical
media_controls:
- previous
- play_pause_stop
- next
volume_controls:
- volume_set
- volume_buttons
show_volume_level: false
card_mod:
style:
/* CSS for Mushroom Popup Media Player */
.secondary:before {
/* Add album name between song title and artist name */
{% if state_attr(config.entity, 'media_album_name') != none %}
content: "{{ state_attr(config.entity, 'media_album_name')}}\A";
{% endif %}
/* Format title to fit on seperate line */
white-space: pre;
text-overflow: ellipsis;
ha-card {
/* Remove border from media player */
--ha-card-border-width: 0;
/* Apply album art color to media player icon & volume bar */
--rgb-state-media-player: var(--album-art-color);
/* Disable transitions */
.actions {
/* Apply album art color to media player controls */
--rgb-primary-text-color: var(--album-art-color);
--primary-text-color: rgb(var(--album-art-color));
/* Move volume button to seperate row */
display: block !important;
ha-card:before {
content: "";
/* Show album art above media player when active and default image when idle */
{% if is_state(config.entity, ['playing', 'paused']) %}
background: url( '{{ state_attr(config.entity, "entity_picture") }}') center no-repeat;
{% else %}
background: url('/local/idle_art.png') center no-repeat;
{% endif %}
/* Add padding around album art */
margin: 0px 4px 16px;
/* Add drop shadow to album art */
filter: drop-shadow(4px 4px 6px rgba(var(--album-art-color), 0.3));
/* Round borders of album art */
border-radius: var(--control-border-radius);
/* Adjust the album art aspect ratio based on media type */
aspect-ratio: 16 / 9;
aspect-ratio: 2 / 3;
{% else %}
aspect-ratio: 1 / 1;
{% endif %}
/* Stretch album art to fit box. Fix for if album art is not sized correctly */
background-size: 100% 100%;
mushroom-button {
/* Size volume button to match other controls and center */
display: flex;
width: calc((100% / 3) - (var(--spacing) / 3) * 2);
margin: auto;
mushroom-media-player-media-control,
mushroom-media-player-volume-control {
/* Correct margins for volume button on second row */
display: flex;
margin-right: 0px !important;
/* Check if PLAY|STOP are supported and adjust margin accordingly */
{% if state_attr(config.entity, 'supported_features') | int | bitwise_and(20480) > 0 %}
margin-bottom: var(--spacing) !important;
{% endif %}
hide:
icon: true
runtime: true
source: true
power: true
state_label: true
volume: true
info: true
progress: false
controls: true
more_info: false
type: custom:mini-media-player
toggle_power: false
group: true
card_mod:
style:
mmp-progress$: |
paper-progress {
/* Apply album art color to progress bar when paused */
--paper-progress-container-color: rgba(var(--album-art-color), 0.2) !important;
/* Apply album art color to progress bar when playing */
--paper-progress-active-color: rgb(var(--album-art-color)) !important;
ha-card {
/* Move progress bar up into gap. Check if PLAY|STOP are supported */
--base-offset: calc(4 * var(--mush-spacing, 12px)
+ 1.33 * var(--mush-spacing, 12px)
+ var(--mush-card-primary-line-height, 1.5) * var(--mush-card-primary-font-size, 14px)
+ var(--mush-card-secondary-line-height, 1.5) * var(--mush-card-secondary-font-size, 12px)
+ var(--mush-control-height, 42px));
/* Check if Play (16385) or Stop (4096) are supported and add control button height if they are */
--control-offset: calc(var(--mush-spacing, 12px) + var(--mush-control-height, 42px));
{% else %}
--control-offset: 0px;
{% endif %}
/* Check if album name is present and add to height if it is */
{% set album_name = state_attr(config.entity, 'media_album_name') %}
{% if album_name == None or album_name == "" %}
--album-offset: 0px;
{% else %}
--album-offset: calc(var(--mush-card-secondary-line-height, 1.5) * var(--mush-card-secondary-font-size, 12px));
{% endif %}
bottom: calc(var(--base-offset) + var(--control-offset) + var(--album-offset));
/* Correct margins for progress bar */
margin: 0px 28px -12px;
/* Set height of card to match pregress bar height */
height: var(--mmp-progress-height);
/* Remove border outline */
/* Round corners of progress bar */
--mmp-border-radius: var(--control-border-radius, 12px) !important;
/* Set height of progress bar */
--mmp-progress-height: 12px !important;
/* Remove transitions to prevent progress bar floating in */
card_mod:
style: |
:host {
/* Assign album art color to variable used in popup */
--album-art-color:
{% if is_state('media_player.currently_playing', ['playing', 'paused']) %}
{{ states('sensor.muted_color') }}
{% else %}
141, 117, 238
{% endif %};
/* Remove background because it is applied to popup */
--ha-card-background: none;
card_mod:
style:
ha-dialog$: |
.mdc-dialog__surface {
/* Apply gradient background to popup using album art colors. Set to default colors when idle */
background: linear-gradient(305deg, transparent 50%, rgba({{ states('sensor.dark_vibrant_color') }}, 0.4)),
linear-gradient(55deg, transparent 50%, rgba({{ states('sensor.vibrant_color') }}, 0.2)),
linear-gradient(180deg, transparent 40%, rgba({{ states('sensor.dark_muted_color') }}, 0.3));
{% else %}
background: linear-gradient(0deg, transparent 40%, rgba(192, 127, 190, 0.3)),
linear-gradient(240deg, transparent 40%, rgba(143, 119, 237, 0.3)),
linear-gradient(120deg, transparent 40%, rgba(122, 181, 239, 0.3));
{% endif %}
ha-header-bar$: |
.mdc-top-app-bar {
/* Remove header background so that popup background is visible */
--mdc-theme-primary: none;
/* Reduced the gap between header and album art */
margin-bottom: -16px;
:host {
/* Set width of popup */
--popup-min-width: 450px;
card_mod:
style: |
display: flex;
--icon-animation: spin 2s linear infinite reverse;
{% elif media_type == 'music' %}
{% elif media_type == 'playlist' %}
{% else %}
{% endif %}
@keyframes beat {
ha-card {
background: rgba(var(--rgb-card-background-color), 0.6) url( '{{ state_attr(config.entity, "entity_picture") }}' ) center no-repeat;
{% endif %}
height: 55px !important;
margin-left: -8px;
card_mod:
style: |
ha-card {
{% if is_state('media_player.currently_playing', ['playing','paused']) %}
background-image: url( '{{ state_attr( "media_player.currently_playing", "entity_picture" ) }}' );
position: relative;
margin-left: -72%;
width: 170%;
{% else %}
width: 50px;
--spacing: 5px;
margin-top: 2px;
margin-left: auto;
margin-right: -64%;
{% endif %}
I also applied a color modification depending on the media being played:
ha-card:before {
content: "";
position: absolute;
top: 0px;
left: 0px;
height: 100%;
width: calc(100% - 2 * var(--ha-card-border-width, 1px));
z-index: -1;
border-radius: 35px;
background: linear-gradient(135deg, rgba({{ states('sensor.dark_vibrant_color') }}, 0.85), rgba({{ states('sensor.dark_muted_color') }}, 0.75));
{% else %}
background: rgba(var(--rgb-card-background-color), 0.20);
{% endif %}
