Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
This should work :slight_smile:
type: custom:mushroom-person-card
entity: person.dimitri_landerloos
primary_info: none
secondary_info: none
icon_type: entity-picture
card_mod:
  style:
    mushroom-shape-avatar$: |
      .picture {
        display: flex;
        border-radius: 50%;
        animation: ping 2s infinite;
      @keyframes ping {
        0% {box-shadow: 0 0 5px 3px rgba(var(--rgb-green), 0.9);}
        100% {box-shadow: 0 0 5px 15px transparent;}
      ha-card {
       --icon-size: 72px;
Ive only collapsed the keyframes {} because that is my preference for how it looks visually. Both are correct already :slight_smile:
The only thing missing was display: flex; and border-radius: 50%;
display: flex; turns everything inside the element into a flex-box element. This esentially just means that now everything inside of .picture will try and share the full space available to them within .picture and since there is only 1 element inside of .picture it will take up the full space. Then when we apply the box-shadow animation it now has an actual size to apply it to.
border-radius: 50%; just makes the shape of the container for the image round as well. By default the container is square.
My main issue here is indentation, I’ve got 1900 lines of code to that card due to using his person card as seen in the tag and I don’t know how to change the indentation for the full code
By example:
https://github.com/Doghousestaffs/Test/blob/7f15d7f26ec38af6f5f1df87190bd76e8ca2405d/.github/workflows/blank.yml
Sorry but i am really never going to get the time to help you with this. I suggest you try and sort out as much as you can yourself. And whenever you get stuck post it here. (If its related to a mushroom card) i can then try to help in those individual cases.
Is there a way to achieve the same with a mushroom chips card? Wanting the symbol in top corner showing the zone
How do I combine different effects ? I have the following (non working)
entity: person.tim
card_mod:
  style:
      .container:before {
        content: "";
        height: 100%;
        width: 100%;
        background: radial-gradient(rgb(var(--rgb-white)) 60%, transparent calc(60% + 1px)), conic-gradient(rgb(var(--rgb-green)) {{ states('sensor.sm_s911b_battery_level') }}% 0%, transparent 0% 100%);
        border-radius: var(--icon-border-radius);
        position: absolute;
        -webkit-mask-image: radial-gradient(circle calc(var(--icon-size) / 2 - 2px) at 50% 50%, transparent 100%, black 0);
        mushroom-shape-avatar {
         {{ 'filter: grayscale(100%);' if is_state('person.tim', 'not_home') }}
        ha-card {
         background: none;
         --ha-card-box-shadow: 0px;
The first stanza puts a nice arc around the profile photo to denote battery charge. But I also want the ‘greyscale when away’ and the none background of the 2nd stanza. Obviously mushroom-shape-avatar is declared twice so it wont work (I’ve never understood the trailing $ and | symbols either :-/ )
Thanks.
is it true that after the lst ha update the animated cards not longer works? what its changed again?
No, but you need to update card mod as well + then clear chache on app/browser.
Here is an explanation of how these symbols work.
$ is used when we want to access the shadow-root of an object. like this here:
the .shape is within the shadow-root of mushroom-shape-icon so to access it and modify it, we would write this:
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
        background: red !important;
you cant just write this, as this wont access the element through the shadow root.
card_mod:
  style: |
    .shape {
the | is just written to denote that you are done with going through elements and that you will now list your final element. so if i have stacked with multiple shadow-roots. it would look like this:
card_mod:
  style:
    mushroom-light-brightness-control$:
      mushroom-slider$:
        .container:
          .slider: |
            .slider-track-active {
              background-color: red !important;
Notice how the last 2 in the stack dont have a $? thats because those elements dont have a shadow-root.
Ok. now that you hopefully understand how those symbols work we can look at your specific example.
card mod has a built in fuction to let you reset yourself back to style: | which is what you need for both ha-card { and mushroom-shape-avatar {
it is using .: if you use it at the right indentation (same line as anything you first place under style:
so like this:
card_mod:
  style:
      .container:before {
        content: "";
        height: 100%;
        width: 100%;
        background: radial-gradient(rgb(var(--rgb-white)) 60%, transparent calc(60% + 1px)), conic-gradient(rgb(var(--rgb-green)) {{ states('sensor.sm_s991b_battery_level') }}% 0%, transparent 0% 100%);
        position: absolute;
        {{ 'filter: grayscale(100%);' if is_state(config.entity, 'not_home') }}
      ha-card {
        background: none;
note where the .: starts is the exact same place as where you initial mushroom-shape-avatar$: | starts. basically treat writing .: | as writting a whole new style: | again.
you can also use it like this (this gets more complex, so feel free to ignore if you dont fully understand it :slight_smile: ):
card_mod:
  style:
    mushroom-state-info$:
      .container: |
        .primary {
          --primary-text-color: #001eff;
        .secondary {
          --secondary-text-color: #00ddff;
        .container {
          display: flex;
          flex-direction: row !important;
          align-items: baseline;
          gap: 10px;
here my .: doesnt start at the same indentation as the first entry under style. it starts at the same entry as under when i declared .container: | reason being is if i wanted to access stuff under .container (like .primary and .secondary) then i cant also access .container (there are other ways to do it, but for illustration purposes this is true), so i put the .: | underneath the mushroom-state-info$: | as i still want to be in the shadow-root of the element as otherwise i cant access .container at all. then i just style the container the way i want.
Thank you so Much its work
Thanks for the detailed explanation Dimitri. I appreciate it. I don’t completely understand it (the card works though) but I have a slightly better understanding of $ and | (something I found pretty much impossible to google without hitting a CSS text book at page 1)
Thats quite alright, we all tend to learn piece by piece :slight_smile:
something you might be interested to look a bit more into as well is the ::before that you are using in your css. it is what is called a pseudo element. basically you are creating another element that inherits its placement from what you used before the ::before. there is also ::after and many others, but before and after as the most common. and as you might expect, they may render before or after the element that you base it off :slight_smile:
Achieve what exactly? Can you send a screenshot of exactly what you want?
That works for me too Dimitri, thanks a lot for your help !!
Here is a working example of restriciton card
This is when the door is locked
and when it is unlocked
type: custom:layout-card
square: false
columns: 1
cards:
  - type: custom:restriction-card
    restrictions:
      pin:
        code: 1234
    exemptions:
      - user: ianid
    card:
      type: custom:mushroom-template-card
      secondary: null
      primary: >
        {% if is_state('binary_sensor.ewelink_contactsensor',
        'on') %}
          Door is Open
        {% elif is_state('binary_sensor.ewelink_contactsensor',
        'off') %}
           Door is Locked
        {% else %}
        {% endif %}
      entity: entity.entity
      icon: null
      tap_action:
        action: call-service
        service: script.turn_on
          entity_id: script.house_door
      fill_container: false
      multiline_secondary: false
      layout: vertical
      picture: /local/png/dot2.png
      card_mod:
        style:
            .primary {
              font-size: 16px !important;
              position: relative;
              overflow: visible !important;
              margin-top: 30px;
              margin-left: -12px;
              --primary-text-color: rgb(var(--rgb-white));
              font-weight: bold;
              text-overflow: ellipsis;
              text-align: left;
              width: 130px;
              background: rgb(0,100,182);
              text-indent: 5px;
              border-radius: 5px;
            .secondary {
              font-size: 14px !important;
              position: static;
              text-align: center;
              margin-left: -18px;
              border-radius: 5px;
              margin-right: 2px;
              text-indent: 10px;
              flex-wrap: wrap !important;
              --secondary-text-color: var(--amber-color);
            .picture {
              border-radius: 0px !important;
              margin-top: 0px;
              margin-left: 0px;
              margin-bottom: auto;
            .shape {
              position: relative;
            ha-card {
            {% if
            'on') %}
              background:  url( '/local/png/live/door-open.png' ) no-repeat center 0px;
              background-position: center;
              background-repeat: no-repeat;
              background-size: cover;
              background-blend-mode: hard-light;
              position: relative;
            {% elif
            'off') %}
                background:  url( '/local/png/live/door-closed4.png' ) no-repeat center 0px;
                background-color: rgba(150,58,27, 0.9);
                position: relative;
               {% else %}
                background:  url( '/local/png/11.png' ) no-repeat center 0px;
                background-color: #1a1a2a;, 1.25);
                position: relative;
              {% endif %}
              --secondary-text-color: grey;
              box-shadow: none !important;
              background-color: rgba(250,130,43, 0.9);
              height: 170px !important;
            :host {
              --mush-icon-size: 70px;
layout_type: custom:vertical-layout
hi,
how can we this make work?
primary: ''
icon: mdi:kettle-steam
icon_color: |-
  {% if is_state('switch.keuken_boiler', 'on') %}
   red
  {% endif %}
entity: switch.keuken_boiler
fill_container: true
layout: vertical
card_mod:
  style:
      ha-state-icon {
        {{'animation: boil 500ms infinite;' if is_state(config.entity, 'on') }}
      @keyframes boil {
        0%, 100% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
        10% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); clip-path: polygon(0 0, 66% 10%, 67% 30%, 88% 52%, 100% 100%, 0 100%); }
        20% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
        30% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
        40% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
        50% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
        60% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
        70% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
        80% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
        90% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
the boil is not shaking
Thanks a lot @berkans ! Works like a charm. Nice cards btw !
Cant have ha-state-icon under mushroom-shape-icon$: | anymore.
Just do it like this instead:
card_mod:
  style: |
    ha-state-icon {
    @keyframes boil {
its work thank you
:wink:
Have you tried to read the “new” guide from Dimitri? He reworked the guides from @rhysb to take care of recent updates in Mushromm and HA core.
See here, maybe this helps a little further with your problem.
PS: between us, the idea posting in the other thread and then delete it, my full respect! Really, great idea and thanks for understanding. And you forced me to write an answer here! Really, my full respect! :+1: :+1: :rofl: :rofl:
