Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
I have this media card :
ksnip_20231209-140443
based on something rhysb posted once
type: custom:stack-in-card
cards:
  - type: custom:mushroom-media-player-card
    entity: media_player.mymediaplayer
    icon: mdi:play
    use_media_info: true
    use_media_artwork: false
    show_volume_level: false
    media_controls:
      - play_pause_stop
      - previous
      - next
    volume_controls:
      - volume_buttons
      - volume_set
    fill_container: false
    card_mod:
      style: |
        mushroom-shape-icon {
          display: flex;
          {% set media_type = state_attr(config.entity, 'media_content_type') %}
          {% if  media_type == 'music' %}
            --card-mod-icon: mdi:music;
            animation: beat 1.3s ease-out infinite both;
          {% elif media_type == 'playlist' %}
          {% else %}
            --card-mod-icon: mdi:play;
          {% endif %}
          {{ 'animation: none;' if not is_state(config.entity, 'playing') }}
        @keyframes flicker {
          0%, 31.98%, 32.98%, 34.98%, 36.98%, 39.98%, 67.98%, 68.98%, 95.98%, 96.98%, 97.98%, 98.98%, 100% { --icon-color: rgba(var(--rgb-indigo), 1); }
          32%, 33%, 35%, 36%, 37%, 40%, 68%, 69%, 96%, 97%, 98%, 99% { --icon-color: rgba(var(--rgb-indigo), 0.6); }
        @keyframes beat {
          0%, 60% { --icon-symbol-size: 21px; }
          5%, 17%, 57% { --icon-symbol-size: 22px; }
          10%, 20%, 51% { --icon-symbol-size: 23px; }
          25%, 45% { --icon-symbol-size: 24px; }
          30%, 39% { --icon-symbol-size: 25px; }
          33% { --icon-symbol-size: 26px; }
        ha-card {
          --ha-card-border-width: 0;
  - type: conditional
    conditions:
      - entity: media_player.mymediaplayer
        state_not: 'off'
        state_not: idle
    card:
      hide:
        icon: true
        runtime: true
        source: true
        power: true
        state_label: true
        volume: true
        info: true
        progress: false
        controls: true
      more_info: false
      type: custom:mini-media-player
      toggle_power: false
      group: true
      card_mod:
        style:
          mmp-progress$: |
            paper-progress {
              {{ '--paper-progress-container-color: rgba(var(--rgb-indigo-color), 0.2) !important;' if is_state(config.entity, 'playing') }}
            ha-card {
              margin: 0px 12px 12px;
              --mmp-progress-height: 12px !important;
              height: var(--mmp-progress-height);
              --mmp-accent-color: rgb(var(--rgb-indigo-color));
              --mmp-border-radius: 12px !important;
card_mod:
  style: |
    ha-card::before {
      transform: translate3d(0,0,0);
      -webkit-transform: translate3d(0,0,0);
      {% if not is_state('media_player.lounge_speaker', 'idle') %}
        content: "";
        position: absolute;
        height: 100%;
        width: 100%;
        background: url( '{{ state_attr('media_player.mymediaplayer', "entity_picture") }}' ) center no-repeat;
        filter: blur(150px) saturate(400%);
        background-size: 100%;
      {% endif %}
    ha-card {
      --primary-text-color: rgb(ff,bf,00);
      --secondary-text-color: rgb(ff,bf,00);
      {% if not is_state('media_player.mymediaplayer', 'idle') %}
        background: url( '{{ state_attr("media_player.mymediaplayer", "entity_picture") }}' ), linear-gradient(to left, transparent, rgb(var(--rgb-card-background-color)) 90%);
          background-size: 20% auto, cover;
        background-position: right;
        background-repeat: no-repeat;
        background-blend-mode: saturation;
      {% endif %}
Iā€™d like to know how to
  1. Swap the artist with the track (ie swap primary & secondary information)
  2. Square off the album cover on the right handside, whilst retaining the rounded edges to the actual card
Thanks :slight_smile:
what am i doing wrong?
            card_mod:
                    style: |
                      ha-card {
                        background: #afc9d1;
                        box-shadow: none;
                        border: none !important;
                      mushroom-shape-avatar$: |
                        .picture {
                          animation: ping 2s infinite;
                        @keyframes ping {
                          0% {
                            box-shadow: 0 0 5px 1px rgba(var(--rgb-green), 0.7);
                          100% {
                            box-shadow: 0 0 5px 15px transparent;
Next time do please state what you are trying to achieve. But in essence your problem is that you cant have 2 | in a row which you had here (if you removed the extra things you had listed)
card_mod:
  style: |
This is not allowed. You need to only have 1 | so like this:
card_mod:
  style:
Then to get back to using style: | which you need for your ha-card you can use .: | this is used to take you back like this:
card_mod:
  style:
      .picture {
        something: test;
      ha-card {
        something-else: test;
So to fix your code it would be like this:
card_mod:
  style:
      .picture {
      @keyframes ping {
        0% {box-shadow: 0 0 5px 1px rgba(var(--rgb-green), 0.7);}
        100% {box-shadow: 0 0 5px 15px transparent;}
      ha-card {
        box-shadow: none;
this now works, but when person is away, how to change the color of the ping?
type: custom:mushroom-person-card
mode: vertical
card_mod:
style:
.picture {
@keyframes ping {
0% {box-shadow: 0 0 5px 1px rgba(var(ā€“rgb-green), 0.7);}
ha-card {
box-shadow: none;
Im not trying to be annoying, but please just ask all your questions in the first post please :slight_smile:
But you can use templates in card mod. So like this:
card_mod:
  style:
      .picture {
        {% if states(config.entity) == 'home' %}
          animation: pinghome 2s infinite;
        {% elif states(config.entity) == 'away' %}
          animation: pingaway 2s infinite;
        {% endif %}
      @keyframes pinghome {
      @keyframes pingaway {
        0% {box-shadow: 0 0 5px 1px rgba(var(--rgb-red), 0.7);}
      ha-card {
        box-shadow: none;
Dimitri?
Im using your mushroom person card
But i wanted to have on right side
Of the icon (person)
The proximity then underneath it
The battery and under that wfi
Is this possible to do?
I saw in persons thread such but not with
Your mushroom cardā€¦
Using it in an horizontal-stack card
So there will be room for itā€¦
entity: person.tork
icon_type: entity-picture
fill_container: true
card_mod:
  style:
      .picture {
      display: flex;
      border-radius: 50%;
      animation: pinggreen 6s infinite;
      {% else %}
      animation: pingred 6s infinite;
      {% endif %}
      @keyframes pinggreen {
      0% {box-shadow: 0 0 5px 3px rgba(var(--rgb-green), 0.9);}
      100% {box-shadow: 0 0 5px 5px transparent;}
      @keyframes pingred {
      0% {box-shadow: 0 0 5px 3px rgba(var(--rgb-red), 0.9);}
      ha-card {
      border: 0.5px outset grey !important;
      height: 69px !important;
      font-variant: small-caps;
Thanks for listing all that you want in 1 question - could you however try and give a bit more detail on what you want? Perhaps some screenshots of what you saw and want to mimic or draw some explanation of what you want where?
Im sorry for not beeing clearā€¦did try thoā€¦heh
1
This is what im trying to adcieveā€¦
Took it from this thread >person card show off
Thank You Dimitri!!!
Something like this?
SmartSelect_20231210_144731_Home Assistant
I dont use a picture so just swap mushroom-shape-icon$: | for mushroom-shape-avatar$: |, .shape { for .picture { and --shape-animation: for animation:
Code
cards:
  - type: custom:mushroom-person-card
    entity: person.dimitri_landerloos
    card_mod:
      style:
          .shape {
            display: flex;
            border-radius: 50%;
            --icon-symbol-size: 58px;
            --icon-size: 80px;
              --shape-animation: pinggreen 6s infinite;
            {% else %}
              --shape-animation: pingred 6s infinite;
            {% endif %}
        mushroom-state-info$: |
          .container {
            --card-primary-font-size: 20px;
            --card-secondary-font-size: 20px;
          ha-card {
            background: none !important;
            height: 116px !important;
          mushroom-badge-icon {
            --badge-size: 24px;
  - type: custom:mushroom-chips-card
    chips:
      - type: template
        icon: mdi:map-marker-distance
        content: 4 km
      - type: template
        icon: mdi:battery-charging
        content: 89%
      - type: template
        icon: mdi:wifi
        content: Signal
    alignment: justify
    card_mod:
      style: |
        ha-card {
          position: absolute;
          top: 2px;
          right: 30px;
          width: 80px;
          --chip-spacing: 0px;
card_mod:
  style: |
    ha-card {
I also dont have the sensors that you mentioned so i just put fixed values instead. But just fill in the content section of each template chip with the state of your sensor.
The chips will be a bit sensitive to width because they arent forced to stay in a column. So just keep that in mind :slight_smile:
Somehow i could not get this workingā€¦
But it was pretty helpfull!
So i did made this:
cards:
    entity: person.tork
    card_mod:
      style:
          .picture {
           display: flex;
           border-radius: 50%;
           {% else %}
           {% endif %}
  - type: entities
    entities:
      - entity: proximity.afstand
      - entity: sensor.sm_a546b_battery_level
    show_header_toggle: false
    state_color: true
    card_mod:
      style: |
        ha-card {
         # background: none !important;
          position: absolute;
          top: -18px;
          right: 50px;
          width: 170px;
card_mod:
  style: |
    ha-card {
     height: 84px !important;
Im still learning!..
There is only 1 prob with itā€¦
The spacing between the both lines ( distance & battry)ā€¦wanted it closer to eachother in line
Thanky!!!
Iā€™m trying to follow your example but I cannot get it to work. This is my current code:
entity: person.ignacio_martinez
primary_info: none
secondary_info: none
tap_action:
  action: navigate
  navigation_path: '#ignacio'
hold_action:
  action: call-service
  service: script.unmute_ignacios_pixel_5
  data: {}
  target: {}
card_mod:
  style:
      .shape {
        display: flex;
        border-radius: 50%;
        --icon-size: 80px;
        {% if states('switch.ignacio') == 'on' %}
        {% else %}
        {% endif %}
        animation: var(--shape-animation);
and this is what the card looks like
I checked in the developer tools console that the if statemet works:
Adjusted now - should work better and no need to change anything other than the entities being referred to :slight_smile:
Untitled video - Made with Clipchamp - 2023-12-10T182936.028
cards:
    card_mod:
      style:
          .picture {
            display: flex;
            border-radius: 50%;
            {% else %}
            {% endif %}
          .container {
            --icon-size: 80px !important;
          .container {
          ha-card {
            height: 96px !important;
            --badge-size: 24px;
    chips:
      - type: template
        content: 4 km
        card_mod:
          style: |
            ha-card {
              border: none;
              box-shadow: none;
      - type: template
        content: 89%
        card_mod:
          style: |
            ha-card {
              border: none;
              box-shadow: none;
      - type: template
        icon: mdi:wifi
        content: Signal
        card_mod:
          style: |
            ha-card {
              border: none;
              box-shadow: none;
    alignment: justify
    card_mod:
      style: |
        ha-card {
          position: absolute;
          top: 2px;
          right: 30px;
          width: 80px;
          --chip-spacing: -10px;
          --chip-background: none;
card_mod:
  style: |
    ha-card {
take a look at the one i just posted instead.
but also in the code you posted you didnt adjust the things that i mentioned for when using a picture.
you shouldnt need to adust anything with the new code provided. but you do need to have stack-in-card from HACS downloaded.
That worked great!!!
And yes the one i posted last i made myself
After fiddling around with yoursā€¦
Keep on rocking Dimitri!!! Yay
You can swap the primary and secondary just by adding
    primary_info: state
    secondary_info: name
to your initial mushroom-media-player-card.
im not getting the card itself to look like yours for some reason. so i am struggling to be able to help you with the album bit.
Thanks for the primary/secondary bit. Youā€™ve made me realise that the album art is being rendered by custom mini player and nothing mushrooms related. I also suspect thereā€™s something in my theme which makes mine appear different to yoursā€¦ Iā€™ll keep tinkeringā€¦ thanks
please tell me how to connect in one line without borders?
Cant be done by default, but easy enough with card mod:
chips:
  - type: entity
card_mod:
  style: |
    ha-card {
      --chip-border: none !important;
      --chip-box-shadow: none !important;
That is super, thanks!
Is this also possible with the mushroom template card?
I have now my chips without background, would love to have this card also without background.
cards:
    icon: mdi:pine-tree
    icon_color: green
    primary: Aantal dagen tot Kerst
    secondary: >-
      {{ (states('input_datetime.christmas') | as_datetime | as_local -
      now()).days + 1 }}
    layout: vertical
    icon: mdi:star-four-points
    icon_color: yellow
    layout: vertical
    card_mod:
      style:
          .shape {
            --shape-color: none;
          ha-card {
            top: -118px;
          ha-state-icon {
            animation: star 8s ease infinite alternate;
          @keyframes star {
            0%, 100% { transform: translateY(-10px) rotate(0deg) scale(0.4); }
            50% { transform: translateY(-10px) rotate(360deg) scale(0.6); }
    icon: mdi:gift
    icon_color: red
    layout: vertical
    card_mod:
      style:
          .shape {
            --icon-size: 20px;
            top: 16px;
            left: 18px;
          ha-card {
            top: -183px;
            right: 10px;
          ha-state-icon {
            animation: surprise 4s ease infinite;
          @keyframes surprise {
            0%, 20%, 100% { transform: translateY(0); }
            2.5% { transform: translateY(-2px) rotate(-27deg); }
            5% { transform: translateY(-2px) rotate(21deg); }
            7.5% { transform: translateY(-2px) rotate(-15deg); }
            10% { transform: translateY(-2px) rotate(9deg); }
            12.5% { transform: translateY(0); }
            15% { transform: translateY(-1.2px) }
card_mod:
  style: |
    ha-card {
      height: 116px;
Found it, this will do :ok_hand:
card_mod:
  style: |
    ha-card {
      background-color: #0000;
Only looking for a way to make it more (or less) transparent.
Any thoughts?
