Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
the important changes nothing.
no theme installed
One last shot
type: custom:mushroom-template-card
primary: |
  {{states('sensor.inverter_1_yield_today')}} kW
secondary: Heute
icon: mdi:lightning-bolt
icon_color: black
fill_container: true
entity: sensor.inverter_1_yield_today
tap_action:
  action: more-info
card_mod:
  style: |
    ha-card {
          border: none;
          border-radius: 25px;
          --icon-symbol-size: 35px;
          --card-primary-color: black !important;
          --card-secondary-color: black !important;
          --card-secondary-font-weight: 400;
          transition: 0s;
          background:
            {% if states('sensor.inverter_1_bt2240102870_realtime_power') < '0.001'%}
            rgb(255, 255, 190)
            {% elif states('sensor.inverter_1_bt2240102870_realtime_power') >'0.001'%}
            rgb(255, 255, 80)
            {%endif%}
           @media screen and (max-width: 400px) {
                ha-card {
You should also be able to clean up you background if statement
background:
            rgb(255, 255, 190)
            {% else %}
            rgb(255, 255, 80)
            {% endif %}
no luck! still the same
Is your PC still correct? Ensure you are on Core 2024.2.1 and Mushroom 3.4.2
yes as u said. all up to date.
only on template card since update yesterday
Unfortunately I’m out of possible answers. Its working fine on my PC and my android.
I like it. Would you share your code?
For me, this works on Template Card
--primary-text-color: black !important;
Oh man, I saw it but miss it :frowning: Dope! Thanks!
Peek 2024-02-12 13-55
@bandit79
--primary-text-color is going to work because card-primary color: uses it, but it can also change a lot of other text in your dashboard if you use --primary-text-color:
@LiQuid_cOOled I have one more q, if a chip have a text, it possible animate icon only and text leave is in normal state?
this gives me grey color in the APP on Android
hi
i am trying to scale the icons of a mushroom chip card with templates (i.e. have bigger icons than the default). i have tried multiple solutions suggested here with card-mod and without but either i am too daft or none of them work for my scenario (snippet of the actual card):
type: custom:mushroom-chips-card
chips:
  - type: template
    entity: switch.tasmota
    icon_color: '{{ ''orange'' if states(''switch.tasmota'') == ''on'' else ''red'' }}'
    icon: mdi:power-socket-de
    content: LEDs
this works perfectly fine but the icons are ever so small on the phone.
any help would be much appreciated
U can set size of chip with this code and your adjustments:
      style: |
        ha-card {
          justify-content: center;
          --chip-icon-size: 64px;
          --chip-height: 64px;
          width: var(--chip-height) !important;
          border-radius: 50% !important;
          --chip-background: rgba(var(--rgb-green), 0.2);
And look at this my post Mushroom Cards - Build a beautiful dashboard easily 🍄 - #10113 by SoulAssassin, today @LiQuid_cOOled gived a best tip for my case, as I understood, u have similiar issue.
thank you very much! that works splendidly
I’m also interested in the .yaml code of the custom mushroom-template-card you made for the washing machine. Looks great.
Can you share the total .yaml code with us please
tap_action: using a template
Possible to do this? This is my code, but doesn’t appear to be working:
  de_mushroom_entity:
    card:
      primary: '[[name]]'
      secondary: ''
      icon: '[[icon]]'
      entity: '[[entity]]'
      icon_color: '{{ ''amber'' if is_state(''[[entity]]'', ''on'') else ''#44739e'' }}'
      layout: vertical
      tap_action:
        action: >-
          {% if 'sensor' in [[entity]] %}
            more-info
          {% else %}
            toggle
          {% endif %}
      double_tap_action:
        action: more-info
Worth noting, I’m also using the ‘decluttering-card’
Thx!
Can someone tell me how to make a mushroom card wider?
I have a vertical layout Im doing for my daughter’s ipad. Full screen is a bit much and distorted, but veritcal layout isn’t quite wide enough. Is there a way to do this based off of a percentage?
This question seems more appropriate for the decluttering topic
explore the @media screen and (max-width: 600px) { settings.
It’s used is to apply different styles for different media types/devices and will not adjust your PC settings.
An example of it’s use
        card_mod:
            style: |
                ha-card {
                  --icon-size: 40px;
                  --icon-symbol-size: 35px ;
                ha-card {
                  --icon-size: 60px;
                  --icon-symbol-size: 45px ;
