Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Thanks a lot for your response
Works like a charm, but maybe too much :smiley:
It makes the text also spin. I should have precised it a bit, but i just want the icon to spin. I’ll try to find a way thanks to the information you provided
EDIT: found a way :
type: custom:mushroom-chips-card
chips:
  - type: entity
    entity: sensor.pinas_fan_speed
    icon: mdi:fan
    icon_color: blue
card_mod:
  style:
    mushroom-entity-chip:nth-child(1)$: |
      ha-state-icon {
        animation: spin 1s linear infinite;
@PetitSphincter Yes sir, That is why I wanted you to read through that specific section. The nth-child(1)$: | method is a great way of splitting CSS elements apart for different mods. Good job!
Mushroom has some animations built in now. Spin is one of them, for one that are preprogrammed you’ll have to use @keyframes.
A keyframes example to spin the fan in reverse.
chips:
  - type: template
    content: Mushroom
    icon: mdi:fan
    icon_color: red
  - type: entity
    content_info: name
card_mod:
  style:
    mushroom-template-chip:nth-child(1)$: |
      ha-state-icon {
      @keyframes spin {
        100% { transform: rotate(-360deg); }
To add:
The built in animations dont tend to work on all browsers when applied through shadow roots.
So to be safe, when using any $ in your path to the element i would always add keyframes. Just to ensure it has broad browser support.
@PetitSphincter
Hello I have this card:
chips:
  - type: entity
    entity: person.pupetti
    content_info: none
    use_entity_picture: true
    tap_action:
      action: fire-dom-event
      browser_mod:
        service: browser_mod.popup
          title: Federico
          content:
            type: vertical-stack
            cards:
              - type: custom:mushroom-entity-card
                layout: horizontal
                icon_type: entity-picture
                primary_info: state
                secondary_info: last-changed
                tap_action:
                  action: none
                hold_action:
                  action: none
                card_mod:
                  style:
                    mushroom-shape-avatar$: |
                      .picture {
                        /* Style shadow ring around person avatar */
                        box-shadow: 0px 0px 4px 2px var(--state-person);
                        margin-right: var(--mush-title-spacing, 12px);
                      ha-card {
                        /* Remove default card styling */
                        --ha-card-background: none;
                        box-shadow: none;
                        --ha-card-border-width: 0;
                        /* Increase icon size */
                        --icon-size: 72px;
                        /* Center card */
                        margin: auto;
                        width: fit-content;
                        /* Add padding to bottom of card */
                        padding: 0px 0px var(--mush-title-spacing, 12px) 0px !important;
                        /* Make card non-responsive to select and pointer */
                        user-select: none;
                        pointer-events: none;
                        transition: all 0s;
                      :host {
                        /* Define Person State colors. Can be added to theme */
                        --state-person-home: var(--green-color);
                        --state-person-not-home: var(--red-color);
                        --state-person-zone: var(--blue-color);
                        --state-person-unknown: var(--grey-color);
                        /* Set Person State color */
                        --state-person:
                        {% if is_state(config.entity, ['home', 'not_home', 'unknown']) %}
                          var(--state-person-{{ states(config.entity) | replace('_', '-') }})
                        {% else %}
                          var(--state-person-zone)
                        {% endif %};
                        /* Match styling to Mushroom Title */
                        --mush-card-primary-font-size: var(--mush-title-font-size, 24px);
                        --mush-card-primary-font-weight: var(--mush-title-font-weight, normal);
                        --mush-card-primary-line-height: var(--ush-title-line-height, 1.2);
                        --mush-card-secondary-font-size: var(--mush-title-font-size, 16px);
                        --mush-card-secondary-font-weight: var(--mush-title-font-weight, normal);
                        --mush-card-secondary-line-height: var(--ush-title-line-height, 1.2);
              - type: history-graph
                entities:
                  - entity: person.pupetti
                hours_to_show: 24
                title: Timeline
                card_mod:
                  style:
                      .card-header {
                        /* Style timeline title */
                        padding: 0px 24px !important;
                        font-size: var(--mush-card-primary-font-size, 14px) !important;
                        font-weight: var(--mush-card-primary-font-weight, bold) !important;
                        line-height: var(--mush-card-primary-line-height, 1.5) !important;
                        color: var(--primary-text-color) !important;
                      ha-card {
                        --ha-card-box-shadow: none;
                        user-select: none;
                      .content {
                        /* Add padding on right */
              - type: horizontal-stack
                cards:
                  - type: conditional
                    conditions:
                      - entity: sensor.fede_l_16_average_active_pace_3
                        state_not: '0'
                    card:
                      type: custom:mushroom-template-card
                      primary: >-
                        {{ states(entity) }} {{ state_attr(entity,
                        'unit_of_measurement') }}
                      secondary: '{{ state_attr(entity, ''distance'') | round(1) }} km'
                      icon: mdi:map-marker-path
                      entity: sensor.fede_l_16_distance_3
                      layout: vertical
                      icon_color: purple
                      tap_action:
                        action: none
                      hold_action:
                        action: none
                      double_tap_action:
                        action: none
                      card_mod:
                        style:
                          mushroom-state-info$: |
                            .primary:after {
                              /* Add destination details */
                              content: "\Ato Home";
                              white-space: pre;
                              text-overflow: ellipsis;
                            ha-card {
                              /* Center card on row */
                              width: fit-content;
                              margin: auto;
                              user-select: none;
                cards:
                  - type: conditional
                    conditions:
                      - entity: sensor.fede_l_16_geocoded_location_3
                        state_not: '0'
                    card:
                      primary: >-
                      layout: vertical
                      icon_color: purple
                      tap_action:
                        action: none
                      hold_action:
                        action: none
                      double_tap_action:
                        action: none
                      card_mod:
                        style:
                            .primary:after {
                              content: "\Ato Work";
                              white-space: pre;
                            ha-card {
                              width: fit-content;
                              margin: auto;
                              user-select: none;
                    primary: '{{ states(entity) }}%'
                    secondary: >
                      {{ 'charging' if
                      is_state('sensor.fede_l_16_battery_state', 'on' ) else
                      'discharging' }}
                    icon: >
                      {% set battery_level = (states(entity) | int / 10) |
                      round(0) | int * 10 %}
                      {% if battery_level == 100 %}
                        mdi:battery
                      {% elif battery_level > 0 %}
                        mdi:battery-{{ battery_level }}
                      {% else %}
                        mdi:battery-alert-variant-outline
                      {% endif %}
                    icon_color: |-
                      {% set battery_level = states(entity) | int %}
                      {% if battery_level > 90 %}
                        green
                      {% elif battery_level > 60 %}
                        light-green
                      {% elif battery_level > 50 %}
                        lime
                      {% elif battery_level > 40 %}
                        yellow
                      {% elif battery_level > 30 %}
                        amber
                      {% elif battery_level > 20 %}
                        orange
                      {% elif battery_level > 10 %}
                        deep-orange
                      {% else %}
                        red
                      {% endif %}
                    entity: sensor.fede_l_16_battery_level_3
                    layout: vertical
                    badge_icon: >-
                      {% if is_state('sensor.fede_l_16_battery_state_3', 'on')
                        mdi:lightning-bolt
                      {% elif states(entity) | int < 10 %}
                        mdi:exclamation-thick
                      {% endif %}
                    badge_color: '{{ ''red'' if states(entity) | int < 10 else ''light-blue'' }}'
                    tap_action:
                      action: none
                    hold_action:
                      action: none
                    double_tap_action:
                      action: none
                    card_mod:
                      style:
                        mushroom-shape-icon$: |
                          .shape {
                            /* Radial progress bar */
                            background: radial-gradient(var(--card-background-color) 60%,
                                                        transparent calc(60% + 1px)),
                                        conic-gradient(var(--icon-color) {{ states(config.entity) }}% 0%,
                                                        var(--card-background-color) 0% 100%);
                          .shape:after {
                            /* Add back icon shape */
                            content: "";
                            height: 100%;
                            width: 100%;
                            position: absolute;
                            border-radius: var(--icon-border-radius);
                            background: var(--shape-color);
                          ha-icon {
                            /* Icon charging animation */
                            {{ '--icon-animation: charge 3s linear infinite;' if is_state('binary_sensor.rhys_phone_is_charging', 'on') }}
                          @keyframes charge {
                            0%, 80% { clip-path: inset(0 0 0 0); }
                            10% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 84%, 34% 84%, 34% 100%, 100% 100%, 100% 0%); }
                            20% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 74%, 34% 74%, 34% 100%, 100% 100%, 100% 0%); }
                            30% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 64%, 34% 64%, 34% 100%, 100% 100%, 100% 0%); }
                            40% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 54%, 34% 54%, 34% 100%, 100% 100%, 100% 0%); }
                            50% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 44%, 34% 44%, 34% 100%, 100% 100%, 100% 0%); }
                            60% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 34%, 34% 34%, 34% 100%, 100% 100%, 100% 0%); }
                            70% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 24%, 34% 24%, 34% 100%, 100% 100%, 100% 0%); }
                          ha-card {
                            width: fit-content;
                            margin: auto;
                            user-select: none;
                  - type: conditional
                    conditions:
                      - entity: sensor.fede_l_16_connection_type_3
                        state_not: <not connected>
                    card:
                      primary: '{{ states(''sensor.fede_l_16_connection_type_3'') }}'
                      secondary: >-
                        {% set signal_level = states(entity) | int %} {% if
                        signal_level != -1 %}
                          {{ signal_level }} dBm
                        {% endif %}
                      icon: >-
                        {% set signal_level = states(entity) | int | abs %} {%
                        if signal_level > 90 %}
                          mdi:wifi-strength-outline
                        {% elif signal_level > 80 %}
                          mdi:wifi-strength-1
                        {% elif signal_level > 70 %}
                          mdi:wifi-strength-2
                        {% elif signal_level > 60 %}
                          mdi:wifi-strength-3
                        {% elif signal_level > 1 %}
                          mdi:wifi-strength-4
                        {% else %}
                          mdi:wifi-strength-off
                        {% endif %}
                      layout: vertical
                      fill_container: false
                      icon_color: cyan
                      tap_action:
                        action: none
                      hold_action:
                        action: none
                      double_tap_action:
                        action: none
                      card_mod:
                        style: |
                          ha-card {
                            width: fit-content;
                            margin: auto;
                            user-select: none;
              - type: custom:mushroom-chips-card
                chips:
                  - type: template
                    tap_action:
                      action: none;
                    hold_action:
                      action: call-service
                      service: notify.mobile_app_fede_l_16
                        message: Ringing phone...
                        title: Find Phone
                          ttl: 0
                          importance: high
                          priority: high
                          tag: Find
                          channel: alarm_stream
                    icon: mdi:target
                    icon_color: red
                    content: Find Phone
                alignment: center
                card_mod:
                  style: |
                    ha-card {
                      /* Style Chip like Mushroom button */
                      --chip-background: rgba(var(--rgb-red), 0.2);
                      --chip-border-radius: var(--mush-control-border-radius, 12px);
                      --chip-height: var(--mush-control-height, 42px);
                      --chip-box-shadow: none;
                      user-select: none;
                    ha-card:active {
                      /* Add effect to give feedback on button press */
                      --chip-background: rgba(var(--rgb-red), 0.4);
              - type: map
                entities:
                dark_mode: false
                hours_to_show: 24
                aspect_ratio: '4:3'
                card_mod:
                  style:
                    ha-map $ ha-entity-marker $: |
                      .marker {
                        /* Style person marker & adjust position to avoid blocking waypoints */
                        border: 3px solid var(--state-person) !important;
                        border-radius: 50% 50% 50% 0px !important;
                        transform: rotate(-45deg) translate(50%, -50%);
                        overflow: visible !important;
                        background: var(--state-person) !important;
                      .entity-picture {
                        /* Correct orientation of person avatar */
                        transform: rotate(45deg);
                        border-radius: 50%;
                    ha-map $: |
                      path:first-child {
                        /* Style accuracy radius */
                        stroke: var(--state-person);
                        fill: color-mix(in srgb, var(--state-person) 50%, transparent);
                        stroke-width: 0px;
                      path:nth-child(even) {
                        /* Styling for waypoints */
                        stroke: var(--purple-color);
                        stroke-width: 4px;
                      path:nth-child(odd):not(:first-child) {
                        /* Styling for lines */
                        stroke-width: 4px;
                      .leaflet-control-attribution {
                        /* Style attribution text */
                        background: rgba(var(--rgb-card-background-color), 0.4) !important;
                        font-size: 10px;
                      .leaflet-container a {
                        /* Set color of zoom icons & attribution text */
                        color: var(--secondary-text-color);
                      .leaflet-control-zoom-in,
                      .leaflet-control-zoom-out {
                        /* Style zoom buttons like Chips */
                        border-radius: var(--mush-chip-border-radius, 19px) !important;
                        padding: 3px;
                        background: rgb(var(--rgb-secondary-text-color), 0.2) !important;
                        margin: 8px 12px 0px;
                        border: var(--ha-card-border-width, 1px) solid var(--ha-card-border-color, var(--divider-color, #e0e0e0)) !important;
                      .leaflet-top {
                        /* Move zoom buttons to bottom of map */
                        bottom: 0px !important;
                      .leaflet-control-zoom {
                        /* Allow buttons to be moved */
                        position: absolute !important;
                        /* Adjust spacing for border */
                        bottom: calc(2 * var(--ha-card-border-width, 1px) + 56px);
                        /* Remove extra margin */
                        margin: 0px !important;
                        /* Remove zoom control border */
                        border: none !important;
                      .leaflet-container:after {
                        /* Fade out map at top */
                        content: "";
                        position: absolute;
                        height: 100%;
                        width: 100%;
                        background: linear-gradient(to top, transparent 65%, var(--card-background-color));
                    ha-icon-button $ mwc-icon-button $: |
                      button {
                        /* Size center button to match Chip */
                        height: var(--mush-chip-height, 36px) !important;
                        width: var(--mush-chip-height, 36px) !important;
                        --mdc-icon-size: 22px;
                      ha-card {
                        /* Remove default card styling without affecting child elements */
                        box-shadow: none;
                        border-width: 0;
                        border-radius: 0px 0px var(--ha-card-border-radius, 12px) var(--ha-card-border-radius, 12px);
                        transition: all 0s;
                      :host {
                        /* Set person state color */
                        --state-person:
                        {% if is_state(config.entities[0].entity, ['home', 'not_home', 'unknown']) %}
                          var(--state-person-{{ states(config.entities[0].entity) | replace('_', '-') }})
                        {% else %}
                        {% endif %};
                      ha-icon-button {
                        /* Position center button */
                        bottom: 12px;
                        left: 12px !important;
                        top: auto !important;
                        /* Style center button to match Chip */
                        color: var(--deep-orange-color) !important;
                        background: color-mix(in srgb, var(--deep-orange-color) 20%, transparent);
                        border-radius: var(--mush-chip-border-radius, 19px);
          card_mod:
            style: |
              :host {
                /* Remove border from poup */
                --popup-padding-x: 0px;
                --popup-padding-y: 0px;
                --popup-min-width: 450px;
              .content {
                /* Remove extra bottom border */
                margin: -18px -24px -24px !important;
    card_mod:
      style: |
        /* Color border around avatar to show person status */
        ha-card {
          --chip-background:
            rgb(var(--rgb-state-person-{{ states(config.entity) | replace('_', '-') }} ))
          {% else %}
            rgb(var(--rgb-state-person-zone))
          {% endif %};
        /* Slightly enlarge & bring to front on hover */
        ha-card:hover {
          transform: scale(1.2);
          transform-origin: top center;
          z-index: 1;
          transition: all 1s;
But the problem is when im in my office. My zone.work creates this situation in my pop up:
I have both conditions home/not_home by my iPhone device tracker …. Could you help me to solve it? Thank you
Cn you please you be more specific what this situation in my pop up: means? Just we are on the same page.
Yes in my photo I have 2 cards with “Lavoro” but it should appear one only. “Casa” when im at home, “Fuori Casa” when im not_home and “Lavoro” when im working in my office.
Now im working and I have two card with “Lavoro”- “Casa” and “Lavoro”-“Fuori Casa”
I hope to have explained better
Understood! Thank you!
Here is my card:
          icon: |-
            {% if is_state('binary_sensor.bathroom_washing_machine_door_contact', 'on') %}
              mdi:tumble-dryer
            {% else %}
              mdi:washing-machine
            {% endif %}
          icon_color: |-
                {% if is_state('binary_sensor.washing_machine', 'on') %}
                  amber
                {% elif is_state('switch.bathroom_washing_machine_socket','on') %}
                  orange
                {% else %}
                {% endif %}
          primary: |-
                {% if is_state('input_select.washing_machine_state','Washing') %}
                  Washing
                {% elif is_state('input_select.washing_machine_state','Drying') %}
                  Drying
                {% elif is_state('input_select.washing_machine_state','Error') %}
                  ERROR!
                  Power On
                {% else %}
                  Power Off
                {% endif %}
          secondary: |-
              Opened
            {% else %}
            {% endif %}
          layout: vertical
          card_mod:
            style: |
                ha-card {
                    --card-primary-color: red;
                    --card-primary-color: green;
                    --card-primary-color: orange;
                  {% else %}
                    --card-primary-color: black;
                  {% endif %}
                :host {
                  --icon-size: 64px !important;
                ha-state-icon {
                  {% if states('binary_sensor.washing_machine') == 'on' %}
                  animation: shake 400ms ease-in-out infinite, drum 2s ease infinite;
                  transform-origin: 50% 110%;
                  {%- else -%}
                  {%- endif %}
                @keyframes shake {
                  0%, 100% { transform: translate(0, 0) rotate(0); }
                  20%  { transform: translate(0.4px, -0.4px) rotate(-4deg); }
                  40%  { transform: translate(-0.4px, 0.4px) rotate(4deg); }
                  60%  { transform: translate(0.4px, 0.4px) rotate(-4deg); }
                  80%  { transform: translate(-0.4px, -0.4px) rotate(4deg); }
                @keyframes drum {
                  50%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0); }
I would like to insert an electrical connection icon as an overlay, is this possible?
Did you figure out the chip animation without the words animated?
I meant to answer you on that.
I am confused about what you are describing. Can you explain it better and/or provide an edited picture of what you want?
hi all,
can somebody my help me,
the code is again broke,
style: |
              ha-state-icon {
                {{'animation: cloudy 10s ease-in-out infinite, rain 1.5s infinite;' if is_state(config.entity, 'on') }}
                  @keyframes cloudy {
                    0%, 100% { transform: translateX(3px); }
                    30% { transform: translateX(-1px); }
                    45% { transform: translateX(1.5px); }
                    75% { transform: translateX(-3.2px); }
                  @keyframes rain {
                    50% { clip-path: polygon(0 0, 100% 0, 100% 73%, 71% 73%, 50% 39%, 29% 73%, 0 73%); }
what its wrong he do not animated, thank you for helping
code is working fine, but it seems the colors are defined incorrectly
Can you provide more of the card code just so we know what we are working with?
This portion and animation is working just fine…
primary: Yellow Clouds
icon: mdi:weather-cloudy
entity: light.pc_hue_bar
icon_color: yellow
card_mod:
  style: |
    ha-state-icon {
      {{ 'animation: cloudy 5s ease-in-out infinite' if is_state(config.entity, 'on') }}
    @keyframes cloudy {
            primary: |-
              {% if is_state('binary_sensor.regensensor', 'on') %}
               Het regent
              {% else %}
               Droog
              {% endif %}
            secondary: ''
            icon: |2-
                  mdi:weather-rainy
                {% elif is_state('sun.sun', 'above_horizon') %}
                  mdi:weather-sunny
                {% else %}
                  mdi:moon-waning-crescent
                {% endif %}
            entity: binary_sensor.regensensor
            icon_color: |-
                blue
              {% else %}
                yellow
              {% endif %}
            fill_container: true
            multiline_secondary: true
            tap_action:
              action: more-info
            card_mod: null
            style: |
              ha-state-icon {
                  @keyframes cloudy {
                  @keyframes rain {
If it is going to rain then the cloud should move and the drop should also flash And the color its good raining its bleu sunny its yellow, is only the animatie, by rain
Let’s start with this…let me know if you get any strange behavior
primary: |-
               Het regent
              {% else %}
               Droog
              {% endif %}
secondary: ''
icon: |-
                  mdi:weather-rainy
                  mdi:weather-sunny
                {% else %}
                {% endif %}
icon_color: |-
                blue
              {% else %}
                yellow
              {% endif %}
tap_action:
              action: more-info
card_mod:
            style: |
              ha-state-icon {
                {{'animation: cloudy 10s ease-in-out infinite, rain 1.5s infinite;' if states(config.entity, 'on') }}
                  @keyframes cloudy {
                  @keyframes rain {
It’s probably my fault that I started with such a gargantuan long post, but can someone offer me some help on this post:
TL:DR : I have a card that isn’t mushroom, that I’m trying to recreate using mushroom and can’t quite get it onto one card. Code attached for the original card as well as attempts at replicating.
Its after 5am for me so I can take a look tomorrow. Your card-mod code definitely needs adjusted it it may be best to tackle this 1 section at a time. It’s best you learn as we go rather than one of us simply providing the end result.
I talking 'bout put in overlay some icon.
Like this, I have a counter in my airwick, but can I add icon not text?
Btw, nope, if it possible I will be implemented this. :+1:
