Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Didnt work
Oh, right. I think I discovered that too. You can just use a hyphen - as a placeholder.
I’m just trying to replicate this the below. Just with a temperature in front of it (and not a lock, obviously).
Buddy, this may offend you, but…
Your plan to have these fancy cards without having any coding background and/or patience is like getting your driver’s liscence and insisting to buy a ferrari: you can’t handle it! (And probably crash it the first hour).
Here’s something to start with although almost all guys shared their code with similar cards before:
type: horizontal-stack
cards:
  - type: custom:stack-in-card
    mode: vertical
    cards:
        primary: Hallways
        secondary: up & down
        icon: mdi:light-recessed
        entity: light.MAYBEAGROUPOFYOURHALLWAYLIGHTS
        icon_color: |-
          {% if is_state('light.MAYBEAGROUPOFYOURHALLWAYLIGHTS', 'on') %}
            orange
          {% endif %}
        fill_container: false
        multiline_secondary: true
        tap_action:
          action: navigate
          navigation_path: CARDTOYOURHALLWAYCOMBINATIONVIEW
        hold_action:
          action: toggle
        double_tap_action:
          action: none
      - square: false
        columns: 4
        type: grid
        cards:
          - type: custom:mushroom-chips-card
            chips:
              - type: template
                icon: null
                double_tap_action:
                  action: none
                content: '↑{{ states(''sensor.DOWNSTAIRSHALLWAYTEMP') | float }}°C'
                entity: sensor.DOWNSTAIRSHALLWAYTEMP
                tap_action:
                  action: more-info
                hold_action:
                  action: none
                card_mod: null
                style: |
                  ha-card {
                    --chip-box-shadow: 0px 0px;
            alignment: center
            chips:
              - type: template
                icon: null
                double_tap_action:
                  action: none
                content: '↓{{ states(''sensor.UPSTAIRSHALLWAYTEMP'') | float }}°F'
                entity: sensor.UPSTAIRSHALLWAYTEMP
                tap_action:
                  action: more-info
                hold_action:
                  action: none
                card_mod: null
                style: |
                  ha-card {
            alignment: center
    cards:
        primary: Whatever
        secondary:  Room
        entity: light.WHATEVERROOM
        icon_color: |-
          {% if is_state('light.WHATEVERROOM', 'on') %}
            orange
          {% endif %}
        tap_action:
          action: navigate
          navigation_path: WHATEVERROOM
        hold_action:
          action: toggle
        double_tap_action:
          action: none
      - square: false
        columns: 4
        type: grid
        cards:
            chips:
              - type: template
                icon: null
                double_tap_action:
                  action: none
                content: '↑{{ states(''sensor.WHATEVERROOM_1'') | float }}°F'
                entity: sensor.WHATEVERROOM_1
                tap_action:
                  action: more-info
                hold_action:
                  action: none
                card_mod: null
                style: |
                  ha-card {
            alignment: center
            chips:
              - type: template
                icon: null
                double_tap_action:
                  action: none
                content: '↓{{ states(''sensor.WHATEVERROOM_2') | float }}°F'
                entity: sensor.WHATEVERROOM_2
                tap_action:
                  action: more-info
                hold_action:
                  action: none
                card_mod: null
                style: |
                  ha-card {
            alignment: center
And now it’s your turn to…
…read this whole thread.
…read about Horizontal Stack Card.
…read about Stack-In-Card
…read about templating
…read about card-mod.
…read this whole thread again.
We all want it all and of course rightnow but that ain’t gonna work! Just copying code of everyone is the redneck-repair-version auf coding. And as I for myself have zero coding background I learned things the hard way AND had a steep learning curve as I just read and tested everything over and over again.
That bottom row is a Mushroom Chips card. You would use a Template or Weather chip for temperature.
More here: lovelace-mushroom/chips.md at b5c361bd29e5788f3ad814d99453c50d08e741ea Ā· piitaya/lovelace-mushroom Ā· GitHub
To template, you’ll need to learn templating as @RodgerDodger mentioned. It’s actually not too difficult once you learn the basic structure. Pay attention to using {{ vs {% and start with other’s working templates substituting your own entities to start.
That and a couple stack-in cards to wrap around the Template and Chips card is all you would need to get the look and function in the screenshot.
Card_mod (and themes) would allow you to further customize the look as you’re seeing with some of these more recent posts.
Also, YouTube is your friend :wink:
I’m having a bit of trouble with this card:
- type: custom:mushroom-entity-card
  entity: switch.tv
  icon: mdi:lightbulb
  tap_action:
    action: toggle
  style: |
     ha-card {
         background-color: rgba(255, 255, 255, .1);
It runs the switch.tv to on and everything runs as expected problem is it’s not turning it off. Here’s the entire thing. Any suggestions/help would be greatly appreciated!!! Thank you!
tv switch →
  switches:
    tv:
      value_template: "{{ is_state('media_player.vizio_smartcast', 'on') }}"
      turn_off:
        service: script.turn_off
          entity_id: script.tv_off
      turn_on:
        service: script.turn_on
          entity_id: script.tv_on
tv script →
tv_on:
  alias: turn on tv
  sequence:
    - service: media_player.turn_on
        entity_id: media_player.shield
    - service: light.turn_on
        entity_id: light.tv_stand_2
        entity_id: media_player.vizio_smartcast
    - delay: "00:01:00"
    - service: media_player.select_source
        source: HDMI-3
    - service: switch.turn_on
        entity_id: switch.living_room_ambient_tv
    - delay: "00:01:30"
tv_off:
  alias: turn off tv
  sequence:
    - service: light.turn_off
    - service: switch.turn_off
    - service: media_player.turn_off
Buddy, yes, your response was offensive. I’ve read through this thread and I’ve seen how incredibly helpful you can be; so this was a surprise. :wink: (Who said I didn’t have patience and tenacity?)
I was missing a few key details: Stack-In-Card and card-mod. I’ve read up on them and am off and running now. Thank you.
Maybe don’t assume someone’s aptitude and willingness to learn next time? Ironically, you mentioned it in your last statement. You learned things the hard way. You were me once scratching your head trying to pull stuff together. That’s all I’m doing here.
While somewhat crass, I appreciate the response nonetheless. You set me on the proper course.
From a fellow aviation enthusiast, thank you. I was missing Stack-In-Card and card-mod reading. For some reason, I had it in my head that this was all done with mushroom. Thanks again.
p.s. Mushroom and YT is what got me down this rabbit hole! Well, that and Vera alienating its original userbase and forcing them to look elsewhere. Happy to be here now.
Anyone had any luck inserting the Mushroom theme variables into a non-Mushroom theme? Specifically, I’m trying to affect font sizes. As a test, I copied all of the font-size variables from here, inserted them in my current theme (iOS) and set them really high, but it doesn’t do anything.
      mush-title-font-size: 44px
      mush-subtitle-font-size: 44px
      mush-card-primary-font-size: 44px
      mush-card-secondary-font-size: 44px
      mush-chip-font-size: 44em
EDIT: Nevermind, apparently reloading themes requires an HA restart or calling the frontend.reload_themes service. I looked under Developer Tools|YAML, but it wasn’t there (seemingly because those only reload backend things). Anyways, those font settings are working like a champ now!
Yes it is a steep learning curve… that’s why I [am not a coder either] will post my successes to share with others who may have a similiar issue. I ask may questions and about 50% go unanswered and I realize that no one is obligted to help but I do appreciate those who do without making me feel like an idiot.
My educational background is a teacher… my profession is I own my own contracting business. It took me years to learn php, js and now I’m trying to learn this. It takes some longer then others but if someone is trying helping them is and/or sharing knowledge is what furthers all of this.
I Thank you for help you’ve given me and yes people do want it right now but if not now then when?
I am in process of writing things that take a few moving pieces to make them work and I have just posted one of them today that I have a question about. If no one helps that’s okay sooner or later I’ll figure it out… or I won’t right now. Not the end of the world. But you can’t learn if you don’t at least try. So if someone is trying no matter if I think they’re over their head or not I’ll still help them if I can.
We all started somewhere.
Hang in there!! Mushroom cards are awesome. I’m just starting myself and am very happy with the results so far. I do constant searches here and on Google looking for examples… things I can try or taking ideas from what I find to better enhance my setup.
You’re doing great… keep it up!
These are the 3 bedrooms in my house. I’m happy so far with the results but I know I’ll want to make changes as soon as I get some time under my belt with this…
I think it is done… at least for now. :smiley:
IMG_6846
IMG_6847
As we’re all living in a world where everybody gets offended by nearly everything.
The point I wanted to state is:
Don’t want/try too much from the beginning or you maybe get frustrated because nothing works.
Climb the ladder rung by rung. Of course you can set your goal to a no handed superman tailwhip over a burning RadioShack but you’d probably better off by starting to ride without training wheels, right?
Maybe it was a stressful morning but it felt like: gimme the code now!
Keep it up, read a lot, be disappointed because trial and error sucks sometimes or your SO doesn’t give a damn about that wobbling green mushy whatever thing you handcoded in a 5h evening session but… be happy as a kid if that one tweak you almost googled back to Alta Vista now works and put on that honest little smile on your face.
TL;DR
And now back to work! Code has to be coded!
This would be awesome!
Can you change the switch state in Developer Tools or even see the state? Does the service call in Developer Tools show you something?
Do them scripts work if you fire them individually?
Looking for some advice on how best to handle this problem. Or should I be looking for other solutions with other cards?
I have been trying to get a mushroom template card to produce the results I am after and I am almost there.
Screen Shot 2022-06-11 at 13.50.47
This card changes entity value (run time) based on whether the AC is idle or cooling. My styling also changes the background color when cooling. (Will update for heating and idle later if this gets sorted.)
Now the problem: I find no way to center that value on the card. Tried various card-mod styles I have researched and none seem to apply. Example below.
If it is NOT possible to center this template card, is there another suggested card where I can still template the states I need to show?
Cheers!
        primary: |
          {% set state=states('sensor.hvac_action')%}
          {% if state == 'idle' %}
          {{states('sensor.idle_time_last_hh_mm_ss')}}
          {% elif state == 'cooling' %}
          {{states('sensor.cool_time_last_hh_mm_ss')}}
          {% endif %}
        secondary: null
        icon: null
        style: |
          ha-card {
            --card-primary-font-size: 28px;
            --card-primary-font-weight: normal;
            --ha-card-background: rgba(0, 190, 255, 0.1);
            {% endif %}
Was asked to share my welcome card code by @Boostin4HP on the HA Facebook group, so here you go!
-Center weather chip navigates to the weather page
-Right temp pops up thermostat card and shows cooling/heating/idle states with colors on icon
-Google calendar card
welcome_card
mode: vertical
cards:
    mode: horizontal
    cards:
        chips:
          - type: template
            entity: sensor.weatherflow_air_temperature_2
            icon: mdi:sun-thermometer-outline
            icon_color: yellow
            content: '{{ states(entity) }} °F'
            tap_action:
              action: more-info
            hold_action:
              action: none
            double_tap_action:
              action: none
            card_mod: null
            alignment: center
            style: |
              ha-card {
        chips:
          - type: weather
            entity: weather.weatherflow_day_based_forecast_2
            show_conditions: true
            show_temperature: false
            tap_action:
              action: navigate
              navigation_path: weather
            hold_action:
              action: more-info
            double_tap_action:
              action: none
            card_mod: null
            style: |
              ha-card {
        alignment: center
        chips:
          - type: template
            entity: sensor.thermostat_temperature
            content: '{{ states(entity)}} °F'
            icon_color: |-
              {% set state=states('sensor.hvac_action') %}
              {% if state=='cooling' %}
              blue
              {% elif state=='heating' %}
              red
              {% elif state=='idle' %}
              grey
              {% endif %}
            icon: mdi:thermometer
            tap_action:
              action: fire-dom-event
              browser_mod:
                command: popup
                title: Thermostat
                card:
                  type: thermostat
                  entity: climate.z_wave_thermostat_2
            hold_action:
              action: none
            double_tap_action:
              action: none
            alignment: end
            card_mod: null
            style: |
              ha-card {
        alignment: end
    card_mod: null
    style: |
      ha-card {
  - type: custom:mushroom-title-card
    title: >-
      {% if now().hour  < 5 %} Night{% elif now().hour < 12 %} Morning{% elif
      now().hour < 18 %} Afternoon{% else %} Evening{% endif %}, {{user}}!
    subtitle: Welcome to Home Assistant
  - type: custom:atomic-calendar-revive
    entities:
      - entity: calendar.your_calendar_here
    enableModeChange: true
    firstDayOfWeek: 1
    maxDaysToShow: 1
    refreshInterval: 240
    showLoader: false
    hideFinishedEvents: true
    showLocation: false
    hideDuplicates: true
    mode: horizontal
    cards:
        icon: mdi:flask
        icon_color: red
        layout: vertical
        tap_action:
          action: navigate
          navigation_path: lab
        hold_action:
          action: none
        double_tap_action:
          action: none
        secondary: Lab
        multiline_secondary: false
        icon: mdi:outdoor-lamp
        layout: vertical
        tap_action:
          action: toggle
        hold_action:
          action: none
        double_tap_action:
          action: none
        entity: input_boolean.auto_back_porch_lights
        icon_color: orange
        secondary: >-
          BP Auto
          {{ iif(is_state('input_boolean.auto_back_porch_lights', 'on'), '',
          'off') }}
        icon: mdi:home-assistant
        icon_color: blue
        layout: vertical
        tap_action:
          action: navigate
          navigation_path: system
        hold_action:
          action: none
        double_tap_action:
          action: none
        secondary: System
        icon: mdi:coach-lamp
        layout: vertical
        tap_action:
          action: toggle
        hold_action:
          action: none
        double_tap_action:
          action: none
        icon_color: green
        secondary: >-
          FP Auto
          {{ iif(is_state('input_boolean.auto_front_porch_lights', 'on'), '',
          'off') }}
        entity: input_boolean.auto_front_porch_lights
        icon: mdi:lightbulb-on
        icon_color: purple
        layout: vertical
        tap_action:
          action: navigate
          navigation_path: lights
        hold_action:
          action: none
        double_tap_action:
          action: none
        secondary: '  Lights'
        card_mod: null
    style: |
      ha-card {
It was actually your nice blue scene card but I love the welcome card too!
Well, that’s embarrassing lol. Here’s the scene card:
mode: vertical
cards:
    primary: Scenes
    secondary: All
    icon: mdi:home-roof
    icon_color: white
    card_mod: null
    style: |
      ha-card {
         background: #3d5afe
    mode: horizontal
    cards:
        mode: horizontal
        cards:
            icon: mdi:power-sleep
            icon_color: white
            layout: vertical
            tap_action:
              action: call-service
              service: scene.turn_on
              service_data: {}
                entity_id: scene.good_night_lights
            secondary: Night
            icon: mdi:television
            icon_color: white
            tap_action:
              service_data: {}
                entity_id: scene.tv_lights
            hold_action:
              action: none
            double_tap_action:
              action: none
            layout: vertical
            secondary: Media
            layout: vertical
            entity: script.1590801199735
            icon_color: white
            tap_action:
              service_data: {}
                entity_id: scene.living_area_lights_100
            double_tap_action:
              action: none
            hold_action:
              action: none
            secondary: 'On'
        card_mod:
          style: |
            ha-card {
              background: #3d5afe
    card_mod: null
    style: |
      ha-card {
card_mod: null
style: |
  ha-card {
    background: #3d5afe
Thanks! I fixed the box shadow issue, here’s the code.
mode: vertical
cards:
    primary: Scenes
    secondary: All
    icon: mdi:home-roof
    icon_color: white
    mode: horizontal
    cards:
      - type: horizontal-stack
        cards:
            icon_color: white
            layout: vertical
            tap_action:
              service_data: {}
            secondary: Night
            icon_color: white
            tap_action:
              service_data: {}
            hold_action:
              action: none
            double_tap_action:
              action: none
            layout: vertical
            secondary: Media
            layout: vertical
            icon_color: white
            tap_action:
              service_data: {}
            double_tap_action:
              action: none
            hold_action:
              action: none
            secondary: 'On'
    style: |
      ha-card {
        box-shadow: none;
        background: #3d5afe
style: |
  ha-card {
    background: #3d5afe
