Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
First off, thanks for such a fantastic and easy to use solution. Very refreshing to not have to spend hours learning and doing yaml.
That said,
FEATURE REQUEST:
Any possibility of a UI setting to add a confirmation message for the Tap, Hold and Dbl Tap Actions?
This worked. Thanks!
Why doesnā€™t the height change?
What is ::before? Like what can I google or look up?
Add !important e.g.:
ha_card {
  height: 266px !important;
It is a CSS pseudo element.
How would I implement the text wrapping?
I tried adding it below the current code and that didnā€™t work.
Hereā€™s the current code:
type: custom:auto-entities
card:
  type: grid
  columns: 2
  square: false
card_param: cards
filter:
  include:
    - domain: light
      state: 'on'
      options:
        type: custom:mushroom-light-card
        vertical: true
        tap_action:
          action: toggle
        double_tap_action:
          action: more-info
        card_mod: null
        style: |
          mushroom-shape-icon {
          --shape-color: none !important;
          --shape-color-disabled: none !important;}
          ha-card {
          --ha-card-background: transparent;
          --card-primary-font-size: 12px;
         mushroom-card:
          mushroom-state-item
            mushroom-state-info:
                .container .primary {
                  white-space: normal;
              mushroom-state-item {
                margin-bottom: 0px;
  exclude:
    - entity_id: light.daniels_bedroom_lights_main
thx working, and how do I make the icon and name be up.
Is there a way to change the color of the slider with card-mod? I dunno what its called
Like --mushroom-slider-color: red
Something like that.
Do you know how to target the slider itself on a dimmer so i can change the color of it?
Hey Everyone,
Im trying to make the mushroom media player have the media_title attribute in de second line but iā€™m unable to. I donā€™t wanne turn on the ā€œuse media informationā€ function because then i lose the name of the device. Does anyone know a trick how to replace the second line with the media_title attribute?.
Current Look
What iā€™m looking for
Does anyone have an idea to solve my ā€œincludeā€ problem? How do you implement your navigation bars or other stuff?
My dashboard was getting a little busy so I decided to clean it up a bit and put some not commonly used items in a dropdown on the welcome card.
type: custom:stack-in-card
cards:
  - type: custom:layout-card
    layout_type: masonry
    layout: {}
    cards:
      - type: custom:mushroom-chips-card
        chips:
          - type: menu
          - type: template
            entity: lock.door_locks
            icon: |-
              {% set state=states(entity) %}
              {% if state=='locked' %}
              mdi:lock
              {% elif state=='unlocked' %}
              mdi:lock-open-variant
              {% else %}
              grey
              {% endif %}
            tap_action:
              action: more-info
            icon_color: |-
              green
              red
              {% else %}
              grey
              {% endif %}
          - type: template
            entity: binary_sensor.door_open_sensors
            icon: |-
              {% if state=='off' %}
              mdi:door-closed
              {% elif state=='on' %}
              mdi:door-open
              {% else %}
              mdi:door
              {% endif %}
            icon_color: |-
              green
              red
              {% else %}
              grey
              {% endif %}
            tap_action:
              action: more-info
          - type: alarm-control-panel
            entity: alarm_control_panel.alarmo
            tap_action:
              action: navigate
              navigation_path: alarm
          - type: template
            content: |
              {{'{0:,.0f}'.format(states(entity)|int)}} W
            entity: sensor.energy_monitor_power
            icon: mdi:flash
            icon_color: amber
            tap_action:
              action: more-info
          - type: action
            icon: mdi:dots-vertical
            tap_action:
              action: navigate
              navigation_path: /lovelace-mushroom/0?disable_km=&edit=1
            hold_action:
              action: none
            double_tap_action:
              action: navigate
            icon_color: white
        alignment: justify
        card_mod:
          style: |
            :host {
              --ha-card-background: rgba(var(--rgb-primary-text-color), 0.025);
            ha-card {
              --chip-spacing: 2px;
        chips:
          - type: conditional
            conditions:
              - entity: light.all_lights
                state: 'on'
            chip:
              type: entity
              entity: sensor.count_lights_on
              icon_color: amber
              icon: mdi:lightbulb-group
              tap_action:
                action: call-service
                service: light.turn_off
                service_data: {}
                  entity_id: light.all_lights
          - type: conditional
            conditions:
              - entity: fan.fans
                state: 'on'
            chip:
              type: template
              entity: sensor.count_fans_on
              icon: mdi:fan
              icon_color: green
              tap_action:
                service: fan.turn_off
                data: {}
                  entity_id: fan.fans
              content: '{{ states(entity) }}'
          - type: conditional
            conditions:
              - entity: sensor.mail_usps_mail
                state_not: '0'
            chip:
              type: template
              icon: mdi:mail
              icon_color: purple
              tap_action:
                action: navigate
                navigation_path: mail
          - type: conditional
            conditions:
              - entity: sensor.garbage_day
                state: '1'
            chip:
              type: entity
              icon_color: red
              name: Put can out
              content_info: name
              use_entity_picture: false
          - type: conditional
            conditions:
                state: '0'
            chip:
              type: entity
              icon_color: green
              name: Bring can in
              content_info: name
        alignment: justify
        card_mod:
          style:
            div:
              mushroom-conditional-chip:nth-child(2) mushroom-template-chip:
                  mushroom-chip ha-icon {
                      animation: rotation 1s linear infinite;
                    @keyframes rotation {
                      0% {
                        transform: rotate(0deg);
                      100% {
                        transform: rotate(360deg);
              :host {
              ha-card {
      - type: custom:stack-in-card
        mode: horizontal
        cards:
            mode: vertical
            cards:
              - type: markdown
                content: |-
                  {% set time = now().hour %}
                  {% if (time >= 18) %}
                     Good Evening, {{user}}
                  {% elif (time >= 12) %}
                     Good Afternoon, {{user}}
                  {% elif (time >= 5) %}
                     Good Morning, {{user}}
                  {% else %}
                     Hello, {{user}}!
                  {% endif %}
                card_mod:
                  style: |
                    ha-markdown {
                      padding: 0 0 0 10px !important;
                      font-size: 28px !important;
                      font-weight: normal !important;
                      line-height: 1.2 !important;
                    ha-card {
                      background-color: #111111;
                      color: #e1e1e1;
                      box-shadow: 0px 0px;
              - type: markdown
                content: Today is **{{ now().strftime('%B %d, %Y') }}**
                card_mod:
                  style: |
                    ha-markdown {
                      font-size: 14px !important;
                      line-height: 1.4 !important;
                    ha-card {
                      color: #9b9b9b;
            card_mod:
              style: |
                ha-card {
                  background: rgba(var(--rgb-primary-text-color), 0.0);
                  color: #e1e1e1;
                  width: 350px
            chips:
              - type: conditional
                conditions:
                  - entity: person.jeff
                    state: home
                chip:
                  type: entity
                  entity: person.jeff
                  content_info: nam
                  use_entity_picture: true
                  card_mod:
                    style: |
                      ha-card {
                          --chip-background: rgba(var(--rgb-state-person-home), 0.7);
                          margin-top: 0px;
                          margin-bottom: 0px;
              - type: conditional
                conditions:
                    state_not: home
                chip:
                  type: entity
                  entity: person.jeff
                  content_info: none
                  card_mod:
                    style: |
                      ha-card {
                        {% if is_state('person.jeff', 'not_home') %}
                          --chip-background: rgba(var(--rgb-state-person-not-home), 0.4);
                        {% elif is_state('person.jeff', 'unknown') %}
                          --chip-background: rgba(var(--rgb-state-person-unknown), 0.4);
                        {% else %}
                          --chip-background: rgba(var(--rgb-state-person-zone), 0.4);
                        {% endif %}
                          margin-top: 5px;
                          margin-bottom: 0px;
            alignment: end
            card_mod:
              style: |
                ha-card {
                 margin: 10px 20px 0 0
        card_mod:
          style: |
            ha-card {
              color: #e1e1e1;
      - square: false
        columns: 4
        type: grid
        cards:
          - show_state: false
            show_name: false
            camera_view: auto
            type: picture-entity
            entity: camera.front_door_main
            camera_image: camera.front_door_main
            aspect_ratio: '5:4'
          - show_state: false
            show_name: false
            camera_view: auto
            entity: camera.front_middle
            camera_image: camera.front_middle
            aspect_ratio: '5:4'
          - show_state: false
            show_name: false
            camera_view: auto
            entity: camera.front_right
            camera_image: camera.front_right
            aspect_ratio: '5:4'
          - show_state: false
            show_name: false
            camera_view: auto
            entity: camera.right_side
            camera_image: camera.right_side
            aspect_ratio: '5:4'
      - type: horizontal-stack
        cards:
            primary: ''
            secondary: House
            icon: mdi:home
            layout: vertical
            icon_color: blue
            tap_action:
              action: navigate
              navigation_path: house
            card_mod:
              style: |
                ha-card {
                  width: 66px;
                  border-radius: 30px;
                  margin-left: auto;
                  margin-right: auto;
                  margin-top: 4px;
                  margin-bottom: -10px;
            primary: ''
            secondary: Lights
            icon_color: orange
            layout: vertical
            tap_action:
              action: navigate
              navigation_path: lights
            card_mod:
              style: |
                ha-card {
                  width: 66px;
                  margin-left: auto;
                  margin-right: auto;
                  margin-top: 4px;
            primary: ''
            secondary: Raptor
            icon: mdi:car-lifted-pickup
            icon_color: grey
            layout: vertical
            tap_action:
              action: navigate
              navigation_path: raptor
            card_mod:
              style: |
                ha-card {
                  width: 66px;
                  margin-left: auto;
                  margin-right: auto;
                  margin-top: 4px;
            primary: ''
            secondary: Secure
            icon: mdi:shield
            icon_color: green
            layout: vertical
            tap_action:
              action: navigate
              navigation_path: security
            card_mod:
              style: |
                ha-card {
                  width: 66px;
                  margin-left: auto;
                  margin-right: auto;
                  margin-top: 4px;
            primary: ''
            secondary: Net
            icon: mdi:lan
            layout: vertical
            icon_color: red
            tap_action:
              action: navigate
              navigation_path: network
            card_mod:
              style: |
                ha-card {
                  width: 66px;
                  margin-left: auto;
                  margin-right: auto;
                  margin-top: 4px;
      - square: false
        columns: 2
        type: grid
        cards:
            chips:
              - type: conditional
                conditions:
                  - entity: input_boolean.welcome_dropdown
                    state: 'off'
                chip:
                  type: weather
                  entity: weather.karr_daynight
                  show_conditions: true
                  show_temperature: true
              - type: conditional
                conditions:
                    state: 'off'
                chip:
                  type: entity
                  entity: sensor.moon
                  icon_color: yellow
              - type: conditional
                conditions:
                    state: 'off'
                chip:
                  type: template
                  content: '{{state_attr(entity, ''current_temperature'')}} Ā°F'
                  entity: climate.thermostat
                  icon: mdi:home-thermometer
                  tap_action:
                    action: more-info
                  icon_color: |-
                    {% if state=='cool' %}
                    blue
                    {% elif state=='heat' %}
                    red
                    {% else %}
                    grey
                    {% endif %}
            card_mod:
              style: |
                ha-card {
                  --chip-box-shadow: none;
                  --chip-background: none;
                  --chip-spacing: 0px;
                  --chip-padding: 15px;
                  margin-left: -6px;
                  margin-bottom: -12px;
                  width: 400px
            alignment: start
            chips:
              - type: template
                icon: |-
                  {% if is_state(entity, 'off') %}
                    mdi:chevron-down
                  {% elif is_state(entity, 'on') %}
                    mdi:chevron-up
                  {% endif %}
                tap_action:
                  action: toggle
                icon_color: disabled
            card_mod:
              style: |
                ha-card {
                  --chip-padding: 0px;
                  --chip-icon-size: 40px;
                  margin-right: -4px;
            alignment: end
      - type: conditional
        conditions:
            state: 'on'
        card:
          type: vertical-stack
          cards:
              cards:
                  primary: ''
                  secondary: Power
                  icon: mdi:transmission-tower
                  layout: vertical
                  icon_color: pink
                  tap_action:
                    action: navigate
                    navigation_path: power
                  card_mod:
                    style: |
                      ha-card {
                        width: 66px;
                        margin-left: 46px;
                        margin-right: auto;
                        margin-top: -24px;
                        margin-bottom: 4px;
                  primary: ''
                  secondary: Battery
                  icon: mdi:battery
                  layout: vertical
                  icon_color: brown
                  tap_action:
                    action: navigate
                    navigation_path: batteries
                  card_mod:
                    style: |
                      ha-card {
                        width: 66px;
                        margin-left: 25.25px;
                        margin-right: auto;
                        margin-top: -24px;
                        margin-bottom: 4px;
                  primary: ''
                  secondary: Mail
                  icon: mdi:package-variant-closed
                  layout: vertical
                  icon_color: purple
                  tap_action:
                    action: navigate
                  card_mod:
                    style: |
                      ha-card {
                        width: 66px;
                        margin-left: auto;
                        margin-right: 25.25px;
                        margin-top: -24px;
                        margin-bottom: 4px;
                  primary: ''
                  secondary: Settings
                  icon: mdi:menu
                  layout: vertical
                  icon_color: cyan
                  tap_action:
                    action: navigate
                    navigation_path: settings
                  card_mod:
                    style: |
                      ha-card {
                        width: 66px;
                        margin-left: auto;
                        margin-right: 46px;
                        margin-top: -24px;
                        margin-bottom: 4px;
            - type: custom:simple-weather-card
              primary_info:
                - wind_speed
                - wind_bearing
                - pressure
              secondary_info:
                - humidity
                - precipitation_probability
                - precipitation
              card_mod:
                style: |
                  ha-card {
                    box-shadow: none;
                    background: none;
                    padding: 0 28px 0 28px !important;
                    margin-left: 0px;
                    margin-right: 0px;
                    margin-top: 0;
                    margin-bottom: 0;
            - type: weather-forecast
              show_current: false
              show_forecast: true
              card_mod:
                style: |
                  ha-card {
                    box-shadow: none;
                    background: none;
                    padding: 0 0 0 0 !important;
                    margin-left: -20px;
                    margin-right: -20px;
                    margin-top: -10px;
                    margin-bottom: -4px;
            - type: grid
              square: false
              columns: 2
              cards:
                  mode: vertical
                  cards:
                    - type: custom:mushroom-person-card
                      entity: person.jeff
                      hide_name: false
                      layout: default
                      tap_action:
                        action: fire-dom-event
                        browser_mod:
                          command: popup
                          deviceID: this
                          title: Jeff
                          card:
                            type: custom:mod-card
                            card_mod:
                              style: |
                                ha-card {
                                   padding-right: 15px;
                                   padding-left: 15px;
                                   padding-bottom: 15px;
                            card:
                              cards:
                                - type: custom:mushroom-entity-card
                                  entity: sensor.jeff_iphone_geocoded_location
                                  primary_info: none
                                  icon: mdi:map-marker
                                  icon_color: yellow
                                  cards:
                                    - type: map
                                      entities:
                                        - entity: device_tracker.jeff_iphone
                                      aspect_ratio: '2'
                      card_mod:
                        style: |
                          ha-card {
                            padding-bottom: 0px !important;
                      mode: horizontal
                      cards:
                          cards:
                              entity: sensor.jeff_iphone_battery_level
                              secondary: '{{ states(entity) }} %'
                              icon: >-
                                {% set battery_level = (states(entity) | int /
                                10) | round(0) | int * 10 %} {% if
                                is_state('sensor.jeff_iphone_battery_state',
                                'Charging' ) %}
                                  {% if battery_level > 0 %}
                                    mdi:battery-charging-{{ battery_level }}
                                  {% else %}
                                    mdi:battery-charging-outline
                                  {% endif %}
                                {% else %}
                                  {% if battery_level == 100 %}
                                    mdi:battery
                                  {% elif battery_level > 0 %}
                                    mdi:battery-{{ battery_level }}
                                  {% else %}
                                    mdi:battery-alert-variant-outline
                                  {% endif %}
                                {% endif %}
                              icon_color: >-
                                {% set battery_level = states(entity) | int %}
                                {% if battery_level > 90 %}
                                  green
                                {% elif battery_level > 60 %}
                                  light-green
                                {% elif battery_level > 50 %}
                                  lime
                                {% elif battery_level > 40 %}
                                  yellow
                                {% elif battery_level > 30 %}
                                  amber
                                {% elif battery_level > 20 %}
                                  orange
                                {% elif battery_level > 10 %}
                                  deep-orange
                                {% else %}
                                  red
                                {% endif %}
                              layout: vertical
                              tap_action: null
                              action: more-info
                              card_mod:
                                style: |
                                  ha-card {
                                    box-shadow: none;
                                    --card-secondary-font-size: 8px;
                              layout: vertical
                              entity: sensor.jeff_iphone_steps
                              icon_color: amber
                              primary_info: none
                              card_mod:
                                style: |
                                  ha-card {
                                    box-shadow: none;
                              layout: vertical
                              entity: sensor.jeff_iphone_distance
                              icon_color: amber
                              primary_info: none
                              card_mod:
                                style: |
                                  ha-card {
                                    box-shadow: none;
                      card_mod:
                        style: |
                          ha-card {
                            box-shadow: none;
                  mode: vertical
                  cards:
                      primary: Scenes
                      secondary: All
                      icon: mdi:home-lightbulb-outline
                      icon_color: blue
                      card_mod:
                        style: |
                          ha-card {
                      mode: horizontal
                      cards:
                          cards:
                              icon: mdi:party-popper
                              icon_color: grey
                              layout: vertical
                              secondary: Party
                              tap_action:
                                service: scene.turn_on
                                service_data: {}
                                  entity_id: scene.party
                              card_mod:
                                style: |
                                  ha-card {
                                    box-shadow: none;
                              icon: mdi:television
                              icon_color: grey
                              layout: vertical
                              secondary: Chill
                              tap_action:
                                service_data: {}
                                  entity_id: scene.chill
                              card_mod:
                                style: |
                                  ha-card {
                                    box-shadow: none;
                              icon: mdi:weather-night
                              icon_color: grey
                              layout: vertical
                              secondary: Sleep
                              tap_action:
                                service_data: {}
                                  entity_id: scene.sleep
                              card_mod:
                                style: |
                                  ha-card {
                                    box-shadow: none;
                      card_mod:
                        style: |
                          ha-card {
                            box-shadow: none;
card_mod:
  style: |
    ha-card {
      padding: 2px;
      background: #1a1a1a;
I have a mushroom person card.
person
        entity: person.john
        layout: horizontal
        #icon: mdi:emoticon-confused-outline
        #primary_info: sensor.sm_f926u1_battery_level
        #secondary_info: sensor.sm_f926u1_battery_level
        hide_state: false
        fill_container: true
        hide_name: false
        layout: vertical
        style: |
          :host {
            --mush-rgb-state-person-home: var(--rgb-blue);
            --mush-rgb-state-person-not-home: var(--rgb-purple);
            --mush-rgb-state-person-zone: var(--rgb-amber);
            --ha-card-background: rgba(227, 245, 250, 0.12);
And I found this battery and charging/discharging chip card.
battery
        chips:
          - type: template
            icon_color: |2-
                    {% if states('sensor.sm_f926u1_battery_state') == 'charging' %}
                    green
                    {% else %}
                    red
                    {% endif %}
            entity: sensor.sm_f926u1_battery_state
            icon: mdi:power-plug
            tap_action:
              action: more-info
          - type: template
            entity: sensor.sm_f926u1_battery_level
            icon: |2
                  {% set bl = states('sensor.sm_f926u1_battery_level') | int %}
                  {% if bl < 10 %} mdi:battery-outline
                  {% elif bl < 20 %} mdi:battery-10
                  {% elif bl < 30 %} mdi:battery-20
                  {% elif bl < 40 %} mdi:battery-30
                  {% elif bl < 50 %} mdi:battery-40
                  {% elif bl < 60 %} mdi:battery-50
                  {% elif bl < 70 %} mdi:battery-60
                  {% elif bl < 80 %} mdi:battery-70
                  {% elif bl < 90 %} mdi:battery-80
                  {% elif bl < 100 %} mdi:battery-90
                  {% elif bl == 100 %} mdi:battery
                  {% else %} mdi:battery-unknown
                  {% endif %}
            icon_color: |2-
                        {% if bl < 10 %} red
                        {% elif bl < 20 %} red
                        {% elif bl < 30 %} red
                        {% elif bl < 40 %} orange
                        {% elif bl < 50 %} orange
                        {% elif bl < 60 %} yellow
                        {% elif bl < 70 %} yellow
                        {% elif bl < 80 %} green
                        {% elif bl < 90 %} green
                        {% elif bl < 100 %} green
                        {% elif bl == 100 %} green
                        {% else %} grey
                        {% endif %}
Is it possible to combine the two? Thanks in advance!!!
batperson
Fabulous! I will definetely have some inspiration.
May I ask what you have under Settings while unfolded ?
I have slightly different setup:
Battery Icon changes color depending on %, and changes the icon + blinks if charging
Below battery icon:
%battery levvel
battery temperature
Thatā€™s nice I really like that!!! I like the size and how itā€™s laid out! Perfect!
Care to share your code?
Thank you!
sure, see below (itā€™s for one person)
Surely some things might be written easier but I;m learning by doing :wink:
mode: vertical
cards:
    mode: horizontal
    cards:
        entity: device_tracker.sg21
        icon_type: entity-picture
        hide_name: true
        layout: vertical
        secondary_info: state
      - type: conditional
        conditions:
          - entity: binary_sensor.sg21_is_charging
            state: 'on'
        card:
          type: custom:mushroom-template-card
          entity: sensor.sg21_battery_level
          layout: vertical
          icon_color: light-green
          icon: mdi:battery-charging-medium
          hide_name: true
          primary: '{{ states(''sensor.sg21_battery_level'') }} %'
          secondary: '{{ states(''sensor.sg21_battery_temperature'') }} Ā°'
          card_mod:
            style: |
                animation: blink 1s linear infinite;
              @keyframes blink {
                50% {opacity: 0;}
      - type: conditional
        conditions:
            state: 'off'
        card:
          layout: vertical
          icon_color: |2-
                      {% set bl = states('sensor.sg21_battery_level') | int %}
                      {% if bl < 10 %} #cc0c16
                      {% elif bl < 20 %} #e61e28
                      {% elif bl < 30 %} #e3464e
                      {% elif bl < 50 %} #f0b93a
                      {% elif bl < 60 %} #f3f56c
                      {% elif bl < 70 %} #f2f536
                      {% elif bl < 80 %} #69f095
                      {% elif bl < 90 %} #2ee669
                      {% elif bl < 100 %} #05ad3b
                      {% elif bl == 100 %} #03872d
                      {% else %} grey
                      {% endif %}
          tap_action:
            action: more-info
          icon: mdi:battery-arrow-down
    secondary: >-
      {{ state_attr('sensor.darek','street') }}, {{
      state_attr('sensor.darek','city') }}, {{
      state_attr('sensor.darek','postal_code') }}, {{
      state_attr('sensor.darek','place_name') }}
    multiline_secondary: true
HUGE Thank you!!!
Iā€™m assuming this is a binary sensor you built? I have the rest of the card working for me :slight_smile:
Again, Thank you!!!
