Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
I donā€™t think itā€™s possible to use templates with chip cardsā€¦ If not please make that work :slight_smile:
In the case Iā€™m using it itā€™s cleaner to use the chip cardā€¦
chips
I want to round the last 2 but donā€™t really want to build sensors to do thatā€¦ so for now Iā€™ll just leave them as they are.
AND is there a possible way to set background on entire card or do I have to do each chip seperately?
Thank you!
is the last chip template or entity chip ?
You don;t need to build sensor to round, just put in lovelace:
  - type: template
    (other code)
    content: '{{ states(''sensor.srednia_temperatura'') | round(1, default=0) }} Ā°C'
PS I;m not so good, and I;m not sure what should be the default , but without default it fails
Is it possible at all to adjust the Title Card with card_mod??
I tried everything I could think of to change the text color, but nothing seems to work. Likewise the padding/margins of that card.
Hi!
Would be possible to do a dropdown like the 1st image, with the appearance of the 2nd one ? I donā€™t know how to disable de background-color: white of the layout-card.
1st
2nd
This is the code for the 1st one:
type: custom:stack-in-card
cards:
  - type: custom:layout-card
    layout_type: custom:grid-layout
    layout:
      grid-template-columns: auto 33px
      margin: '-4px -4px -8px -4px'
    cards:
      - type: custom:mushroom-title-card
        subtitle: Apertura Cancela
        entity: input_boolean.apertura_cancela
        primary: ''
        secondary: ''
        icon: >-
          {{ 'mdi:chevron-down' if is_state(entity, 'off') else 'mdi:chevron-up'
        icon_color: disabled
        hold_action:
          action: none
        card_mod:
          style: |
            ha-card {
              align-items: flex-end;
              background: none;
              --ha-card-box-shadow: 0px;
            mushroom-shape-icon {
              --shape-color: none !important;
    card_mod:
      style: |
        ha-card {
          background-color: #fafafa !important;
  - type: conditional
    conditions:
      - entity: input_boolean.apertura_cancela
        state: 'on'
    card:
      type: horizontal-stack
      cards:
          primary: Coche
          icon: mdi:garage
          hold_action:
            action: none
          double_tap_action:
            action: none
          entity: switch.cancela
          fill_container: false
          multiline_secondary: false
          icon_color: ''
          primary: Peatonal
          icon: mdi:door
          double_tap_action:
            action: none
          tap_action:
            action: none
          hold_action:
            action: none
          icon_color: ''
This should work
cards:
    layout:
    cards:
        entity: input_boolean.dropdown_radios
        primary: ''
        secondary: ''
        icon: >-
        hold_action:
          action: none
        card_mod:
          style: |
            ha-card {
              background: none;
    card_mod:
      style: |
        ha-card {
  - type: conditional
    conditions:
      - entity: input_boolean.dropdown_radios
        state: 'on'
    card:
      cards:
          primary: Coche
          icon: mdi:garage
          hold_action:
            action: none
          double_tap_action:
            action: none
          icon_color: ''
          primary: Peatonal
          icon: mdi:door
          double_tap_action:
            action: none
          tap_action:
            action: none
          hold_action:
            action: none
          icon_color: ''
card_mod:
  style: |
    ha-card {
      background: rgba(var(--rgb-primary-background-color), 0.1);
      --paper-item-icon-active-color: #2196f3;
      --paper-item-icon-color: #6f6f6f;
You can also set the background full transparent with this:
card_mod:
  style: |
    ha-card {
      background: transparent;
Not 100% sureā€¦ I think you may have to do a template such as this:
https://community.home-assistant.io/t/change-entity-picture-if-i-turn-on-a-switch-run-a-script-scene-etc/21079/20
Any reason you donā€™t want to make Melanie a ā€˜Personā€™ entity and use that tracker for her?
I use different tracker entities for my cat - and just use the Person card for him in the chips.
Today heā€™s chilling at a Cottage.
I have been dealing with creating a new mobile page using mushroom, for a month now. I am on my final page which is the ā€œMultimediaā€ page.
I have 3 Amazon Echo dot, 1 Echo Show 5 and a Fire TV. I also have a Music follow automation which music follows me in every room which I am present. For example if I start the music in office and leave the room and enter the kitchen, the music also transfers to the kitchen. Basically it travels with me within the house.
So I wanted to control all of my Amazon devices from one tab from my mushroom multimedia page. The easiest way to achieve this was to create a dropdown. But I wanted to be as simple as possible while building my mushroom instance. So I created a simple automation running template commands over media players. Due to their state of standby ,idle, paused or playing, my media card also changes. I also used a Input.boolean with on - off. And of course ā€œConditional Cardā€ does all the work here. You can accomplish wonders with it.
As you can see there is only one multimedia card which represents office echo dot. But if I pass the music to bedroom this card also disapperas and Bedroom Echo multimedia card appears on the same spot. If I use more then one media player then every of them appears on the screen like this :
And finally when any of media players stops playing music meaning passes to standby, idle or paused state then the cards or a single card disapperas and everywheere multimedia card becomes active.
I also used browser mode within chips to access spotcast list and firetv remote so that they do not appear on main page.
With a single touch to Spotify chip icon the Spotcast media screen appears. And again with a double tap action, the spotcast list disappears. For the fire remote I used browser mode. With a simple touch to the mushroom chip (red remote icon) makes the remote appear on screen in a popup.
So after using this everything is clean and feels minimalistic. With transparency everything looks very nice. I will share my configuration and screenshots whenever I complete my design.
Is it possible to hide the map when no door is open and vice versa when one is open?
type: custom:mushroom-template-card
primary: >-
  expand('group.tueren_kg_eg')|selectattr('state','eq','on')|map(attribute='name')|list|join(',
secondary: ''
icon: mdi:door
icon_color: ''
badge_icon: mdi:exclamation-thick
badge_color: red
picture: ''
multiline_secondary: true
Or ist is it possible to get the template in a chip?
Hey thatā€™s pretty cool. It donā€œt no- how to get the first row off, so that only chip cards seeing! Maybe you could help meā€¦
Itā€™s just using Bar Chart
Yeah, i just started with home-assistant and the platform i came from (Homey) you had to make a flow for life 360 and update the location for the personā€¦ i just discovered that itā€™s just a person and a tracker here :smiley: thank you! and say hi to Dexter from me :slight_smile:
OMG Iā€™m sorry itā€™s a chip cardā€¦
- type: custom:mushroom-chips-card
  chips:
    - type: entity
      entity: sensor.budd_st_weather_uv
      card-mod:
           style: |
              ha-card {
              background-color: rgba(255, 255, 255, .1);
     - type: entity
       entity: sensor.budd_st_weather_wind_speed
       icon: mdi:turbine
     - type: entity
       entity: sensor.budd_st_weather_rel_pressure
       icon: mdi:gauge
     - type: entity
       entity: sensor.budd_st_weather_dew_point
       icon: mdi:thermometer-water
  alignment: center
You have to use conditional card and input booleans together. Just tell me what you want to do.
How can I get the navigation Line off?
On yours it is off - am I right ?
installed it via hacs.
configuration.yaml
kiosk_mode:
  hide_header: true
Check configā€¦no kiosk mode found
White background is gone, thx!
But box-shadow and border-radius (30% in my other cards) of the mushroom template card is missing :sob:
In case anyone is wonderingā€¦hereā€™s the answer to my ā€˜templateā€™ and chip card answer!! Thanks @Posreg
  chips:
      - type: entity
      - type: entity
       icon: mdi:turbine
     - type: template
       content: "{{ states('sensor.budd_st_weather_rel_pressure') | round(0, default=0) }}%"
       icon: mdi:gauge
     - type: template
       content: "{{ states('sensor.budd_st_weather_dew_point') | round(0, default=0) }}%"
   alignment: center
Result!
chips
Nice last name. Family of Emile? :grinning:
Iā€™m on my way to use mushroom all over my dashboards (theme/decluttering_templates/card_mod) and i was wondering if i could enable slider indicator everywhere ?
like this (changed class from slider-track-active to slider-track-indicator on browser for screenshot) while keeping coloring
