Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 2)
This is awesome, much better than what I had in mind.
Can you create a “black” (or “dark”) mushroom theme easily or is there any one already available?
I’m asking for this because the current frontend set theme API from HA does not allow you to set dark / light theme through it (the existing “mode” setting does something different) and the browser_mod which allows you to control this is too flaky.
So my solution is to set devices I want to control to use the “Default Theme” and then to have a specific dark mode theme.
If anyone is aware of a dark/black mushroom theme, pls let me know. Or how I can create one myself. Thanks!
I just use caule-themes-pack-1/info.md at 0ec8a4b7acf63d8618bcf2fdd968d6256e998acb · ricardoquecria/caule-themes-pack-1 · GitHub or GitHub - AmoebeLabs/HA-Theme_M3-C11-Purple: Material Design 3 / Material YOU theme for Home Assistant. A separate theme can be applied as default for light or dark mode using the the call service. Make sure you press the call service button for each setting.
Want dark all the time, set the dark theme for both light and dark.
Set each dashboard to no theme and do not apply any themes to the cards. The system will follow default then.
Make sure theme is set for default on each device used to login.
Here is the code for the animations. Message me if you have any issues implementing it.
type: custom:stack-in-card
cards:
    icon: mdi:stove
    icon_color: white
    primary: Stove
    card_mod:
      style: |
        ha-card{
         background: none !important;
         border: none !important;
         padding-bottom: 0px !important;
         z-index: 0;
         height: 50px !important;
    icon: mdi:heat-wave
    icon_color: orange
    card_mod:
      style:
        mushroom-shape-icon$: |
          .shape {
           --icon-symbol-size: 20px;
           {% if states('sensor.range_cooktop_burner') == 'run' %}
           {% else %}
           --icon-color: transparent;
           {% endif %}
          ha-card {
           margin-top: -74px !important;
           border: none;
          ha-state-icon {
             animation: top 2s alternate infinite;
             {% endif %}
           @keyframes top {
            0%, 100% { clip-path: inset(100% 0 0 0); }
              0% { clip-path: inset(35% 0 0 0 ); }
    icon: mdi:radiator
    icon_color: red
    card_mod:
      style:
          .shape {
           rotate: ;
           --icon-symbol-size: 17px;
           {% if states('sensor.range_oven_job_state') == 'cooking' %}
           .shape:before {
            content: "";
            height: 12px;
            width: 16px;
            border-width: 0;
            position: absolute;
            background: black;
            top: 12px !important;
            left: 12px !important;
            {% else %}
            {% endif %}
          ha-card {
           margin-top: -65px !important;
           border: none;
          ha-state-icon {
             animation:  oven 2s alternate infinite;
            {% endif %}
          @keyframes oven {
            0%, 100% { clip-path: inset(50% 0 0 0); }
              0% { clip-path: inset(0 0 0 0 ); }
For my understanding, these settings aren’t working for you? redline highlight
What does the box say where I highlighted green?
You even have the option to create your own theme, which is quite simple.
Amazing, thank you, I implement when I get in and let you know.
Thanks, it works but only without other styles. Can this work with ha-card and for all light chips?
- type: custom:mushroom-chips-card
    card_mod:
      style: |
        mushroom-light-chip:nth-child(1)$: |
          ha-state-icon {
            --icon-color: blue;
        ha-card {
          --chip-box-shadow: none;
          --chip-background: none;
          -chip-spacing: none;
          --chip-icon-size: 22px;
          --primary-text-color: rgb(var(--rgb-disabled));
    chips:
      - type: light
yes you can add ha-card. checkout this guide
especially the
What the $ and .: | symbols do
chips:
  - type: light
    entity: light.lights_off
    icon: mdi:ceiling-light
  - type: light
    entity: light.kitchen
  - type: light
    entity: light.bar_2
card_mod:
  style:
      ha-state-icon {
        --icon-color: blue;
    mushroom-light-chip:nth-child(2)$: |
      ha-state-icon {
        --icon-color: red;
    mushroom-light-chip:nth-child(3)$: |
      ha-state-icon {
        --icon-color: green;
      ha-card {
I have 8 custom:mushroom-template-card’s with tap actions, when tapped running (the same) script.
Is there a way to check in the script which custom:mushroom-template-card is tapped ?
I made 1 script for the 8 cards, but when one is pressed, I want to set the state to on, before the script starts running…
Is there a possibility to change the text of the status, for example so that instead of “Off” it prints the text I want!
If state is off then “text” ?
Yes, but on the chip card itself!
Like this ?
chips:
  - type: template
    tap_action:
      action: toggle
    content: |-
      {% if 'on' in states('light.nspanel_relay_1') %}
        ON, maybe?
      {% else %}
        OFFish
      {% endif %}
    icon: mdi:lightbulb
    entity: light.nspanel_relay_1
@LiQuid_cOOled Thank you very much, works great.
Change Mushroom Number Card Slider Colour based on state.
Thought I would post because I could not find many examples, this one based on a soil moisture meter.
Made to align with this gauge card.
  - type: custom:mushroom-number-card
    entity: input_number.back_garden_set_moisture
    display_mode: slider
    name: Back Garden Set Moisture Level
    card_mod:
      style:
        mushroom-number-value-control$: |
          mushroom-slider {
            {% set nbr= states('input_number.back_garden_set_moisture') | float %}
            {% if nbr<21 %}
            --main-color: #F75050 !important;
            --bg-color: #700700 !important;
            {% elif nbr<41 %}
            --main-color: #EEE049 !important;
            --bg-color: #737500 !important;
            {% elif nbr<61 %}
            --main-color: #55E84A !important;
            --bg-color: #006122 !important;
            {% elif nbr<100 %}
            --main-color: #39BEEA !important;
            --bg-color: #006875  !important;
            {% endif %}
Gradient Slider Background.
Grandients made with CSS Gradient
HARD GRADIENT
type: horizontal-stack
cards:
    name: Back Garden Set Target Moisture Level
    card_mod:
      style:
          mushroom-slider {
            {% if nbr<21 %}
            --gradient: -webkit-linear-gradient(360deg, rgba(112,7,0,1) 20%, rgba(115,117,0,1) 21%, rgba(115,117,0,1) 40%, rgba(0,97,34,1) 41%, rgba(0,97,34,1) 60%, rgba(0,104,117,1) 61%) !important;
            {% elif nbr<41 %}
            {% elif nbr<61 %}
            {% elif nbr<100 %}
            {% endif %}
SOFT GRADIENT
cards:
    card_mod:
      style:
          mushroom-slider {
            {% if nbr<21 %}
            --gradient: -webkit-linear-gradient(360deg, rgba(112,7,0,1) 10%, rgba(115,117,0,1) 30%, rgba(0,97,34,1) 50%, rgba(0,104,117,1) 75%) !important;
            {% elif nbr<41 %}
            {% elif nbr<61 %}
            {% elif nbr<100 %}
            {% endif %}
Thank you !
Is it possible for this to work within a chip card? Something like below?
chips:
    entity: switch.fan
    icon: mdi:fan
    icon_color: '{{ ''grey'' if states(config.entity) == ''off'' else ''blue''}}'
    primary: '{{ ''Not Running'' if states(config.entity) == ''off'' else ''Running''}}'
    tap_action:
      action: navigate
      navigation_path: /lovelace/temperature
    card_mod:
      style: |
        ha-icon {
          {{ 'animation: spin 1s linear infinite;' if states(config.entity) == 'on' else 'animation: none;' }}
This should work
chips:
  - type: template
    entity: switch.fan
    icon: mdi:fan
    content: '{{ ''Not Running'' if states(config.entity) == ''off'' else ''Running''}}'
    tap_action:
      action: navigate
card_mod:
  style:
    mushroom-template-chip:nth-child(1)$: |
      ha-state-icon {
       {{ 'animation: spin 1s linear infinite;' if is_state('switch.fan', 'on') else 'animation: none;' }}
       @keyframes spin {
       100% { transform: rotate(360deg); }
Thank you, that works on it’s own but won’t work when I build it into my room tile.
Ignore all the entities being all over the place at the moment, I’m just testing and creating the card so using lights for now as conditions etc.
Any suggestions?
cards:
    primary: Bathroom
    secondary: >-
      {{ states('sensor.openweathermap_temperature') | round (1) }}°C - {{
      states('sensor.openweathermap_humidity') }}%
    icon: mdi:tree
    entity: light.soffit_lights
    hold_action:
      action: toggle
    tap_action:
      action: navigate
      navigation_path: /home-v2/outside
    icon_color: '{{ "orange" if is_state("light.soffit_lights", "on") else "disabled" }}'
    fill_container: true
    layout: horizontal
    multiline_secondary: false
    card_mod:
      style:
        mushroom-state-info$: |
          .primary {
            text-shadow: 0px 0px 5px black;
            --card-primary-font-weight: 325;
           --card-primary-color: white;
            --card-primary-font-size: 20px;
            align-items: end;
            margin-top: 175px;
            inline-size: 180px;
            height: 25px;
          .secondary {
            --card-secondary-font-size: 13px;
           --card-secondary-color: white;
            --card-secondary-font-weight: 350;
              margin-top: -2px;
          :host {
          {% if is_state('light.soffit_lights', 'off') %}
            background: url('/local/images/areas/bathroom.jpg') center;
            background-size: cover;
            background-position-y: 70px;
            background-blend-mode: overlay;
            #filter: grayscale(70%);
            background-color: rgba(var(--rgb-card-background-color), 0.0);
          {% endif %}
            --mush-icon-size: 0px;
            height: 220px;
            margin-left: -15px !important;
            margin-top: -70px !important;
          {% if is_state('light.soffit_lights', 'on') %}
          {% endif %}
          mushroom-shape-icon {
            --shape-color: rgba(var(--rgb-{{ 'orange' if is_state('light.soffit_lights', 'on') else 'disabled' }}), 0.4) !important;
    chips:
      - type: template
        entity: light.dining_room_lamp
        icon: mdi:fan
        content: ''
        tap_action:
          action: navigate
        card_mod:
          style:
              ha-state-icon {
               {{ 'animation: spin 1s linear infinite;' if is_state('light.dining_room_lamp', 'on') else 'animation: none;' }}
               @keyframes spin {
      - type: template
        icon: >-
          {{ 'mdi:lightbulb' if expand(area_entities('outside')) |
          selectattr('domain','eq','light') | selectattr('state','eq','on') |
          list | count > 0 else 'mdi:lightbulb-outline' }}
        icon_color: >
          {% set lights_in_outside = expand(area_entities('outside')) |
          selectattr('domain', 'eq', 'light') | list %} {{ 'orange' if
          lights_in_outside | selectattr('state', 'eq', 'on') | list | count > 0
          else 'grey' }}
        content: >-
          {{ expand(area_entities('outside')) |
          list | count }}
        tap_action:
          action: call-service
          service: light.toggle
            area_id: outside
        hold_action:
          action: more-info
    alignment: end
    card_mod:
      style: |
        ha-card {
          --chip-spacing: -15px;
          margin-top: -10px;
card_mod:
  style: |
    ha-card {
      height: 180px;
      width: 180px;
      margin-left: auto;
      margin-right: auto;
          #box-shadow: 0 0 20px rgba(245, 173, 66, 0.5);
          #border-radius: 10px;
          #background: rgba(245, 173, 66, 0.3);      {% endif %}
