Mushroom Cards - Build a beautiful dashboard easily ๐Ÿ„ (Part 2)
Oh that came out well. I think you have doubled it but its working. How about the background in this case?
I doubled to ensure it would work on a second chip. That is where modding chips get interesting. Give me a few to generate that code.
Cool thanks. Used one instance.
type: custom:mushroom-chips-card
chips:
  - type: template
    entity: weather.liverpool_hourly
    tap_action:
      action: navigate
      navigation_path: "#Weather"
    icon: |
      {% set weather = states(config.entity) %}
      {% if weather == 'clear-night' %} mdi:weather-night
      {% elif weather == 'cloudy' %} mdi:weather-cloudy
      {% elif weather == 'fog' %} mdi:weather-fog
      {% elif weather == 'hail' %} mdi:weather-hail
      {% elif weather == 'lightning' %} mdi:weather-cloudy
      {% elif weather == 'lightning-rainy' %} mdi:weather-lightning
      {% endif %}
    icon_color: |
      {% if weather == 'clear-night' %} red
      {% elif weather == 'cloudy' %} green
      {% elif weather == 'fog' %} blue
      {% endif %}
    card_mod:
      style: |
        ha-card {
        --chip-background:
          {% if weather == 'clear-night' %} rgba(6, 148,148, 1)
          {% elif weather == 'cloudy' %}  rgba(6, 148,148, 1)
          {% elif weather == 'fog' %} rgba(6, 148,148, 1)
          {% elif weather == 'hail' %} rgba(6, 148,148, 1)
          {% elif weather == 'lightning' %} mrgba(6, 148,148, 1)
          {% elif weather == 'lightning-rainy' %} rgba(6, 148,148, 1)
          {% endif %}
All the colors you have in the chip background code are the same?
Man kudos to you. It just works. Yeah meant to change colors etc once I get all of it working.
Now just gotta make sure not you use same colors for background and iconsโ€ฆ
Appreciate itโ€ฆThrow me a like or two on our posts. Thanks for being easy to communicate with!
Have another quick one if I may?
Have this button on tablet dash and wanted to add a space between the fan state and the timer if possible
type: custom:stack-in-card
cards:
    entity: switch.bathroom_ixl_l1
    icon: mdi:fan
    icon_color: yellow
    primary: Bathroom Fan
    secondary: >
      {{states('switch.bathroom_ixl_l1') }}
      {% set f = state_attr('timer.bathroom_fan', 'finishes_at') %} {{ "" if f
      == None else (as_datetime(f) - now()).total_seconds() |
      timestamp_custom('%H:%M:%S', false) }}
    card_mod:
      style: |
        ha-card {
          padding-bottom: 10px !important;
Like this?
card_mod:
      style:
        mushroom-state-info$: |
          .secondary {
             margin-left: 30px;
         ha-card {
No meant between the state and timer
this is what I have now
Need to add room between the off and the timer it self
Try it this way
cards:
    icon: mdi:fan
    icon_color: yellow
    secondary: |
    card_mod:
      style:
          .secondary::after {
            content: "{% set f = state_attr('timer.bathroom_fan', 'finishes_at') %} {{ "" if f
             timestamp_custom('%H:%M:%S', false) }}";
            position: absolute;
            top:29px;
            left: 90px;
            color: lime;
            display: flex;
          ha-card {
Getting a timer to update on a Mushroom or Tile card is an issue if I remember correctly.
I have used a button card to see the timer countdown.
For example:
The card on the left is a Mushroom card and updates only on dashboard interaction.
Untitled video - Made with Clipchamp (2)
Oh man that works well. The space helps a lot. Yes the updating is an issue but at least saves me from having to check the timer.
So what do you recommend? Whatโ€™s on the right there?
It is also a combo of Button and Mushroom cards. Iโ€™ll put an example together for since you are already using custom Button and Mushroom cards.
Canโ€™t thank you enough man
Happy to assist!!
Just realized when the fan is off the icon does not go back to default color.
I am working on multiple threads. Can you post the code? It helps me expedite a resolution. :grinning:
oh I meant the code you added the space for the timer. I completely missed that it does not go back to default. So expecting this
cards:
    icon: mdi:fan
    icon_color: yellow
    secondary: |
    card_mod:
      style:
          .secondary::after {
            position: absolute;
            top:29px;
            left: 90px;
            color: lime;
            display: flex;
          ha-card {
This should do itโ€ฆ
cards:
    icon: mdi:fan
    icon_color: |
      {{ 'yellow' if is_state(config.entity, 'on') else 'grey' }}
    secondary: |
      {{states(config.entity) }}
    card_mod:
      style:
          .secondary::after {
            position: absolute;
            top:29px;
            left: 90px;
            color: lime;
            display: flex;
          ha-card {
@LiQuid_cOOled after our discussion yesterday I have updated:
Thanks for the new style of template, much easier to follow.
THEMES FOR STICKY FLOATING NAVIGATION MENU - All Devices - Mushroom Chips Card
FULL CODE FOR CARD IS AVAILABLE FROM THIS LINK
CARD-MOD COLOURED PEBBLE
  • No Transparency
CARD-MOD COLOURED GLASS
  • Allows to see through buttons and any information they may be blocking
INNER GLOW
INNER GLOW OUTLINE
DASHBOARD MUSHROOM THEME SELECTOR IS HERE
  • custom:mushroom-select-card
  • Add to dashboard via GUI
  • Change themes right from the dashboard
Awesome. Any reason why this button shows on/off as opposed to On/Off like my other buttons?
Regular button
type: custom:mushroom-light-card
icon: mdi:lightbulb-on
icon_color: yellow
as opposed to
