Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 2)
It the way the device reports the state. It is different amongst different devices. With a tempalte card you can use something similar to this:
 secondary: |
       {{ 'On' if is_state(config.entity, 'on') else 'Off' }}
Legendary stuff
                                              - type: horizontal-stack
                                                cards:
                                                    secondary: Oefenzaal
                                                  - type: custom:mushroom-chips-card
                                                    chips:
                                                      - type:  template
                                                        tap_action:
                                                          action: perform-action
                                                          perform_action: script.climate_increase_decrease_temp_airco
                                                          target: {}
                                                            entity_id: input_number.volume_oefenzaal
                                                            step: -0.2
                                                        icon: mdi:minus
                                                    secondary: '{{ states(''input_number.volume_oefenzaal'')}}'
                                                    chips:
                                                      - type:  template
                                                        tap_action:
                                                          target: {}
                                                            step: +0.2
                                                        icon: mdi:plus
I want the - temp and + closer to each other and more space for the first mushroom card, how do I achieve this ?
I’d suggest using the layout-card Swap your entities for mine.
type: custom:layout-card
layout_type: custom:grid-layout
layout:
      grid-template-columns: 40% 20% 10% 10%
      margin: 0px 0px 0px 0px
cards:
    secondary: "{{ states('input_number.sprinkler_number')}}"
    chips:
      - type: template
        tap_action:
          perform_action: script.sprinkler_timer_finish
          target: {}
            entity_id: input_number.sprinkler_number
            step: 0.2
        icon: mdi:plus
    chips:
      - type: template
        tap_action:
          target: {}
            step: -0.2
        icon: mdi:minus
I do similar, using a mushroom template card:
type: custom:mushroom-template-card
primary: Desk Plug
secondary: >-
  {{states('switch.desk_plug') | title }} ·
  {{states('sensor.desk_plug_power')}}W
icon: mdi:desk
entity: switch.desk_plug
icon_color: |-
  {% if is_state('switch.desk_plug', 'on') %}
    blue
  {% else %}
    grey
  {% endif %}
Your code appears to be fine.
I’d look at your Display precision for that device
Can you use this instead ?
{{ states(config.entity) | title }}
I was replying to a post above
Not sure I have seen that method before. If you want to display an attribute I use something like this:
secondary: |
      {{ state_attr('light.toilet_1', 'max_mireds') }}
Not to display an attribute, to capitalise the state, instead of this:
 secondary: |
This is one method I know about. Your method works well, apparently I missed your point. Appreciate the education, always learning! :brain:
    secondary: |
      {{states(config.entity)}}
    card_mod:
      style:
        mushroom-state-info$: |
          .secondary {
            text-transform: capitalize;
These can be used too
{{ states(‘sensor.devonport_fire_danger_0’) | upper }}
      {{ states('sensor.devonport_fire_danger_0') | capitalize }}
sorry for my bad paint skills :slight_smile:
How can i change reduze the padding on the left side.
Screenshot 2025-01-17 133857
entity: switch.ps5_tom_power
primary: PS5 Ben
secondary: |
  {% if is_state('switch.ps5_726_power', 'on') %}
    {% if is_state('sensor.ps5_726_activity', 'idle') %}
      Ruhemodus
    {% elif is_state('sensor.ps5_726_activity', 'playing') %}
      {{ state_attr('sensor.ps5_726_activity', 'title_name') or states('sensor.ps5_726_activity') }}
    {%- else -%}
    {%- endif -%}
  {%- elif is_state('switch.ps5_726_power', 'unavailable') -%}
   Aus
  {%- elif is_state('switch.ps5_726_power', 'off') -%}
   Aus
  {%- else -%}
    {{ states('switch.ps5_726_power') }}
  {%- endif -%}
picture: |
  {% if is_state('sensor.ps5_726_activity', 'playing') %}
  {{state_attr('sensor.ps5_726_activity', 'title_image')}}
  {% else %}
  /local/playstation.jpg
  {% endif %}
card_mod:
  style: |
    ha-card {
      height: 48px !important;
      border-radius: 100px;
      --icon-size: 40px;
    :host {
      --mush-icon-size: 40px;
Didn’t test it, but try
card_mod:
  style:
    mushroom-shape-avatar$: |
      .container {
       left: -5px !important;
     ha-card {
      --icon-size: 40px;
     :host {
Danke / Thank you
If you need the text to move in conjuction use
card_mod:
  style:
      .container {
       --icon-size: 40px;
     ha-card {
Hello again :slight_smile:
How can i move the icon to the left side? (now i use icon: mid:…)
primary: Haustür
icon: mdi:door
icon_color: green
fill_container: false
badge_icon: |
  {% if is_state('binary_sensor.nuki_home_locked', 'on') %}
  mdi:check-bold
  {% else %}
  mdi:lock-off
  {% endif %}
card_mod:
  style: |
    ha-card {
     padding-right: 10px !important;
     margin: 15px 0px 15px 0px !important;
     --icon-size: 40px;
     filter: drop-shadow(0px 0px 12px green) contrast(1.0);
Screenshot 2025-01-18 140144
primary: Haustür
icon: mdi:door
icon_color: green
badge_icon: |
  mdi:check-bold
  {% else %}
  mdi:lock-off
  {% endif %}
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
        left: -5px;
      ha-card {
        --icon-size: 40px;
I now use
grid-template-columns: 50% 15% 20% 15%
and gives me
afbeelding
as you can see, the number is not in the center. what do I do wrong ?
Can you post the full card code?
