Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
You didn’t post your code, but here is the code from mine and maybe it will point you in the right direction.
hvac filter
cards:
  - type: custom:layout-card
    layout_type: custom:grid-layout
    layout:
      grid-template-columns: 42px auto 25px
      margin: '-4px -4px -8px -4px;'
    cards:
        entity: sensor.hvac_filter_remaining
        icon: mdi:air-filter
        icon_color: |
          {% set filter_days = states(entity) | int %}
          {% if filter_days < 11 %}
            red
          {% elif filter_days < 21 %}
            orange
            green
        card_mod:
          style: |
            ha-card {
              border-width: 0px;
              background: none;
              --ha-card-box-shadow: 0px;
      - type: custom:bar-card
        height: 42px
        min: '0'
        max: '30'
        entity_row: true
        severity:
          - color: rgb(76, 175, 80)
            to: 90
          - color: rgb(255, 152, 0)
            to: 20
          - color: rgb(244, 67, 54)
            to: 10
        positions:
          icon: 'off'
          indicator: 'off'
        card_mod:
          style: |
            ha-card {
              border-width: 0px;
              padding: 12px;
              margin-left: 12px;
              --bar-card-border-radius: 12px;
            bar-card-value {
              margin: 12px;
              font-size: 12px;
              font-weight: bolder;
            bar-card-name {
              margin: 12px;
              font-size: 12px;
            bar-card-backgroundbar {
              opacity: 0.2;
              filter: brightness(1);
        entity: input_boolean.hvac_filter_dropdown
        icon: mdi:chevron-down
        icon_color: disabled
        hold_action:
          action: none
        card_mod:
          style: |
            ha-state-icon {
              transition: transform 0.14s !important;
              {{ 'transform: rotate(-180deg);' if is_state(config.entity, 'on') }}
            ha-card {
              border-width: 0px;
              align-items: flex-end;
              background: none;
              padding-left: 20px!important;
            mushroom-shape-icon {
              --shape-color: None !important;
  - type: custom:stack-in-card
    mode: horizontal
    cards:
      - type: custom:mushroom-entity-card
        entity: input_datetime.hvac_filter
        icon: mdi:calendar
        layout: vertical
        primary_info: state
        secondary_info: name
        card_mod:
          style: |
            ha-card {
              border-width: 0px;
              width: 130px;
              margin-left: auto;
              margin-right: auto;
        entity: sensor.hvac_filter_days_since_replaced
        layout: vertical
        primary_info: state
        card_mod:
          style: |
            ha-card {
              border-width: 0px;
              width: 130px;
              margin-left: auto;
              margin-right: auto;
        entity: input_number.hvac_filter_threshold
        icon: mdi:calendar-edit
        layout: vertical
        primary_info: state
        tap_action:
          action: none
        hold_action:
          action: more-info
        double_tap_action:
          action: none
        card_mod:
          style: |
            ha-card {
              border-width: 0px;
              width: 130px;
              margin-left: auto;
              margin-right: auto;
        primary: Reset
        secondary: ''
        icon: mdi:refresh
        layout: vertical
        tap_action:
          action: none
        hold_action:
          action: call-service
          service: script.hvac_filter_replace
          data: {}
          target: {}
        double_tap_action:
          action: none
        card_mod:
          style: |
            ha-card {
              border-width: 0px;
              width: 130px;
              margin-left: auto;
              margin-right: auto;
    card_mod:
      style: |
        ha-card {
          border-width: 0px;
          margin-top: -14px;
card_mod:
  style: |
    ha-card {
      {{ 'height: 66px;' if is_state('input_boolean.hvac_filter_dropdown', 'off') }}
If you want to preserve the use of the update card, you can make the secondary info transparent and overlay your own text this way.
mode: horizontal
cards:
  - type: custom:mushroom-update-card
    entity: update.home_assistant_core_update
    show_buttons_control: true
    secondary_info: state
    card_mod:
      style:
        mushroom-state-info$: |
          .container {
           --card-primary-color: yellow;
           --card-secondary-color: transparent;
        mushroom-shape-icon$: |
          .shape:after {
             content: "Your text here";
             height: 18px;
             width: 90px;
             border-width: 0;
             font-size:13px;
             color: red;
             position: absolute;
             background: transparent;
             margin-top:24px;
             margin-left:150px;
          ha-card {
            border: none !important;
I’ve removed Mushroom Theme in HACS due to it being not used, I use the normal mushroom (built-in?) theme. Or so I thought.
But now the interface looks like this:
interface mushroom
It used to be without borders around the card and chips, like this:
working mushroom
This is the code for the Slaapkamer card:
cards:
    primary: Slaapkamer
    secondary: null
    icon: mdi:bed-double
    entity: group.slaapkamer_lampen
    tap_action:
      action: navigate
      navigation_path: slaapkamer
    hold_action:
      action: toggle
    icon_color: '{{ ''orange'' if is_state(entity, ''on'') else ''red'' }}'
    fill_container: true
    layout: horizontal
    multiline_secondary: false
    card_mod:
      style: |
        :host([dark-mode]) {
          background: rgba(var(--rgb-primary-background-color), 0.2);
        :host {
          background: rgba(var(--rgb-primary-text-color), 0.025);
    chips:
      - type: template
        entity: group.rolluiken
        icon: |-
          {% if is_state(entity, 'closed') %}
            mdi:window-closed
            mdi:window-open
        icon_color: |-
          {% set state=states('group.rolluiken') %}
          {% if state=='closed' %}
            grey
          {% elif state=='open' %}
            blue
            red
        tap_action:
          action: none
        hold_action:
          action: none
      - type: template
        entity: climate.airco_slaapkamer
        icon: |-
          {% set state=states('climate.airco_slaapkamer') %}
          {% if is_state(entity, 'cool') %}
            mdi:fan
          {% elif state=='heat' or state=='dry' or state=='fan_only' or
          state=='auto' %}
            mdi:fan
            mdi:fan-off
        icon_color: |-
          {% if state=='off' %}
            grey
          {% elif state=='cool' %}
            blue
          {% elif state=='heat' %}
            red
          {% elif state=='dry' %}
            orange
          {% elif state=='fan_only' %}
            green
          {% elif state=='auto' %}
            green
            pink
        tap_action:
          action: none
        hold_action:
          action: none
    alignment: end
    card_mod:
      style:
        .chip-container :nth-child(2)$: |
          ha-state-icon {
            {{ 'animation: spin 3s linear infinite;' if is_state('climate.airco_slaapkamer', 'cool') or is_state('climate.airco_slaapkamer', 'heat') or is_state('climate.airco_slaapkamer', 'dry') or is_state('climate.airco_slaapkamer', 'fan_only') or is_state('climate.airco_slaapkamer', 'auto') }}
          @keyframes spin {
            100% { transform: rotate(360deg); }
          ha-card {
            --chip-box-shadow: none;
            --chip-background: none;
            --chip-spacing: 0;
card_mod:
  style: |
    ha-card {
      height: 102px;
      {% if is_state('group.slaapkamer_lampen', 'on') %}
       background: rgba(255, 152, 0, 0.1);
Even after reinstalling the Mushroom Theme, it stays broken. I could recover from a snapshot but I’m curious what’s wrong?
Try this, your theme was controlling the card borders for you. I adjusted this
            --chip-border-color: transparent;
card_mod:
 style: |
      ha-card {
       box-shadow: none;
       --ha-card-border-width: 0px;
Entire card
cards:
    primary: Slaapkamer
    secondary: null
    tap_action:
      action: navigate
    hold_action:
      action: toggle
    layout: horizontal
    card_mod:
      style: |
        :host {
    chips:
      - type: template
        icon: |-
            mdi:window-closed
            mdi:window-open
        icon_color: |-
            grey
            blue
            red
        tap_action:
          action: none
        hold_action:
          action: none
      - type: template
        icon: |-
            mdi:fan
          state=='auto' %}
            mdi:fan
            mdi:fan-off
        icon_color: |-
            grey
            blue
            red
            orange
            green
            green
            pink
        tap_action:
          action: none
        hold_action:
          action: none
    alignment: end
    card_mod:
      style:
          ha-state-icon {
          @keyframes spin {
          ha-card {
            --chip-spacing: 0;
card_mod:
 style: |
      ha-card {
       box-shadow: none;
Still need help on this if possible before it gets buried
When you include the content line it will spin with the icon.
content: >
                {{ expand(states.group.fans) | selectattr( 'state', 'eq', 'on')
                | list | count }}
You could switch to a Mushroom template card to address the issue. and add a badge to generate the same card,
type: custom:mushroom-template-card
entity: fan.bedroom_fan
icon: mdi:fan
primary: Primary Text
secondary: |
 secondary
badge_icon: mdi:numeric-1
badge: |
                | list | count }}
card_mod:
  style: |
    ha-state-icon {
      animation: spin 1s linear infinite;
      color: green;
    mushroom-badge-icon {
      --icon-color: white !important;
      --main-color: green !important;
@dimitri.landerloos has an extensive guide here
not the best solution, but there is probably no other solution, and it works. Thank you!
Agreed, not the best , but the JS draws from that line from HA. You can anything to that content line to include sensors or attributes.
Template is a way, but you’ll need to design the icon and update buttons.
Thank you! Works like a charm.
Also is this a bug in the theme? The climate card is not showing the icons anymore of hvac modes:
ac hvac modes
It used to have the hvac modes but since a recent update it’s gone. It’s functions still work well.
This is the card_mod code (it was really awesomely made by @rhysb I believe):
    card_mod:
      style: |
          {% if is_state(config.entity, 'auto') %}
            --card-mod-icon: mdi:autorenew;
            animation: spin 3s ease-in-out infinite alternate;
          {% elif is_state(config.entity, 'heat') %}
            --card-mod-icon: mdi:fire;
            animation: heat 2s infinite;
          {% elif is_state(config.entity, 'cool') %}
            --card-mod-icon: mdi:snowflake;
            animation: cool 6s ease-in-out infinite;
          {% elif is_state(config.entity, 'dry') %}
            --card-mod-icon: mdi:water-percent;
            animation: dry 1.5s linear infinite;
          {% elif is_state(config.entity, 'fan_only') %}
            --card-mod-icon: mdi:fan;
            --card-mod-icon: mdi:air-conditioner;
          display: flex;
        @keyframes cool {
          0%, 100% { transform: rotate(25deg); }
          25% { transform: rotate(-25deg); }
          50% { transform: rotate(50deg); }
          75% { transform: rotate(-50deg); }
        @keyframes heat {
          0%, 100% { --icon-color: rgba(var(--rgb-red), 1); }
          10%, 90% { --icon-color: rgba(var(--rgb-red), 0.8); }
          20%, 80% { --icon-color: rgba(var(--rgb-red), 0.6); }
          30%, 70% { --icon-color: rgba(var(--rgb-red), 0.4); }
          40%, 60% { --icon-color: rgba(var(--rgb-red), 0.2); }
          50% { --icon-color: rgba(var(--rgb-red), 0); }
        @keyframes dry {
          0%, 100% { --icon-symbol-size: 21px; }
          10%, 90% { --icon-symbol-size: 22px; }
          20%, 80% { --icon-symbol-size: 23px; }
          30%, 70% { --icon-symbol-size: 24px; }
          40%, 60% { --icon-symbol-size: 25px; }
          50% { --icon-symbol-size: 26px; }
        ha-card {
          box-shadow: none;
Are you updated to Mushroom 3.4.1?
Ah you are correct again:
There’s an open issue regarding this.
Thank you sir!
Yes sir, thanks for checking the issues and posting what you found. Helps others :person_tipping_hand:
@mr_aleks, you can combine a template card with the update card with a stack in card like this:
cards:
    entity: update.home_assistant_supervisor_update
    icon: mdi:update
    icon_color: blue
    primary: test
    secondary: test2
    card_mod:
      style: |
        ha-card {
          padding-bottom: 0px !important;
    card_mod:
      style: |
        mushroom-state-item {
          display: none;
the top card you can then put whatever you want. with your theme you may need to remove borders from each card too with card mod.
Ah true. I got too fancy
Not too fancy, your solution is a good solution and its super useful to know how to replace something in a card with something else using card mod.
Made me thinking…I have this card for my HA Server:
mode: horizontal
cards:
    icon_type: entity-picture
    primary: Version Information
    secondary: >-
      Installed v{{ state_attr('update.home_assistant_core_update',
      'installed_version')}}
      Latest v{{ state_attr('update.home_assistant_core_update',
      'latest_version')}}
    icon: mdi:package-variant-closed
    multiline_secondary: true
    tap_action:
      action: more-info
    icon_color: |-
      {% if is_state('update.home_assistant_core_update', 'on') %}
        orange
        green
    badge_color: |-
        red
        blue
    badge_icon: |-
        mdi:help
        mdi:check-bold
Now, my question is: how is it possible that the icon is not round, but somewhat like a “drop” ?
btw to fix the issue of content spinning with the icon, you can just add the animation only to the chips icon:
        chips:
          - type: conditional
            conditions:
              - entity: fan.all
                state: 'on'
            chip:
              type: template
              icon: mdi:fan
              icon_color: green
              content: >
                | list | count }}
              tap_action:
                action: fire-dom-event
                browser_mod:
                  service: browser_mod.popup
                    title: Ventoinhas
                    content:
                      type: custom:vertical-stack-in-card
                      horizontal: false
                      cards:
                        - type: custom:mushroom-fan-card
                          entity: fan.air_purifier
                          icon_animation: true
                          collapsible_controls: true
                          show_percentage_control: true
                          tap_action:
                            action: toggle
                          hold_action:
                            action: more-info
                          double_tap_action:
                            action: navigate
                            navigation_path: /lovelace/ambience
                          card_mod:
                            style: |
                              ha-card {
                                --rgb-state-fan: var(--rgb-cyan);
                        - type: horizontal-stack
                          cards:
                              entity: fan.living_room
                              show_oscillate_control: true
                              tap_action:
                                action: toggle
                              hold_action:
                                action: more-info
                              double_tap_action:
                                action: navigate
                              entity: fan.bedroom
                              tap_action:
                                action: toggle
                              hold_action:
                                action: more-info
                              double_tap_action:
                                action: navigate
        alignment: justify
        card_mod:
          style:
            mushroom-conditional-chip:nth-child(1):
              mushroom-template-chip$: |
                ha-state-icon {
                  animation: spin 1s linear infinite reverse;
                @keyframes spin {
                  100% { transform: rotate(280deg) scale(1); }
definitely not as easy though :slight_smile:
Sorry note sure what you mean? which icon do you want shaped like a drop?
the picture one or the other one? or both somehow? and what exact shape do you mean (direction of the drop)
Sorry. More specific: the Home Assistant icon.
I used this in the config:
But it is not round, it is like a drop in my opinion, where I want it to be round?
