sparkydave
(š¦šŗ Dave)
January 25, 2023, 7:18am
5130
I tried to adapt this code for my garage door but it isnāt working.
icon_color: >-
{{ 'red' if states.binary_sensor.paradox_z3_garage_door.state == 'off'
else 'green' }}
When used in a mushroom cover card I simply get the default icon colours (grey when closed, blue when open) but in a mushroom entity card it completely removes part of the iconā¦
Any ideas?
Also, in the mushroom entity card the icon does not change between an open or closed garage door but the cover card does. I take it we need to template the icon for the entity card in a similar way to the colour but Iād like to get that bit working first.
not sure if this is causing your issue, but regular jinja rules strongly suggest you to use the below format:
{{ 'red' if states('binary_sensor.paradox_z3_garage_door') == 'off'
else 'green' }}
to prevent issues when the state is not known to the system. thereās a warning sign in the jinja docs on this
sparkydave
(š¦šŗ Dave)
January 25, 2023, 7:51am
5132
Thanks for the tipā¦ Itās still not working though.
- type: custom:mushroom-cover-card
entity: cover.garage_door
icon_color: >-
{{ 'red' if states('binary_sensor.paradox_z3_garage_door') == 'off' else 'green' }}
Canāt see icon_color
as an option for the cover card ? Maybe need to use card_mod
https://github.com/piitaya/lovelace-mushroom/blob/b664347715cfaabc16de880617095d6e8e2256df/docs/cards/cover.md
I have this working but only in the template card:
icon_color: "{{ is_state('person.xxxxxx', 'home') | iif('green', 'red') }}"
rak
(Ralf KlĆ¼ber)
January 25, 2023, 9:02am
5134
We have been discussing template card. I started suing template card more and more bc I am fully flexible what to show. Combine multiple entities ā¦ what not. Requires you become fluent in jinja.
rhysb
(Rhys)
January 25, 2023, 9:51am
5135
Perhaps something like this.
Mushroom Restriction Card:
type: custom:mod-card
card:
type: custom:restriction-card
restrictions:
confirm:
text: Do you want to proceed?
card:
type: custom:mushroom-entity-card
entity: switch.coffee_machine
tap_action:
action: toggle
card_mod:
style:
restriction-card$: |
ha-icon {
display: flex;
position: absolute;
justify-content: center;
align-items: center;
top: 8px;
left: 40.5px;
background: rgb(var(--rgb-grey-color));
color: rgb(var(--rgb-white-color));
border-radius: 50%;
--lock-icon-size: 0.9em;
--lock-opacity: 1;
width: 17px;
height: 17px;
Restriction Card was easier to customize, so would recommend sticking with that .
o yes, that was what I had in mind indeedā¦ though I would have hoped to leave card-mod/mod-card home when talking about mushroom/tileā¦
but yes, that Is a very good setup. cool thanks!
we should loop Paul in , and hope he can make this available in core HA Tileā¦
the badge icon is much bigger here though (because I have the some restriction variables set in my theme already):
restriction-lock-row-margin-left: calc(100% - 25px) #95%
restriction-regular-lock-color: red
restriction-lock-opacity: 0.8
I tried to set it to:
--mdc-icon-size: var(--badge-icon-size);
but that is not recognized (I did not set it in my themes, and hoped it would be a system default variable, so I need to set the size to 14px (maybe even 16?)
its almost there (though the icon itself is a bit too big, and the badge circle seems a tad too tiny:
even on a regular Tile card (sorry if thats not allowed hereā¦)
for comparison:
- type: custom:mushroom-climate-card
entity: climate.heater_library
show_temperature_control: true
# hvac_modes:
# - auto
# collapsible_controls: true
# fill_container: false
layout: horizontal
- type: tile
entity: device_tracker.google_home_library
- type: custom:mod-card
card:
restrictions:
confirm:
card:
type: tile
entity: switch.espresso_keuken
tap_action:
action: toggle
card_mod:
style:
ha-icon {
--mdc-icon-size: 16px;
display: flex;
position: absolute;
top: 8px;
left: 40px;
background: red;
border-radius: 50%;
have to struggle with the var(ālock-icon-size) that is used in Chrome, (where does that come formā¦) while Safari immediately shows the size Ive set in the modā¦
rhysb
(Rhys)
January 25, 2023, 10:23am
5137
There are already some variable for this, --mush-rgb-state-cover-open
& --mush-rgb-state-cover-closed
. You can use these in card-mod or your theme.
card_mod:
style: |
:host {
--mush-rgb-state-cover-open: var(--rgb-red-color);
--mush-rgb-state-cover-closed: var(--rgb-green-color);
rhysb
(Rhys)
January 25, 2023, 10:44am
5138
Itās defined in :host
--lock-icon-size: var(--restriction-lock-icon-size, var(--mdc-icon-size, 24px));
So --restriction-lock-icon-size
takes precedence over --mdc-icon-size
For sizing I found it easier to use a Mushroom Template Card with a badge and overlay the lock badge over that with opacity 0.5.
rhysb
(Rhys)
January 25, 2023, 10:58am
5139
Add some debugging to your Node Red flow to see where the issue is. Your sensor entities should have values like this:
the icon-size variable wont work in my mods unfortunately, and I need to set it via mdc-icon-size.
since this would be a mod to use throughout the config, I made a decluttering-template out of it:
card_mod:
style:
ha-icon {
display: flex;
position: absolute;
top: 8px;
left: 40px;
background: blue;
border-radius: 50%;
card:
restrictions:
confirm:
card:
type: '[[type]]'
entity: '[[entity]]'
tap_action:
action: toggle
and used it like:
- type: custom:decluttering-card
template: badge_mod
variables:
- type: 'custom:mushroom-entity-card'
- entity: switch.espresso_keuken
but look what happens:
the mod is not applied at allā¦ same happening on a core tile card.
another reason for Paul to make this into core
uhm, please elaborateā¦?
primary: >
{{state_attr(entity,'friendly_name')}}
secondary: >
{{states(entity)|title}}
# card does not default to the icon attribute if the set entity, so this requires yet another template
icon: >
mdi:{{iif(is_state(entity,'on'),'coffee','coffee-off')}}
badge_icon: mdi:lock
badge_color: red
shows the badge on the perfect spot indeed, and nicely margined and padded, just like it should.
but now how to get the active lock there?
btw, template state does not translateā¦ always an issue somewhereā¦
and for complete disclosure, I managed to get some of the restriction card variables in the styling:
card_mod:
style:
ha-card {
--restriction-lock-icon-size: 14px;
--restriction-regular-lock-color: rgb(var(--rgb-white-color));
--restriction-success-lock-color: green;
--restriction-lock-opacity: 0.8
/*--restriction-lock-row-margin-left: 40px;*/
/*--restriction-lock-row-margin-top: 0px;*/
ha-icon {
display: flex;
position: absolute;
top: 8px;
left: 40px;
background: red;
border-radius: 50%;
BeastHouse
(Damien)
January 25, 2023, 12:12pm
5142
Hi all. Slowly changing over to mushroom cards, they look great. I have one card that currently changes the name through a template sensor. Is it possible to do this with the mushroom entity card?
Example of what I currently use:
if (states['binary_sensor.home_assistant_versions_update_available'].state === 'off') return "Current";
else return "Updates";
jetolu
(Jetolu)
January 25, 2023, 12:58pm
5143
Itās possible using the Template card! When migrating to Mushroom cards, I started using Entity cards but soon switched to template cards which are far more versatile. See the example below, where I show different icons based on an attribute.
{% if state_attr(entity, 'changePercent') > 0 %}mdi:arrow-up{% elif state_attr(entity, 'changePercent') == 0 %}mdi:arrow-right{% else %}mdi:arrow-down{% endif %}
brewston
(Tim Jones)
January 25, 2023, 1:06pm
5144
There is a mushroom update card :
type: custom:mushroom-update-card
entity: update.home_assistant_core_update
had another check on my earlier effort for the decluttering card, and noticed now I made a small but sgnificant mistake:
card:
card_mod:
style:
ha-card {
ha-icon {
display: flex;
position: absolute;
top: 8px;
left: 40px;
background: red;
border-radius: 50%;
card:
restrictions:
confirm:
card:
type: '[[type]]'
tap_action:
action: toggle
does the trick.
always open the decluttering cards with a
card:
type:
allowing this to be used like:
template: badge_mod
variables:
and with some more tinkering:
card:
type: custom:config-template-card
entities:
- '[[entity]]'
variables:
id: states[ '[[entity]]' ].attributes.friendly_name
card:
card_mod:
style:
ha-card {
ha-icon {
display: flex;
position: absolute;
top: 8px;
left: 40px;
background: red;
border-radius: 50%;
card:
restrictions:
confirm:
text: ${'Wil je ' + id + ' schakelen?'}
card:
type: '[[type]]'
tap_action:
action: toggle
we get a nice confirmation message based on the attribute selected to our liking
template: badge_mod
variables:
- type: tile #'custom:mushroom-entity-card'
note I moved the conformation itself to the cinfig-template-card, because a decluttering-card by itself can Not evaluate templates.
stban1983
(stban1983)
January 25, 2023, 2:33pm
5146
Here the screenshot, after clicking on the volume button:
(I donāt use node-red)
EDIT:
find!
that was:
ha-card {
--ha-card-border-width: 0;
--rgb-state-media-player: var(--album-art-color); ## THIS ONE
--control-icon-size: 32px;
background-color: transparent;
margin-top: 172px;
For the vol+ and vol-, i donāt know, maybe itās a media_player limitation ?
Moss
(Marco)
January 25, 2023, 3:32pm
5147
Without Node red you wonāt be able to do this because an extra sensor is created.
You can see it at the bottom of the code.
I donāt use node red either, just use an older version of Rhysās Media Player Card.
I promise you the music will play just as good as with this one
or change it to:
:host {
margin-top: 50px !important;
--album-art-color: var(--rgb-indigo-color);
Greetings
Marco
tpbillund
(Tpbillund)
January 25, 2023, 4:21pm
5148
Hi @seanmccabe
So beautiful
Can you tell me why I get circles around my stuff?
I use the code you have listed further down.
seanmccabe
(SeƔn McCabe)
January 25, 2023, 6:22pm
5150
Because HA updated their material design implementation, and by default it adds the stupid border around things.
The majority of us all hate that.
You will need to set the border to 0 to remove, or use a theme where the border is off by default.
