Ok guys…I called Shell today on their hotline, told them to activate the DPM and voila, they just did
So…As I live in Germany and have a 3 phase grid connection I had to test around. @thomase1234 told me to first manually test by adjusting the CT-values in ESP.
First of all: IT WORKS!
But. The charger has a REALLY strange behaviour.
I have a 35A 3 phase grid connection and my charge has a 25A fuse, this is what Shell put in the config.
First I tried my 3 phase cable:
Charging need is in default 23,75A (pf 0,95), so everything is correct.
I started to adjust all 3 CT values in ESP and had the following results:
CT1-3 Value | Charger Limited Now Value | sum of both
20A | 19,5A | 39,5
22A | 17,5A | 39,6
23A | 16,7A | 39,7
25A | 14,3A | 39,3
until here everything is fine. We know that the charger at least needs 8A to charge, but what then happened was strange:
25,2A | started with 12,5A and went down .12,2A…11,7A…10,9A…drops → turns off
27 A | turns off immediately
so…14A or below in a three phase connection does not seem to work
The adjustment on only ONE CT-value has led to the same result! It seems that the charger takes the min of CT1 CT2 CT3 into account.
I then tried with a single phase cable which I also have.
At the beginning I still adjusted all 3 CT values at the same time:
0 A | 23,75A
15A | 8,75A
15,5A | 8,25A
15,7A | 8,10A
15,8A → goes down and turns off
But ok…as I use a SINGLE phase cable I started to play around with only ONE CT-Value at a time…and it started to get even stranger:
CT1: 15,7A CT2= 0,0A CT3=0,0A → 23,75A at the charger available
CT1: 0,0A CT2= 15,7A CT3=0,0A → 8A at the charger available
CT1: 0,0A CT2= 0,0A CT3=15,7A → 8A at the charger available
It’s a pity that the 3 phase cable does not work with 8A, therefore I will have to use the single phase cable and charge between 1,8kw and 5,8kW , which is ok during fall and winter as I don’t think that I’ll have often my full solar power (12kW).
