Spend $15 on a Sonoff SV + magnetic reed sensor, you’ll never need to wait again.
Since I do (begrudgingly and infrequently) use the MyQ app (connected on a separate VLAN on my home network) I really don’t need the HA integration for opening and closing my garage door. My automation is around sensing the door is open or closed. That’s why I also highly recommend a separate sensor for your garage door.
I have Z-Wave, so in my case I came across a DSB29 Door/Window Sensor (2nd Edition)
by AEON Labs. It’s a simple magnetic sensor. Attaching it to the door and integrating with OZW (beta) was simple and it has worked continuously since spending the 15 minutes or so installing.
Here’s an image showing how I mounted it:
