in fact I didn’t have help with SSH I just installed the add-on and logged in with root user
I found a tutorial that I need to login with core-ssh login, but I don’t know this login
Look at screen capture when you log in ssh it’s not the same as bubez81.
I don’t know how it works. I’m using a pure debian.
Do you think I better migrate from a system?
Do you use debian on VM or physical?
All my infra is vm or container in proxmox.
You could make a try why not depending of your need.
which server is better to install debian or ubuntu?
Try a simple debian for start.
What does the command hcitool -lescan do?
Hum it should not do that but list Bluetooth LE device near the dongle like the Nespresso machine (even without connection to it).
So all must be good just install the integration and configure it. You should see your value.
would that be integration?
- platform: nespresso
mac: DD:A0:A5:A5:C8:82
resource: 89ac4f5c47ddc41f
scan_interval: 30
That’s for the configuration. And in hacs install the custom components.
is already installed and configured even then does not appear :(, is there any other test I can try?
