The beauty, wonder and conundrum of HA - 25 differnt ways to achieve the same outcome. Most of them not elegant when I finish with them
Yup, doesnât have to be pretty to be functional!
Im thinking im still on 0.9.13 as im on 0.89.1, any way to find out what version im running. Also anyway you can update nessclient from ssh in docker?
Matt
Try running pip3 show nessclient
to verify what version youâre on. Then you can run pip3 install nessclient==0.9.14
to upgrade.
Interesting you mention this - the client will transition through different states when an arm occurs - should go via arming
, exit_delay
then armed
. This appears to work as expected for me. Can you confirm this is the case for you? I noticed you mentioned some things about automations above.
Unfortunately this fix didnât make it into the 0.89 release, but should make be in 0.90. As other mentioned, you can upgrade the client manually in the container.
I can only see mine go through arming
and then disarmed
, occasionally it will enter armed
before quickly reverting to disarmed
Iâve triple checked that I donât have any automation which could be interfering and disabled the one I do have (only sends push notifications upon alarm state changes). Problem doesnât exist under 0.88.2
with same configuration.
I have no automations atm until Iâm sure itâs all running well. I notice it will not update alarm status correctly if I do it via HA, but if I do it via Ness and keypad it works. âarmingâ only flashes for like 3-5 seconds then will go back to disarm then will goto armed away once system is actually armed after the cooldown beeps for leaving
Very weird, but I expect it is due to the changes I made in Get arming state on update by nickw444 ¡ Pull Request #25 ¡ nickw444/nessclient ¡ GitHub.
To confirm, can you install the latest version of nessclient
and run:
ness-cli events --host alarm.home --port 8234
And whilst that is listening, arm your panel manually and watch for messages like
Alarm state changed to ArmingState.DISARMED
Can you let me know the flow it goes through when you do this please?
For me, it does the following:
** send arm command **
Alarm state changed to ArmingState.ARMING
Alarm state changed to ArmingState.EXIT_DELAY
Alarm state changed to ArmingState.ARMED
** send disarm command **
And does not go back into DISARMED
as far as I can tell
Ok. Updated to nessclient==0.9.14
and the results are below:
note no disarm command was sent
<ArmingUpdate {'address': 0, 'timestamp': None, 'request_id': <RequestID.ARMING: 20>, 'status': []}>
<SystemStatusEvent {'address': 0, 'timestamp': datetime.datetime(2018, 7, 20, 1, 39, 14), 'type': <EventType.ARMED_NIGHT: 39>, 'zone': 1, 'area': 3}>
<SystemStatusEvent {'address': 0, 'timestamp': datetime.datetime(2018, 7, 20, 1, 39, 14), 'type': <EventType.EXIT_DELAY_START: 34>, 'zone': 1, 'area':
3}>
<ZoneUpdate {'address': 0, 'timestamp': None, 'request_id': <RequestID.ZONE_INPUT_UNSEALED: 0>, 'included_zones': []}>
Zone 1 changed to False
Zone 2 changed to False
Zone 3 changed to False
Zone 4 changed to False
Zone 5 changed to False
Zone 6 changed to False
Zone 7 changed to False
Zone 8 changed to False
Zone 9 changed to False
Zone 10 changed to False
Zone 11 changed to False
Zone 12 changed to False
Zone 13 changed to False
Zone 14 changed to False
Zone 15 changed to False
Zone 16 changed to False
Very interesting, do you mind doing that again, except this time with debug enabled?
ness-cli --log-level debug events --host alarm.home --port 8234
Would like to get to the bottom of why your alarm is responding to the S14 request with a disarmed state.
Sure, anything I can do to help figure this thing out. Results from --log-level debug
DEBUG:nessclient.client:Attempting to connect
DEBUG:nessclient.client:Decoding data: '8200036014000007'
DEBUG:nessclient.packet:Decoding bytes: '8200036014000007'
DEBUG:nessclient.client:Decoding data: '820003600000001b'
DEBUG:nessclient.packet:Decoding bytes: '820003600000001b'
DEBUG:nessclient.client:Decoding data: '8700036127010318072001441353'
DEBUG:nessclient.packet:Decoding bytes: '8700036127010318072001441353'
<SystemStatusEvent {'address': 0, 'timestamp': datetime.datetime(2018, 7, 20, 1, 44, 13), 'type': <EventType.ARMED_NIGHT: 39>, 'zone': 1, 'area': 3}>
DEBUG:nessclient.client:Decoding data: '87008361220103180720014413d8'
DEBUG:nessclient.packet:Decoding bytes: '87008361220103180720014413d8'
<SystemStatusEvent {'address': 0, 'timestamp': datetime.datetime(2018, 7, 20, 1, 44, 13), 'type': <EventType.EXIT_DELAY_START: 34>, 'zone': 1, 'area':
3}>
DEBUG:nessclient.client:Decoding data: '8700036123000318072001442249'
DEBUG:nessclient.packet:Decoding bytes: '8700036123000318072001442249'
<SystemStatusEvent {'address': 0, 'timestamp': datetime.datetime(2018, 7, 20, 1, 44, 22), 'type': <EventType.EXIT_DELAY_END: 35>, 'zone': 0, 'area': 3}>
Looks like it might be due to the arming mode youâre using here, I have only tested with arm away, no other modes like arm home, etc. as we do not use these in my household.
Are you able to see if the issue persists if you try arm using arm away instead? (Ultimately weâd find a way to have this library support all arming modes, after all, the official app supports it)
We donât usually either, just exclude a few zones and then arm_away
but was thinking about using home in the future.
I believe arm_home
wasnât an issue before either, even though you hadnât tested it.
Debugged again, this time using arm_away
DEBUG:nessclient.client:Decoding data: '8700036124010118072001535804'
DEBUG:nessclient.packet:Decoding bytes: '8700036124010118072001535804'
<SystemStatusEvent {'address': 0, 'timestamp': datetime.datetime(2018, 7, 20, 1, 53, 58), 'type': <EventType.ARMED_AWAY: 36>, 'zone': 1, 'area': 1}>
DEBUG:nessclient.client:Decoding data: '8700836122010118072001535886'
DEBUG:nessclient.packet:Decoding bytes: '8700836122010118072001535886'
<SystemStatusEvent {'address': 0, 'timestamp': datetime.datetime(2018, 7, 20, 1, 53, 58), 'type': <EventType.EXIT_DELAY_START: 34>, 'zone': 1, 'area':
1}>
DEBUG:nessclient.client:Decoding data: '8700036123000118072001540756'
DEBUG:nessclient.packet:Decoding bytes: '8700036123000118072001540756'
<SystemStatusEvent {'address': 0, 'timestamp': datetime.datetime(2018, 7, 20, 1, 54, 7), 'type': <EventType.EXIT_DELAY_END: 35>, 'zone': 0, 'area': 1}>Alarm state changed to ArmingState.ARMED
Thanks for that extra info. Definitely looks like an issue with the way your panel responds to the Arming
request that nessclient
makes. However something is a bit suspicious to me - the ness-cli youâre running isnât showing the commands it is running (i.e. S16, S00
DEBUG:nessclient.client:Requesting state update from server (S00, S14)
DEBUG:nessclient.client:Sending payload: '8300360S00E9\r\n'
DEBUG:nessclient.client:Sending payload: '8300360S14E4\r\n'
Can you confirm you are running v0.9.14
please by running pip show nessclient
Version: 0.9.14
Summary: Implementation/abstraction of the Ness D8x / D16x Serial Interface ASCII protocol
Home-page: https://github.com/nickw444/nessclient
Author: Nick Whyte
Author-email: [email protected]
License: UNKNOWN
Location: /Users/nickw/.local/share/virtualenvs/test--MzFoo-H/lib/python3.7/site-packages
Requires: justbackoff
Required-by:
If you are not running the latest version, you can do so by running
pip install --upgrade 'nessclient[cli]'
If you were not running the latest version before, can you please re-run the command to obtain the debug data? Thanks.
@nickw444 just to let you know I updated to .90b on friday and my issue is now resolved, seems to be running great other than the reported Armed Home dropping back to disarmed. But other than that it seems really stable. Thanks heaps for your work.
Iâve had to jerry-rig an input_boolean
triggered on arming
as a way of tracking when itâs armed for my automations which rely on the alarm to function.
Hopefully @nickw444 finds time to troubleshoot the issue since it was working flawlessly before this recent change, especially with the added scan_interval
option, if I can provide any further debugging info just let me know.
Hi @cryptelli Iâm still a bit suspicious about the logs you provided, even though you were able to confirm you are running 0.9.14
. It will be very difficult to reproduce and debug the issue without being able to see what data ness-cli
is sending to your IP module.
I would expect output similar to the following
when running the command:
(Notice the verbose output of what is being sent to the IP module).
Also out of curiosity, and maybe to assist debugging, what is your scan_interval
set to at the moment?
I wasnât really sure what to reply with initially, apart from supply a screen recording to show that itâs honestly not producing the information youâre looking for⌠when I had a strange idea to run that debug command in the docker container where I had tested the scan_interval
which was running HA 0.89.0.dev0
and too my surprise it flipping displayed the same information youâre after, though only upon initial connection the alarm events still arenât showing any verbose output.
The below debug log was run using HA 0.91.0.dev0
using docker.
root@56f41e46d2dc:/usr/src/app# ness-cli --log-level debug events --host IP --port PORT
DEBUG:nessclient.client:Decoding data: '87008361240101180726033544ae'
DEBUG:nessclient.packet:Decoding bytes: '87008361240101180726033544ae'
<SystemStatusEvent {'address': 0, 'timestamp': datetime.datetime(2018, 7, 26, 3, 35, 44), 'type': <EventType.ARMED_AWAY: 36>, 'zone': 1, 'area': 1}>
DEBUG:nessclient.client:Decoding data: '8700036122010118072603354430'
DEBUG:nessclient.packet:Decoding bytes: '8700036122010118072603354430'
<SystemStatusEvent {'address': 0, 'timestamp': datetime.datetime(2018, 7, 26, 3, 35, 44), 'type': <EventType.EXIT_DELAY_START: 34>, 'zone': 1, 'area': 1}>
DEBUG:nessclient.client:Decoding data: '87008361230001180726033553a1'
DEBUG:nessclient.packet:Decoding bytes: '87008361230001180726033553a1'
<SystemStatusEvent {'address': 0, 'timestamp': datetime.datetime(2018, 7, 26, 3, 35, 53), 'type': <EventType.EXIT_DELAY_END: 35>, 'zone': 0, 'area': 1}>
Donât know if the above is of any use, but Iâm not sure what else I can do from my end to get the results youâre after. Interested to hear your thoughts on this.
I lowered my scan_interval
to 2s
but havenât been using it as it wasnât in 0.89.2
and my attempt to override the default component wasnât successful, only tested it briefly in the test instance I mentioned above. Figured Iâd just wait until it was officially supported in 0.90.0
