@nickw444 was the information provided in my previous post enough for you to debug and work on a fix?
Please let me know if I can do anything else to assist.
sensors are working fine but arm home isnât working for status update. arms the panel but stays as âdisarmedâ
on latest 0.90.1
logs seem normal. but iâll keep checking
2019-03-23 21:43:00 DEBUG (MainThread) [nessclient.client] Decoding data: â820003601700867eâ
2019-03-23 21:43:00 DEBUG (MainThread) [nessclient.packet] Decoding bytes: â820003601700867eâ
2019-03-23 21:43:00 WARNING (MainThread) [nessclient.client] Failed to decode packet
ValueError: 23 is not a valid RequestID
File â/usr/local/lib/python3.7/site-packages/nessclient/client.pyâ, line 123, in _recv_loop
event = BaseEvent.decode(pkt)
File â/usr/local/lib/python3.7/site-packages/nessclient/event.pyâ, line 39, in decode
return StatusUpdate.decode(packet)
File â/usr/local/lib/python3.7/site-packages/nessclient/event.pyâ, line 149, in decode
request_id = StatusUpdate.RequestID(int(packet.data[0:2], 16))
File â/usr/local/lib/python3.7/enum.pyâ, line 309, in call
return cls.new(cls, value)
File â/usr/local/lib/python3.7/enum.pyâ, line 561, in new
raise exc
File â/usr/local/lib/python3.7/enum.pyâ, line 545, in new
result = cls.missing(value)
File â/usr/local/lib/python3.7/enum.pyâ, line 574, in missing
raise ValueError("%r is not a valid %s" % (value, cls.name))
Iâve been conducting some further tests and below are my findings:
| Home Assistant Version |
nessclient Version |
Observations (HA UI) | Stable |
0.88.2 |
0.9.9 |
Alarm initially disarmed state, after entering pin and using ARM HOME, goes to âARMINGâ state, then âAWAYâ. | Yes |
0.88.2 |
0.9.10 |
Alarm initially in the disarmed state, after entering pin and using ARM HOME, goes to ARMING then shortly changes to DISARMED. |
No |
0.88.2 |
0.9.11 |
ditto | ditto |
0.88.2 |
0.9.12 |
ditto | ditto |
0.88.2 |
0.9.13 |
ditto | ditto |
0.88.2 |
0.9.14 |
ditto | ditto |
0.99.1 |
0.9.9 |
0.99.1 |
0.9.10 |
No |
0.99.1 |
0.9.14 |
ditto | ditto |
Based on the above it would appear the issue has crept in from modifications made in nessclient==0.9.10. I hope this can assist you @nickw444 in narrowing down the changes that could have caused this.
Iâve reverted my installation back to 0.9.9 until a fix is released since it was pretty stable and reported the state update reliably.
Very good observations
Hi @Yuddy and @cryptelli, thanks for those details. The version breakdown is going to help me a lot in working out what went wrong. I have a feeling it is to do with this change https://github.com/nickw444/nessclient/pull/23. I havenât had much time lately, but I think I will find some time later this evening to take a deeper look into the problem and potentially solve it.
Iâm sure youâve both posted it above, but to make sure I have it, would you both be able to report your panel version please?
@nickw444 Im not super fluent on Python, but the code doesnt look to handle anything other than AREA_1_ARMED or AREA_1_FULLY_ARMED and because in Home it receives a different value it defaults back to disarmed.
If I remember correctly when working on pComms, I had to send 8300360S14E4 after the Exit Delay had ended to capture the correct state of the alarm as I dont think it always sends the status.
I hope that makes sense.
Matt
I wasnât sure where you were at since the debug information didnât seem to be useful so Iâm glad the version breakdown is going to assist in resolving this, however I feel youâve already narrowed it down successfully.
I updated to nessclient==0.9.14, restored the code from before PR #23 and everything is working as it should.
@cryptelli : 5.7
@Yuddy: 8.6
I test with home (saves me excluding zones while playing around). Under nessclient==0.9.9 itâs able to handle both arming in HOME and AWAY (without reverting to DISARMED) itâs just that HOME is reflected in the UI as âArmed awayâ.
Hi @cryptelli Iâve had a further look into the issue and honestly canât work out why your panel would return an empty response to the S14 request:
8200036014000007
This is what is causing the client to revert back to the DISARMED state. The reason this worked originally is because I had a workaround for the incorrect enum documentation which mean I had to infer the DISARMED state via system status events rather than user interface request responses.
Not to worry though, I have brought back the âinferenceâ functionality until we can find a better solution.
I have put this configuration option behind a flag as it could introduce buginess for currently working setups (like my own). There is potential for setups using this flag to now get stuck/report an ARMED or ARMING state and never return to DISARMED if the panel never emits (or it is not received) a system status event declaring the panel is disarmed. (Unlikely though)
If this solution proves to be successful and applies to particular panel versions (i.e. <5.8 ), then I can introduce a version check at startup and have this functionality auto-configured to avoid needless setup to get a working system. This would use the newly added #36 functionality.
This is the command being sent periodically to the panel (denoted by update_interval), which is what is causing the empty response to be returned described above.
Anyway, that aside, I have released a new pre-release version 0.9.15b1 which can be installed the same as before:
pip install --upgrade 'nessclient[cli]==0.9.15b1'
It would be greatly appreciated if you could test it with the following command, which switches on the state assumption branch:
ness-cli --log-level debug events --host alarm.home --port 8234 --infer-arming-state
Letâs see if this resolves the issue. If this is successful, I will release the fix and bump the version in HA.
Again, thank you @nickw444 for trying to iron these kinks out for some of us, itâs greatly appreciated. Iâm also at a loss as to why my panel doesnât respond normallyâŚ
I received the notification on GitHub that youâd released 0.9.15b1 and was already upgrading as were posting, thanks for the detailed explanation of the problem and what your plans are to resolve it when this is sorted
At this stage itâs a 50/50 successful state change, half gets to âARMEDâ and reverts to DISARMED after a couple of seconds (slower to revert than before) and the other half doesnât make it past ARMING before reverting.
Iâm running tests now and will post back with the debug messages.
Logs using --infer-arming-state flag as requested. Once that last arming update hit the UI reported DISARMED.
EDIT: I know its armed using NIGHT/HOME but the behaviour is the same with AWAY.
DEBUG:nessclient.client:Requesting state update from server (S00, S14)
DEBUG:nessclient.client:Attempting to connect
DEBUG:nessclient.client:Sending payload: '8300360S14E4\r\n'
DEBUG:nessclient.client:Sending payload: '8300360S00E9\r\n'
DEBUG:nessclient.client:Decoding data: '8200036014000007'
DEBUG:nessclient.packet:Decoding bytes: '8200036014000007'
<ArmingUpdate {'address': 0, 'timestamp': None, 'request_id': <RequestID.ARMING: 20>, 'status': []}>
Alarm state changed to ArmingState.DISARMED
DEBUG:nessclient.client:Decoding data: '820003600000001b'
DEBUG:nessclient.packet:Decoding bytes: '820003600000001b'
<ZoneUpdate {'address': 0, 'timestamp': None, 'request_id': <RequestID.ZONE_INPUT_UNSEALED: 0>, 'included_zones': []}>
Zone 1 changed to False
Zone 2 changed to False
Zone 3 changed to False
Zone 4 changed to False
Zone 5 changed to False
Zone 6 changed to False
Zone 7 changed to False
Zone 8 changed to False
Zone 9 changed to False
Zone 10 changed to False
Zone 11 changed to False
Zone 12 changed to False
Zone 13 changed to False
Zone 14 changed to False
Zone 15 changed to False
Zone 16 changed to False
DEBUG:nessclient.client:Decoding data: '87008361270103180801005304f2'
DEBUG:nessclient.packet:Decoding bytes: '87008361270103180801005304f2'
<SystemStatusEvent {'address': 0, 'timestamp': datetime.datetime(2018, 8, 1, 0, 53, 4), 'type': <EventType.ARMED_NIGHT: 39>, 'zone': 1, 'area': 3}>
Alarm state changed to ArmingState.ARMING
DEBUG:nessclient.client:Decoding data: '8700036122010318080100530576'
DEBUG:nessclient.packet:Decoding bytes: '8700036122010318080100530576'
<SystemStatusEvent {'address': 0, 'timestamp': datetime.datetime(2018, 8, 1, 0, 53, 5), 'type': <EventType.EXIT_DELAY_START: 34>, 'zone': 1, 'area': 3}>
Alarm state changed to ArmingState.EXIT_DELAY
DEBUG:nessclient.client:Decoding data: '87008361230003180801005314e7'
DEBUG:nessclient.packet:Decoding bytes: '87008361230003180801005314e7'
<SystemStatusEvent {'address': 0, 'timestamp': datetime.datetime(2018, 8, 1, 0, 53, 14), 'type': <EventType.EXIT_DELAY_END: 35>, 'zone': 0, 'area': 3}>
Alarm state changed to ArmingState.ARMED
The log you attached appears to end before the next DISARMED was registered. Was there more output? Can you please attach that as it will help me figure out what is causing it to go back to DISARMED.
If thatâs all the output there is, then thatâs good, since internally the alarm state is still set to ARMED.
I like good! No further update reflecting a DISARMED status, just ran it again and when the UI reflected DISARMED the below was output into the console:
EDIT: Just happened to notice that the logs now show a âSending payloadâ?
Ah interesting. Just checking that youâve restarted home-assistant since upgrading the package within the environment?
Sure did
Interesting, I feel like it might be easier to debug this over discord. Are you in the home-assistant discord chat?
I was starting to feel the same way, back and fourth on text can only get so far :). I can be, give me 5.
For future readers, we resolved this issue over DM - the patch to nessclient works, however we continued to see the issue as home-assistant has not been modified/updated to use the new functionality. I have raised a PR against Home Assistant to introduce this new configuration option:
Huge shoutout to @nickw444 for his assistance via DM in debugging the issue after it persisted while running nessclient==0.9.15b1.
The continued support is benefiting all of us who use Ness panels, thanks Nick.
Yeah I concur. Thanks so much @nickw444 i finally have automations with my sensors that I never had before and life has been ⌠Automated lol.
