Sure, you are welcome.
2021-04-19 20:46:18 ERROR (MainThread) [homeassistant.components.camera] Error while setting up netatmo platform for camera
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 205, in _async_setup_platform
await asyncio.shield(task)
File "/usr/src/homeassistant/homeassistant/components/netatmo/camera.py", line 53, in async_setup_entry
await data_handler.register_data_class(
File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 166, in register_data_class
await self.async_fetch_data(
File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 129, in async_fetch_data
self.data[data_class_entry] = await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/local/lib/python3.8/site-packages/pyatmo/camera.py", line 91, in __init__
self.update_camera_urls(camera_id)
File "/usr/local/lib/python3.8/site-packages/pyatmo/camera.py", line 164, in update_camera_urls
temp_local_url = check_url(vpn_url)
File "/usr/local/lib/python3.8/site-packages/pyatmo/camera.py", line 154, in check_url
resp = self.auth.post_request(url=f"{url}/command/ping")
File "/usr/local/lib/python3.8/site-packages/pyatmo/auth.py", line 172, in post_request
f"{resp.status_code} - "
File "/usr/local/lib/python3.8/site-packages/requests/models.py", line 900, in json
return complexjson.loads(self.text, **kwargs)
File "/usr/local/lib/python3.8/site-packages/simplejson/__init__.py", line 525, in loads
return _default_decoder.decode(s)
File "/usr/local/lib/python3.8/site-packages/simplejson/decoder.py", line 370, in decode
obj, end = self.raw_decode(s)
File "/usr/local/lib/python3.8/site-packages/simplejson/decoder.py", line 400, in raw_decode
return self.scan_once(s, idx=_w(s, idx).end())
simplejson.errors.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
