Ok…in a follow up from this post, I don’t think that my Homeassitant is crashing but instead it is losing network connection.
Lost connection again this morning.
Could not ping HomeAssiistant.
I have also tried to configure the wifi on the homeassistant and I could see that it was available on the WIFI network but did nto haev an IP
I went and Unplugged the LAN cable to it and plugged ti back in and presto back online.
Belwo is the log data I was able to get from around the time it went offline
023-01-08 09:26:13.317 WARNING (Thread-6) [pychromecast.socket_client] [upstairs(192.168.0.120):8009] Heartbeat timeout, resetting connection
2023-01-08 09:26:41.374 ERROR (MainThread) [homeassistant.components.androidtv.media_player] Failed to execute an ADB command. ADB connection re-establishing attempt in the next update. Error: Reading from 192.168.0.126:5555 timed out (9.0 seconds)
2023-01-08 09:26:41.962 WARNING (MainThread) [androidtv.adb_manager.adb_manager_async] Couldn't connect to 192.168.0.126:5555. OSError: Network unreachable
2023-01-08 09:26:43.344 ERROR (Thread-6) [pychromecast.socket_client] [upstairs(192.168.0.120):8009] Failed to connect to service ServiceInfo(type='mdns', data='Cosmos-4d1d5e2f7d09a3095f9fde66ba9d946c._googlecast._tcp.local.'), retrying in 5.0s
2023-01-08 09:26:45.074 ERROR (MainThread) [homeassistant.components.ipp.coordinator] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2023-01-08 09:26:49.444 WARNING (Thread-5) [pychromecast.socket_client] [Family room TV(192.168.0.118):8009] Heartbeat timeout, resetting connection
2023-01-08 09:26:49.450 ERROR (Thread-5) [pychromecast.socket_client] [Family room TV(192.168.0.121):8009] Failed to connect to service ServiceInfo(type='host', data=('192.168.0.121', 8009)), retrying in 5.0s
2023-01-08 09:26:51.658 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=22 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=22, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 42040)>
2023-01-08 09:26:51.671 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=22 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=22, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 42040)>
2023-01-08 09:26:52.221 ERROR (MainThread) [homeassistant.components.upnp] Error fetching 4G+ LTE Router data: Unable to communicate with IGD at: http://192.168.0.1:5500/rootDesc.xml
2023-01-08 09:26:56.411 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for energymonitor @ 192.168.0.196: Error connecting to ('192.168.0.196', 6053): [Errno 101] Network unreachable
2023-01-08 09:26:57.771 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=35 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=35, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 38895)>
2023-01-08 09:27:18.399 WARNING (MainThread) [zeroconf] Error with socket 19 (('192.168.0.110', 5353))): [Errno 101] Network unreachable
File "/usr/local/lib/python3.10/asyncio/selector_events.py", line 1054, in sendto
self._sock.sendto(data, addr)
OSError: [Errno 101] Network unreachable
2023-01-08 09:27:24.080 ERROR (MainThread) [homeassistant.components.homeassistant_alerts] Error requesting homeassistant_alerts data: Cannot connect to host alerts.home-assistant.io:443 ssl:default [Try again]
2023-01-08 09:27:27.779 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=35 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=35, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 38895)>
2023-01-08 09:27:29.972 WARNING (MainThread) [androidtv.adb_manager.adb_manager_async] Couldn't connect to 192.168.0.116:5555. OSError: Network unreachable
2023-01-08 09:27:57.785 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=35 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=35, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 38895)>
2023-01-08 09:27:58.483 ERROR (MainThread) [meteireann] http://metwdb-openaccess.ichec.ie/metno-wdb2ts/locationforecast?lat=51.67239989879772;long=-9.44894671396469;alt=70;from=2023-01-07T9:00 returned Cannot connect to host metwdb-openaccess.ichec.ie:80 ssl:default [Try again]
2023-01-08 09:28:27.791 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=35 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=35, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 38895)>
2023-01-08 09:28:50.297 WARNING (MainThread) [androidtv.adb_manager.adb_manager_async] Couldn't connect to 192.168.0.116:5555. OSError: Network unreachable
2023-01-08 09:28:51.659 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=22 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=22, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 42040)>
2023-01-08 09:28:51.664 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=22 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=22, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 42040)>
2023-01-08 09:28:57.801 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=35 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=35, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 38895)>
2023-01-08 09:29:27.807 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=35 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=35, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 38895)>
2023-01-08 09:29:57.817 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=35 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=35, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 38895)>
