New widgets: input slider(horizontal and vertical), input select and light with brightness
Ok, done that, I get
Unable to find widget type ‘input_select’
Unable to find widget type 'new_input_slider
wrong place or you didnt copy the yaml file.
very starnge I have this
i have no idea what i am looking at.
that is how it was before …
maybe a cash problem.
or you edited your dashboard wrong
or somewhere else there is a cash problem.
  1. clear the cash from your browser
  2. clear the subdirs in the dir compiled (leave the structure)
  3. restart appdaemon
  4. restart the complete device.
steps in that order and check in between if it solved the problem.
I opened in new browser in incognito mode
I do not understand this …
in the configuration dir, there is a subdir compiled.
that dir has 3 subdirs.
leave the 3 subdirs but clear all the files that are in it.
and i dont know if incognito mode will clear everything. i advice actively clearing cash. (and use normal mode, unless you already did use the incognito mode without troubles)
I have 2 instances of appdaemon: one on a NUC and one on a pi3
On the pi3 I found the compiled directory you mentioned andfollowed your instructions
On the NUC there was no compiled directory …
In both I have the same problem: I cleaned the cache and restarted … nothing, still the same
if there was no compiled directory, you never have looked at a dashboard from that device.
why do you have 2 instances from appdaemon?
and do they look at different instances from home assistant as well?
did you do exactly the same in both (create the same files on the same place, etc)?
its 2 machines, 2 HASS, 2 appdaemon, totally independent.
Until today was all working fine
Oh well, I cancel these custom_css, custom_widget, and revert back. Will wait until is in the official version
2 machines, 2 appdaemon, 2 hass, can not have the same dashboard (only 2 simular files on 2 different places)
to get to a dashboard you need an url, 2 dashboards means 2 different urls.
I cancelled the custom directory cleared the cache, restarted hass, and still same problem
it was working perfectly before: 2 machines, 2 hass, 2 URL, 2 set of files, two totally different machines in the same LAN (different IP)
did you make the dashboard like it was?
because you probably did something wrong in the dashboard.
restarting hass doesnt do anything. you should restart AD or your device.
ahhh restarting HASS is not restarting appdaemon?
Appdaemon is a completely different program that you installed seperatly.
you also dont restart your browser by restarting your mediaplayer :wink:
Ok,
I restarted appdaemon, still have the same weird fonts
