like i asked before
I got the same look when I tried to install a theme and forgot to put the CSS in the folder. If you open the browser’s console and reload the page do you get any error?
Nothing changed in the dashboard
Will check this. I have just added custom_css folder, nothing more nothing less.
Is this now included in new appdaemon version?
If so, I will wait for the HASSIO addon update
it is added to AD 3.0 beta
but it will be a few months untill that release will come out of beta and an addon will be created (unless someone creates a addon for the beta)
css from custom_css has to be put somewhere else?
in custom_css you only do put you selfmade(or copied) skins
the css in those files need to be accurate
I downloaded yours, without touching anything. It has to be in the same place as custom_widhet?
Finally is working, the solution is that you do not have to use the custom_css at all, just custom_widget. Nowhere was written this.
. Below is my code. Now I see the slider and I see the selectbox correctly. Now need to cnnect this to my entity_id.
If one box is a volume slider, other box is select source of AVR, what would you do: a third box for launching a script that takes the value of the volume and source???
marantz_volume:
widget_type: new_input_slider
entity: input_number.marantz_volume
title: Marantz
title2: Volume
marantz_video_select:
widget_type: input_select
entity: input_select.marantz_video_select
title: Marantz
title2: selectbox
tried this script but not working
marantz_dashboard:
alias: Marantz volume set and source select
sequence:
- service: media_player.turn_on
entity_id:
- media_player.marantz
- service: media_player.volume_set
entity_id: media_player.marantz
volume_level: '{{ states('input_number.marantz_volume') }}'
- service: media_player.select_source
data_template:
source: '{{ states('input_select.marantz_video_select') }}'
sorry i have no idea about scripts. i never used them
what would be the code for a input_slider to change volume on a AVR?
input slider widget needs an entity that can be set by the input number service.
so i expect that it can only set an input_number
you could create an input_number in HASS and and automation that changes the volume from the AVR when the input_number changes.
ahh right! How would be a code inside an automation for a “change” in input_slider?
sorry i cant help you with that.
i dont use automations.
that’s the solution for anyone interested
input_number:
portable_speaker_volume:
icon: mdi:volume-high
initial: 40
min: 0
max: 100
step: 1
automation:
- alias: Set Portable speaker Slider Position
- platform: state
entity_id: media_player.portable_speaker
condition:
- condition: template
value_template: "{{ not is_state_attr('media_player.portable_speaker', 'volume_level', states('input_number.portable_speaker_volume') | int / 100) }}"
- service: input_number.set_value
entity_id: input_number.portable_speaker_volume
data_template:
value: "{{ trigger.to_state.attributes.volume_level | multiply(100) | int }}"
- alias: Set Dining room speaker Volume
- platform: state
condition:
data_template:
volume_level: "{{ states('input_number.portable_speaker_volume') | int / 100 }}"
trying now to do the same with input_select.
Help appreciated
Im getting issues, where stdout is coming up with errors such as
WARNING Variable definition not found in CSS Skin variables: $new_input_slider_title_style
WARNING Variable definition not found in CSS Skin variables: $new_input_slider_title2_style
WARNING Variable definition not found in CSS Skin variables: $new_input_slider_minvalue_style
WARNING Variable definition not found in CSS Skin variables: $new_input_slider_maxvalue_style
WARNING Variable definition not found in CSS Skin variables: $new_input_slider_value_style
WARNING Variable definition not found in CSS Skin variables: $new_input_slider_slider_style
WARNING Variable definition not found in CSS Skin variables: $new_input_slider_widget_style
My dashboard entry is
MornTemp:
entity: input_number.morning_temp
title: Just a
title2: slider
Any ideas?
you need to put the variables in the skin.
if you use the default skin you need to find the variables.yaml in a dir like:
/usr/local/lib/python3.5/dist-packages/appdaemon/assets/css/default
then you need to add the variables that i have put in the file
in that file.
if you use a skin or a default skin you need to put the variables in the variables.yaml from that skin.
thanks, i’ll give it a go. Swift response
