yes and maybe show sensor status in and additional page?
I have had a rethink about the priorities of this project. I think we need to replicate the functions of Yet another alarm panel (YAAP).
So I think he priorities should be as below.
- override (bypass) open sensors. This way if something is open/detected it wont trigger the alarm.
- Display of sensors (similar to the log function)
- Display arming countdown
- not sure make a suggestion!!!.
I am only new at Node red so I am asking for help. If anyone would like to participate please reply and check out my github.
Thanks.
Ben
uff you have many doing points … I never try to build something complex …
I think point 3 should be easy to do …
all others needs time … and time is something i don’t have at the moment …
Thanks @manzn I am working on point 1. I am using a get entities node that get all entities starting with binary_sensor.alarm whose state is on then piping that into an array for display then I want to write the entities to the alarm.yaml file in the override section.
What do you think?
I cannot seem to get the pin to work. I keep getting incorrect pin. The arm away and all the status work, but I cannot arm or disarm on the node red flow. I am using bwalarm from https://github.com/akasma74/Hass-Custom-Alarm and have mapped the flow to the correct yaml file. I just cannot figure out how you check the pin in the check pin function. I am a newbie, so I grasp some of what is going on in that function, but cannot seem to figure out where the pin is stored to compare to waht has been entered. Any help would be appreciated, as I really like the look of the node red dashboard on my fire
Did you ever get your issues worked out, Mike? I ended up tweaking quite a bit to get it functioning properly and working properly with bwalarm. I can share the code with you, if you want.
I’m not done with all the enhancements that I would like to do, but it’s close. My two outstanding items are a countdown display, and a scrolling list of open sensors.
Mylo
I have done some tweaking myself but if you can share yours, I would be interested.
GV
I think I might actually fork the forked repo, in case the OP ever wants to incorporate it back in.
I never did, and gave up for a bit Sharing your code would be great!
I would also be interested in your code. Do you have it on github?
Hi, Just trying to find out which combination of open sensors others using this would like displaying on the interface. I’ve currently got a Work in Progress which displays the Open Sensors for (Immediate and Warning) sensors that aren’t also listed in the override sensors.
Or would anyone prefer to see all the open sensors even the Override ones that are configured in BWAlarm. Here’s how it looks.
It overlays over the keypad and then pressing cancel hides the open sensors window and displays the keypad.
If this has already been done do you mind sharing your code as this is a first attempt for me so probably won’t be the most efficient method of implementing it.
Dear Keith,
It has taken me 2 weeks to find the incorrect pin problem and the pictures of the arm disarm arm away pics on the panel.
I think it is time to give up and request if possible your assistance and maybe sharing the code that is working
Should you asists me would be a relief for me
I am not a totally newbie but it seems i cannot figure out the logic on yaml file and variable sets
Thanks in any case
harris
So far I’ve almost got this working. I used the default panel in BWalarm, but since the HTML changes broke the Alarm side panel I decided to give this a try.
PINs are being recognized, but the alarm state isn’t changing. I think it’s due to MQTT looking for different messages as I see in the Node-RED panel everything is lower case, but in BWalarm, every thing is CAPS.
Is that the issue?
EDIT:
That’s no the issue. MQTT is getting the proper commands caps and all. BWalarm just isn’t doing anything when it gets the commands. It seems that MQTT isn’t passing the PIN to BWAlarm.
@Chmark I finally forked and checked in my working code into the dev branch of this repository. It’s still a work in progress, but I checked it last night, and it does still work with the Ak47 edition of bwalarm.
It still doesn’t handle any bypass logic. If there is an open sensor when you try to arm the system, it just fails without a good error message.
does this take up a whole ‘window’ or can it be brought up by pressing a button on a seperate window?
Thanks a lot for your reply I will input the new code tonight and check how it is working
What is the proper way to show present
Depict the node red dashboard to a tablet ??
For easy usage ;
Harris
I have the node red dashboard on two of the smaller Amazon Fire tablets that I have near my front door, and my garage door. But you can certainly test it out on a phone or computer browser.
That URL is: http://[your home assistant base url (minus the 8123 port)]:1880/endpoint/ui
If your node red configuration includes a username and password, you’ll be presented with a login prompt.
once again thanks a lot i will test tonight
Harris
thanks so much for your time, i hope a lst question and my initial problem
I have installed the code and integration and it is working , Icons are shown now
The big problem is with the pin code, i definitely input the correct code, cause i try t on HASS and on another mqtt alarm application and it is the correct one.
I input the code and it always always return incorrect pin
This si driving me crazy for months and i cannot fix it
I can arm and disarm through HASS Gui but not through the node-red application which is the nice part
Any ideas please ?
Once again thanks for the support
Doing such things at the mid 50s can be a bit challenging …
Harris
Hi Mike
have you fixed your problem with the incorrect pin as i am having it for the last to months and is getting me bad…
thanks
Harris
