State your trigger and spread the word
Like this blueprint? Consider hitting the
button below ![]()
You must be on Home Assistant Version 2024.6 or later.
Need help?
See our FAQ: Click Here
The Automation Process:
Trigger Options:
- Specify the state change of one or more entities that will initiate the automation from a dropdown list. You can also specify your own custom state if it is not available from the dropdown list.
- State Change Options: The available state changes include:
- General States: Button or any state, ON, OFF, Unavailable or Unknown
- Location-Based States: Home or Not Home
Notification Options:
- Choose to send messages to one or more devices. Compatible with Apple iOS and Android devices.
- Choose to send voice messages to one or more devices.
- Choose to send messages via WhatsApp
- Choose to send messages via Telegram
- Choose to display notifications directly in the Home Assistant user interface (UI).
- Choose to send text-to-speech announcements to selected media players.
- Choose to use a custom action.
Time-based Automation and Repetition:
- Enable or disable the repeat service for one or more notifications, entering the delay for each notification and the number of repetitions.
- Specify precise start and end times along with weekday selections to define when the automation can run.
Global Conditions:
- Enter any custom conditions to further customize the automation process.
button below ![]()
Thanks to the Blueprint: Blacky
CHANGELOG
- Version: 2025.12(2) - 03 Dec-25 - Telegram part changed
- Version: 2025.12(1) - 02 Dec-25 - Added notification repeat
- Version: 2025.12 - 01 Dec-25 - Initial release
MY OTHER BLUEPRINTS
Notifiche & Annunci con Telegram e WhatsApp
Timbratura Ingresso/Uscita NFC in Google Sheet
button below ![]()
